LKits
23.03.2013 10:31:02
TrueCrypt - Free open-source disk encryption software |
http://www.truecrypt.org
TrueCrypt is software for establishing and maintaining an on-the-fly-encrypted volume (data storage device). On-the-fly encryption means that data is automatically encrypted right before it is saved and decrypted right after it is loaded, without any user intervention. No data stored on an encrypted volume can be read (decrypted) without using the correct password/keyfile(s) or correct encryption keys. Entire file system is encrypted (e.g., file names, folder names, contents of every file, free space, meta data, etc).
Files can be copied to and from a mounted TrueCrypt volume just like they are copied to/from any normal disk (for example, by simple drag-and-drop operations). Files are automatically being decrypted on the fly (in memory/RAM) while they are being read or copied from an encrypted TrueCrypt volume. Similarly, files that are being written or copied to the TrueCrypt volume are automatically being encrypted on the fly (right before they are written to the disk) in RAM. Note that this does not mean that the whole file that is to be encrypted/decrypted must be stored in RAM before it can be encrypted/decrypted. There are no extra memory (RAM) requirements for TrueCrypt. For an illustration of how this is accomplished, see the following paragraph.
Let's suppose that there is an .avi video file stored on a TrueCrypt volume (therefore, the video file is entirely encrypted). The user provides the correct password (and/or keyfile) and mounts (opens) the TrueCrypt volume. When the user double clicks the icon of the video file, the operating system launches the application associated with the file type – typically a media player. The media player then begins loading a small initial portion of the video file from the TrueCrypt-encrypted volume to RAM (memory) in order to play it. While the portion is being loaded, TrueCrypt is automatically decrypting it (in RAM). The decrypted portion of the video (stored in RAM) is then played by the media player. While this portion is being played, the media player begins loading another small portion of the video file from the TrueCrypt-encrypted volume to RAM (memory) and the process repeats. This process is called on-the-fly encryption/decryption and it works for all file types (not only for video files).
Note that TrueCrypt never saves any decrypted data to a disk – it only stores them temporarily in RAM (memory). Even when the volume is mounted, data stored in the volume is still encrypted. When you restart Windows or turn off your computer, the volume will be dismounted and files stored in it will be inaccessible (and encrypted). Even when power supply is suddenly interrupted (without proper system shut down), files stored in the volume are inaccessible (and encrypted). To make them accessible again, you have to mount the volume (and provide the correct password and/or keyfile). |
Väga vabandan, et ei ole viitsinud seda iseloomustavad teksti tõlkida eesti keelde, kuid ma usun, et ei saaks sellega väga hästi hakkama ka.
Niisiis - kui HV kasutajate seas on keegi, kellel on tahtmist ja aega see ülesanne ette võtta, siis tõlgitud teksti ja/või parema ülesehitusega postituse võib saata mulle sõnumiga - viin sisse vajalikud muudatused
viimati muutis LKits 20.10.2013 21:52:26, muudetud 1 kord |
| Kommentaarid: 13 loe/lisa |
HacaX
28.03.2013 14:54:11
Eeee.... kas sa pool tosinat aastat, või rohkemgi, hiljaks pole jäänud? Otsingusse "truecrypt" ja teemasid kus seda mainitud või soovitatud on tuleb hulgim, ei näe erilist mõtet järjekorde teema järele milles isegi seda pole mainitud miks ta alternatiividest parem oleks.
| Kommentaarid: 24 loe/lisa |
22 |
LKits
HacaX
28.03.2013 16:03:46
Ei. Aga sa saad oma mitte-peidetud volume'i tuksi keerata ning seejärel väita, et valest paroolist tingitud. Pluss on olemas SecureTrayUtil mis hotkey peale volume'i wipe'ida suudab. Tõsi küll, see eeldab, et opsüsteem on juba tööle läinud.
See on tegelikult üks nendest funktsioonidest mis teoorias kõlavad põnevalt, aga praktikas suhteliselt kasutud on. Kui parooli sisestamist nõuab politsei, siis andmete hävitamisega saadki andmete hävitamise süüdistuse kaela (ning see et puutu enam asjasse, kas andmed olid üldse hävitamist väärt); kui parooli tahavad mingid kapid, siis murravad nad sul sellise lükke peale sõrmed; kui tahad vältida, et suvaline häkerdav naabripoiss kallale saab, siis saavutad ainult selle, et iga kord kui ta masina kallal on oled oma andmetest ilma. Ning kui kui sul on tagavarakoopiaid, siis nende turvamisega on täpselt samad probleemid. See mida TC ja analoogid praegu pakuvad - peidetud konteiner mis avaneb õige parooli korral - on märksa parem. Seal hoiad oma salajasi andmeid; kõik mis elulise tähtsusega pole, pluss üht-teist mis pole illegaalne aga mille omamist võiks häbeneda, hoiad põhikonteineris ja kui avama pead, siis tolle avadki.
PS! Kui juba teema on, siis kindlasti peaks ka TC miinused välja tooma. Esiteks - keegi ei tea kas ta on nii turvaline kui väidetakse. Kood on avalik, aga kas sa kompileerisid selle ise (mis IIRC oli parajalt keerukas tegevus) või kasutad kodulehelt tiritud EXEsi mille puhul sa tegelikult ei tea, kas need sellele koodile vastavad? Teiseks - autorid on näinud hulga vaeva, et oma isikuid varjata. Turvamaailmas suhteliselt ebaharilik lähenemine. Kolmandaks - TC on üks väheseid diskikrüptijaid mille vastu reaalselt toimivat malware'i liikvel (Stoned bootkit ja Evil Maid).
22 |
rv30
28.03.2013 21:04:17
| HacaX kirjutas: |
| Kui parooli sisestamist nõuab politsei, siis andmete hävitamisega saadki andmete hävitamise süüdistuse kaela (ning see et puutu enam asjasse, kas andmed olid üldse hävitamist väärt); |
Nii need asjad nüüd küll ei ole. Esiteks ei ole karistusseadustukus sellist paragrahvi - andmete hävitamine ja kui ei ole paragrahvi, siis ei saa ka karistada. Teiseks on põhiseaduse paragrahv 22, mis sätestab:
Kedagi ei tohi käsitada kuriteos süüdi olevana enne, kui tema kohta on jõustunud süüdimõistev kohtuotsus.
Keegi ei ole kriminaalmenetluses kohustatud oma süütust tõendama.
Kedagi ei tohi sundida tunnistama iseenda või oma lähedaste vastu.
Lahtiseletatult tähendab see seda, et politsei vaadaku ise kuidas hakkama saab, mina neid iseenda suhtes toimuva uurimise suhtes aitama ei pea.
PS Politseile teadmiseks - minu arvutis ei ole mitte midagi teile huvipakkuvat.
| Kommentaarid: 7 loe/lisa |
Märt.
28.03.2013 21:15:22
Selle peale tulevad nad seda oma silmaga kaema.
| Kommentaarid: 29 loe/lisa |
23 |
HacaX
28.03.2013 21:20:34
Eesti seadustik ei karista asitõendite teadliku hävitamise eest? OK, ei teadnud, ilmselt olen liialt välismaised juhtumeid jälginud, kus sellise asja eest vahele saab võtta. Veelgi enam - on kante, kus kehtib seesama "ei tohi sundida tunnistama iseenda vastu" mõte, aga lisaks eksisteerib kohustus krüptimiseks kasutatud võtmete üleandmiseks (UK parim näide, kus sellest keeldumise tõttu on reaalselt vastu pead saadud).
Aga kindlasti leidub ka Eesti õigusruumis olukordi, kus võidaks peidetud failide nähtavakstegemist küsida, a'la väiksem karistus, kui koostööd teed ja peidupaiga avad. Ja kui siis on tagajärjeks hoopis kõvaketta tühjenemine kuna kogemata parooliga eksisid...
22 |
rv30
28.03.2013 21:53:48
Karistusseadustikus on vastava koha peal kirjas järgmist:
§ 316. Tõendi kõrvaldamine ja kunstlik loomine
Tõendi kõrvaldamise või kunstliku loomise eest eesmärgiga takistada kuriteona karistatava teo olemasolu või selle puudumise või muude tõendamiseseme asjaolude tuvastamist – karistatakse rahalise karistuse või ühe- kuni viieaastase vangistusega.
Loomulikult hoian ma oma kasutajatunnuseid, paroole ja muid sensitiivseid andmeid krüpteerituna ja nad on krüpteeritud TrueCrypt'iga. Kogu minu arvuti on täis igasuguseid faile aga ükski neist ei ole TÕEND ja ma kustutan a loon neid nii nagu ise heaks arvan - see ei ole politsei asi.
HacaX
28.03.2013 22:13:37
Kui politsei sul ukse maha murrab ja leiab eest tühjakstehtud kõvaketta, siis saavadki nad ju seda paragrahvi rakendada. Mingid tõendid olid neil ju juba olemas, muidu poleks ukse mahamurdmiseni jõutudki. Nad ei pea kogu süüdistuse sellele ühele tõsiasjale üles ehitama, vaid saavad muudele asjadele lisaks panna (nagu pannakse su piraaditud Windows).
Mu mälu võib nüüd alt vedada, aga olen kuulnud, et Eestis on trahvi tehtud "asitõendite hävitamise" eest isikule kes dubleeritud multikaid jagas. Multikaid endit ta arvutist enam ei leitud, aga kuna IP klappis jagaja omaga siis sai puudumist "hävitamiseks" keerata ja kuna asi päris kohtusse ei läinud (IIRC oli kiirmenetlus ja inimese vanemad maksid pikema jututa trahvi kinni) siis ei tekkinud ka vastuvaidlemise kohta.
Kokkuvõtlikult ikkagi sama tulemus, et vale parooli peale HD tühjenemine ei ole tegelikult hea liigutus. Parem kasutad nii head parooli, et ei saaks tõestada et su arvutis midagi on, ja kasutad topeltkonteinerit, et olukorras kus sa konteineri avamisega midagi võidad saaksid ebaolulisema volume'i ohverdada.
22 |
stayout
28.03.2013 22:46:49
Need krüpteeritud failid on ikka tõendid küll. Politsei asi ei ole tõesti see, kui tihti sa neid enda arvutisse tekitad või eemaldad, vaid pigem tõendite endi kogumine menetluse käigus. Täpsemat infot leiad kriminaalmenetluse seadustikust, tõendamise ptk alt link. Samuti on seal kenasti § 62 all kirjas, et tõendamisese on kuriteo toimepannud isikut iseloomustavad andmed ja muud tema vastutust mõjutavad asjaolud, nii et politsei asi see tõesti ei ole aga kohtu asi on küll .
LKits
napoleon
Unknown virus
29.03.2013 18:14:32
Kui niipidi mõelda, siis võivad mu sokid või vanad kingad ka midagi politsei jaoks põnevat sisaldada ja võimalik, et seda mõne juhtumi uurimisel, kus mina pole ei kannatanu ega kahtlustatav. AGA niikaua kui keegi pole mulle öelnud, et need on asitõendid, võin oma asjadega teha mis tahan. Failidega peaks sama lugu olema, isegi kui minu ip-lt on midagi illegaalset jagatud, ei tõesta veel miski, et need andmed just konkreetse masina konkreetsel kettal olid või et need andmed üldse kunagi minu valduses olid(võibolla käis keegi külas, naabripoiss häkkis wifi-sse jne.). Minu teada ei keela ka ükski seadus arvutis tühja ketast hoida, seega peaks politsei suutma tõestada, et kettal tõepoolest midagi oli ja ma selle hävitasin. Kui andmete puhastamise funktsioon näitab lihtsalt generic teadet a'la "operatin system not found" ja hakkab taustal andmeid kustutama, siis pakun et suurem osa miilitsatest ei saaks üldse aru, et midagi toimub.
Aga kordades lihtsam on mitte tegeleda asjadega, mille vastu politsei huvi võib tunda ja siis pole ka selliseid probleeme.
| Kommentaarid: 79 loe/lisa |
60 |
19.10.2013 15:01:57
Millist krüpteeringut oleks TrueCrypti puhul kõige otstarbekam välise ketta puhul kasutada? Pakub mingi hunniku valikuid erinevate algoritmidega
571 |
Mario.
19.10.2013 17:18:35
| Saad ju benchmark'ida.
6 :: |
217 |
19.10.2013 18:47:01
| Kiirus ei mängi absoluutselt rolli. Pigem töökindlus ja ühilduvus. Asja hakatakse kasutama nii Linuxi kui Windowsi all.
571 |
Uhuu
19.10.2013 18:56:31
AES suht standard vist.
_________________ Windows ei ole viirus, viirus teeb midagi... |
| Kommentaarid: 15 loe/lisa |
15 |
dksvertix
19.10.2013 19:22:48
| Betamax kirjutas: |
| Kiirus ei mängi absoluutselt rolli. Pigem töökindlus ja ühilduvus. Asja hakatakse kasutama nii Linuxi kui Windowsi all. |
Ühilduvus millega? TC töötab ühtemoodi nii Windowsi, kui ka Linuxi all. Vähemalt siis töötas, kui kasutasin oma välise ketta peal Serpent-Twofish-AES.
19.10.2013 19:25:07
| Just. Ei taha sellist situatsiooni, kus ketas ühendatakse arvutile külge ja opsüsteem/programm hakkab kisama, et ei leia või toeta miskit.
571 |
Uhuu
19.10.2013 19:33:02
Kusjuures kasutasin tc päris mõnda aega jagatud kettal nii Linuxi kui Win keskkonnas.
Mingeid iseärasusi ei tekkinud, peale selle et failisüsteemi peavad mõlemad toetama, milleks kasutasin ntfs, ma kujuan et fat sobib ka.
15 |
19.10.2013 19:56:08
| OK, tänud. Proovin siis AES-iga.
571 |
Mario.
19.10.2013 20:03:35
| Betamax kirjutas: |
just.
6 :: |
217 |
HacaX
20.10.2013 17:10:37
| Uhuu kirjutas: |
| AES suht standard vist. |
Lisaboonus: too on ainus algoritm mille puhul on lootust tavainimese CPUst riistvaralist tuge leida (AESNI käsustik), s.t. kui masinal kuhu ühendad on sobiv prose saad üksjagu jõudlust juurde.
Isiklikult läheksin küll Twofishi teed, aga see on pigem paranoiast tingitud.
22 |
degreal
21.10.2013 00:24:42
| HacaX kirjutas: |
| Kui politsei sul ukse maha murrab ja leiab eest tühjakstehtud kõvaketta, siis saavadki nad ju seda paragrahvi rakendada. |
Huvitav kas sellist algoritmi pole olemas kus vastavalt võtmele erinevat infot avaldada saab. Siis politsei ei saagi kunagi teada kas kurikael tegelikult kah info avaldas või mitte. Ja kuidas sa saad siis info varjamises süüdistust esitada kui sa kindel pole kas sa varjad või mitte.
26 |
napoleon
Unknown virus
60 |
HacaX
21.10.2013 11:44:39
Eelmine postitaja viitas asjakohasele funktsionaalsusele, aga point oli selles, et kui politsei sul juba ukse maha murrab, siis ei ole see "igaks juhuks", vaid neil on juba mingi syydistusmaterjal olemas. Ja sellises olukorras TC ketta lahtitegemine t@hendaks yhte kahest: kas kettal on sama info mis neil oli juba olemas (ja saa saad kergema syydistuse kuna "tunnistasid yles ja tegid koost88d") v6i midagi syytut, mille peale k@ivad nad omapoolse materjali v@lja ja saavad sulle v6ib-olla lisasyydistuse kaela v@@nata (stiilis "meil on t6endeid, et sul oli selline ja selline materjal olemas, kuna enam pole siis, j@relikult, h@vitasid").
Lihtne n@ide: v@idetavalt oled sa vabariigi suurim piraat kes BitTorrenti vahendusel terabaitide kaupa illegaalset kraami jagab. Sina oled kaval ja hoiad k6ik oma P2P vidinad/tirimised/uppimised kryptitud kettal. Kui politsei sind kylastab, siis on neil kindlasti posu logisid sellest, kuidas nende kontrollklient sai yhendust sinu IP otsas istuva BT kliendiga ning sai tolle k@est ka reaalselt mindagi tiritud. Sellises olukorras sinupoolne v@ide, et ei tea asjast midagi ja TC konteinerist ka muud kui gigade kaupa porri v@lja ei kooru, sind ei aita. On sinu sõna nende logide vastu. Veelgi enam - logide p6hjal saavad nad v@ita, et oled tahtlikult materjali kustutanud. Kas nad seda teevad on muidugi iseasi.
22 |
LKits
Mario.
21.10.2013 12:29:29
| HacaX kirjutas: |
Lihtne n@ide: v@idetavalt oled sa vabariigi suurim piraat kes BitTorrenti vahendusel terabaitide kaupa illegaalset kraami jagab. Sina oled kaval ja hoiad k6ik oma P2P vidinad/tirimised/uppimised kryptitud kettal. Kui politsei sind kylastab, siis on neil kindlasti posu logisid sellest, kuidas nende kontrollklient sai yhendust sinu IP otsas istuva BT kliendiga ning sai tolle k@est ka reaalselt mindagi tiritud. Sellises olukorras sinupoolne v@ide, et ei tea asjast midagi ja TC konteinerist ka muud kui gigade kaupa porri v@lja ei kooru, sind ei aita. On sinu sõna nende logide vastu. Veelgi enam - logide p6hjal saavad nad v@ita, et oled tahtlikult materjali kustutanud. Kas nad seda teevad on muidugi iseasi. |
Sellisel juhul aitab vastutust "jagada" avatud WiFi taga istudes?
Ala Thomson ruuterid, mida Elion jagas - nendele on võtmegeneraatorid olemas - ja see, mis toimub minu IP tagant, on sel juhul sama püsiv alus süüdistusele, kui tatiga tellist liimida. Antud juhul võid alibi genereerimiseks ühe sinu käsutuses mitteoleva kliendi (kasvõi nutifoni) "põõsasse" visata, et ruuter ka kõrvalist valduses mitte asuvat seadet logiks; enamus odavaid karpe maht-per-klient nagunii ei tee - või kui, siis läheb keerulisemaks.
6 :: |
217 |
21.10.2013 12:53:22
| Sinu seadme MAC ja terve hunnik muid parameetreid on ISP-le kenasti näha selle kiidetud Thomsoni või suvalise avatud võrgu tagant. See jumalik VPN võib varjata su liiklust, aga mitte su seadmeid ja ühenduspunkte. Proksiga võid sa lihtsalt foorumites trollida ja Ameerika filme vaadata kusagilt piiratud teenusest. Nii kaua, kuni sa ISP teenuseid kasutad (tänapäeval muud varianti polegi), oled sa kenasti monitooritav suuremal või vähemal määral. Siinkohal ei mängi rolli ka see põõsas istuv seade.
571 |
Mario.
21.10.2013 13:08:25
MAC spoofing @ every restart.
Ma pean siiski silmas IP siduvust isikuga, mida on keeruline läbi viia, kui teenuse taga on mitmeid kasutajaid (loe: olgu selleks ühika, suur leibkond, ruuteri võrk on avatud) ning diskrimineerivatele materjalidele ligi ei saada.
viimati muutis Mario. 21.10.2013 14:06:20, muudetud 1 kord |
6 :: |
217 |
LKits
21.10.2013 13:08:44
Ega jah - arvutit vangi ei saada...
On siis reaalseid kohtukeisse ka olnud taolistes situatsioonides? Justnimelt Eestist räägiks - mitte mikidemaast.
degreal
21.10.2013 18:25:38
| LKits kirjutas: |
On siis reaalseid kohtukeisse ka olnud taolistes situatsioonides? Justnimelt Eestist räägiks - mitte mikidemaast. |
Mikidemaal on selline tore jupp teksti nagu 5th Amendment. Et kaitsta inimest kasvõi poliitilise tagakiusamise eest võimude poolt, ei pea inimene privaatvõtit andma kui ta ei soovi. Oleks ju kurb lugu kui eestis vastupidi oleks.
26 |
Mario.
21.10.2013 19:46:57
| Täpselt sama rida leidub ka meie seadustikus
6 :: |
217 |
HacaX
23.10.2013 00:23:17
| degreal kirjutas: |
| LKits kirjutas: |
Mikidemaal on selline tore jupp teksti nagu 5th Amendment. Et kaitsta inimest kasvõi poliitilise tagakiusamise eest võimude poolt, ei pea inimene privaatvõtit andma kui ta ei soovi. Oleks ju kurb lugu kui eestis vastupidi oleks. |
Mikidemaal hetkel pole, aga näiteks UK's on seadus mis teatud olukorras kohustab süüdistatavat oma parooli andma. Keeldumine ise on piisav põhjus, et vangi minna. Ja nagu praktika näitab - "teatud olukord" oleneb süüdistajast. http://en.wikipedia.org/wiki/Key_disclosure_law
Eesti kontekstis võtmete üleandmisest ei tea, küll aga olen kuulnud (mitte kohtus, aga kiirmenetluse raames), et reaalselt on (alaealisele) piraadile väänatud just selle eest, et materjali ta arvutist "enam" ei leitud*. Seega olukord kus sa võiksid omaenda huvides parooli avaldama ei pruugi puhtalt teoreetiline olla.
* - toimus hea hulk aastaid tagasi ja täpsemaid detaile ei tea, seega pole välistatud padaajamine (politsei poolt hirmutamiseks, või äkki hoopis süüdistatu poolt, et oma lugu põnevamaks teha) ega seegi, et tänapäeval ei pruugi samasuguseks asjaks õiguslikku alust olla.
22 |
Mario.
23.10.2013 05:04:33
See on äärmiselt ebatõenäoline.
Kiirmenetluse raames võib! nõustuda süüdistuse ning karistusega, aga eks see on hirmutamise ja just padajutu tulemus, sest üks täiemõistuslik võtmehaldaja vaikib ning laseb kohtuveski käima.
Jah; hea argument, kui minu avaliku IP alt on jagatud-tiritud ning seda enam ei leidu - kuid kaitsja oskab ilusti rääkida just seda juttu, mida mina teoretiseerisin e minu sisevõrk ei ole turvaline (tahtlikult või mitte) jne
6 :: |
217 |
HacaX
23.10.2013 17:35:45
| Mario. kirjutas: |
| täiemõistuslik võtmehaldaja vaikib ning laseb kohtuveski käima. |
Vot selles ma küll kindel ei oleks. Kui sulle ikka pannakse ette valik, et kas mängid kaasa ja saad väiksema karistuse, või ei mängi ja oodata on suuremat karistust, siis enamus inimesi valiks esimese. Seda enam, et kohtusseminek pole naljaasi - kulutab oluliselt aega, kui sa riikliku kaitsja peale loota ei taha siis ka kõvasti raha ja positiivses lõpptulemuses ei saa kunagi liialt kindel olla.
Kes on kunagi bussijänesena vahele jäänud või pisirikkumise osas kiirmenetlusega nõustunud teab kindlasti rääkida kui lihtne oli valitud lahenduskäiku põhjendada
22 |
napoleon
Unknown virus
23.10.2013 17:57:37
Oleneb siiski millega tegemist. Kui liikluse pisirikkumise ainuke tõestus oleks näiteks minu autos oleva kaamera krüptitud salvestus, siis mis hea pärast peaksin selle võtme vabatahtlikult miilitsale andma. Aga liikluse pisirikkumisega on enamasti tunnistajaks vähemalt kaks politseiniku ja suht pointless on kiirementlusega mitte nõustuda kui nad just maksimumi väänata ei ürita.
Point on ikka selles, et kui seda võtit nõutakse, siis tõenäoliselt neil pole muid tõendeid piisavalt. Jutt kaasa mängimisest ja väiksemast karistusest ongi selleks, et saada kahtlusalune ise oma sigadust üles tunnistama
Aga kokkuvõttes on puhtam, kuivem ja muretum tunne elada nii, et võimuesindajatel poleks põhjust käsi väänama tulla
60 |
HacaX
23.10.2013 19:16:07
| napoleon kirjutas: |
| Point on ikka selles, et kui seda võtit nõutakse, siis tõenäoliselt neil pole muid tõendeid piisavalt. |
Huvitav argument, polegi asjale nii vaadanud
Minupoolne point on tegelikult selles, et kui ajahetk kätte jõuab ei pruugi sa asjale sama objektiivselt vaadata. Sa oled ebameeldivas olukorras, vastaspool käib välja mõtte kiirelt asjaga ühele poole saada ja sa nõustudki. Olen kindel, et suurem osa kiirmenetlustest ongi just selle tõttu sõlmitud - süüdistatu ei andnud endale üldse aru, et mingi muu lahenduskäik oleks olemas.
"Täiemõistuslik võtmehaldaja" võib olla tark inimene, aga kui ta täiskohaga kriminaal ei ole, siis otsustaval hetkel ei pruugi sest tarkusest väga palju järel olla. Ehk siis sellisele situatsioonile eelnenud lootus stiilis "kui olukord peaks tekkima, küll ma siis parima otsuse teen" ei pruugi paika pidada. Iga võtmehaldaja peaks läbi kaaluma nii selle mis tema tegutsemine kaasa võib tuua, kui ka selle kuidas ta nende tagajärgede korral käituks. Seda täiesti sõltumata sellest, mislaadi võtmeid ta haldab.
22 |
Mario.
24.10.2013 05:17:41
Seda ma silmas pidasingi.
Ennast diskrimineerivate materjalide paljastamine küsimise peale ei ole reeglina tark tegu - õigusemõistmine töötab teisiti; k.a kohtunik, kes käsitleb vaid olemasolevaid fakte, mitte kahtlustusi. Selles kogu point ongi.
Kui ei uurimine ega sina uusi materjale ei genereeri, seda parem. Kui bluffile allud.. jah; hea tähelepanek, kes on "täiemõistuslik võtmehaldaja" ka kriitilisel hetkel.
6 :: |
217 |
angelafmy
03.01.2014 09:42:10
________________________________________________
My XBOX classic games Fifa 14 A new hot games! Look forward to your competition!
Mein Name: Kresse, Xiedetele
More information: Buy FIFA 14 PS3 Coins
essu
31.01.2014 08:08:52
Truecrypti jaoks on google serveris kräkk täitsa olemas: http://code.google.com/p/truecrack/
Politsei ei hakka sinu krüpteeritud failidega üldse tegelema. Võtab muul moel pihtide vahele: näiteks "ülipikad läbirääkimised". Kui eestlasest politsei pihtide vahele jääd, siis soovitan soojalt kohe alla anda.
Ta võib sind kuude viisi tülitada nii, et lõpuks sa lihtsalt vastu ei pea.
Ja kui nad peaksid kuude viisi sinu krüpteeritud faile lahti kräkkima, siis nad eelistavad ühe kuuga sind ise lahti kräkkida.
Ajakirjanduse jaoks on see krüptimine suht vajalik. Näiteks läpakas peaks krüptitud olema, samuti poliitikutel.
Samas on poliitika suurem mõiste ja korralikel poliitikutel ei ole vaja midagi krüpteerida (ainult digi dokumente), kõik asub nende peas.
LKits
31.01.2014 13:57:23
Politsei ei või ilma kohtu otsuseta midagi erilist teha. Uuri veidi karistusseadustiku.
Huvitav, kuidas lähenetakse arvutile, kui omanikuks on Aafrikas elav kodanik ning mul on lihtsalt mingisugune kasutusleping (kasvõi suusõnaline). Kuidas tõendab politsei, et minu valduses olev arvuti on reaalselt ka minu oma, vaid mitte tolle aafriklase?
EDIT: Igasugune "bruteforce" sõnaraamatute põhjal on võimalik.
Sellepärast soovitataksegi kombineerida kasvõi terve lause ühte parooli ning asendada mingid tähed mingite tähemärkidega. Näiteks, kõik "i" tähed asendad "!" märgiga. Või siis mõtled ise midagi välja. Paned parooli algusesse ja lõppu täiesti seosetud fraasid/sõnad.
SeitsmeMaaJaMereTagaElasidPrintsJaPrintsess -> "asdfS3itsm3M44JaM3r3Taga3lasidPrintsJaPrints3ssqwerty"
Edu sulle sellise parooli murdmisel.
essu
31.01.2014 15:21:33
| LKits kirjutas: |
Edu sulle sellise parooli murdmisel. |
See parool on nüüd kasutu, ta on listis.
Ise kasutan seda http://ccrypt.sourceforge.net
32 bitisest paroolist peaks piisama.
LKits
HacaX
01.02.2014 12:14:45
| essu kirjutas: |
| LKits kirjutas: |
32 bitisest paroolist peaks piisama. |
Failide krüptimiseks on tosinate kaupa vidinaid, kettakrüptijad on need millest võiks rohkem avatud koodiga isendeid olla
Samas on avatud kood ka kergeks probleemiks - miski ei takista dekodeerimisfunktsiooni suvalisse skripti kopeerida mis avaks etteantud konteineri, loeks sõnaraamatust paroole ja üritaks siis dekodeerida. Ehk siis täpselt see mida TrueCrack teeb.
Ma selle E=>3 teisenduse peale väga ei panustaks, sellist standardset l33tsp34ki peaks iga veidigi võimekam murdja toetama. Kui teisendada siis ikka moel mis vaid sulle endale loogiline on.
22 |
essu
01.02.2014 12:23:45
| HacaX kirjutas: |
Ma selle E=>3 teisenduse peale väga ei panustaks, sellist standardset l33tsp34ki peaks iga veidigi võimekam murdja toetama. Kui teisendada siis ikka moel mis vaid sulle endale loogiline on. |
See truecrypt on hea kui tal lasta näiteks aes-serpentit korraga kasutada ja parool peaks olema üle 20ne märgi.
Endal on luks ja lvm2 kõvakettal. Isegi kui NSA jaoks on ta häkitav, siis minu enda jaoks ta ei oleks. See on peamine.
LKits
01.02.2014 12:42:04
| HacaX kirjutas: |
| essu kirjutas: |
| LKits kirjutas: |
Jah 13375p34k küll, aga kui juba lisad parooli algusesse ja lõppu mingi täiesti suvalised sõnad, siis on olukord juba VÄGA raskendatud.
HacaX
13.03.2014 18:00:29
Veel üks vidin samaks, veidi kasutajasõbralikum ja graafuline, aga ei paista GPUd toetavat: http://unprotect.info/
TC kasutajatele aga soovitaks, juhul kui jõudlus kriitilise tähtsusega ei ole, AESi asemel mõnd muud algoritmi kasutada. Põhjus lihtne: AESi võtmed on tuvastatavad (softiga nagu aeskeyfind lausa automaatselt) kui mälule on ligipääs. Muude algoritmide puhul ei paista seda varianti veel laiemalt uuritud olevat.
22 |
22.03.2014 13:35:19
| HacaX kirjutas: |
| Põhjus lihtne: AESi võtmed on tuvastatavad (softiga nagu aeskeyfind lausa automaatselt) kui mälule on ligipääs. |
Selgita maakeeli lähemalt, palun, kuidas see täpsemalt käib? Kas TrueCrypti kasutamise ajal või/ja siis, kui see on suletud?
571 |
rastik1
27.03.2014 16:59:41
| HacaX kirjutas: |
TC kasutajatele aga soovitaks, juhul kui jõudlus kriitilise tähtsusega ei ole, AESi asemel mõnd muud algoritmi kasutada. Põhjus lihtne: AESi võtmed on tuvastatavad (softiga nagu aeskeyfind lausa automaatselt) kui mälule on ligipääs. Muude algoritmide puhul ei paista seda varianti veel laiemalt uuritud olevat. |
ccrypt on siiani parim.
jah, kui sa 4 aastat pead võtit otsima, siis elektriarve on suur.
HacaX
29.03.2014 20:07:11
| Betamax kirjutas: |
| Selgita maakeeli lähemalt, palun, kuidas see täpsemalt käib? Kas TrueCrypti kasutamise ajal või/ja siis, kui see on suletud? |
TC kasutamise ajal. Praktikas on vaja füüsilist ligipääsu masinale aga kui see olemas, siis dumpid raali mälu faili ja söödad seejärel dumpfaili progele, mis leiab need võtmed mida TC kasutas.
Kombineeri see FireWire kaudu mälu lugemisega või cold boot attackiga ja saadki olukorra, kus PC lukustamine või restartimine kui politsei su ukse maha murrab ei pruugi ligipääsu su krüptitud ketastele oluliselt takistada. Lihtne samm - AESi asemel mõne muu pakutava algoritmi valimine - teeks asja politseile natukenegi keerulisemaks (kuna siis peaks võtmed käsisti dmpist üles leidma).
22 |
