Heroes & Generals is an online war game with multiple game modes accessible from multiple platforms. Play the game as the hero on the battlefield, the officer making the tactical decisions to win the battle, the general command devising the grand strategy and everything in between.
viimati muutis Rallih007 26.04.2012 19:51:23, muudetud 1 kord
Mõtlesin et tõmban vajalikud asjad ära, aga ei lase sisse logida browseris, ilmselt peab play sessionit ootama. Loodetavasti ka väga suur mäng pole, sest play session kestab ainult 2 tundi ja aeglane nett.
A handful of players have reported, that running Microsoft’s Disk Cleanup tool, after installing Heroes & Generals, corrupted their Windows installation.
We have managed to reproduce the problem and can confirm that it is a bug in Microsoft’s Disk Cleanup tool, which is triggered if the full path of a file becomes longer than about 260 characters. As a result Disk Cleanup starts deleting things it should leave alone.
So this is actually an issue with Microsoft’s tool, but we are working on making a workaround for Heroes & Generals instead of waiting for them to fix it.
Our recommendation is simply to not run Disk Cleanup until we have made a workaround and patched it into the game. So if you don't have the need to run Disk Cleanup, then you can just wait for our workaround patch, which will be installed automatically when you log in when we have deployed our upcoming build 'Bradley'. The 'Bradley' build will most likely be ready and up next week (maybe even this week).
But if you wish to run Disk Cleanup before we deploy the patch, you should locate and delete the '%temp%\HNG' folder first.
You can locate the %temp% folder and delete the HNG folder like this:
Click on the "Start" button in Windows
Write '%temp%' in the Search field and press enter
This opens a window showing the content of the %temp% folder.
Find and delete the folder called 'HNG'
If you log in on game.heroesandgenerals.com, after deleting the 'HNG' folder, then the files will automatically be re-installed.
We're terribly sorry about any inconvenience this may have caused and hope that we with this mail are able to save you some trouble!
Mängisin paar tundi, päris huvitav.
Meenutab Call of duty kõige esimest ja natuke Day of Defeat (mitte source). Üllatavalt hästi läbi mõeldud liikumine, laskmine, reload. Lähivõitluses aga kuidagi konarlik.
Ei saanud aru mida on vaja strateegia osast osavõtmiseks
Ning kuidas teha mitte-infantry mees? Tahaks tanki või lennukisse. _________________ You win again, gravity!
C-4 can make a dull day fun
there are very few problems that can't be remedied with the proper application of explosives
Hmm!! Jah peaks ütlema, et WW2 mängudest on Heroes And Generals kõige huvitavam ja hetkel läks ta mu lemmikute nimekirjas esimeseks.
Kuna tegemist on taktikalise online mänguga siis tugev skoor igaljuhul.Mis on kummaline,et ma avastasin selle mängu alles nüüd 06.03.2013.
kasutaja on eero78.
The long awaited Oster build is being released as we speak. As per usual, the build contains many new features, changes and bugfixes!
Have you always wanted a Mechanized Recon Assault Team? Grab your chance now! The M8 Greyhound and Sdkf 222 are now available in the Mechanized Recon squad. Use your vehicle to spot enemy tanks and take care of some infantry as well with the powerful guns.
But that's not all, notice anything new about the screenshot above? That's right, the Airfield map now has a refurbished living quarters! Don't fall a sleep on the beds though.
Generals are now also able to equip their motorized infantry with health packs. So instead of having to look for a supply / health kit you can also run to your jeep.
Here's some other special features which will be available to you:
Always wanted to know how your feet look like? You can now see them.
Tired of getting shot from just a helmet? You now shoot from your gun instead of the head.
Added well over 100 new towns on the Campaign map.
Dislike so much fog? The amount of fog battles has been reduced to 10%!
Play around with 3 brand new weapons! Panzerschreck, BAR and the MG34 (handheld)
Adjusted weapon modifications
Proovisin ka mängu. Kas kõigile nii, et kui tahad kaardilt mingi mapi valida, siis tuleb tekst wrong tier? Ühesõnaga ühte mapi põhim saan ainult koguaeg mängida, sealt kust on enter combat.
