Superglue
19.01.2004 09:18:57
Esimesed Intel Socket 775 pildid |
link :: Socket 775
Äkki keegi pole veel näinud
| Kommentaarid: 62 loe/lisa |
58 |
XeStAiSy
Aeg Maha 2a
19.01.2004 10:20:21
polegi n6inud imestama paneb see punasega
Apparently a total of 10 Tejas samples have been shipped out to various friends of Intel, all running at 2.8GHz. What's also interesting to note is that our sources have informed us that at 2.8GHz Tejas uses around 150W of power - about 50% more than Prescott at the same clock speed.
milline katlamaja siis
| Kommentaarid: 12 loe/lisa |
lamp
19.01.2004 14:45:26
one possible explanation would be that Tejas is indeed some variation of a multicore CPU
| Margus kirjutas: |
milline katlamaja siis  |
| Kommentaarid: 191 loe/lisa |
168 |
XeStAiSy
Aeg Maha 2a
19.01.2004 18:51:10
what the hell 150W multicore CPU @ = katlamaja
p6ris fun on seda 150w'ist proset jahutada eriti kui see full loadis on ilmselt on sinna sisse ehitatud midagi MP sarnast
Superglue
19.01.2004 18:52:39
| Peab vist uue veepumba ostma. 1200L/h. See ju puhta kuum asi.
58 |
XeStAiSy
Aeg Maha 2a
19.01.2004 19:07:33
| Superglue kirjutas: |
| Peab vist uue veepumba ostma. 1200L/h. See ju puhta kuum asi. |
ilmselt veekogusest j66b ka v6heseks midagi triplex radika s6steemi sarnast peaks olema
HDD
20.01.2004 09:46:52
Noo ei usus ,et see asi nüüd nii hull on ...
Asi peaks ikka inteli stock jahutusega töötama. Ei usus ,et intel uute prosedega vee ka kaasa annab
_________________ The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it  |
57 |
lamp
20.01.2004 14:18:44
Nojah aga fantaseerida ja samal ajal tyhja mula foorumitesse sodida on ka ju tore
aga muidu nagu räägivad laias internetis, pidid anandtechis siiski olema prescotti, mitte tejase screenid.
| HDD kirjutas: |
Asi peaks ikka inteli stock jahutusega töötama. Ei usus ,et intel uute prosedega vee ka kaasa annab  |
168 |
