kaspar00
25.01.2013 20:20:00
| Sven kirjutas: |
Mis timmingutel need 2133MHz töötavad? Pean ise varsti midagi analoogset muretsema. Mõtlen kas need native 2133 mälud ära tasuvad... |
igapäevaselt jooksutan 1866 def peal ja pole eriti süvenenud mis parimad seaded on millega 2133 veel stabiilne oleks, eile sai lastud 12-12-12-27 @1,65V
aga eks praegu juba leiab poest 2133gi suht sama hinnaga ja norm 1.5v variante juba
102 |
Ho Ho
25.01.2013 20:40:11
| kaspar00 kirjutas: |
benchisin ajaviiteks gta4 erinevate mälukiirustega, muidu samadel MED/HIGH( https://foorum.hinnavaatlus.ee/viewtopic.php?p=7458260#7458260 ) seadetel
1333Mhz - 27FPS
1600Mhz - 32FPS
1866MHz - 34FPS
2133MHz - 36FPS
oleks 2133 peal timeingud samad saand jätta kui muudel kiirustel siis vist oleks 10fps vahe kätte saand puhtalt mälu pealt  |
Vana nali. Integreeritud videokaardid on kiiruses suht-koht lineaarselt mälu ribalaiusega skaleerunud juba päris mitu põlvkonda.
86 |
kaspar00
25.01.2013 21:10:25
nii ta on, nii see elu käib, polnud viitsind lihtsalt varem uurida kas päriselus ka asi nagu internetti reviewdes
102 |
One
26.01.2013 09:17:41
link :: GizmoSphere Launches an AMD APU-based Gizmo Board for Embedded Systems Inventors
AMD today announced that the newly launched Gizmo board, a low-cost board geared toward x86-based embedded system development available from GizmoSphere,
is powered by an AMD Embedded G-Series Accelerated Processing Unit (APU). Gizmo is a 4-inch by 4-inch x86 development board that can run a variety of operating
systems including Android, Linux, RTOSes and Windows. AMD is a founding member of GizmoSphere, a not-for-profit organization whose collective goal is to drive and
enable technology projects of interest to independent developers, with a focus on stimulating and encouraging innovation around multicore heterogeneous computing using APUs.
The Gizmo board includes the G-T40E dual-core processor running at 1.0 GHz, combined on a single die with AMD Radeon HD 6250 discrete-class graphics.
The board provides a performance capacity of 52 gigaFLOPS (GFLOPS) at less than 10 watts. Custom high- and low-speed edge connectors enable a full range
of functions. This unprecedented level of integration between serial and parallel processing offers a power-efficient foundation for high-performance multimedia
content delivery across a broad range of embedded designs such as digital signage, x86 set-top box (xSTB), IP-TV, thin client, information kiosk, point-of-sale,
casino gaming, media servers and industrial control systems |
728 |
Chidori
26.01.2013 11:20:02
| nad võiksid vorpida mingi aparaadi kus HD7k või HD8k int video - see oleks püss.
99 |
Sven
05.02.2013 01:42:26
| Sain oma FM2 setupi jupid kokku, kuid ei hakka tööle. Pilti ei võta ette. Kahtlustan e-bayst tellitud ASrocki FM2A75M-ITX plaati.
| Kommentaarid: 35 loe/lisa |
kaspar00
05.02.2013 11:30:51
| Sven kirjutas: |
| Sain oma FM2 setupi jupid kokku, kuid ei hakka tööle. Pilti ei võta ette. Kahtlustan e-bayst tellitud ASrocki FM2A75M-ITX plaati. |
ega eraldi videokaarti pole? siis pidi biosis enne midagi tuunima, et tööle hakkaks
102 |
Sven
05.02.2013 14:17:36
| Sven kirjutas: |
ega eraldi videokaarti pole? siis pidi biosis enne midagi tuunima, et tööle hakkaks |
Peab proovima, loodan, et emaplaat defektne pole.
dmWM
Sven
05.02.2013 21:54:48
| Sven kirjutas: |
Nüüd sai proovitud erinevate variantidega, aga kahjuks ei tööta mitte mingi nurga alt.
kaspar00
102 |
Sven
06.02.2013 10:09:04
Kas kellelgi on FM2 prose + emaplaati ja viitsimist aidata? Tahaks teada kas mu prose/mobo töötavad, hetkel ei saa pilti ette.
E: Tänan kaspar00 -it, aga ootan pakkumisi Tallinnast ja selle ümbrusest.
Optimist
11.02.2013 09:32:21
| dmWM kirjutas: |
AMD A10 6800K gpu HD 8670D. ...
Level 3 cache on ikka puuda. |
Kõikidel APUdel on L3 puudu, selle asemel on ju GPU. L3 kasu tuleb kõige paremini välja paljude tuumade korral aga APU'd pole veel sinnamaale jõudnud.
| Kommentaarid: 10 loe/lisa |
One
20.02.2013 16:31:56
link :: AMD "Jaguar" Micro-architecture Takes the Fight to Atom with AVX, SSE4, Quad-Core
AMD hedged its low-power CPU bets on the "Bobcat" micro-architecture for the past two years now. Intel's Atom line of low-power
chips caught up in power-efficiency, CPU performance, to an extant iGPU performance, and recent models even feature out-of-order execution.
AMD unveiled its next-generation "Jaguar" low-power CPU micro-architecture for APUs in the 5W - 25W TDP range, targeting everything from
tablets to entry-level notebooks, and nettops.
At its presentation at the 60th ISSC 2013 conference, AMD detailed "Jaguar," revealing a few killer features that could restore the company's
competitiveness in the low-power CPU segment. To begin with, APUs with CPU cores based on this micro-architecture will be built on TSMC's
28-nanometer HKMG process. Jaguar allows for up to four x86-64 cores. The four cores, unlike Bulldozer modules, are completely independent,
and only share a 2 MB L2 cache. |
728 |
wa666ou
06.03.2013 10:13:26
Ehk on siin juba arutatud, aga selline mure.
Sai selline kast tuttavale tehtud valmis:
* korpus: Aerocool QS-200 Lite
* toitekas: Corsair CX430
* prose: AMD A10 X4 5800K
* emaplaat: Asus F2AA55-M
Kuidas see nii on, et olles BIOSis tõuseb temp suht julmalt mingi 60 kraadile...
Panin küll teise pasta vahele - MX-2 vms.
Ja tempid lähevad 75+ kraadi Winis, kui prose 4,3 GHz (turbo) peal töötab Ongi normaalne?
Ja selles turbo mode's vist näitas CPU-z voldiks mingi 2V vms ka. Tundub, veits karm anda nii palju volti juurde, tõstes takti vaid 500 MHz.
95 |
kaspar00
06.03.2013 10:16:33
stock cooleri tempe ei mäleta aga kindlasti olid nad väiksemad, praegu mingi tagasihoidliku aftermarketiga on idle mingi 30ga ja load jääb ilmselt 50ga millegi kanti. cpu-z volti näitab mul ka vahepeal 1.9V midagi, see vist on bug
102 |
wa666ou
06.03.2013 10:18:32
No kui on nö säästuprogramm, siis oli idle alla 40 kindlasti, sest prose tiksub 1,5GHz peal.
Aga turbos läheb lolliks igatahes.
95 |
kaspar00
06.03.2013 10:21:12
ma selle turbo kohta ei tea sest ma vist def kellal pole prose kasutandki ja klokitult see turbo sees pole küll aga lasin ma selle originaal cooleriga 4,7GHz peal asja vahepeal... päris koledat häält tegi aga üle ei kuumenend keegi siin kirjutas et tal oli 5600k kus oli prose heatsinkiga mingi probleem ja vist lasi lausa välja vahetada, äkki sul ka mingi teema? kui see on kindel et termopastaga probleeme pole.
102 |
One
07.03.2013 07:24:22
| Mobol ikka uusim bios peal?
728 |
wa666ou
07.03.2013 09:28:30
Sai pandud Cooler Master HYPER 212 EVO jahutus peale ja kõik korras.
Nüüd ei lähe temp enam fullis üle 50-55C. Ja idle 35-40 C.
Biosi pole uuendanud.
95 |
Optimist
Sven
07.03.2013 17:01:05
| 7870 on juba päris püss arvestades, et see hakkab otse raualt jooksma...
Chidori
08.03.2013 00:29:43
| wa666ou kirjutas: |
| Kuidas see nii on, et olles BIOSis tõuseb temp suht julmalt mingi 60 kraadile... |
See on aegade algusest ja kõikide platvormidega nii olnud. Kõik energiasäästu režiimid lähevad maha biossis oleku ajal, ehk prose jookseb maksimaalse pinge ja taktiga.
99 |
One
728 |
Optimist
