Hmph, ei saagi sooloda seekord. Igatahes üritan nädalavahetusel saadaval olla kui peaks tekkima idee miski HV punt jälle kokku ajada kasvõi ainult squad goal jaoks. 2-4 krogan või turian või vorcha või quarian jne. 4 kroganit oleks suht loogiline valik . 4 arc grenaderit oleks kah muidugi huvitav. _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Balansimuudatused September 25, 2012
Battlefield 3 soldier kit now available as a new Rare card
Typhoon Assault Rifle
- Recoil no longer gets worse as the weapon levels up.
Striker Assault Rifle
- Max spare ammo increased from [48-60] to [60-72]
Eagle Pistol
- Damage increased from [74.9-93.7] to [86.1-107.7]
- Encumbrance decreased from [0.6-0.25] to [0.45-0.25]
Paladin Pistol
- Encumbrance decreased from [1.25-0.7] to [1.0-0.7]
Talon Pistol
- Encumbrance decreased from [1.1-0.6] to [0.9-0.6]
Carnifex Pistol
- Encumbrance increased from [1.0-0.5] to [1.2-0.7]
Piranha Shotgun
- Clip size decreased from 8 to 6
Frag Grenade Power
- Base damage increased from 750 to 900
- Evolution 4 bleed duration reduced from 10 to 5 seconds. The total damage applied remains the same.
Lift Grenade Power
- Evolution 3 increase to max grenades increased from 1 to 2
Sticky Grenade Power
- Base damage increased from 900 to 1100
Cluster Grenade Power
Inferno Grenade Power
- Base damage increased from 125 to 150 per second
- Evolution 6 impact radius bonus increased from 40% to 50%
Kaun, Oled sa proovinud Piranhat peale nerfi? 6 lasku endise 8 asemel. Mina küll ei tunne et midagi väga teisiti oleks. Samas ma kasutan seda oma Paladinil. Paar-kolm lasku maas oigavate tegelaste pihta peale kilbiga äsamist ja reload edasi liikudes. Ainuke, mis muutus mingil määral on bosside maha võtmine. Seal tuleb tihedamalt reloadida. Aga jällegi - praktiliselt ei tunneta erinevust.
Ei ole veel aga kuna ma mängin enamasti kulda ja plaatinumi, siis kindlasti annab tunda boss vastate puhul. Teised vastased surid 3-4 lasuga ennem ja arvatavasti ei pane seal üldse tähele muudatust _________________ PC: Planetside 2, Warframe
xbox tag: Plat0nius
Tegin just platinumi. Tunda oli küll et tihedamini peab reloadima aga samas ei kannata mu Paladin liiga pikalt Platinumis pea peidust väljas olla nii ehk naa. Ühesõnaga ütleksin et vägagi mõistlik nerf.
EDIT2:
Balance changes October 2, 2012
AT-12 Raider Shotgun now available as a new Rare weapon
Gear Items
- Decreased bonuses from Densified Ammunition to max out at 10% instead of 12%
- For the following items, any bonuses that maxed out at 10% now max out at 12%
- Berserker Package
- Operative Package
- Commando Package
- Warfighter Package
- Expert Package
- Stronghold Package
- Guerrilla Upgrade
- Combatives Upgrade
- Shock Trooper Upgrade
- Juggernaut Shield
- Martial Biotic Amp
- Omni-Capacitors
Singularity Power
- Singularity duration decreased to 8 seconds in preparation for the re-design of the power in the upcoming patch
Shockwave Power
- Rank 3 force bonus increased from 20% to 25% (May 9 balance changes missed this)
Wraith Shotgun
- Damage increased from [102.3-127.8] to [117.6-147.0]
Crusader Shotgun
- Damage increased from [573.4-716.75] to [630.7-788.4]
Argus Assault Rifle
- Damage increased from [131.8-164.8] to [164.8-206.0]
Black Widow Sniper Rifle
- Damage increased from [514.1-642.6] to [591.2-739.0]
EDIT3: Operation OVERDRIVE (October 5th-7th)
Based on intel recovered during Operation PATRIOT, we are anticipating a massive strike from the Reapers on multiple fronts. Our information officers and special-ops teams stationed behind enemy lines require immediate extraction.
Squad Goal: Full extraction on any map at any difficulty in 20 minutes or less. Squads can be any size.
Allied Goal: Complete 200,000 extraction waves on any difficulty. Squads can be any size. Full extraction not required.
Special Circumstance: None
Squad Goal Success: All squad members awarded a Commendation Pack
Allied Goal Success: All players awarded a Victory Pack
Aga päris head muudatused ikka. Nüüd on mõtet ka extractida ja boss headshotid on tagasi toodud
Lisaks veel muud head-paremat. Pöidlad pihku, et mingeid uusi suuri buge ei teki.
raitl, Jep viisin ennast "ajalooga" kurssi . Vb siis Valkerye järgmine nädal . Vähemalt mp dev videotest on näha olnud seda juba ammu, seega see on neil olemas. 3 milli krediiti mul kah arvel seismas aga ootan patchi ära enne, kui kulutama hakkan. Kavatsen osta 50 SP pakki _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
Tomorrow, Raideri drop rate on haruldaselt madal. Argus tuli enamusel kohe jutti, kui muidu rared maxis olid. Raider kukub tublisti harvemini. Ise sain 3 SP ja 2 PSP-ga Raideri II peale. Argus tuli absoluutselt igast pakist, PSP'st kaks levelit korraga. Ühel sõbral, kellel manifest 100% maxitud ning peale 2.2mil kulutamist oli tal Raider IV
viimati muutis raitl 04.10.2012 09:54:37, muudetud 1 kord
Sai proovitud raiderit eile, täitsa mõnus. Samas jah, spread on tal suht karm, snaipima sellega ei hakka. Võibolla turian soldieriga siiski, peaks proovima _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Kas keegi kellel on peal uusim 1.04 patch nüüd tänase seisuga ja kellel on originaal ingliskeelne ME3 (võib ka Deluxe jms eriversioon olla) jagaks järgnevaid faile?
Kui pätš lõpuks laekub siis saab ehk kusagile üles riputatud, kui keegi ette ei jõua. Eeldatavasti siis kell 7-8-9> _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
> I see references to things called "Blood Pack Spike Thrower", "Blood Pack Melee", and "Blood Pack Harpoon"
> For you soloists out there, in the rewards section of the challenges rewards list, there is one called "solomastery".
Veidi jama, et neid uusi klasse nii arvukalt tuleb, sest Spectre pakkidest hakkab relvade ja muu kraami asemel arvukalt igasugu masti Voluseid kukkuma.
Ära sa märgi. Sain Raideri vähem kui 500k eest III peale ja siis alles kukkus Argus I.
Need UR gearid tundub, et kukuvad nüüd tihedamini. Ma mõtlen need mis ei tahtnud kuidagi tulla pärast Earth DLC-d.
21:20 seisuga on Retaliation saadaval Originis. Suurusega 421.39 MB. Üllatavalt väike. Edu mängimisel
EDIT:
Nii mõlemad uued turianid lahti ja üles leveldatud. Mõlemad uued relvad X peale leveldatud. Kõvasti uut geari lahti ja ka UR Voluse sain lahti
1.1 milli jäi veel kontole. Alustasin 3.75 milli pealt.
EDIT2:
Nii. Tükk aega siis mängitud. Muljed on positiivsed. Kõik uued tegelased meeldivad. Isegi Volus
Turinitel on väga lahe jetpackiga ringi kimada. Lisaks veel unlimited use. Ja power combod on kah just sellised mida ma olen tahtnud. Stasis ja cloack ühes ja overload ja cloack ühes. Võimas.
Vastased on ka võimsad. Cerberus Dragoon on tõsine nuhtlus - nagu hästi mobiilne pyro. Jubedus kuubis.
Reaperitel uut unitit pole ja nemad on nüüd kõige lihtsamad vist. Gethe ei proovinud. Collectorid on väga julmad ikka. Scionid külvavad terve ruumi granaatidega üle ja neid suuri putukaid tuleb kah korraga kolm tükki peale + putukaparved ja muu.
Mappidest sai proovida Reactor Hazard versiooni. Nii lahe oli tiimiliikmeid reaktoriruumi surema lukustada . Vastaseid kah muidugi, kuigi krdi banshee tuli sealt eluga ikka välja, kui uksed avanesid
Relvadest proovisin Collector Rifle. Lahja. Turian Havoc suri mul miskipärast väga tihti. Ghosti ja volusega seda probleemi polnud.
Niipalju siis esmamuljeid.
EDIT 3:
Nii. Tänahommikune osturalli siis kulges positiivselt. 1.3 milli kulutasin ja ostsin ainult SP pakke. Kukkusid järgmised UR-d: Collector SMG I - Indra III - Wraith III - Harrier III - Saber III - päris kena "saak" kõigest 1.3 milli eest imo .
Sain ka kõik uued weapon modid lahti. Commendation Packist vupsas välja Valiant V . Lukus on veel 1 Gear,1 Character ja 1 relv. Vastavalt siis Assault loadout,Volus Engineer ja Talon. Nii, et leveldamine edeneb kenasti. Ma arvan, et hakkan solo challengitest pihta, et saab ka banneri lahti
Ma võtsin retaliation alguses ette tavalised spectre pakid ja ei saanud sittagi (vist ainult 1 UR, saber, pfff). Peale mõndakümmet SP otsustasin PSP kasuks ja tulemus hoopis midagi muud, muuhulgas ka 2 talon upgrade ja 1 harrier ^^. Varem tundusid SPd nagu paremad olema UR lahtisaamiseks, guess not
edit:
Time played: 561H 8M 40S _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
peale viimast patchi on vist jah parandatud PSP pakkidest tulevat kraami, mul on SP pakkidest tulnud palju rohkem UR kui PSP pakkidest. Viimane kord kui ostsin neli SP pakki, sain 2 UR jälle :/ _________________ PC: Planetside 2, Warframe
xbox tag: Plat0nius
Vahetan mingi aeg see nädal manifesti lingid esimeses postis välja N7 HQ linkide vastu Origin kasutaja velvetyne eemaldasin.
EDIT 2: Ühtlasi teen ettepaneku eemaldada järgmised kasutajad, kuna neil on mängitud vähem kui 50 mängu:
jahipuuk (0?)
Retroh (14)
EstBearKilla (26)
LihaPudi (38)
KuufiEST (51)
Vb eemaldada ka need kellel pole HV kontot või kes pole teema vastu huvi tundnud?
Mitteaktiivseid pole vast mõtet eriti hoida jah, teine variant on lihtsalt kribada juurde, et mitteaktiivne.
Viimased balansimuutused jms kah, vist polnud veel välja toodud siin
October 9, 2012
Singularity Power
- Duration of singularity decreased from 25 to 8 seconds (October 2 balance changes missed this)
Cryo Explosion Power Combo
- Like Biotic Explosion or Tech Burst combos, this combo can now occur without killing the target.
- The target must still be fully frozen to be detonated.
- Damage increased from [50-125] to [75-200]
- Impact radius decreased from [3-5] meters to [2-4] meters
Fire Explosion Power Combo
- Impact radius decreased from [3-6] meters to [2-4] meters
- Damage decreased from [150-375] to [100-250]
- Damage-over-time damage decreased from [20-50] to [12.5-31.25]
Bug Fixes
- Fixed issue where you could get an unlimited number of the new character cards
- Fixed issue allowing players to see the unreleased Retaliation kits in the character selection screen
Also, here are some additional changes that were included with the Retaliation DLC or missed in our patch notes.
- Geth Pyros can now stomp players who are downed
- Marauders can now stomp players who are downed
- Atlas now moves faster
- Atlas rocket will add a small damage-over-time effect on players that prevents shield regeneration for a short time
- Geth Prime drone now attacks players
- New map layout for Firebase White and Firebase Glacier
- Wave changes to Geth faction to account for new Geth Bomber enemy
- Wave changes to Cerberus faction to account for the new Dragoon enemy
- Weapons in the lobby show their rarity as a border around the weapon
- Can now see the last pack you purchased in the store
- Consumables now show statistics in their descriptions
- Destroyer's missile launcher now shows "Hawk Missile Launcher" in the kill feed instead of "Missile Launcher"
- When 3 of 4 players are ready in the lobby, there is a 20 second countdown before the match automatically begins
- Promoting a character preservers name and appearance, and doesn't assign any talent points
- Carnage power can now set up Fire Explosion power combos
Igasugu tech plahvatusi on nüüd suht kerge esile manada ja engineeride mängimine muutus palju nauditavamaks. _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
ma saan ikka ainult UR relvi tavalistest specter packidest... ostsin täna jälle 2, sain 2 levelit black widowle. lahe aga tahaks oma kullast asjad ka lahti saada ennem _________________ PC: Planetside 2, Warframe
xbox tag: Plat0nius
Huvitav ikkagi mis n*ss see on, et osade inimestega ei ühenda ära ja osade inimestega ühendab . Eriti jabur (eile) oli see, et kui muidu ühe inimese lobbysse ei saa, siis samasse lobbysse läbi teise inimese sai . Kusjuures see polegi vast ainult meie banaanivabariigi probleem, ühe usa inimesega oli sarnane häda, teisega jälle mitte. Õnneks ühine sõber oli abiks, temaga saime mõlemad ühenduse.
Tuleb vist jälle mõttes Origin meeskonnale raske ilmega keskmist näidata. _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Nii vist sain oma ühenduse probleemidest jagu. Üsna kindel, et nüüd peaks kõik saama minu hostitud mängu liituda ja mina teiste mängu. Nimelt oli kriitiline viga tehtud portide suunamisel. Trigger Port väli tuli tühjaks jätta - vastasel korras näitas, et vajalik port on ikka kinni, kuigi kõik muu oli paigas.
Nii peaks Elioni inimestel asi välja nägema:
Täna õhtupoole testin. Ahjaa. Weekend Challenge tegin ära järgneva tegelasega:
Auhinnaks Hurricane III
LOL pilt kah lõppu :
EDIT:
Nii. Hakkab juba looma. Sai enamvähem vabalt kaas HV-lastega mängida. Mõned probleemid siiski veel olid. Mina kukkusin korra lobbyst välja ja teine inimene kaotas raha/xp mingi hetk ära. Paar korda oli ka juhuseid kus power/granaat ei registreerinud või läks vastastest läbi, aga viimane võib ka mängu bug/hetkeline lag olla. Veel paar pilti ruuteri confist:
Origini portide avamine pole siiski vajalik, aga ma tegin ka selle igaks juhuks ära.
Veidike veel ja saab juba inimesemoodi MP mängida
Täna (s.o pühapäeval) tahaks ka mikrit testida. Et kas teised tiimiliikmed kuulevad jne. Ma tavaliselt ei kasuta mikrit, aga see võib teatud olukordades vägagi kasuks tulla
Mul tuli mail origin supportist commendation pack kohta olgugi, et ma neile miskit ei kirjutanud, dafuq? Reede õhtul tegin ära ja laupäeva hommikul sain hurricane 6 <3 _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Naeruväärne. Ei saa ma Gold solo ära teha. Peaks nagu lihtne olema, aga ei õnnestu. Suren tavaliselt wave 8-9. Täna õnnestus teha wave 10 peale, aga minu õnnetuseks sattus wave 10 olema target elimination ja mul oli ainult 1 cobra alles. seega pidin üritama ülejäänud kolm killida the old fasion way. Varem oleks see lihtsam olnud, aga nüüd see neetud geth bomber komplitseerib asju. Muus osas Kroguard+Reegar+Responder gear ( +3 extra medigeeli )+disruptor ammo jms. Ei ürita rambotada just kah ja jätan prime-d viimaseks. Wave 2 läks esimene medigeel. wave 3 teine. wave 5 kolmas jne. Wave 10 alguses oli 3 alles, kui 9-ga alustasin. Poleks see lollakas target missioon viimaseks sattunud oleksin ära teinud. Aga nüüd tuli jälle cobradest puudu. Krt vihale ajas . Teed kõik omast arust õieti, aga ei saa seda gold solo tehtud _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
Ma tegin ühe gold soolo kroguardiga nii, et kasutusel incendiary ammo 4, shotgun amp 3, cyclonic modulator 4 ja umm... kas shield booster või shotgun amp gear. Kroguard spec peaks n7hqs näha olema. _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Mirage, Võibolla seal kala peitubki, kuna ma speccisin Barrierist välja. Mõni BSN tegelane küsiks selle peale: umad bro?
Aga jah tahtsin veidi rohkem long range powerit kah Carnage näol. Aga specin Carnage-st välja ja proovin uuesti
Kummalisel kombel on Cerberus minu jaoks lihtsam, kui Geth. Ma arvan, et vähem stunlocke ja vähem granaate. Muidugi turreteid tuleb vältida ja kaks sync kill unitit liiguvad kah ringi.
Missioonid olid pizza delivery,target elimination ja hack.
Origin läks kah lolliks minu solo õnnestumise peale ja kukkus offline umbes 20:40 meie aja järgi . Vahetult peale seda kui ära tegin selle.
Muidugi korra tuleb veel teha
Norm, hästi tehtud . Oleks wave 6 või 10 objective 1234 olnud oleks dragoonid korralikult läbi n*ssind nii läks minu turian ghostiga. _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Teine gold solo läks rohkem üle noatera, või ütleme üle phantomi mõõgatera . Viga oli kasutada Phasic rounde. Incendiary ikka parem, kuna lisab DoT effekti (damage over time) ja see on orgaaniliste vaenlaste healthile väga mõjuv.
Aga tehtud ma selle sain. Tegin ka enamus over-cover grabidest ära. Märksõnad cerberus-bronze-fb giant ja campida kontrollruumis teise laua taga, samas kui mehikesed vudivad esimese laua taha varju. Siis joosta ise sinna ja hea juhul 3x grab järjest . Siise jälle tagasi teise laua taha - rinse & repeat. Kuskil wave 6-ni tasub ära teha. Pärast seda meelega feilida, kuna kaovad ära tavalised vastased ja tekivad atlased,drawgoonid ja guardianid. _________________ Win11 upgrade skriptid neile kelle masin ise ei taha 23H2, 24H2 või 25H2 pealt ennast uuendada: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11720738#11720738
See over cover grab on paras huumor omaette, pidevalt näeb rahvast (ise kaasaarvatud) peale passimas ja varjus olevate vastaste juurde jooksmas _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
Nii sain oma medigeelid ja värgid jälle 255 peale. Vahel olid need täiesti nullis. Muide kes vihkab dragoone, siis õigesti specitud N7 Shadow suudab neid väga lihtsalt oneshottida goldi peal. Seda ka siis kui täis armor neil alles veel on.
Pilt:
- Some composition changes to Geth and Cerberus waves 9, 10, and Extraction on Bronze/Silver.
- Some Geth Hunter and Geth Prime nerfs across all difficulties.
- Some buffs to Drell and the original Turians.
- One of the more highly requested kits is being released...
Collectoritega tuleks tõesti midagi ette võtta. Eile mängides sai millegipärast korduvalt satutud kaardile kus sadas happevihma ja vastaseks olid collectorid. Uploadid toimusid siis siseruumis ja ajasid tõsise masenduse peale, sest iga paari sekundi pärast ujutati kogu ruum granaatidega üle või jooksis mingi sepp sisse ja plahvatas, lisaks pressis igast uksest aegajalt Praetorian sisse. See polnud enam põnev mäng vaid põrgu. Just nende plahvatavate tüüpide juures tuleks midagi reguleerida - plahvatus nõrgemaks, raadius väiksemaks vms.
Crusader on hea ront, aga sellele leveldamisest tulev kasu on minu arvates liiga marginaalne.
Gethidest vajaks nerfi minu arvates ainult bomber, mida peaks olema lihtsam puruks lasta. Ehk ainult kiire manööverdamine peaks olema selle kaitse, mitte lisaks veel soomus.
Dragoonidega sama teema - sellised kiiresti ringi kargavad tüübid ei tohiks olla soomustatud. See on üsna ebaloogiline ja teeb snaiprite ja kergete relvadega
tegelaste elu extractioni ajal kui kogu koht nendega üle ujutatakse liiga kurvaks. Lisaks kipuvad need veel kahe-kolme kaupa liikuma. Kui sellise jõuguga üksi vastamisi sattuda, siis pole mõne klassiga eriti mingit pääsu.
Lisaks olen tähele pannud, et peale viimast patchi kipuvad pahalased uppi kukkunud indiviide liiga agaralt tallama jooksma. Kedagi elustama enam eriti ei jõua, sest sageli saab juba 2-3 sekundiga kabelimatsu ära.
Crusader on läägi puududes täitsa norm, jep. Tiba läägi ja pff.
Collectorid on tiba rasked jah. Crusaderist rääkida siis sellega õnnestus wave 9 collector ära sooloda kui tiim kõrvad pea alla pani, ise arvasin et silver mäng oli alguses, tüübid hiljem mainisid et gold, mul karp lahti. Parema meelega seda ei kordaks. Rahvas võiks selle medigeli mittekasutamisest ükskord üle saada .
Rio on täiesti pekkis omadega, just sai lõpetatud üks mäng, collector gold jälle, (esimest korda sattusin thee3nd lobbysse, xcalizorz juutuubis kui keegi peaks tema gameplaysi jälgima) sai tehtud, aga peale mõne inimese crashi nagu ikka toimusid minuga igasugu veidrused . Nimelt ei teinud mu eviscerator absoluutselt dämmi, granaate loopides ei juhtunud peale animatsiooni midagi, veidral kombel kaasaolev acolyte toimis . Ammot sai üles korjata, küll aga ei teinud spacebar mitte kottigi üritades pizzat üles korjates või teisi resurrectida. Pole varem sellist pulli seal olnud, tavaliselt kah crash. Üritasin heavy meleega asja korda saada, teinekord on abi, kui relvaga tulistamine ei õnnestu või ammot ei saa korjata, tolku polnud. _________________ Terrorists have two eyes, pandas have two eyes. Coincidence? I think not!
October 24, 2012
Asari Valkyrie Sentinel kit now available as a new Rare card
New hazard maps available this week are Firebase Glacier and Firebase White
Krogan Shaman
- Now moves at the same speed as other Krogan when carrying objectives
- Added skin tone as a customization option
Turian Ghost and Havok
- Now move at the same speed as other Turians when carrying objectives
Reaper Husk
- Score rewards for kills and assists on Husks increased by 50%
Reaper Brute
- (Silver) Armor increased from 7500 to 9000
- (Gold) Armor increased from 9000 to 13500
- (Platinum) Armor increased from 11700 to 15210
Cerberus Wave Data
- (Bronze) Wave 9: Removed 1 Dragoon and added 1 Engineer
- (Silver) Wave 9: Removed 1 Dragoon and added 1 Centurion
- (Silver) Extraction: Removed 1 Dragoon and added 1 Centurion
Geth Wave Data
- (Bronze) Extraction: Removed 1 Hunter and added 1 Trooper
- (Silver) Wave 10: Removed 1 Prime and both Hunters and added 3 Troopers
- (Silver) Extraction: Removed 1 Prime and both Bombers and added 3 Rocket Troopers
Geth Prime
- (All Difficulties) Cooldown for spawning Turrets and Drones increased by 50%
Geth Hunter
- Delay between shotgun bursts increased from [0.9-1.5] to [1.2-1.8]
- Shotgun rate of fire decreased from 60 to 45
- The hit reaction chance multiplier is the chance for players to hit react the Hunter
- (Bronze) Hit reaction chance multiplier went from 80% to 90%
- (Silver) Hit reaction chance multiplier went from 65% to 75%
- (Gold) Hit reaction chance multiplier went from 50% to 60%
- (Platinum) Hit reaction chance multiplier went from 40% to 50%
- (Silver) Movement speed modifier while cloaked decreased from 90% to 80%
- (Gold) Movement speed modifier while cloaked decreased from 110% to 90%
- (Platinum) Movement speed modifier while cloaked decreased from 110% to 100%
Drell Assassin Passive Power (All Drell Kits)
- Rank 1 power damage bonus increased from 5% to 10%
- Evolution 1 weapon damage bonus increased from 7.5% to 10%
- Evolution 2 power damage bonus increased from 10% to 15%
- Evolution 3 power damage bonus increased from 15% to 20%
- Evolution 4 head shot damage bonus increased from 20% to 30%
- Evolution 6 weapon damage bonus increased from 10% to 12.5%
Turian Veteran Passive Power (Original 2 Turian Kits)
- Rank 1 weapon damage bonus increased from 7.5% to 10%
Devastator Mode Power
- Base magazine size bonus decreased from 25% to 15%
- Rank 2 magazine size bonus decreased from 10% to 5%
- Evolution 3 magazine size bonus decreased from 25% to 15%
- Evolution 4 rate of fire bonus decreased from 25% to 15%
Hawk Missile Launcher Power
- Base damage and force increased from 150 to 200
- Evolve 1 shield penalty reduction increased from 25% to 40%
Supply Pylon Power
- Base frequency for spawning ammo increased from 15 to 17.5 seconds
- Base frequency for spawning grenades increased from 20 to 24 seconds
- Evolution 3 weapon damage bonus decreased from 15% to 10%
- Evolution 4 power damage bonus decreased from 15% to 10%
- Damage increased from [75-200] to [100-250]
