Ma ei sa tõesti aru mida te, siis tõesti oodate multiplayerist. Mäng on nagunii ammu ära rikutud ja keegi ei osta elusees seda mängu multiplayeri pärast olgu see milline tahes.
Tomb Raider publisher Square Enix has listed the game's PC specs and named the studio that has been helping on the game's conversion.
That studio is Nixxes, a well-established partner for Square Enix releases dating back to the days of Legacy of Kain.
More recently Nixxes has handled PC versions of Deus Ex: Human Revolution, Lara Croft and the Guardian of Light, Tomb Raider Underworld and Kane and Lynch 2: Dog Days.
Square Enix describe the PC version of the game as "extensively optimised". Steamworks and Big Picture Mode support, increased detail tessellation, improved SSAO and post-filter effects and tip-top resolution textures are among the upgrades.
The game also supports AMD HD3D and AMD Eyefinity, for those with the right kit. And for those with older machines, the game even supports Windows XP.
Those numbers in full:
Minimum system requirements for PC
• Windows XP Service Pack 3, Windows Vista,7,8 (32bit/64bit)
• DirectX 9 graphics card with 512Mb Video RAM: AMD Radeon HD 2600 XT, nVidia 8600
• Dual core CPU: AMD Athlon64 X2 2.1 GHz (4050+), Intel Core2 Duo 1.86 GHz (E6300)
• 1GB Memory (2GB on Vista)
Recommended system requirements for PC
• Windows Vista, Windows 7 or Windows 8
• DirectX 11 graphics card with 1GB Video RAM: AMD Radeon HD 4870, nVidia GTX 480
• Quad core CPU: AMD Phenom II X2 565, Intel Core i5-750
• 4GB Memory
Tuletan meelde, et siin paar vahepealset osa (Legend ja sellele eelnenud) olid teatud stuudio poolt samuti ära solgitud juba varemgi. Kahju muidugi kui seekordne sama teed läheb.
Vanematest Tomb Raideritest ei meeldinud vist pea ükski, aga see uus tundub tükk maad asjalikum ja tekitab nüüd juba tõelist huvi.
Ega kes see ikka viitsib enam otsida ja mõistada mängudes või sadu kordi surma saada valesti hüpates või lõksu astudes. Mängud peavad sirgejoonelised ja ühes suunas olema. Teel palju jobusid keda maha nottida ja võimalikult palju plahvatusi nagu iga minut ja kõige idiootsemal viisil.
Sinusugustele uncharted, gears of wars, cod, god of war jne ei piisa? Vaja ka vanu häid tiitleid ära rikkuda, mis olid hoopis teisest žanrist? _________________ Gdesainer
viimati muutis ahvilõust 23.02.2013 19:35:41, muudetud 1 kord
Mis puzzle solvimist kohe üldse ei ole? Kas Square Enix´i devid üldse on mänginud Tomb Raideri seeriat?
noh need esimesed tomb raiderid olid lihtslalt liialt kerulisted tänapäeva inteligentsi jaoks, uued osad saavat tõenaoliselt kõik puuga pähe olevat, annyversari oli ka viimane mis oli suht hea tomb raider
ja wtf multiplayer?????
seda ta oli, sisu oli sama ja kaardid meenutasd ka vana hea tomb raiderit, aga olid natuke väiksemad, see eest oli väga hea turnimine ja tonnide kaupa puzzlesid
Eks videod näitavad tõesti kahtlaseid asju, loodan, siiski, et tuleb korralik mäng ja hea PC port, ära plaanin igatahes mängida, muidugi kui ta ei feili nagu Aliens tegi _________________ Youtube: FranticM3rcury
Steam: Frantic M3rcury
Õnneks pole too ülivajalik TressFX AMD eksklusiiv:
"As we suspected, AMD's press release has been very carefully worded. 'TressFX is not exclusive to AMD,' a spokesperson for the company has told us. 'It works on any DirectX11 card, similar to some other AMD-built technologies - for example Order-Independent Transparency (OIT) or High Definition Ambient Occlusion (HDAO).' Thus is the truth revealed: any DirectX11-capable graphics hardware, including those from rival Nvidia, will be able to make use of AMD's hair-rendering know-how." Allikas http://www.bit-tech.net/news/hardware/2013/02/26/amd-tressfx/1
Aga mäng ise tundub päris muhe, sihke Uncharted-lik action simman PC'le, peab vist ka järgmine nädal ligi võtma
Ideelt on tore asi see TressFX, aga jubetalt tirib fps´i alla ja karvade alused varjud on ka kohati sakilised ja koledad.
Benchmark piltidel on erinevus ainult normal ja TressFX juuste vahel. Teised seaded kõik max.
Viimane tomb raider mulle meeldis,see mingi anniversary oli vist ? Peaks seda ka proovima,mulle on alati sellised puldi klõbistamisega mängud meeldind kui saab vahepeal mingeid mõistatusi ja puzzlesi ks nuputada ? ei tea kas selles tomb raideris ka ikka neid on ?
iseasi kas see mäng minu vanaraua peal üldse jookseb
