praegune kellaaeg 05.07.2026 12:41:02
30.07.2012 16:08:07
Konfime virtuaalselt võimsaima tööjaama |
Huvitav et sellist teemat pole siia varem tehtud.
Niisiis võiks konfida virtuaalselt võimsaima saadaoleva tööjaama, mida reaalselt tellida saab ja millele tehase täisgarantii kehtib jne.
Teeme otsa lahti:
FUJITSU CELSIUS R920 ½ TB mäluga ja 4TB SSD-ga ning 3 videokaardiga (kokku 14 GB)
http://globalsp.ts.fujitsu.com/dmsp/Publications/public/ds-CELSIUS-R920.pdf
S26361-K1400-V215 CELSIUS R920power 1
"Base unit: System board D3118, Chipset: Intel C602; Theseus system management controller, 1100 W wide range power supply, optical USB tilt- wheel-mouse; prepared for rack mounting (rack mount kit optionally available), EraseDisk and DeskView license included. Slots: 16 DIMM-slots (8 Slots per CPU), 8 channels (4 per CPU); 7 expansion slots: 4x PCIe Gen3 x16, 1x PCIe x4 Gen3 (mechanical PCIe x16), 1x PCIe x4 Gen2 (mechanical PCIe x8), 1x PCI (32-bit / 33 MHz) 2nd CPU (CPU1) is needed for the usage of three and/or four PCIe x16 addon cards. Onboard I/O devices: 2x 1Gbit network controller Intel 82579LM & 82574L, SATA controller (2x SATA 6Gbit and 4x SATA 3Gbit Ports), HD-Audio 5.1 CX20642 SAS upgrade option (Intel C606): SAS 3Gbit controller optional via UpgradeRom (8 Ports, SAS/SATA RAID 0, 1 und 10 ) Bays: 2x 5,25"" und 2x 3,5"" FlexiBays externally accessible, 4x 3,5"" internal HDD bays or [2x 3,5"" internal HDD bays and 2x 2,5"" internal HDD/SSD bays] oor [8x 2,5"" internal HDD/SSD bays] - all internal HDD bays accessable from the front. Front interfaces: 2x USB 2.0, 2x USB 3.0, 1x audio out, 1x audio in Rear interfaces: 2x LAN RJ45, 1x eSATA Gen2, 6x USB 2.0, 1x audio in, 1x audio out, 2x PS/2 for mouse and keyboard, Internal interfaces: 2x USB 2.0, 1x serial, 1x USB 2.0 with standard connector (e.g. Dongle) Embedded security (TPM 1.2) - Infineon Disable / Hide TPM option EraseDisk
Standard warranty:
3 year, Bring-in Service, 5 days / 9 hours (5x9, local business hours), FTS wide / Fujitsu or auth. Servicepartner"
S26361-F4537-E690 Xeon E5-2690 2.9GHz 20MB Turbo Boost 1
S26361-F4540-E690 2nd Xeon E5-2690 1
S26361-F3382-E438 32GB DDR3-1333 rg LR ECC 16
S26361-F2856-E601 NVIDIA Quadro 6000 6GB 1
S26361-F2856-E602 2nd NVIDIA Quadro 6000 6GB 1
S26361-F2856-E995 3rd NVIDIA Quadro 6000 2GB 1
S26361-F3077-E51 MCR 24in1 + USB 3.0 front con., 3.5" 1
S26361-F3523-E530 Blu-ray Disc Triple Writer SATA 1
S26361-F4030-E8 Bracket for mounting of 8x 2,5" HDD 1
S26361-F3758-E512 SSD SATA III 512GB high speed 8
S26361-F4030-E40 Rails for 2x HDD 2.5" 4
S26361-F4030-E23 Cable for 4x SAS HDD 1
S26361-F2581-E43 8-Port SAS-UpgradeRom 1
S26361-F3050-E10 USB 3.0 PCIe x1 1
S26361-F2930-E141 Country kit Euro-cable (EU+) 1
S26381-K551-E446 KB400 PS2 black EST 1
S26361-F2210-E325 Lizenz EU/MM - Windows 7 Ultimate 1
S26361-F2210-E315 REC-DVD Win7 Ultimate 64bit 1
S26361-F2109-E751 REC-DVD 2 Win7 MAIN+Office2010s 1
S26361-F2210-E305 Win7 Ultimate64 + Office2010s 1
FSP:GA3S20Z00DEWSS SP 3y OS Svc,NBD Rt,5x9 1 |
_________________ Erakopeerimistasu tõstmise ettepaneku tagasilükkamine
7 :: |
362 |
erick
30.07.2012 17:23:07
Pane siis juba hind ka juurde
96 |
7 :: |
362 |
1dumbpcuser
97 |
7 :: |
362 |
neros
30.07.2012 20:17:12
Oot... ma ei saa päris hästi aru kellel täpselt sellist tööjaama vaja läheb?
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
| Kommentaarid: 48 loe/lisa |
40 |
part24
30.07.2012 21:35:24
viimati muutis part24 19.09.2013 16:00:23, muudetud 1 kord |
| Kommentaarid: 37 loe/lisa |
Scart
30.07.2012 23:54:38
| madedog kirjutas: |
| Oot... ma ei saa päris hästi aru kellel täpselt sellist tööjaama vaja läheb? |
Ei imestaks, kui ILMi taolised firmad just selliseid masinaid kasutavad. Transformers 3 puhul suutsid ainult peadisainerite masinad avada filmi peamise efektishotti töötlusprogrammis (ja selle avamiseks kulus üle tunni aja) ja neil masinatel oli rammu ja videot ning proset rohkem kui poolel Eestil kokku.
101 |
7 :: |
362 |
part24
31.07.2012 00:51:01
viimati muutis part24 19.09.2013 16:00:38, muudetud 1 kord |
WAV
31.07.2012 00:52:26
Masinal on 512GB mälu, kuid Win7 Ultimate ülemine mälulimiit on 192GB.
Kas on idee virtuaalmasinate konfis või on mul midagi märkamata jäänud?
| Kommentaarid: 7 loe/lisa |
Anton
31.07.2012 02:54:49
| No 3D renderdamiseks pole sel masinal midagi liiga palju. Oleneb vaid, millist renderdudtarkvara kasutada.
| Kommentaarid: 87 loe/lisa |
81 |
ThedEviL
31.07.2012 11:10:12
Hmm...
Defineerida tööjaam. Mis see nüüd täpsemalt on?
Erinevus serverist ja kalkuleerimisplatformist?
Minu laua pealt käis läbi server/tööjama hinnapakkumine üüberarvutuste tegemiseks.
Sisaldas mõningaid Tesla'sid ning hinnalipik oli 300k€
Vaja see ülesse leida või see on nüüd "mitte tööjaam"?
viimati muutis ThedEviL 31.07.2012 11:20:27, muudetud 1 kord |
97 |
7 :: |
362 |
ufo56
31.07.2012 11:13:30
Hind on ülemõistuse kallis. Ja pealegi win 7 toetab vaid 196gb mälu
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
7 :: |
362 |
7 :: |
362 |
Anriil
31.07.2012 11:37:10
| part24 kirjutas: |
CAD?
No andeks, mul käib PTC Pro Engineer Wildfire 5, SolidWorks 2012 ja Mastercam X5 kiidetud tööjaamast võrreldamatult tagasihoidlikuma koosluse pääl teinekord kõik korraga ja ka võrgus, ja seda nõnda, et arvuti ressurssi jääb tugeva kolmandiku võrra ülegi, ja sedagi 32-bit XP Pro pääl, sest tööriistade 64-bit töötavaid versioone ei ole õieti kusagil veel luua suudetud, vähemaste ses CAD/CAM/CAE tsüklis.
Et siis pingpongilaua suuruse ekraani päält ülehelikiiruse lendavate virtuaalkärbeste jahtimise masin, Battlefield 263? |
Sa pead ikka väga lihtsate koostude või üksikdetailidega tegema, et sulle sellisest kastist piisab. 4GB mäluga CAD asju tehes oleksin ma praeguseks eriala vahetanud või hullumajas...
ThedEviL
31.07.2012 11:47:42
| Tanel kirjutas: |
Absoluutselt nõus, kõige kallimad komponendid on 32GB mälupulgad 16tk (ainuüksi 1tk 32GB list price on ca 2000 EUR, ehk kokku 32 000 EUR)
Kui need asendada 16GB pulkadega, oleks "hinnasääst" tervelt 27 000 EUR
Minu teema mõte ongi selles, et mida üldse OEM-idel tööjaamade vallast pakkuda on  |
Tegelikult pole asi üldse nii hull.
Võib juhtuda, et see 27000€ mälu ongi vajalik, et mingi visuaaleffekt või füüsika simulatsioon valmis renderdada. Prosede puhul on kuldreegel: Kui on vähem, on aeglasem. Mälu puhul: kui on vähe, siis ei saa. Vaja jälle mitu nädalat tegeleda kalkulatsioonide optimeerimisega. Niipalju lihtsam on, kui on sigasuur hunnik mälu, mis tähendab, et ei pea ennast siniseks optimeerima.
Lisaks: Nt ühe suure kalkulatsiooniplatformi taga teeb tööd mitu uurimisgruppi. Kui kalkulatsioon tehakse 1 kuu asemel 2 kuuga, on reaalne kulu( oletades eesti teadlase kehva palka) 2000€ per kärss(palgafond kuus) ning kui 10 inimest seisab 2 kuud tööta, kuna see üüberplaform on kooma lastud siis on ju kulu 40 000 euri, mille oleks võinud kohe investeerida kas järgmisse Tesla Blade'i või tõesti nende 2k$ per tükk mälukaartidesse.
Ja kui me võtame nüüd lääneülikoolide teadlased või nt pixari "joonistajad" siis 1 kuu lisaseisak läheb juba maksma vähemalt 6000€ per kärss.
BF3'e mängides muidugi pole mingit vahet, kas sul on 400€ või 400 000€ maksev aparaat.
Kuigi ma kardan et bf3 ei jooksekski nende Tesla "kalkulaatorite" peal.
| ot: |
Tanel, tsiteerides sind: "topeltposti tegemine on keelatud ka modedele, muuda eelmist posti" |
97 |
7 :: |
362 |
WAV
31.07.2012 13:09:29
| Tanel kirjutas: |
| Päris servereid siia ei hakkaks toppima, jäägu konkreetne teema tööjaamade tasemele. |
Kõige võimekamad tööjaamad on klastersüsteemid. Mõni nimetab neid serveriteks, mõni mitte.
7 :: |
362 |
part24
31.07.2012 22:50:45
viimati muutis part24 19.09.2013 16:01:04, muudetud 1 kord |
Anriil
31.07.2012 23:17:58
| part24 kirjutas: |
| Lihtsuses peitub ilu ja lihtsuses peitub ka jõud. Ega palju ei tulegi teha, mõned stantsid ja muud pudi-padi, mis ühe 5-teljelise ja kolme vähemteljelise alt ette nähtud tulema. Aga hullumajja ei aja küll mitte, sest XP puhul sest va 3,28 gigast piisab täiega, XP-l põle ju vajadust mingit totakat mäluõgivat pildiraamatut ja muud visuaalpornograafiat käitada, ja sellegi vähese juures, mida ta käitama pandud, täiesti normaalselt ruunatav nii, et arugi ei saa, et tegemist windoosarajakaga. |
Sel juhul täiesti arusaadav jah. Mu viimane tööjaam oma 32GB ramiga hakkab juba vaikselt jalgu jääma, see peab ka käitama kooste 5000-10000 detailiga, antud teema "ülepakutud" tööjaamad sellistel juhtudel on vägagi teemakohased
| Kommentaarid: 92 loe/lisa |
guest1902
03.08.2012 18:31:34
Annan ka oma panuse - http://www.picocomputing.com/sc_series.html
SC5 FPGA superklaster, HPC (t2isarvude kalkulatsiooniks) jaoks ideaalne, ulme v6imsus.
Palju optimeerimist laskub HDLile tho... Kuid tulemus on suurusj2rkudes v6imsam, kui tavalisel PC arhitektuuril.
SC5 specid http://www.picocomputing.com/pdf/SC5_sm.pdf
Kuskil j2i silma 20kEURine hinnalipik, aga kuskilt kinnitust ei leia
edit:
toon igaks juhuks numbreid - A5/1 crackimine rainbow tabelite abil võtab 30s (ordinaarne pc teeb seda 3 kuud), 56bitise v6tme 3 p2evaga, wpa v6tmeid proovib sekundis l2bi 1,8 miljonit (kuid sellise arvutuskiiruse juures j22ks pudelikaelaks ruuter )
_________________ assumption is the mother of all fuck ups
,,think before you print and save a ROOT::TTree''
viimati muutis guest1902 03.08.2012 19:55:02, muudetud 1 kord |
03.08.2012 19:01:56
| Tanel, ütleme ausalt et suure tõenäosusega sina seda oma kokku pandud komplekti ei vea ringi kaenla all. Tahad öelda antud komplekti kaalu?
| Kommentaarid: 85 loe/lisa |
7 :: |
362 |
dud66
06.08.2012 20:55:08
LIAN LI PC-V2120X All Black Full Tower Case, HTPX, 11 slots, No PSU, Aluminum
COOLER MASTER Silent Pro M2 1500W Power Supply w/ Modular Cables, 80 PLUS® Silver, ATX12V 2.3, 6x 8/6-pin + 6x 8-pin PCIe, Retail
SUPERMICRO H8DA6+, LGA1207 /2, AMD® SR5690, DDR2-800 ECC 128GB /16, SAS RAID 10 /8, SATA RAID 10 /6, VGA, HDA, GbLAN /2, EATX, Retail
AMD 2 x Opteron™ 2356 Quad-Core (Barcelona) 2.3GHz, LGA1207, HT 1000MHz, 2MB (4 x 512KB) L2 cache, 75W, Retail w/o Fan
NOCTUA 2 x NH-U12DO CPU Cooling Fan, Socket 754/939/940/1207, Copper/Aluminum, Retail
KINGSTON 256GB (64 x 4GB) ValueRAM™ Dual-Rank PC2-5300 DDR2 667MHz CL5 1.8V SDRAM DIMM, ECC Registered
PNY NVIDIA® Quadro® 6000G, 6GB GDDR5, PCIe x16, DVI+2x DP+ST, G-Sync Board, Retail
NVIDIA 3 x Tesla™ C2075 Computing Processor, 6GB GDDR5 1.5GHz, PCIe x16, Retail
PNY NVIDIA® Quadro® Plex 7000 RackMount Dedicated Visual Computing System, 3U, Quadro 6000 /2, 12GB (6GB x 2), w/ PCIe HIC card, Retail
OCZ 1TB Z-Drive R2 P88 SSD, MLC, 1.4/1.4 GB/s, PCIe x8, Retail
INTEL 300GB 710 Series SSD, MLC, 240/210 MB/s, 2.5-Inch, SATA 3 Gb/s, Retail
OCZ 1TB Octane SSD, MLC Indilinx Everest, 460/330 MB/s, 2.5-Inch, SATA 6 Gb/s, Retail
LSI MegaRAID SAS 9260CV-8i SAS/SATA RAID Controller, 8-ports (2 x SFF-8087) 6 Gb/s, Levels 0/1/5/6/10/50, 512MB DDR2 cache, PCIe x8, Full-height/Low-Profile, Retail w/ Cables
RAID RAID 10 (mirroring and striping), min 4 hard drives required
LITE-ON iHDS118 Black 18x48x DVD-ROM Drive, SATA, OEM
LITE-ON iHAS524-98 Black 24x DVD±RW Dual-Layer Burner w/ LabelTag, SATA, Retail
LITE-ON iHES112-04 Black 12x/16x/48x BD/DVD±RW/CD, Blu-ray Disk™ Combo Drive, SATA, OEM
PLEXTOR PX-LB950SA 12x/16x/48x BD/DVD/CD Blu-ray Disc™ Burner w/ Lightscribe, SATA, Retail
KOUTECH FPH430 4-port SuperSpeed USB 3.0 Front Panel Hub, 3.5" Bay, USB Type B / SATA Power (With USB3.0 Type B Cable)
QLOGIC QLE2562 Fibre Channel Host Bus Adapter, SFP+ (LC) /2, 8Gbps, PCIe x8, Full-height/Low-profile, Retail
USROBOTICS USR5610C Internal 56K V.92 Performance Pro Faxmodem, PCI, Retail
HT OMEGA eClaro Sound Card, 7.1 channels, 24-bit 192KHz, PCIe x1, Full-height/Low-profile, Retail
PEACHTREE AUDIO Nova Stereo Amplifier w/ DS5.5 High-End Bookshelf Speakers, Rosewood
SAMSUNG MD230X6 Black LCD Monitors, 23" /6 Full HD, 1920x1080, 5760x2160, 300 cd/m², 8ms, VGA/DVI/DP, Fixed Stand
MICROSOFT Wired Desktop 400, Keyboard & Mouse, Black, USB, Retail
MICROSOFT Arc™ Touch Mouse, Black, 3 Buttons, 2.4GHz RF Wireless, USB, Retail
APC NET8, Network SurgeArrest 8 Outlet 120V, Beige
RED HAT Enterprise Linux 6 Server Premium, 2 Sockets, Unlimited Guests, 1 Year Subscription, No Media
MICROSOFT Office Professional 2010, OEM, No Media
SYMANTEC Norton™ Internet Security 2012, 3 Users / 1 Year, Retail
MICROSOFT Flight Simulator X Gold Edition, Retail
WARRANTY Assembled & Tested, Express Priority Service (3 Years Limited Parts, Lifetime Labor Warranty)
Hinnalipikuks küsiti $62739.94 ja kokkutõstmiseks kuni 3 päeva
_________________ Kommenteerige kasutajaid, siis teavad teised ka mida oodata! |
| Kommentaarid: 55 loe/lisa |
52 |
7 :: |
362 |
dud66
06.08.2012 21:01:38
Mängu valikutena olid veel WoW, fallout 3 jne - Sobilik arvuti kõikidele maitsetele
52 |
