uus teema   vasta Uudised »  Riistvara »  Kingston toob turule 1TB mahuga USB 3.0 mälupulga märgi kõik teemad loetuks
sõnum 13.01.2013 03:33:48 Kingston toob turule 1TB mahuga USB 3.0 mälupulga vasta tsitaadiga
link :: ocworkbench
Kingston teatas CES 2013 infotehnoloogiamessil DataTraveler HyperX Predator 3.0 512GB ja 1TB mahuga USB 3.0 mälupulkadest, millest viimane on väidetavalt maailma suurima mahuga. Andmete lugemiskiiruseks lubatakse 240MB/s ja kirjutamiskiiruseks kuni 160MB/s. Uued mälupulgad ühilduvad ka vanema USB 2.0 standardiga.
Loe ka pressiteadet: http://www.kingston.com/us/company/press/article/6487
2013 Flash Press Release
Kingston Digital Ships Its Fastest, World’s Largest-Capacity USB 3.0 Flash Drive
DataTraveler HyperX Predator 3.0 will be Available Up to 1TB
Data Transfer Speeds up to 240MB/s Read, 160MB/s Write
Certified SuperSpeed USB 3.0
2013 International CES Las Vegas, NV and Fountain Valley, CA -- January 7, 2013 -- Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., the independent world leader in memory products, today announced the DataTraveler® HyperX® Predator 3.0 USB Flash drive. DataTraveler HyperX Predator 3.0 is the world's largest-capacity USB 3.0 Flash drive as it will be available in a 1TB capacity later in Q1. It is shipping now in 512GB capacity. DT HyperX Predator 3.0 is the fastest USB 3.0 Flash drive in the Kingston® family, with speeds of up to 240MB/s read and 160MB/s write. It has also achieved SuperSpeed USB 3.0 certification.
"Our new DataTraveler HyperX Predator 3.0 allows users to store their entire digital world on a portable USB 3.0 Flash drive," said Andrew Ewing, Flash memory business manager, Kingston. "The large capacity and fast USB 3.0 transfer speeds allow users to save time as they can access, edit and transfer applications or files such as HD movies directly from the drive without any performance lag."
DataTraveler HyperX Predator 3.0 is compliant with next-generation USB 3.0 specifications and is optimized for newer PCs with USB 3.0 ports. Users who work with large video or graphics files, or gamers who like to travel with their entire library will appreciate the drive's speed and capacity. The casing is made of zinc alloy metal for superior quality, shock resistance and high-end design. DataTraveler HyperX Predator 3.0 ships with a custom Kingston key ring and a HyperX valet keychain. It is also backwards compatible with USB 2.0 for efficient data transfer rates.
DataTraveler HyperX Predator 3.0 USB Flash drive is part of the HyperX Predator family, which represents the highest-performance products offered from Kingston HyperX. The drive is backed by a five-year warranty, free technical support and legendary Kingston reliability.
For more information visit www.kingston.com.
Kingston is celebrating 25 years in the memory industry. The company was founded on October 17, 1987, and has grown to become the largest third-party memory manufacturer in the world. Watch the 25th anniversary video and see more information including a timeline of Kingston's history. In addition, HyperX memory is celebrating its 10th anniversary. The first HyperX high-performance memory module was released in November 2002.
HV-s ID-kaardiga autentimine
Kommentaarid: 464 loe/lisa Kasutajad arvavad:  :: 5 :: 7 :: 361
WAV
sõnum 13.01.2013 03:52:25 vasta tsitaadiga
Vaadates seda pilti nüüd... Huvitav kas maksimaalse mahu tagaajamisel pole tänapäeval enam oluline kui paks see mälupulk ka olema saab? icon_wink.gif
Nii võin ju võtta misiganes USB ühendust omava storage kasti (kasvõi SSD'de baasil) ja selle mälupulgaks nimetada (noh, viisakuse mõttes siis pistiku vahetult kasti külge pannes, mitte juhtmega, siis on ju mälupulga moodi ikka, eksole?)
viimati muutis WAV 13.01.2013 03:53:39, muudetud 1 kord
sõnum 13.01.2013 03:53:18 vasta tsitaadiga
WAV, samas on ta ikkagi kompaktsem võrreldes mille iganes muuga.
WAV
sõnum 13.01.2013 03:58:04 vasta tsitaadiga
Mina kehtestaksin ikkagi mälupulkadele maksimaalsed gabariidid. Muidu kaob asja mõte ära. Juba see jurakas siin ei pruugi mitte iga õhukese seadme külge sobida enam, rääkimata naaber-USB-pesa kasutamiskõlblikuks jäämisest seejuures...
Või siis teine variant, pangu mälupulga pistik näiteks 10cm juhtmejupi otsa. Selles karbis, ehee, tundub, et ongi üks jupike selle jaoks kaasa pandud!
sõnum 13.01.2013 03:58:28 vasta tsitaadiga
Seda küll, eks see entusiastist ostja teab mida ta ostab. Tädi Maalile see ilmselgelt mõeldud pole.
Esimesed suure mahuga serveri kõvakettad olid ka ju "ohhoo mis mõõtmetega"... icon_biggrin.gif
WAV
sõnum 13.01.2013 05:06:33 vasta tsitaadiga
Põhimõtteliselt, seda pildilolevat jurakat kõigest 2 korda veel jämedamaks tehes oleksid nad saanud lihtsa vaevaga ka hetke suurima mahuga HDD maailmarekordi nagu naksti üle lüüa... Ehk siis tegelikult mälupulkade mahu võidujooksus polegi praktiliselt mingeid takistusi ees.
Pigem peaks hakkama võrdlema ja rekorditena arvestama neil toodetel hoopis erimahutavust (GB/cm3).
sõnum 13.01.2013 05:13:10 vasta tsitaadiga
aga väga hea ju kui on valikuvabadust - keegi ei käsi sul ju seda osta kui see on sinu arvates liiga paks icon_smile.gif
Kellele tütar, kellele ema. Aga lihtsalt kritiseerida seda, et selline asi üldse valmis tehtud, pole ka nagu mõtet.
ranel
sõnum 13.01.2013 05:38:25 vasta tsitaadiga
Mulle see meeldiks. icon_biggrin.gif Op sys ja tähtsad asjad ssd peal ning oma muusikat, pilte ja filme saaks mälupulgal hoida. Väiksem ikka, kui praegu kasutatav väline kõvaketas.
WAV
sõnum 13.01.2013 08:11:07 vasta tsitaadiga
Tanel kirjutas:
Asi pole selles, et kas osta või mitte, kas tehtud või mitte (loomulikult võib neid teha), asi on selles, et promotakse rekordeid, mis on mõttetud, jättes nende hõiskavate uudistega tarbijatele petliku mulje nagu oleks hakkama saadud suure saavutusega see 1TB tehniline piir mälupulgaga kätte saada nüüd. Praktiliselt tehnilist piiri ju polnud ees, kuna mälupulga mõõtmed on niiöelda kummist. Erinevalt näiteks HDD'dest (ja enamusest SSD'dest), kus korpuse mõõdud on raudpolt paigas nagu aamen kirikus (v.a. mõned üksikud samuti ebaausad näited 2,5" ketaste standardist paksemaks tegemisest) ja sinna ruumalasse sisse toppida suudetav salvestuspinna(platterite) või flashmälu maht on tõepoolest tehniline saavutus.
Waldof
sõnum 13.01.2013 11:28:41 vasta tsitaadiga
Natuke suur on, aga ostaks ikkagi.
Kuna see mälupulk on 1 tb kohta ikka väga väike. Ning inimestele kes ütlevad, et see pulk võtab kahe usb augu eest ruumi ära, siis kasutage usb pikendust ( on tülikam küll, et pead juhet kaasas kandma, aga kui sul need augud nii tähtsad siis kuskilt tuleb kompromiss leida.)
sõnum 13.01.2013 11:31:19 vasta tsitaadiga
USB pikendus on ju komplektis kaasas. Kas te üldse esimest posti ei jälgi?
siinus
siinus
sõnum 13.01.2013 11:32:03 vasta tsitaadiga
Nii enamvähem alternatiiviks olekski väline ketas, mis niikuinii on eraldi juhtmega ühendatav.
Mina vingumiseks põhjust ei leia.
suck less | no slop grenade
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
sõnum 13.01.2013 12:47:38 vasta tsitaadiga
Mul näiteks läpaka USB 3.0 pesa asukoht ongi just selline, et see läheks tõenäoliselt ilma juhtmeta kenasti külge.
Teiste läpakate/arvutite kohta ei oska kommenteerida, kuid paljudel on USB pesa tasapinnas korpusega, seega väga palju probleeme ei tohiks esineda.
Samas ostavad selliseid tooteid just entusiastid (early adopters), kellel on palju raha või teavad täpselt, mida ostavad.
sõnum 13.01.2013 13:02:00 vasta tsitaadiga
Tanel kirjutas:
Selline raske, suure gabariidiga USB-pulk võib Sul läppari USB-pesa puruks väänata või siis skeemist lahti väänata. Nii, et ikkagi vahe-üleminek ja siis on läppari elu ohutu. beer_yum.gif
siinus
siinus
sõnum 13.01.2013 13:14:04 vasta tsitaadiga
Ega see alumiiniumist ja tsingist karbike nüüd nii raske ka pole, et usb pesa kohe puruks läheb.
Sinul see muidugi õnnestuks päris lihtsalt.
sõnum 13.01.2013 13:14:28 vasta tsitaadiga
tahanteada, no nii nõrk see pesa ka pole ja USB pulk nii palju ka ei kaalu icon_idea.gif
Ho Ho
Ho Ho
sõnum 13.01.2013 13:14:51 vasta tsitaadiga
Poole terase pulga hind väidetavalt 1750 taala: http://www.technobaboy.com/2013/01/09/kingstons-datatraveler-hyperx-predator-30-1tb-flash-drive/
Kaalu koha pealt ma ei usu, et see üüratuma raske oleks. Kujutan ette, et mu kunagi SC2 CE pakis istunud kobakas paksu metallkorpusega pulk just oluliselt kergem polnud ning senini pole see ühtki asja puruks väänanud.
alliance
The Transporter
alliance
sõnum 13.01.2013 13:24:54 vasta tsitaadiga
Kardan et selle asja hind saab röögatu olema.
Kommentaarid: 531 loe/lisa Kasutajad arvavad:  :: 0 :: 5 :: 431
lopes39
lopes39
sõnum 13.01.2013 13:36:26 vasta tsitaadiga
Ho Ho kirjutas:
lugesin seda 1TB uudist kuskilt gizmodo vms ja seal oli et 1TB maksab 1750 usd
aga ega see suurus nii suureks ka jää kui vaadata et 16GB pulgad on juba mini usb-d ja kui on olemas micro sd kaardid mis on 64GB ja suuremad siis küll need TB suurused ka kahanevad välimusest
kui usb 4.0 millalgi tulevikkus välja tuleb küll siis need 1TB pulgad ka juba tavaline nähtus ja ei maksa enam sellist ulmelist hinda ka kui praegu
sõnum 13.01.2013 13:46:28 vasta tsitaadiga
Ho Ho kirjutas:
Vaata, lihtne värk - on olemas kaks USB-pesade kinnitusversiooni:
1. kindlam, tugevam, kus pesaühendused on "läbi trükkplaadi".
2. ja kehvem, lahjem versioon, kus klemmid on joodetud trükkplaadi pinnale.
Ja vot, kui on pinnale joodetud pesad, siis piisab tihti väga väiksest lisaraskusest või väändest, et need klemmid lahti väänduks.
Ei räägi asjata, olen juba praegugi remontinud läpparite emaplaate, kus isegi praeguste USB-pulkadega on suudetud pesad lahti väänata.
PS: Ja paistab, et vähemalt Tablettidega on juba targemaks saadud:
mini-USB pesa + üleminek tavalisele USB-le, vältimaks USB-seadmete otsest külgeühendamist.
siinus
siinus
sõnum 13.01.2013 14:08:29 vasta tsitaadiga
tahanteada kirjutas:
ok
jyrisa
sõnum 13.01.2013 14:20:38 vasta tsitaadiga
Ho Ho kirjutas:
Ma ei taha ette kujutadagi kuidas sul linade vahel see asi käib. Seal ka koguaeg seletad teisele poolele, et "Oota, nii ei saa, võib ära murduda!".
siinus
siinus
sõnum 13.01.2013 14:26:41 vasta tsitaadiga
jyrisa, oled asjast õigesti aru saanud.
radok
sõnum 13.01.2013 21:36:52 vasta tsitaadiga
WAV
sõnum 13.01.2013 21:50:10 vasta tsitaadiga
lopes39 kirjutas:
Jaa, 64GB micro-SD kaartidest saaks tegelikult kokku panna sellest teemas jutuksolevast jurakast veel oluliselt pisema ruumalaga 1TB mälupulga! 16 tk neid micro-SD kaarte üksteise peale asetatuna annab klotsi mõõtmetega 15 x 11 x 16 mm
Muidugi nii kiiret asja sedasi kokku ei saa (micro-SD ei kasuta kõige kiiremaid mälukiipe ja nende RAID'imist ning kokkuprotsessimist), kuid mahu osas saab asja küll. Ning tunduvalt odavama ka.
Omapärane lahendus oleks ka selline mälupulk, kus on näiteks tihedalt koos 16 micro-SD pesa (pluss üks ühine kontroller) ja kasutaja saab siis selle mälupulga ise justnagu legona moodulitest kokku panna. Kui seal saab siis veel faile salvestada erinevate moodulite järgi, siis kokkuvõtteks saaks kasvõi igaks tööks parajasti vajaliku infoga pulga kokku monteerida, suurema micro-SD kaartide arhiivi baasil icon_wink.gif
DVDRW
DVDRW
sõnum 14.01.2013 09:35:04 vasta tsitaadiga
Sama mõte! 64GB microSD GB hind on praegu 3x kallim 32GB omast. Seega praegu laoks 16x32GB = 500GB. Hind oleks 18x16= 288€.
Praegu pulga GB hind on 0,392€.
Seega selle 1TB pulga mõistlik hind oleks ~400€
sõnum 14.01.2013 14:46:22 vasta tsitaadiga
sõnum 14.01.2013 15:21:15 vasta tsitaadiga
DVDRW, ja selliseid pulki laod 64-tk kokku, lisades mingi kivi, mis seda kõike majandada oskab?
reaalsemate 32gb või 64gb pulkade hinnatase on juba suts suurem.
rääkimata siis sellest, et neis usbipulkades on nii kiiruse kui vastupidavuse osas (vähemalt) klass nõrgemad mälukivid.
- londiste
Karmalaks
Karmalaks
sõnum 17.01.2013 20:39:35 vasta tsitaadiga
Selle üle, et kui selle USB puga väidetav hind tuleb kuskil 1750$ kanti, siis selle üle ei tasu eriti imestada, kuna keegi peab selle toote algse arenduse/tootmise ka kinni maksma. Kui konkurents tiheneb langeb toote hind märgatavalt ja algab GB ralli, mis kunagi toimus HDD valdkonnas, siis SSD (ka hetkel) ja nüüd, siis USB vallas.
Igasugust: http://www.youtube.com/user/RunningOtacon?feature=mhee
