praegune kellaaeg 20.11.2026 17:17:03
13.01.2013 02:16:07
Crucial ja Micron toovad turule M500 seeria SSD-d, mahuga kuni 960GB |
link :: Storagereview
Crucial toob koostöös Microniga turule uue M500 seeria SSD-d, mahuga 120GB, 240GB, 480GB ja 960GB. Varustatud on need Marvell 9187 SSD kontrolleriga ja Micron püsivaraga, mis võimaldab kuni 80,000 IOPS, lugemiskiirusega kuni 500MB/s ja kirjutamiskiirusega kuni 400MB/s, 480GB ja 960GB SSD seadmetel.
Jaemüüki tuleb M500 Crucial nime all ja OEM tootjatele Micron nime all. 960GB mahuga SSD eest küsitakse 600 dollarit.
Micron’s new 80mm x 22mm form factor, called M.2, along its support for the mSATA form factor, underscore the company’s commitment to the ultrathin market. The M500 incorporates device sleep (DEVSLP), drawing an average of 150mW during active use and 5mW during sleep. Micron says that the time to ready for the M500 will be five times faster than its previous generations, down to 0.2s.
The M500 SSD features a 6Gb/s SATA controller with Micron firmware that delivers up to 80,000 IOPS, with sequential read and write speeds up to 500 MB/s and 400 MB/s for 480GB and 960GB drives, respectively with a Marvell 9187 SSD controller. The M500 SSD also incorporates TCG Opal 2.0 + IEEE 1667, 256-bit AES encryption hardware encryption to maintain data security in the event of theft or loss as well as an adaptive thermal monitoring system to adjust power consumption and thermal load based on usage.
Availability
Crucial M500 SSDs will be available in 120GB, 240GB, 480GB and 960GB capacities in the first quarter of 2013. M.2 and mSATA form factors will be available in 120GB, 240GB and 480GB capacities in the second quarter. Micron M500 SSDs will be made available directly to OEMs and through Micron’s distribution network. |
7 :: |
364 |
WAV
13.01.2013 02:26:58
| $600 hind ca 1TB SSD eest on ju tegelikult juba päris mõistlikku suurusjärku jõudmas. Isegi mõneti üllatav. Kõigest 6x kallim samasuure 2,5" HDD'ga võrreldes. Andmete säilivuse huvides tuleb muidugi backup 1TB HDD ikka ka lisaks osta, ehk siis kokku $700. Sarnane koos backupiga ainult HDD'dega variant maksaks kokku $200, seega nüüd tuleb hinnavahe kõigest 3,5 korda ainult! Täiesti mõeldav...
| Kommentaarid: 7 loe/lisa |
SurfData
| Kommentaarid: 84 loe/lisa |
74 |
dud66
17.01.2013 14:23:57
| Hinnavaatlus.ee põhjal saab Eestist "terabaidise" SATA 2.5 SSD ketta ka ümmarguselt 2760 euroga. Olgu see teile siis alternatiivne säästuvariant. |
Vägagi tervitatav nähtus, et meedia HV-d kasutab
_________________ Kommenteerige kasutajaid, siis teavad teised ka mida oodata! |
| Kommentaarid: 55 loe/lisa |
52 |
