danny
27.01.2013 18:45:31
| commoon kirjutas: |
| Mis selle originaal 4.1.2 ja leaked versiooni vahe on? |
Üks on leaked teine ei ole lihtsalt veel meie maale välja lastud.
Lisaks on JB baasil Wanamlite.
Based on latest Jelly Bean base LS8
Repacked Stock Kernel + Safe CWM (Thanks to Philz)
Deodexed (smali 1.4.2) & Rooted & Zipaligned & Busybox
Pure Stock Themed
Aroma installer
Unlimited SMS recipient list
No SMS to MMS convert
Automatic SMS encoding (Arabic support)
23 customizable Status bar + Numeric Circle battery (Available on a separate patch)
Numeric Circle battery (Optional on Aroma)
Tweaked Speed & Battery life
Disabled scrolling cache
Enabled All languages (Arabic, Hebrew...) on settings menu and keyboard
Debloated (Removed Apps available on Aroma installer)
Large APN list
No incremental ringtone
Enabled Call recording
Enabled Ripple effect on Stock Lockscreen (Optional on Aroma)
Enabled Sensor aiding for fast GPS lock & better battery life
4 Way reboot
Fixed Right to Left allignement for Arabic/Hebrew (Optional on Aroma)
4 Shortcuts on the Lockscreen
Clean build.prop for best Market compatibility
Kies support
Call Button on Contacts List (You can hide it from Aroma installer)
Stock dialer buttons
Hacked Email App
Unlimited Wifi AP clients
Unlimited Contact joining
Disabled Shutter on Apps
Moved All system apps on Preload partition to get more space on System partition
Swype keyboard (Optional on Aroma)
Enabled Shutter sound menu on Camera
Tweaked CPU sampling rate for better battery life
| Kommentaarid: 49 loe/lisa |
42 |
ivar80
28.01.2013 11:25:01
| Kiire akutühjenemine oli ka minu telefonil probleemiks, kui seda testversiooni JB'd kasutama hakkasin. Suurim põhjus oli selles, et vaikimisi seadetega hakkab google+ üles laadima kõiki pilte ja videosid mis sul telefonis on, konks maha ja kohe palju parem. Teine suur killer oli "Asukoha teenuste" all asuv google asukohamääraja.
| Kommentaarid: 40 loe/lisa |
38 |
cuda
30.01.2013 16:57:11
Üritan seda wanamlite'i ROMi peale lasta aga system recovry annab järgmise veateate:
E:unknown volume for path [SDCARD:/romi asukoht mälus]
E:can't mount SD card SDCARD:/romi asukoh mälus
Hetkel on peal see ametlik jelly bean'i hispaania versioon. Rootimiseks kasutasin CWM-SuperSU-v0.87.zip-i.
Wanamlite'e ROMi zip on kopitud telefoni sisemälusse ja siis CWM rom manager'ist valides "install ROM for SD card" annab ülaloleva veateate.
Esimest korda mässan rootimisega ja seege üsna tõenäoline, et teen midagi valesti.
Oskab keegi abistada?
| Kommentaarid: 6 loe/lisa |
30.01.2013 17:12:29
Sa pead minema sd kaardile ja selle. zip yles otsima ja siis vajutama ok.
Ma ei saanud aru, kas sa tegid nii.
Kui ma õigesti mäletan, siis mobla mälu ei saanud kasutada (võin ka eksida)
Google abiks
Edit:
Vaatasin järgi
Install zip> choose zip internal>otsi yles zip yles ja installi ära
cuda
30.01.2013 17:35:07
| jeesus188 kirjutas: |
| Install zip> choose zip internal> |
Kus sellised valikud on? CWM menüüst midagi sellist ei leidnud (ROM manager 5.5.1.7)
30.01.2013 17:41:06
| cuda kirjutas: |
Kus sellised valikud on? CWM menüüst midagi sellist ei leidnud (ROM manager 5.5.1.7) |
Ee, ma ei tea, mul wanamlite koguaeg peal, CWM on alati kaasas olnud
Pole midagi juurde installinud.
Pane siis läbi ODINi peale, kui nii ei õnnestu
eltso
31.01.2013 00:35:19
sa üritad seda telefoni menüüst teha, see ei toida. Pead minema CWM recoverysse ja selleks lülita telefon välja ja hoia vol+ home power korraga all. Seal on need vajalikud valikud olemas
| Kommentaarid: 14 loe/lisa |
14 |
31.01.2013 00:55:29
| eltso kirjutas: |
sa üritad seda telefoni menüüst teha, see ei toida. Pead minema CWM recoverysse ja selleks lülita telefon välja ja hoia vol+ home power korraga all. Seal on need vajalikud valikud olemas  |
kuna mul pole kunagi mõte isegi selle peale tulnud, siis ma ei osanud seda oodata
eltso
31.01.2013 01:06:20
Ma mingil hetkel kunagi proovisin ka ühe telefoni sisest imeproge, aga ei toiminud see asi seal väga, seega tunne on tuttav
14 |
marti384
31.01.2013 14:22:26
jamad järgmised:
1. WIFIga netis olles vahel telefon lambist lülitab ennast välja, samas kui aku on näidu järgi (battery indicator app) veel 50-60% ringis. Kui telefon uuesti sisse lülitada, siis näitab et aku on peaaegu tühi....vaid 10% ringis alles.
2. vahel kiilub WIFI nupp kinni. Kui telefonile restart teha, siis on jällegi aku näit kõvasti langenud.
telefon ise 1a 4kuud vana. 5 kuud tagasi garantiis vahetatud esipaneel, sest kodunupp pani segast (võttis tihti ühe nupuvajutuse ikkagi 2 nupuvahetuse pähe ja see aktiveeris Voice commandi...muutus väga häirivaks).
androidi versioon 4.0.3
on see selle android 4.0.3 viga? või on aku läbi? või midagi muud?
Tänud ette vastajatele.
night596
31.01.2013 14:50:45
| See et wifi nupp kiilub on androidi viga,sest 4.1.2 seda enam pole. AGA kui sa wifi kastutad , kas telefon muutub soojaks ka v, kui jah siis koormab mingi muu asi telefoni ja sp näitabki 10% aga miks ta välja lülitub seda ma öelda ei oska.
föönitaja
31.01.2013 17:53:00
| Kuna SII-l puudub notification LED indikaator, siis kas keegi on leidnud programmi, millega saaksin alumised puutetundlikud nupud panna vilkuma kui olen maha maganud kellegi kõne, sõnumi või muu notificationi? Ainukene programm mille leidsin on NoLED, kuid too kuvab mulle ekraanile vaid väga ebapäraselt paigutatud väikesed ikoonid. Kuna olen selline minimalist, siis neoon-värvides ikoonid ei ole just minu teema. Äkki kellelgi sama mure?
| Kommentaarid: 9 loe/lisa |
9 |
isiklik
31.01.2013 18:16:20
| föönitaja kirjutas: |
| Kuna SII-l puudub notification LED indikaator, siis kas keegi on leidnud programmi, millega saaksin alumised puutetundlikud nupud panna vilkuma kui olen maha maganud kellegi kõne, sõnumi või muu notificationi? Ainukene programm mille leidsin on NoLED, kuid too kuvab mulle ekraanile vaid väga ebapäraselt paigutatud väikesed ikoonid. Kuna olen selline minimalist, siis neoon-värvides ikoonid ei ole just minu teema. Äkki kellelgi sama mure? |
Mina vajutan HOME nuppu ja vaatan, kas on vastamata kõnesid, SMS-e jms.
eZ
31.01.2013 19:45:31
Kui kasutad CustomROMi ja kernel toetab BLN muutmist siis on see võimalik, STweaks või misiganes selle appi nimi ei olnud, millega saad kerneli seadetes BLN seadeid näppida.
| Kommentaarid: 26 loe/lisa |
25 |
kr6ll
31.01.2013 20:56:13
| kuulge. ma siin yritan seda 4.1.2 peale panna aga ilge jama on selle tar.md5 unzippimisega. millega seda teha
| Kommentaarid: 89 loe/lisa |
69 |
Dijital
| Kommentaarid: 41 loe/lisa |
teitur
31.01.2013 21:10:18
| marti384 kirjutas: |
jamad järgmised:
Tänud ette vastajatele. |
Mul tutikas telefon lülitas ka ennast välja ja tõmbas aku tühjaks kui õigel ajal jaole ei saanud.
Viisin garantiisse, eks varsti näeb siis mis kostavad.
| Kommentaarid: 42 loe/lisa |
37 |
kr6ll
31.01.2013 21:10:23
| seal odin 3.7. kuhu ma selle faili panen. kas sinna PDA, PHONE või kuhu? Need õpetused imevad.
69 |
Dijital
31.01.2013 21:21:07
| kr6ll kirjutas: |
| seal odin 3.7. kuhu ma selle faili panen. kas sinna PDA, PHONE või kuhu? Need õpetused imevad. |
Need õpetused, mida mina näinud olen (suvalised google'i esimesed lingid) on ikka väga korralikud olnud. Kui nendest aru saamisega probleeme, siis ma parem ei torgiks
kr6ll
31.01.2013 21:25:57
| korralikud õpetused jah aga failid mis seal on, mul nagu selliseid pole. Kust seda alla 4.1.2 tõmmata?
69 |
night596
kr6ll
31.01.2013 22:37:00
Juba olemas. Esimene kord. Lihtne
69 |
31.01.2013 22:59:53
| kr6ll kirjutas: |
Juba olemas. Esimene kord. Lihtne  |
Ei olnud ju lihtne, kui sa tahtsid tar.md5 faili lahti pakkida
kr6ll
31.01.2013 23:11:34
no mingi õpetus oli et tee odin lahti ja siis pane yks fail phone ja teine ma ei tea kuhu nupu alla jne. Lihtsalt need õpetused imevad. Siis arvasingi et tuleb ehk see lahti pakkida kuna mul polnd selliseid asju nagu need seal õpetuses näitasid. Lõpuks oli mul nii savi et panin lihtsalt tuimalt nagu ise arvan et õige on. Abi oli sellest et öeldi siin et pakkida lahti pole vaja
69 |
Zeto
01.02.2013 17:09:12
| teitur kirjutas: |
jamad järgmised:
Viisin garantiisse, eks varsti näeb siis mis kostavad. |
Mu oma käis ka kohe peale ostmist garantiis. Samamoodi lülitas end poole aku pealt lambist välja ja käima ilma akut korra eemaldamata ei saanudki.
Oli 2 nädalat elisas remondis ja kättesaades oli tarkvara uuendus tehtud.
Aga nüüd pole rohkem jamanud. Lasin kohe Jelly Beani ka peale, ehk see ka abiks.
Kui aga akuteema välja jätta (mis peab ikka häbematult vähe) olen aparaadiga rahul, eriti Wildfire pealt tulnuna.
Siiamaani parim norm suuruse ekraaniga mobla turul.
firemark
01.02.2013 17:12:43
soovitan soojalt võimsam aku osta. 2000mAh. minu kasutuse juures peab päeva rohkem
93 |
tiitise
01.02.2013 18:21:45
| Zeto kirjutas: |
Siiamaani parim norm suuruse ekraaniga mobla turul. |
Kui palju see häbematult vähe siis on?
Endal wanamlite rommiga peab kuskil 2 päeva. Seal on sees 2..3 tundi filmivaatamist, kõned, igasugu sünkimised jne. (3g stabiilselt sees)
kriist
01.02.2013 18:22:04
| firemark, Millist võimsamat soovitad, need ebay hiinakad vist eriti ei "toida".?
93 |
siinus
| Kommentaarid: 70 loe/lisa |
63 |
Spacefly
01.02.2013 19:04:06
Mul ka algusest peale see originaal 2000 aku. Muidu rahul aga spets mudeli autohoidikutega ning silikon jms kestadega võid hüvasti jätta. Kui hoidiku saad universaalse võtta, siis kesta kahjuks ei olegi olemas vist. Nimelt siis akuga tuleb kaasa ka uus kaas ja telefon muutub pisut paksemaks st kogu telefon on sama pak, kui muidu on see alaosa väike jupp.
_________________ Parim tegevus, kui und ei tule, on lambaid ja nende postitusi lugeda. |
| Kommentaarid: 63 loe/lisa |
60 |
Satakas
siinus
02.02.2013 02:09:22
kuskil on piir. Liiga paksuks ei tasu ka lasta. Eriti veel, selle tagakaane välimus pole suurem asi...
_________________ suck less | no slop grenade
63 |
Satakas
02.02.2013 10:40:31
| aga kelle asi, kui pidavust jätkub kaks korda kauemaks ja seda mitte mingis hipsterite kohvikus feissbuuki uuendades vaid midagi olulist teges?
cs_sux
02.02.2013 18:21:11
| Kuulsin, et KIES annab juba JB Eestis. Kas v6ib keegi proovida? Ise ei saa, mul custom, aga tahaks samsungi oma proovida.
| Kommentaarid: 18 loe/lisa |
18 |
Olaf
02.02.2013 18:23:42
| cs_sux kirjutas: |
| Kuulsin, et KIES annab juba JB Eestis. Kas v6ib keegi proovida? Ise ei saa, mul custom, aga tahaks samsungi oma proovida. |
Kust selline info?
| Kommentaarid: 81 loe/lisa |
75 |
cs_sux
02.02.2013 18:27:11
| Olaf kirjutas: |
| Kust selline info? |
Venekeelne android foorum
18 |
Gunnar19
Kaevur
02.02.2013 18:30:29
Väga kõva küll kui KIESiga juba saab JB.
Mul ei tööta usb otsik, ainult laadida saab.
Huvitav millal see uuendus võib nagu otse telefonile tulla?
Garantiisse ei viitsi viia, saab paar kuud ilma telefonita chillida.
tnis33
02.02.2013 19:17:30
| Minul ei paku läbi KIESi uuendust...
Gunnar19
Kaevur
Olaf
75 |
Gunnar19
Kaevur
02.02.2013 23:52:16
hahaha, iraani kuttidel on endiselt Gingerbread
taff911
03.02.2013 03:27:08
Vara veel, läbi Kies JB ei paku, proovitud...veidi veel kannatust, kuigi kanntus hakkab katkema juba
| Kommentaarid: 32 loe/lisa |
30 |
SilQ
03.02.2013 11:57:18
| taff911 kirjutas: |
Vara veel, läbi Kies JB ei paku, proovitud...veidi veel kannatust, kuigi kanntus hakkab katkema juba  |
Mul katkes eelmine nädal, Hispaania versioon läks peale
215 |
isiklik
03.02.2013 21:45:23
| SilQ kirjutas: |
| taff911 kirjutas: |
Mul katkes eelmine nädal, Hispaania versioon läks peale  |
Ja mis vahet on Hispaania ja Eesti versioonil?
Gunnar19
Kaevur
03.02.2013 22:16:46
isiklik, pakun et väljalaske kuupäev ongi erinev.
SilQ
04.02.2013 08:09:18
| isiklik kirjutas: |
| SilQ kirjutas: |
| taff911 kirjutas: |
Ja mis vahet on Hispaania ja Eesti versioonil? |
Versiooni vahe, mitte midagi muud. MobiilID töötab ja eesti keel valikus.
215 |
isiklik
04.02.2013 09:34:05
| SilQ kirjutas: |
| isiklik kirjutas: |
| SilQ kirjutas: |
| taff911 kirjutas: |
Versiooni vahe, mitte midagi muud. MobiilID töötab ja eesti keel valikus. |
Mul on see Hispaania versioon - ei saa nagu aru, et MobiilID puuduks, või ei töötaks. Olemas on ka täitsa eestikeelne eesti keel.
ivar80
04.02.2013 10:10:19
Suurim erinevus on see, et hiljem sa ei saa enam KIESi kaudu tarkvara uuendada
ja pead seda tegema Odini või CWM kaudu.
38 |
SilQ
04.02.2013 10:34:24
| isiklik kirjutas: |
| SilQ kirjutas: |
| isiklik kirjutas: |
| SilQ kirjutas: |
| taff911 kirjutas: |
Mul on see Hispaania versioon - ei saa nagu aru, et MobiilID puuduks, või ei töötaks. Olemas on ka täitsa eestikeelne eesti keel. |
Seda ma just ju ütlesin
ivar80
ja pead seda tegema Odini või CWM kaudu. |
Jah seda ka. Aga see pole teab mis raketi teadus.
215 |
04.02.2013 10:56:05
Ja kust see hispaania variant siis peale saab?
Ikka odini või cwm kaudu
Kiesi kasutasin vaid korra, kunagi mu samsa mobiilse ajaloo algusaastal
