Lord Ami
10.10.2012 12:30:18
Comodo Internet Security 6 |
http://forums.comodo.com/beta-corner-cis/comodo-internet-security-602528292560-beta-released-t87274.0.html
What is New in V6?
NEW! Completely redesigned touch friendly and task oriented user interface
The new user interface is designed from scratch to make CIS as user friendly as possible. While we kept a lot of advanced settings for the advanced users, novice users will find it very easy to use now.
NEW! COMODO Cleaning Essentials and Killswitch are now parts of CIS
IMPROVED! Dramatically improved sandbox and virtualization
Virtualization has been improved significantly so that more applications are now able to run inside sandbox.
New sandbox allowed us to implement a whole new desktop with its own application ecosystem: Virtual Kiosk.
We have also introduced automatic virtualization of unknown applications for advanced users.
IMPROVED! Lightest and fastest CIS so far!
CIS 6 is the fastest and the least resource intensive product we have released so far. Real-time responsiveness of the PCs improved significantly. Manual scans are now less resource intensive. Second scan speed improvements are dramatic.
There are literally hundreds of other improvements over old versions. I listed only a few major features/improvements. There are a lot of other major features/improvements which you will notice while using it from rescue disks to rating scanning, virtual shortcuts to shared spaces.
Täna sai siis valmis esimene public beeta CIS 6'st. Endal peal ja paistab väga stabiilne ning probleeme pole esinenud. Arvuti performance mõttes tundub väga light ning slow-downe pole märganud.
Virtual Kioski pole hetkel katsetanud, aga teen seda kindlasti
Eesti keele tõlge hetkel poolik, ei oska öelda kuna 100% tõlgitud saada võib.
Mida arvate? Tasuta tõhus tõrje kindlapeale
viimati muutis Lord Ami 05.02.2013 20:10:48, muudetud 1 kord |
Kommentaarid: 57 loe/lisa |
52 |
AJ
10.10.2012 21:05:49
Võiks proovida, aga ei hakka selle pärast sinna foorumisse kasutajat tegema.
Kommentaarid: 37 loe/lisa |
36 |
Lord Ami
52 |
AJ
11.10.2012 19:27:38
Tänud Lord Ami.
36 |
hendrik32
12.11.2012 00:32:50
Lasin endale ka peale just pärast seda, kui aastane litsents läbi sai, siiamaani kõik töötab.
Kommentaarid: 16 loe/lisa |
12 |
AJ
12.11.2012 10:05:28
Ma kuu aega kasutanud ja senini toimib ilusti.
36 |
hendrik32
01.12.2012 14:53:54
Teine beetaversioon on ka nüüd saadaval:
http://download.comodo.com/cis/download/installs/2000_beta/standalone/cispremium_installer.exe
Versiooni number: 6.0.258294.2626 BETA
Parandused:
tsitaat: |
IMPROVED! The desktop widget now have common tasks pane and status pane which shows # of sandboxed apps, unrecognized files etc.
IMPROVED! Killswitch now shows the traffic per process by default(should run as admin)
IMPROVED! Maximize window support added to relevant dialogs such as advanced settings, Quarantined items windows etc.
IMPROVED! Right click menu has been added to grids in relevant dialogs such as advanced settings
IMPROVED! Sound effects are used in alert windows to grab users' attention
IMPROVED! Log viewer has been redesigned to fir CIS 6 theme
IMPROVED! Offline virus database update functionality - Import Virus Database feature has been introduced
IMPROVED! File submission and lookup operations have been introduced
IMPROVED! Reboot reminder alert has been introduced to various places
IMPROVED! Diagnostics download missing files from the Internet
IMPROVED! Error log in updater is now accessible for more information
IMPROVED! Web Browser Data Folders file group has been created so that it could be added to sandbox exceptions to preserve various browser data e.g. downloads, bookmarks, chrome apps etc.(Not added by default currently)
IMPROVED! Configuration editor and virus scanning operations can now be performed in safe mode
IMPROVED! Better keyboard support(Press and hold ALT key to see options)
IMPROVED! Non-blocking grids with progress(e.g. trusted files, submitted file etc.)
IMPROVED! Trust connect integration reintroduced
IMPROVED! Upgrade to paid products is now possible
IMPROVED! Browse processes dialog has been improved
IMPROVED! Verbose mode for HIPS alerts added to configuration list
IMPROVED! Added an option to disable cache builder for antivirus
IMPROVED! Help buttons added to all dialogs
FIXED! cmdagent constantly access disk
FIXED! Behavior Blocker does not intercept some COM related operations for auto-sandboxed apps such as PCFlank leak test
FIXED! Windows 8 black screen of death on some computers
FIXED! Computer freezes after resetting sandbox
FIXED! Sandboxed bittorent doesnt function properly
FIXED! Sandboxed IE cannnot browse certain web pages with flash support
FIXED! Sandboxed browsers leak memory on some flash based web sites
FIXED! Cannot sandbox Dragon/Chrome if an instance is already running
FIXED! Password protection doesnt work in UI and Kiosk
FIXED! Firewall creates popup alerts in Game mode
FIXED! It is not possible to set Chrome/Dragon as default browser when they run in sandbox
FIXED! CIS consumes too much CPU while applying actions in scan windows
FIXED! Smart screen window closes automatically in Kiosk on Windows 8
FIXED! HIPS does NOT stop screen capturing/key logging when unknown apps run outside the sandbox
FIXED! CIS cant be started if cmdagent is disabled
FIXED! Web Browser option is missing in firewall alerts
FIXED! CIS alerts for shell32.dll after hibernation
FIXED! CIS shows undefined popup alert
FIXED! BSOD while running backup with shadowprotect
FIXED! AV alert freezes while applying some actions or being shown
FIXED! BSOD in kiosk during Firefox update
FIXED! Firewall creates alerts with random process names for IGMP |
EDIT: Uus beetaversioon:
Versiooni number: 6.0.259057.2639
Parandused:
tsitaat: |
FIXED! Killswitch consumes too much CPU
FIXED! Killswitch does not exit properly
FIXED! Virtual Kiosk hangs in some computers
FIXED! Submission status dialog is shown during cloud scanning
FIXED! Browser home pages are changed to Yahoo after opting out
FIXED! Kiosk does not fit to VMWare screen
FIXED! KillSwitch doesn't handle rating for processes which launched from network location
FIXED! Ping command doesnt work inside sandbox
FIXED! No 'Run in COMODO Sandbox' function in right-click menu before reboot
FIXED! Killswitcxh deosnt allow blocking files
FIXED! Various fixes in Russian language translation
FIXED! CLT.exe running as 'Sandboxed application' is not placed in the list 'Show only Sandboxed Processes' |
12 |
Lord Ami
52 |
maakas1
18.01.2013 12:23:42
No paistab, et täisversioon väljas. Kasutan mõni päev juba ja töötab tõepoolest paremini, kui kunagi varem. Natuke nilbevõitu on näppida küll, et interface on rohkem mingi puutetundlikul ekraanil tömbi näpuga torkimiseks, aga mälukasutus on mõistlik ja ei küsi liialt totraid küsimusi ka.
EDIT:
CIS 6 juba mõnda aega masinas W8 all. Mõtlesin esiti, et lasen ta nimme selle nn. Win Defenderi peale (sama, mis MSE), et kas tekib konflikte või on mingi segav lüli, aga installimise käigus lülitas CIS Defenderi üldse maha. Endiselt väga mõistlik mälukasutus. Viiruste kohta ei oska väga öelda.. pole, mille peal testida.
Kommentaarid: 32 loe/lisa |
Lord Ami
52 |
kasutaja01
02.02.2013 11:22:12
Lord Ami kirjutas: |
EDIT:
Kes soovib esimest eestikeelset versiooni katsetada siis:
http://www.upload.ee/files/3034833/CIS_GUI_EST.zip.html
Failid tuleb siis asendada siin kaustas olevate failidega
C:\Program Files\Comodo\COMODO Internet Security\translations
Seejärel CIS'i UI'st valida Tasks - kõige alumine - Advanced settings ning muuta Language Eesti keeleks. Seejärel parem klikk ikoonil ja CIS sulgeda. Pärast uuesti avamist peaks juba emakeelne olema
Vigadest võite PSi kirjutada. |
Viimases versioonis on juba mingisugune eesti keel olemas, kas need upload failid on täiuslikumad või sama? On need mõeldud ainult CIS jaoks või sobib ka lihtsalt antiviirusele?
Kommentaarid: 25 loe/lisa |
23 |
Lord Ami
02.02.2013 14:13:27
tsitaat: |
Viimases versioonis on juba mingisugune eesti keel olemas, kas need upload failid on täiuslikumad või sama? On need mõeldud ainult CIS jaoks või sobib ka lihtsalt antiviirusele? |
Jah, uploaditud on täiuslikumad. Tegelikult mul veel uuemad failid, panen vist pärast üles. Suurt erinevust pole, paar viga jne parandatud.
Töötab ka antiviirusega.
Hetkel on muidugi probleem selles, et CIS "uuendab" tõlget ise ja paneb vanad failid tagasi. Selle peaks parandama programmiuuendamise kinnikeeramine seadetes (või siis ajavahemik panna 30 päeva vms). Sellisel juhul peaks CIS ainult andmebaase uuendama.
52 |
estdata
03.02.2013 19:01:48
Kuidas siis selle efektiivsusega on , kuidas ta püüab viirused jne...
ja arvuti resurssidega ..
kui saa vaid tulemüür siis mul ruuter ise tulemüüri ees ja korralikult , muide CIS konfimine sama hea kui see minu enda ruuteris
Kommentaarid: 22 loe/lisa |
16 |
hendrik32
12 |
Lord Ami
03.02.2013 21:16:37
tptdairy kirjutas: |
kui saa vaid tulemüür siis mul ruuter ise tulemüüri ees ja korralikult , muide CIS konfimine sama hea kui see minu enda ruuteris  |
Efektiivne on, püüab küll ning mida ei tunne, paneb liivakasti jooksma
ressurssi võtab vähe, ei oska selle koha pealt väga kommenteerida.
52 |
estdata
03.02.2013 23:29:12
ressurssi võtab vähe, ei oska selle koha pealt väga kommenteerida. |
sama hasti võib öölda et see mida vaja ei ole võib edukalt ka efektiivne nat ruuter ära panna ta muidugi aint paketid mitte vajalikud viskab välja ära
igastahes point selles selle cis'ga , olen kasutanud ja iga pidi algaja versionis kas või , blockis mul kõik lehed ära ja ma ei saanud netti ja mitte kuhugile see pärast võtsngi ta maha
16 |
Lord Ami
04.02.2013 00:09:27
igastahes point selles selle cis'ga , olen kasutanud ja iga pidi algaja versionis kas või , blockis mul kõik lehed ära ja ma ei saanud netti ja mitte kuhugile see pärast võtsngi ta maha |
Vat ei oska kommenteerida. CIS võimaldab spetsiifilisi rakendusi keelata, et need siis välismaailmaga suhelda ei saaks (keyloggers nt).
52 |
Mnator
04.02.2013 13:09:12
Lord Ami, keylogger puhastatakse üldse arvutist minema, mitte ei üritata tema tööd pelgalt häirida
Kommentaarid: 1 loe/lisa |
Lord Ami
04.02.2013 13:14:14
Mnator kirjutas: |
Lord Ami, keylogger puhastatakse üldse arvutist minema, mitte ei üritata tema tööd pelgalt häirida  |
Eks see ole iga inimese "unistus", aga tegelikkuses on suht-koht vastupidi. Reeglina varastatakse andmed enne, kui asjast arugi saadakse.
Siinkohal jääb vaid loota, et viirusetõrje teeb oma tööd hästi ja tunneb klahvinuhi ära.
52 |
Mnator
04.02.2013 13:32:20
Seda suudab ta iseseisvalt tüüpiliselt vaid praktiliselt kogu veebiliiklust ära blokeerides..... Pole viitsinud viimaseid versioone enam proovidagi aga comodo varemalt oli igati loll ses suhtes - algul nagu hakkas õpetustest aru saama, et mida lubada ja ülejäänu kahtlasteks tunnistada ja eraldi tabelis ülevaadatav; peale mõnekuulist tööd aga otsutas näiteks turvalisi (https) ühendusi kõiki halbadeks liigitada ja isegi enam ei loginud neid eritabelisse, kus siis oleks olnud võimalus talle eksistus ära öelda. Mul tegelikult sel ajal ühtki pahalast peale "traking cookie'de" arvutisse ei roninud............. Minu järeldus oli, et comodo mulle ei sobi üldse!
Genobe222
05.02.2013 19:38:42
Mul mingi nädal tagasi jooksis arvuti iga kord kokku, kui update'ist keeldusin. Lõpuks tegin ära ja hetkel on korras.
maakas1
20.02.2013 16:11:43
Üks väike tähelepanek: HIPS on saatanast.
Lugege see jama läbi, tehke muudatused ja salvestage konfiguratsioon kuhugi, et ka hiljem oleks hea võtta.
Üldiselt pole muud vaja, kui proaktiivseks muuta ja siis HIPS kus kurat lennutada.
Kassmees
25.02.2013 08:27:36
Kas keegi Comodo Linuxi versioonist kah head või halba jutustada oskab?
http://www.comodo.com/home/internet-security/antivirus-for-linux.php
Lasin omal Bodhi Linuxi all peale. Alguses oli probleeme, neist ja nende lahendamisest saate lugeda näiteks siit (siin leidus meetod, mis mind aitas):
http://forums.comodo.com/comodo-antivirus-for-linux-cavl/kernel-module-t87150.0.html
Mõte on mul selles, et Windowsi kasutades internetti üldse vältida, teeks vaid musa ja HDR-pilte. Netikasutus käib mul juba mõnda aega täielikult Linuxi kaudu ja miks mitte sealt Windowsi partitsiooni skanneerida. Ehk saan Winni all koormavaist lisaprogrammidest üldse loobuda. Paraku Windowsi uuendusi vist läbi Linuxi tirida ei saa - kui saab, siis oleks juba ülikõva ja ma saaks Winnilise internetiteenused eksperimendi korras üldse välja lülitada(y)
Kommentaarid: 59 loe/lisa |
46 |
looder123
27.02.2013 03:26:57
Kas kuidagimoodi on võimalik seda vanat GUI'd ka tagasi saada? See uus on ikka pask rsk.
Kommentaarid: 5 loe/lisa |
maakas1
12.03.2013 14:58:29
Tegelikult tahaks pikemat aega juba kõigi tõrjurite GUI-d maha kiskuda. Kunagi oli Avast 5-s vist viinati olemas variant kogu ülikond eemaldada ja win9x stiilis hoida.
* Siiski skin, millest jutt käib. Vaevalt, et keegi kugugi käsureale toksima viitsib minna.
