sakinaga
31.01.2013 20:32:23
Toreda uudisena teatas HTC et nemad vähemalt esialgu HTC HD7-le Windows Phone 7.8 uuendust teha ei kavatse. Päris kurb...
154 |
estliiga
31.01.2013 20:54:51
| maatriks kirjutas: |
| Toreda uudisena teatas HTC et nemad vähemalt esialgu HTC HD7-le Windows Phone 7.8 uuendust teha ei kavatse. Päris kurb... |
Masendav ikka, olen ka juba pikkisilmi oodandud seda uuendust oma telefonile
| Kommentaarid: 60 loe/lisa |
56 |
linni
GinPenGuin
31.01.2013 21:15:15
| rebane09 kirjutas: |
| Proovisin küll Zune kaudu, aga ei näita küll mingit uuendust. Kas kellelgi Lumia omanikest on juba 7.8 peal? |
Jah, minu Lumia 800 on, aga mul käis telefon garantiis ja seal ma palusin peale panna WP 7,8. See mul ca 3 nädalat olnud!
| Kommentaarid: 25 loe/lisa |
24 |
whitiker
31.01.2013 21:21:42
lumia 800 ja eile tuli zune kaudu!
Johan11
31.01.2013 21:23:07
Force update mode oled proovinud. Kas 7.8 update ei pidanud otse MS-lt tulema. Ma oma Dell Venue Pro sain uuendatud, kahtlen, et Dell kavatse oma ammu unustatud telefoni esirinnas uuendada.
Connect your Windows Phone to a PC and launch the Zune software
Click on Phone > Settings > Update. Allow the software to tell you whether an update is available. If so, skip this guide. If not continue to the next step.
Time to force the update. Click another button (any of the options above or below the word Update). Then click the Update button again, and this time disconnect your computer from the internet after 2-3 seconds. Do this by pulling out the Ethernet cable, disabling Wi-Fi, etc. If it says your phone is already up to date, you didn't disconnect quickly enough and need to try this step again.
Wait 30 seconds or so and Zune should display a notification that an update is available.
Now reconnect to the internet and continue with the update process through the Zune software.
Remember to:
(1) Put your phone to airplane mode
(2) Unplug the cable physically! (Turning off wifi did not work for me)
Other than that, if you see "can't check for update @!#$#@", that means you're unplugging it too soon, and if you're seeing "your phone is up to date", then as mentioned in previous posts, you didn't do it quick enough. There seems to be a specific unplugging timing for you to get the update, not too fast, but not too slow either.
| Kommentaarid: 43 loe/lisa |
37 |
sakinaga
31.01.2013 22:29:06
Hmm, huvitav, proovisin niisama Zune kaudu uuendada ja tulemuseks:
Annan tulemustest kohe teada kui valmis saab.
Tegemist siis HTC HD7-ga
Windows Phone 7.8 siis kenasti peal. Ainuke liigutus mida tegin oli telefoni lennurežiimi panek.
viimati muutis sakinaga 31.01.2013 22:34:34, muudetud 1 kord |
154 |
Siim159
31.01.2013 22:32:33
| Tahaks ka enda HTC 8S-i Zunega ära ühendada, kuid mismoodi? Ühendan telefoni ilusti arvutile järgi, kuid Zune ei näita, et oleks ühendatud. Olen teinud Zunele reinstalli, telefoni sisse-väljalülitanud, kuid ei mingit tulemust...
| Kommentaarid: 22 loe/lisa |
21 |
sakinaga
31.01.2013 22:39:27
Windows Phone 8 enam ei suhtle minuteada Zunega, peaks mingi uus süsteem olema. Täpsemalt ei ole kursis. Positiivse poole pealt sai muusikat vist ka läbi iTunesi hallata mis on Windowsi peal kordades parem kui Zune oli.
154 |
Johan11
37 |
linni
31.01.2013 22:44:06
| Siim159 kirjutas: |
| Tahaks ka enda HTC 8S-i Zunega ära ühendada, kuid mismoodi? Ühendan telefoni ilusti arvutile järgi, kuid Zune ei näita, et oleks ühendatud. Olen teinud Zunele reinstalli, telefoni sisse-väljalülitanud, kuid ei mingit tulemust... |
Windows Phone app for desktop.
Lumia 900 ei taha Flight mode petekat omaks võtta. Eks ootame.
Siim159
31.01.2013 22:44:54
Mingi app installis jah peale esimest arvutiga ühendamist... See ongi saa samune "Windows Phone" app, jah?
Aga selge siis.
21 |
thoppers
31.01.2013 22:51:43
| Võibolla ei istu teemasse see jutt nüüd, aga täna sattusin poes seda lumia 800 näppima ja tekkis küsimus peas, miks kõik tõesti neid suuri labidaid toodavad? See 3,7 tolline istub nii ilusti käes ja kuidagi hea oli kasutada. Ise olen androidi kasutaja, aga see kiirus ja sujuvus on ikka võrreldamatu. Tahaks ka WP üle minna ning mõneks hetkeks tekkis isegi mõte osta seda lumia 800, sest see päris soodne ka ju nüüd ja peaks isegi wp7.8 nüüd samma eks?
prtv
31.01.2013 22:54:32
| thoppers kirjutas: |
| Võibolla ei istu teemasse see jutt nüüd, aga täna sattusin poes seda lumia 800 näppima ja tekkis küsimus peas, miks kõik tõesti neid suuri labidaid toodavad? See 3,7 tolline istub nii ilusti käes ja kuidagi hea oli kasutada. |
Sest multimeediumi tarbimiseks jääb reaalselt 3.7"'st väheks. Kui ainult helistad ja sõnumineerid, siis käib kah, natukenegi midagi muud teha, siis suurus seab omad piirid.
| Kommentaarid: 82 loe/lisa |
73 |
heff
31.01.2013 23:02:37
Lumia 800 ja sai ka forcemist korduvalt tehtud, lõpptulemusena sai 2 esimest update'i tehtud (olen 8783 peal), aga kolmandat ei tule üldse, iga kord (ükskõik kaua oodata) annab teate, et update service pole saadaval. Andsin alla praegu ja tiksun oma wp7.5 peal
Seevastu tüdruk sai oma Lumia 800 väga valutult uuendatud, telefon ütles kohe, et uuendus saadaval, pani juhtme külge ja Zune'is sai kõik kenasti tehtud.
Minu oma on iseenesest UK päritolu, ei tea kas see mõjutab.
Suuruse kohta - eks ta ole jah, kust otsast vaadata. Ise kibeleks millegi suurema poole, et mobiilselt veidi rohkem saaks ära teha, 3.7" ekraan jääb netis kolamisel pisut jalgu. Teine asi, mis mind ära on tüüdanud, on rakendustebaas, mis vähemalt enne wp8-t on nadi. Ei saa öelda, et ma mingist rakendusest puudust tunneks, aga pigem on probleem olemasolevates rakendustes endis - konkurentidega võrreldes on tohutult maha jäädud ja isegi funktsionaalsus on rohkem piiratud. Hea meelega vaataks Lumia 820 poole, aga resolutsioon on küll kiviaegne sellises hinnaklassis seadme kohta. Ilmselt ise liigun üsna pea Androidi peale tagasi. Siiski hindan kõrgelt Windows Phone'i kasutajaliidest, mis on väga kiire, mugav ja loogiline.
94 |
thoppers
31.01.2013 23:03:15
Jah, seda nüüd tõesti...ma ise kasutangi enamusajast lihtsalt helistamiseks ja mõne neti lehe vaatamiseks. Samas ei saa aru kes viitsib pidevalt telefonist filme ka vaadata. See 4,7" pole ka ju nüüd nii suur et võiks lausa filme hakata vaatama aga tõesti, maitse asi on see jah...
Lisaks ma mõtlen koguaeg, kuidas see 4,7" või suurem kuskil teksade taskus tundub..
Johan11
31.01.2013 23:04:06
| Täna hommikul sai ka 3nda uuendusega pikemalt jebida. Ajastus peaks seal suht tähtis olema. Nende paari sekundi jooksul peaks ta alguses selgeks saama et uuendus on olemas. Peale seda uurib mudeli ja regiooni järgi kas ta sulle hetkel peaks pakkuma. Kui ütleb, et uuendust ei ole, siis oled tõenäoliselt hiljaks juhtme välja tõmbamisega jäänud.
37 |
rebane09
01.02.2013 00:27:36
Olen ka juba kaks force update teinud ja ikka pole 7.8 peale saanud.
Praegu 7.10.8783.12
| Kommentaarid: 149 loe/lisa |
131 |
M8T0
01.02.2013 00:30:33
no küll ta tuleb - ega ta tulemata ei jää.
hirmsasti kipitab siis siin mõni leht tagasi oli õpetus kuidas seesama update navifirmi kaudu peale ajada.
kiiremad härrad lasid juba mitu kuud tagasi 7.8 peale (k.a. ma ise).
| Kommentaarid: 87 loe/lisa |
linni
01.02.2013 07:40:04
| Johan11 kirjutas: |
| Täna hommikul sai ka 3nda uuendusega pikemalt jebida. Ajastus peaks seal suht tähtis olema. Nende paari sekundi jooksul peaks ta alguses selgeks saama et uuendus on olemas. Peale seda uurib mudeli ja regiooni järgi kas ta sulle hetkel peaks pakkuma. Kui ütleb, et uuendust ei ole, siis oled tõenäoliselt hiljaks juhtme välja tõmbamisega jäänud. |
Mul tuli ka lõpuks ära. Pigem on neti katkestamise vahemik sinna 4 - 5 sekundi kanti, kui 2 - 3 sekundit, nagu algses õpetuses kirjas.
Johan11
01.02.2013 07:47:22
| Eks ta sõltub kas neti kiirusest või millestkist. Mul 3-4 sekundiga juba ütles, et uuendust ei ole.
37 |
extreme2
kaspir
01.02.2013 10:15:57
Sain endale ka peale aetud 7.8 Lumia 800'le. Seda interneti välja tõmbamist sai kõvasti harjutatud, kuni lõpuks 7.8 update üles leidis. 15 korda kindlasti kolme update peale kokku. Aga asi töötab ja enam ei pea avakuval 6 tile'ga piirduma, vaid kenasti kõik tähtis kohe ees
_________________ |
| Kommentaarid: 15 loe/lisa |
Forss
01.02.2013 21:32:19
7.8 on väga hea uuendus ikka.
Kaabli kiskumisest sain ka uuendused kätte
Bluetooth share tuli juurde, aga pole veel katsetanud.
Üks küsimus ka, et see volume nuppu vajutades tuleb (<<) alla mingi raadiolainete ikoon ja siis avab WhatsApp programmi. Millest see tuleneb? Kas whatsapp töötab siis kogu aeg taustal, aga näiteks viber mitte?
Siim159
01.02.2013 21:42:39
Mul HTC 8S-ga selline jama tekkinud selle unlock asjaga, kus tuleb see pilt üles tõmmata, et telefon unlockida, et vahete vahel ei saa kohe unlockida, vaid telefon on korraks nagu "freezed". Varem sellist jama pole olnud. Millest võib see tuleneda?
Pigem esineb seda siis, kui pole kauemat aega telefoni näppinud. Kui aga alles telefoni sai kasutatud ja uuesti unlockid, siis pigem seda probleemi ei esine. Nagu vahepeal lülituks midagi välja selle tüki aja jooksul ja siis kui sisse lülitan, laeb selle "freeze" seisundis uuesti midagi tööle vms - jääks nagu selline mulje.
21 |
