uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 58, 59, 60 ... 239, 240, 241  järgmine
chesm6mmi
chesm6mmi
sõnum 11.08.2012 20:41:27 vasta tsitaadiga
tundub küll nagu jah, mul sisseminnes ütleb ka et server outdated...
Kommentaarid: 107 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 102
Kruvi
sõnum 11.08.2012 21:23:14 vasta tsitaadiga
DrZ kirjutas:
http://dayzmod.com/forum/index.php?/topic/65601-they-are-banning-you-for-updating-to-revision-95777/
Nagu aru sain siis ajutine viga vms.
Praegu kindlalt enam probleeme pole sellega.
Battleye lehelt
Global Bans in ArmA 2: Operation Arrowhead [ 10.08.2012 • 13:45 ]
We're aware of the global banning issue and are investigating since yesterday. Appropriate action will be taken if a false-positive scenario is found. If that is indeed the case we're terribly sorry for it and will take measures to prevent this from happening in the future.
An update will be posted once more is known.
Update: The issue has been investigated with the help of Ondrej Spanel (BIS lead programmer) and we found that there is a possibility of a race condition on BE's side during the game's disconnect process. It can essentially destroy the integrity of the environment that BE expects and trigger a certain detection. The problem has been fixed and all of bans of the past two days that could have been triggered by such a condition have been removed. There might still be cheaters among those, but that doesn't matter. What matters is that the innocent players should be unbanned now.
We're honestly deeply sorry for this and will do everything to ensure that something like this won't happen again.
Timberg
ööKARU
Timberg
sõnum 11.08.2012 21:57:18 vasta tsitaadiga
pots4t4j4 kirjutas:
[spoiler][img]
ItZ the end of dayZ...
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 11.08.2012 23:16:55 vasta tsitaadiga
endal ka probleeme ei ainta six up, comander egast ka manuaalselt .
Paistab et peab ootma jääma uut uuendusi. vast õnnestub uuesti mängima hakata ?
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
Velociraptor
Velociraptor
sõnum 12.08.2012 00:19:05 vasta tsitaadiga
Glitche(artifacte) ei suudetud ikka fixida(foorumis räägitakse), lisaks on mingi kala, et kui serverit vahetad(või lähed eemale ja tuled samasse servusse tagasi), siis spawnid rannikul.
viimati muutis Velociraptor 12.08.2012 00:37:03, muudetud 1 kord
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
chesm6mmi
chesm6mmi
sõnum 12.08.2012 00:25:13 vasta tsitaadiga
jap seda suvalist spawnimist olen täheldand juba teistes serverites... täiesti rändom kohtades nagu ala oleks varem surma saanud vms, samas kõik asjad on siiski alles..
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 12.08.2012 00:39:00 vasta tsitaadiga
Wth vaja kiirelt ära käia. et siis peab arvutile resa tegema et mitte sponida mere ääres ?
et siis hakkaktakse lihtsalt mereääres künkal passima icon_biggrin.gif ja kille tuleb nii mis kolin. see asi küll ei sobi, jätan parem üldse mängimatta.
naguuus
sõnum 12.08.2012 02:13:13 vasta tsitaadiga
roflrofl täna pelasin mingid DE servus natuke aega, sain omale manti Elektrost ja järsku läks sekundiga kottpimedaks ja igal pool tänava ning põldude peal hakkasid randomilt URALi truckid spawnima mis vilgutasid tulesid ja lasid signaali. Kogu pull kestis võibolla 2 minutit peale mida tekkis järsku mu selja taha ghillie suitiga vend ja lasi kuuli pähe, siis läks server offline. Peab tunnistama, et tõmbas väga jahedaks kui killer järsku selja taga oli ning peale seda panin mängu kinni ka icon_biggrin.gif
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 12.08.2012 02:28:49 vasta tsitaadiga
lasin arma ja ja oa maha tänu steamile. ei sa lihtsalt sellist debiilsust arvutis jooksutada! T*rä
parem juba piraadin mänge kui lasen arvutisse mingit spämmi ääreni täis ning mingid ajuvabade kasutus liidesega, mis ei kõlba karu piix ka.
Cracker
sõnum 12.08.2012 07:55:49 vasta tsitaadiga
Keegi ei käskinud steami versiooni osta :p
parm
sõnum 12.08.2012 10:05:18 vasta tsitaadiga
dohc-48v12 kirjutas:
Ja selleasemel et probleemist rääkida, pritsid lihtsalt täitematerjali foorumisse icon_biggrin.gif
Mul 4s masinas ARMA2:CO steami kaudu peal ning inimesed mängivad DayZ-i. Samamoodi ma ise ning Steami kaudu ostetud ning mingeid probleeme ei ole.
Ise hetkel kuskil Berezino kandis varustusega ning kui keegi sealkandis, võiks õhtul ringi mütata DE 231-s kui see ära uuendanud ennast on 1.7.2.5 peale icon_wink.gif
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 55
Fallout
Fallout
sõnum 12.08.2012 10:29:25 vasta tsitaadiga
Mul on peale patchi kõik piixus, serverisse ligi saamine võta umbes 5miljonit aastat aega ja siis of FPS 1-3 vahel :S
vahet ei ole mis serveriga tegu :S
Trying is the first step towards failure!
Velociraptor
Velociraptor
sõnum 12.08.2012 11:03:04 vasta tsitaadiga
Mul ikka versioon 2.4... sixlauncher ei taha ikka veel updateda.
Tuleb ikka vist manuaalselt teha
parm
sõnum 12.08.2012 11:16:01 vasta tsitaadiga
Ma ei saa aru, mida te kepite selle sixlauncheriga ajusid kui on olemas kaks programmi mis lihtsalt töötavad.
http://www.dayzcommander.com/
või http://www.worrom.com/ ainult uuendamiseks
Lovvi
Lovvi
sõnum 12.08.2012 11:18:46 vasta tsitaadiga
parm kirjutas:
Keegi pole neid peale six launcheri kuulutanud siin
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
Velociraptor
Velociraptor
sõnum 12.08.2012 11:26:16 vasta tsitaadiga
Vahet pole, panin manuaalselt peale. Spawnisin cuba bayst elektro sadamasse icon_rolleyes.gif kopp.gif
parm
sõnum 12.08.2012 11:28:37 vasta tsitaadiga
Lovvi kirjutas:
parm kirjutas:
Õnneks meil ei ole Hiina, kus Suur Tulemüür takistaks välismaiseid internetisaite külastada icon_biggrin.gif
Neile kes soovivad ennast DAYZ uudistega kursis hoida igapäevaselt, on väga abiks http://www.reddit.com/r/dayz/
Fallout
Fallout
sõnum 12.08.2012 12:37:51 vasta tsitaadiga
http://youtu.be/7XYBKuzuItk
tiivik
tiivik
sõnum 12.08.2012 13:05:18 vasta tsitaadiga
Sai ka eile 1.2.5 proovitud. Esimesse serverisse jäigi sisse logima, aga mingisse UK omasse sain sisse. Siis spawnising rannikule kuigi olin põhja pool üldse. Asjad olid alles kuigi statsid debug monitoris olid resetitud. Bandiidi skinn (rätipea) oli küll peale pandud mulle kuna oli eelnevalt 3 murderit. Veidi aega mängitud siis lambist läks 1st personisse ning 3rd personisse tagasi lülitades oli bandiidirätik kadunud icon_rolleyes.gif Seda juhtus ka hiljem, kuna sain surma vahepeal ning uuesti spawnides uue karakteriga oli koheselt bandiidi rätt peas. Ehk siis stats'id ei resettigi peale suremist!?
Glitchimise kohapealt, et balota lennuväljal enam ei glitchinud, sain vabalt surnud sõdurite juures kõndida aga chernos glitchis ikkagi. Kuskilt lugesin, et võibolla nüüd tulevad glitchid nüüd sodihunnikutest.
Aga ülipositiivne on see, et zompsid ei ületa helikiirust paremate animatsioonide tõttu, ning nüüd on võimalik neile jooksu pealt kah pihta saada thumbs_up.gif
Fallout
Fallout
sõnum 12.08.2012 13:11:24 vasta tsitaadiga
Lovvi kirjutas:
parm kirjutas:
Kuigi postitusel oli ebaviisakas alatoon olen sunnitud sind tänama nende linkide eest. Update võttis küll kaua aega aga nüüd toimib kõik perfektselt icon_smile.gif
Tänud.
Velociraptor
Velociraptor
sõnum 12.08.2012 13:24:25 vasta tsitaadiga
Kui oled loadingscreenis kinni ja teed mängule resa, spawnid samuti rannikul.
GG thumbs_up.gif , tuleb jälle oodata mingit fixi. Ei viitsi küll rannikult jooksma hakata koguaeg.
troglodyte
troglodyte
sõnum 12.08.2012 13:34:33 vasta tsitaadiga
Kas see on normaalne, et üle õhkulastud majade käies surma saab ja pärast enam seal labavat laipa lootida ei saa?
ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn
parm
sõnum 12.08.2012 15:52:41 vasta tsitaadiga
Fallout kirjutas:
Lovvi kirjutas:
parm kirjutas:
Tänud.
pole hullu, iga kord kui ma sixlauncheri nime kuulen lähevad karvad püsti - need paar korda mis ma olen seda proovinud kasutada on alati kehvasti lõppenud icon_biggrin.gif
kas keegi täna plaanib trippida ka kuskil Chernaruses?
LKits
LKits
sõnum 12.08.2012 16:40:45 vasta tsitaadiga
Oejah... olge valmis, et nii mõnigi aus mängija võib banni saada.
"Häkkerid" leidsid meetodi, kuidas enda GUID asendada ausa mängija GUIDiga ning häkkida tema karakteriga ja suure tõenäosusega saab banni ka - aus mängija.
Lisaks on häkkeritel võimalik enda server püsti panna, millel on küll BattlEye olemas, aga tekitatud niiöelda "whitelist", kuhu on märgitud teatud GUID'id/karakterite nimed, kellel siis BattlEye ei aktiveeru.
Ehk siis DayZ devvide silmis on server täitsa legaalne, aga samas on serveris osadel mängijatel BattlEye maha võetud.
Kisub jamaks ära...
Velociraptor
Velociraptor
sõnum 12.08.2012 17:06:58 vasta tsitaadiga
🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr
uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) mine lehele eelmine  1, 2, 3 ... 58, 59, 60 ... 239, 240, 241  järgmine
