uus teema   vasta Uudised »  Varia »  Amazon hakkab kasutatud e-raamatuid müüma märgi kõik teemad loetuks
sõnum 11.02.2013 13:05:39 Amazon hakkab kasutatud e-raamatuid müüma vasta tsitaadiga
Amazonile omistati hiljuti patent, millega saab ettevõte hakata vahendama e-raamatute lugemisõiguste edasimüümist.
Loe edasi Fortest.
Kommentaarid: 472 loe/lisa Kasutajad arvavad:  :: 13 :: 7 :: 359
LKits
LKits
sõnum 11.02.2013 13:37:16 vasta tsitaadiga
NightStriker
sõnum 11.02.2013 13:52:23 vasta tsitaadiga
Allverelaev sukeldub määramata ajaks...
viimati muutis NightStriker 15.06.2024 03:31:17, muudetud 1 kord
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
sõnum 11.02.2013 13:56:44 vasta tsitaadiga
Kas tuleb ka samasugune lahterdamine nagu reaalsete raamatute puhul? icon_lol.gif
New: Just like it sounds. A brand-new, unused, unopened item in its original packaging, with all original packaging materials included. Original protective wrapping, if any, is intact. Original manufacturer's warranty, if any, still applies, with warranty details included in the listing comments.
Refurbished: Use only if noted in the Category-Specific Condition Guidelines. A refurbished product has been professionally restored to working order. Typically this means that the product has been inspected, cleaned, and repaired to meet manufacturer specifications. The item may or may not be in its original packaging. The manufacturer's or refurbisher's warranty must apply and should be included in the listing comments. Refurbished items are sometimes referred to as "remanufactured."
Used - Like New: An apparently untouched item in perfect condition. Original protective wrapping may be missing, but the original packaging is intact and pristine. There are absolutely no signs of wear on the item or its packaging. Instructions are included. Item is suitable for presenting as a gift.
Used - Very Good: A well-cared-for item that has seen limited use but remains in great condition. The item is complete, unmarked, and undamaged, but may show some limited signs of wear. Item works perfectly.
Used - Good: Use only if noted in the Category-Specific Condition Guidelines. The item shows wear from consistent use, but it remains in good condition and works perfectly. It may be marked, have identifying markings on it, or show other signs of previous use.
Used - Acceptable: Use only if noted in the Category-Specific Condition Guidelines. The item is fairly worn but continues to work perfectly. Signs of wear can include aesthetic issues such as scratches, dents, and worn corners. The item may have identifying markings on it or show other signs of previous use.
Kommentaarid: 746 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 561
soomer
sõnum 11.02.2013 14:19:40 vasta tsitaadiga
radist87 kirjutas:
Rohkem nagu WTF uudis. Kogu sellest e-raamatu innovatsioonist sõidavad üle igasugused e-juriidilised absurdid. Amazon hakkab tõsimeeli e-raamatu kõrval müüma kasutatud e-raamatu versiooni?
Tegelikult võibolla nii WTF ei olegi. Mõtle ise, tagasiostetud raamatu eest on raamatu autorile juba üks kord makstud, seega amazon ei pea enam autorile või publitseeriale selle eest enam midagi maksma.
Saab inimestele raamatu odavamalt müüa ning tõenäoliselt suurema marginaali hinna sisse panna.
NightStriker
sõnum 11.02.2013 14:30:49 vasta tsitaadiga
viimati muutis NightStriker 15.06.2024 03:31:10, muudetud 1 kord
sõnum 11.02.2013 14:40:07 vasta tsitaadiga
Ajuvaba tegelikult - tegemist on kasutatud failiga lihtsalt. Mis krdi tagasiostmine ja "kasutatuks" lahterdamine. Lihtsalt õhu müümisega raha tegemine.
sõnum 11.02.2013 14:42:18 vasta tsitaadiga
Sarnasel teemal on ju kohtuvaidlus Apple vs. Bruce Willis - viimane tahab oma legaalselt iTunes'ist ostetud muusikakogu pärandada oma tütrele, aga Apple ei luba seda.
http://www.guardian.co.uk/film/2012/sep/03/bruce-willis-apple-itunes-library
UB
UB
sõnum 11.02.2013 15:50:58 vasta tsitaadiga
Tegelikult peaks kõik asjad olema ühtemoodi edasimüüdavad, see asi oleks vaja lõpuks korralikult selgeks rääkida. Kui asjadel oleks õige hind ning normaalne kättesaadavus, siis ei viitsiks keegi isegi mitte pirada. Praegu on aga igasugused regioonipoliitikad ning muu jamps nii üle pea kasvanud. Paned filmi käima ja enne seda näidatakse sulle minu minutit piraadivastast kampaaniat ja reklaame, kuigi oled asja eest maksnud. Piraadid ei maksa midagi ja itsitavad pihku, kui saavad kohe filmi juurde asuda.
Kui e-raamatute hinnad oleksid ka mõistlikud ning neid hoitakse sinu kontol samamoodi nagu seda teeb Amazon oma raamatutega või Steam mängudega, siis ei hakkaks ka keegi pirama vaid makstakse mugavuse eest.
Kommentaarid: 45 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 39
Leinö
Leinö
sõnum 11.02.2013 15:55:52 vasta tsitaadiga
radist87 kirjutas:
Nagu ma ütlesin: e-juriidika, mitte e-raamatu uudis. Järgmine uudis tuleb selle kohta, et järelturul liikuvate e-raamatute pealt autor ja publitseerija ei teeni. Kuna nende rahakott läheb seetõttu õhemaks, siis on vaja ju esmaostjatele hinda tõsta. Autori jaoks pole see sel juhul parem piraatlusest.
Müüge mulle see e-raamat parem kohe mõistliku hinnaga (ärge küsige paberi+trüki+transpordi hinda). Niikaua, kui e-raamatu kõrval olev paperback maksab vähem, kui digitaalne koopia (neid näiteid on amazonis liigagi palju), võivad nad minu poolest kogu selle teema endale pähe tõmmata ja paraadile minna.
Samamoodi ei teeni kirjanik kasutatud raamatute pealt.
Igast antiigipoed, kaltsukad jne, seal leidub tohutult vanu raamatuid (leidub ka uuemaid), mis siis mõnele koju riiulisse läheb.
Renka
Renka
sõnum 11.02.2013 18:59:31 vasta tsitaadiga
Tanel kirjutas:
Sellist asja ei ole juhtunud icon_lol.gif Järgmine päev lükati asi juba ümber.
http://www.gizmodo.com.au/2012/09/bruce-willis-not-suing-apple-after-all/
sõnum 11.02.2013 19:05:20 vasta tsitaadiga
OK. Aga mis see lahendus on siis, saab lihtsalt pärandada oma lastele või ei saa?
HV valuutakalkulaator
Renka
Renka
sõnum 11.02.2013 19:08:56 vasta tsitaadiga
Ei kujuta ette.
Kirjutad testamenti useri ja parooli vmt :d
klf
sõnum 12.02.2013 01:07:09 vasta tsitaadiga
Betamax, http://www.27bslash6.com/overdue.html
