| Palju aega võtaks sinu steam kontol olevate mängude läbimine? |
| 1-10 tundi |
4% |
[ 21 ] |
| 10-25 tundi |
3% |
[ 18 ] |
| 25-100 tundi |
9% |
[ 43 ] |
| 100-200 tundi |
10% |
[ 48 ] |
| 200-500 tundi |
8% |
[ 39 ] |
| 500-1000 tundi |
12% |
[ 55 ] |
| Rohkem kui 1000 tundi |
50% |
[ 228 ] |
| hääli kokku : 452 |
Goon
23.07.2012 20:18:56
| Mis asja te erutute ... Saate aru, et enamus teist on ostnud need mängud kui on soodukad olnud. See lehekülg aga kalkuleerib poe hinna järgi. Et see lehekülg näitab sisuliselt aiateibaid.
titskiolen
23.07.2012 21:03:39
Steami probleem |
Tere!
Tean, et see ei ole õige koht abi küsimiseks, aga ei leidnud praegu muud kohta kust abi küsida. Nimelt siis probleem steamis.
Mõningad mängud (Saints Row 3, Shogun 2, Left 4 dead 2) ei tööta kui neid avada. Põhjus siis selles,et lööb ette sellise errori :
In order to run Steam properly on this version of Windows, the Steam service component must be installed.
The service installation process requires administrator priviledges.
<<Install Service>> <<Cancel>>
Kui vajutan Install Service läheb natuke aega ja steam crashib.Olen saatnud ka Steam supporti kirja, kust on pakutud mitut viisi kuidas sellest lahti saab, aga tulutult. Lisan siia ka siis Steami vestluse.
Hi!
Whenever i start Shogun 2 it says that it is installing it and is at 0% after it reaches 1% it says that it needs to install a service that will make it compatible to the current version of windows.Before the last update i could start it up and play without no problems.After it has installed it, it restarts Steam and the same thing continues.I have reinstalled the game and done the unfragment of the game files.
2 Message by Support Tech Ryan on Fri, 13th Apr 2012 10:35 pm
Hello Matu,
Thank you for contacting Steam Support.
Please exit Steam and go to the folder called C:\Program Files\Steam\ (this is the default location for a Steam installation - if you set a different installation directory, you will need to browse to it).
Delete all of the contents of this folder except:
The Steamapps folder and Steam.exe (If 'exe' is not visible, look for the black and white Steam icon)
Restart your computer.
Then, you will need to launch Steam.exe from within the Steam installation folder, and not from a pre-existing shortcut.
With Steam running, re-test the original issue.
Note: This process will not affect your currently installed games.
If the issue persists, view the following article for further troubleshooting:
Title: Troubleshooting Network Connectivity
Link: http://support.steampowered.com/kb_article.php?ref=1456-EUDN-2493
Please follow all suggestions in this article, even if your network appears to be functioning correctly.
3 Message by you on Fri, 1st Jun 2012 6:56 pm
Hello!
I did all of the things suggested here but the problem still exists.Now the same problem is with Saints Row: The Third too. I have reinstalled them both twice. Everyother game runs smoothly and without problems.These are the only games i have problems with.
4 Message by Support Tech Ryan on Sat, 2nd Jun 2012 1:30 am
Hello Matu,
There may be a problem with the Steam client Service.
This service is a required component of Steam on Windows Vista and Windows 7. If the Service is not operating properly, certain Steam functions may fail.
To repair the Steam Client Service, please do the following:
Click the Start button, then 'All Programs', and 'Accessories'
Right-click on Command Prompt and click "Run as administrator..."
In the command prompt, type the following command, including quotation marks, and press Enter:
"C:\Program Files\Steam\bin\SteamService.exe" /repair
Note: C:\Program Files\Steam\ is the default installation directory for Steam - change this to the correct directory if you installed Steam to a different location.
This process will take a few minutes to complete. Once finished, the message "Steam Client Service repair completed." will appear.
Now, reboot your computer and re-test the original issue.
If the issue continues please provide an MSINFO32 report:
Title: MSINFO32 Reports
Link: http://support.steampowered.com/kb_article.php?ref=1376-WTZN-9132
5 Message by you on Sun, 15th Jul 2012 7:53 pm
Hi!
Im sorry for reopemomg the question so late again, but anyway, heres my MSINFO32 report.And the issue is with Left4dead 2 too.I just didnt have it on my computer so i didnt know that it doesnt work.
Steam ms info.nfo (File Size : 4.4 MB)
6 Message by Support Tech Ryan on Mon, 16th Jul 2012 10:25 pm
Hello Matu,
If you have any further questions, please let us know - we will be happy to assist you.
7 Message by Support Tech Ryan on Mon, 16th Jul 2012 10:26 pm
Hello Matu,
Please disregard the previous response as it was sent in error.
The following instructions describe how to temporarily disable applications running in the background which can cause conflicts with Steam. These instructions are for temporary, diagnostic use only and your system should not be left in this state.
Please try this:
Click the Start button, then "Run" (or Windows key + R)
Type in:
msconfig
Choose "Selective Startup"
Uncheck the box labeled "Load Startup Items".
Now, click on the "Services" tab.
Please make sure the "Hide All Microsoft Services" box *is* checked.
Then, click "Disable All".
If you are using Vista or Windows 7, please re-check the "Steam Client Service" as this is required for Steam to function on these operating systems.
Click "OK" and allow your computer to restart.
Test the issue and let us know the results. This is for diagnostic purposes only. You should not leave your computer in this state, but it may help us determine the cause of the issue.
To set the system back to normal, launch msconfig again and choose "normal startup", close the window and restart your computer.
If the issue persists, please *temporarily* uninstall (not disable) all Avast and Mcafee software then re-test the issue.
Should the issue continue, please provide an Msinfo report *after* making the above changes.
Title: How to run and submit MSINFO32 Reports
URL: http://support.steampowered.com/kb_article.php?ref=1376-WTZN-9132
8 Message by you on Mon, 16th Jul 2012 11:39 pm
Hi!
I did all that you suggested and nothing changed.
msinfo32.nfo (File Size : 4.4 MB)
9 Message by Support Tech Ryan on Wed, 18th Jul 2012 6:11 pm
Hello Matu,
Exit Steam.
Click the Start Button, then "Run" (or hold the Windows Key and press R)
Type the following command:
services.msc
This should open a list of services on your computer.
Look for "Steam client Service"
Right click on it, choose Properties.
On the General tab, set Startup type to Automatic and click OK.
Then, restart your computer and re-test the issue.
10 Message by you on Thu, 19th Jul 2012 9:17 am
Hi!
Still the same thing. Nothing has changed.
11 Message by Support Tech Ryan on Fri, 20th Jul 2012 9:46 pm
Hello Matu,
Please try completely removing Steam and re-installing. You may want to print out these instructions for quick reference.
1. Write down your Steam Account name and password - you will need them to log back into Steam once you have reinstalled
2. Logout of Steam
3. Exit Steam
4. If you currently have any Steam games installed that you would like to keep, please copy the Steamapps folder from C:\Program Files\Steam to your desktop or another directory.
5. Delete the Steam folder in the default location C:\Program Files\Steam
6. Hit windows key + r ( run at the start menu ) and type regedit
7. Delete HKEY_CURRENT_USER\Software\Valve and HKEY_LOCAL_MACHINE\SOFTWARE\Valve (or HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Valve on 64-bit Windows)
8. Download and install the Windows Installer CleanUp Utility from the following link: http://www.majorgeeks.com/Windows_Installer_CleanUp_Utility_d4459.html
9. Run Windows Install Clean Up from the Start menu.
10. Select Steam from the list. The list is only partially in alphabetical order, so be sure to check carefully.
11. Select Remove.
12. Select OK.
13. Reboot your computer.
14. Download and install a fresh copy of the Steam installer from http://store.steampowered.com/about/
15. Run the installer and re-test the Steam client.
12 Message by you on Sun, 22nd Jul 2012 12:03 pm
Hello!
i did all you asked, but no, nothing has changed.
(Pole endal inglise keel väga hea.)
Ausalt öelda hakkab juba see asi nõmedaks muutuma. Ehk oskab keegi teist mind aidata?
_________________ 47 on püha arv. |
23.07.2012 21:41:46
Goon, http://alabasterslim.com/worth.php näitab ka soodushindadega summat.
need numbrid on üldiselt kõik paras kräpp
_________________ - londiste
217 |
lxx2
23.07.2012 22:26:56
You own 12 games worth: 189.93€
Reaalselt raiskasin 16 euri..
| Kommentaarid: 37 loe/lisa |
37 |
M3rcury
| Kommentaarid: 25 loe/lisa |
24 |
renhoelder
23.07.2012 22:46:49
Pff... minu Steami konto on ainult raha raiskamise ja e-pe:nise pikendamise eesmärgil, ühtegi mängu ma ei mängi.
Aga tõsiselt, mul näiteks moodustavad päris suure osa igasugustesti bundle'itest tulnud mängud, lisaks veel siin kasutaja zpsy käest ja muude saitide aledega omandatud Steami võtmed, nii et reaalne summa mille ma investeerinud olen on kindlasti kõvasti väiksem. Samas backlog on suur ja igasugused aled ei aita just selle kahanemisele kaasa. Aga no, muu elu tahab ka elamist, ei ole aega koguaeg mängida kahjuks.
| Kommentaarid: 75 loe/lisa |
71 |
Scart
23.07.2012 23:34:25
You own 205 games worth: $3,174.25 USD
If you bought all these games on sale it would have cost: $938.23 USD
You spend an average of $15.48 USD ($4.58 USD) per game.
101 |
bitCON
24.07.2012 02:45:39
haiged tüübid
Archangel
24.07.2012 05:16:21
Found 33 Games with a value of
$460.68 USD
Suht vähe mänge siiski Steamis ning enamik on vanemad mängud mille hetke-väärtus obviously madal. Kulutatud summa võib küll vast 2x suurem olla.
25 |
UB
24.07.2012 06:03:37
| Found 204 Games with a value of $2825.97 USD - õnneks saan öelda, et pere peale oleme me peaagu kõik mängud käbi mänginud, ainult mõned vanad ja koledad mängud on tulnud mingi pakiga kaasa ja siis on need jäänud menüüst kõrvale. Eks muidugi pettumusi on ka, aga enamus on siiski hea olnud. Pärast Summersalet muidugi lisandus neid mänge juurde, mis alles läbitegemist ootavad...
| Kommentaarid: 45 loe/lisa |
39 |
muff
24.07.2012 19:38:49
| Goon kirjutas: |
| Mis asja te erutute ... Saate aru, et enamus teist on ostnud need mängud kui on soodukad olnud. See lehekülg aga kalkuleerib poe hinna järgi. Et see lehekülg näitab sisuliselt aiateibaid. |
Muidugi saame aru, see näitab mängude täishindasid, ehk siis seda mida asjad tegelikult väärt on. Samas selge ju kas see, et enamus ostab asju aledega. Lihtsalt huvitav näha seda kui oleks asjad ostnud 100% hindadega.
| Kommentaarid: 13 loe/lisa |
Anna tooli
24.07.2012 20:37:10
http://store.steampowered.com/app/550/
Midweek Madness - Left 4 Dead 2 - 75% off!
During this week's Midweek Madness, save 75% off the Left 4 Dead 2!
Also, make sure to check out the "Cold Stream" update today! This 5 campaign DLC includes Crash Course, Death Toll, Dead Air, Blood Harvest and the community created Cold Stream. The update also makes all mutations available to play any time. |
300 |
Kriisa H
25.07.2012 02:13:49
Õigel ajal crashis see steami server ära
| Kommentaarid: 87 loe/lisa |
72 |
tiido
484
25.07.2012 09:46:27
| Kas oleks huvilisi L4D2 nelibäki ostul ?
| Kommentaarid: 139 loe/lisa |
130 |
chatro
25.07.2012 11:50:05
| tiido kirjutas: |
| Kas oleks huvilisi L4D2 nelibäki ostul ? |
Palju see pärast ühe hinnaks teeks ?
| Kommentaarid: 23 loe/lisa |
21 |
K3ndu
120 |
chatro
25.07.2012 12:05:00
| Ei, ma lihtsalt ei viitsinud otsida, palju 4pack maksab (:
21 |
warkriss
25.07.2012 23:58:24
Tundub, et mu eelnev emotsioonidepuhang oli enneaegne- pole midagi ära kustutatud ja sain nüüd kasutaja tagasi. (kuigi veider on see, et kasutaja polnud minu emailiga seotud ja et ma tema parooli ei mäletanud).
Minu paha
E: kas keegi äkki mäletab ühte vana mängu, mis steamis tasuta oli.. oli mingi sõjamäng, vanemast ajast, britid/usa (kumbki kahest) oli esindatud. Teine pool kas oli äkki prantsusmaa? pole kindel. Sai vintpüssi/püstoliga ühe lasu teha, siis laadis pool päeva- pani püssirohtu, puhastas, pani kuuli sisse ja siis alles sai uuesti tulistada- vahepeal käis action mõõga või täägiga. Ei tea mis sellest saanud on?
| Kommentaarid: 30 loe/lisa |
30 |
Ertai
| Kommentaarid: 52 loe/lisa |
47 |
chatro
26.07.2012 02:30:29
| warkriss kirjutas: |
E: kas keegi äkki mäletab ühte vana mängu, mis steamis tasuta oli.. oli mingi sõjamäng, vanemast ajast, britid/usa (kumbki kahest) oli esindatud. Teine pool kas oli äkki prantsusmaa? pole kindel. Sai vintpüssi/püstoliga ühe lasu teha, siis laadis pool päeva- pani püssirohtu, puhastas, pani kuuli sisse ja siis alles sai uuesti tulistada- vahepeal käis action mõõga või täägiga. Ei tea mis sellest saanud on? |
Ilmselt mõtled Battlegrounds 2'e ? Eks seda mängitakse siiani.
http://www.bgmod.com/
21 |
Timo1337
26.07.2012 09:10:00
| warkriss, no oli see kasutajanimi siis see mida koguaeg sisse üritasid meeleheitlikult tagauda?
| Kommentaarid: 49 loe/lisa |
46 |
warkriss
26.07.2012 10:12:14
| Timo1337 kirjutas: |
| warkriss, no oli see kasutajanimi siis see mida koguaeg sisse üritasid meeleheitlikult tagauda? |
Jah, ehk siis minu vana emaili aadress.
Voh just! Tänud!
30 |
Braien
27.07.2012 21:36:06
Praegu Broderlands tasuta, neile teadmiseks kes ei tea.
90 |
prtv
27.07.2012 21:55:39
| braien334 kirjutas: |
| Praegu Broderlands tasuta, neile teadmiseks kes ei tea. |
Ainult nädalavahetusel on tasuta.
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
Braien
27.07.2012 22:52:40
gan3b, Mul laseb tõmmata juba.
90 |
prtv
27.07.2012 23:00:18
| gan3b, Mul laseb tõmmata juba. |
Kuna ajaerinevused eksisteerivad, siis saab tõmmata sellest ajast saadik kui austraalias hakkas laupäev.
_________________ |
73 |
warkriss
28.07.2012 19:26:31
| Mis asja, mul näitab, et -75% ehk 5€
30 |
Archangel
28.07.2012 20:16:10
| Mis asja, mul näitab, et -75% ehk 5€ |
25 |
hanz
| Kommentaarid: 7 loe/lisa |
karlutikas
29.07.2012 13:19:39
| Selline huvitav probleem, et Steam ei lisa mängude shortcute desktopile, tee mis tahad. Iga kord kui ära installin siis panen linnukese sinna, et ta looks siis shortcuti ka. Aga seda pole Steam siiski teinud. Täna proovisin siis libraryst manuaalselt klikkida sinna, et ta looks shortcuti. Ütleb küll et tegi, aga ikkagi on desktop tühi. Mis siis nüüd peale hakata, operatsioonisüsteem on windows xp.
Ollaz
29.07.2012 13:22:21
| Kustuta steami kaustast clientregistry.blob ja proovi uuesti.
| Kommentaarid: 83 loe/lisa |
57 |
karlutikas
29.07.2012 13:56:11
| Kahjuks ei aidanud, eks ma siis käivitan library kaudu, aga aitäh ikka.
Aeron
| Kommentaarid: 72 loe/lisa |
65 |
madness
30.07.2012 09:54:17
| Indie Galal on ikka eraldi võtmed olnud...
Mukii
30.07.2012 15:20:09
Ise ostsin indie galad 2-5, nüüd jätan vahele, kuna pole väga väärt mängud, ja 6€ on ka raha. Pigem ostan Humble Bundleid, kõvasti parem bang for buck.
_________________ You're programmed to die when a 180-second countdown ends. The countdown resets every time you take a breath. |
| Kommentaarid: 20 loe/lisa |
20 |
W!ngs
23 |
Ertai
01.08.2012 00:06:51
päris asjalik. võibolla võtan üks-kaks. paljud olemas juba.
47 |
Gunnar19
Kaevur
08.08.2012 12:21:03
Ma ei saa aru kuidas saab nii odavalt kogu bundle ära anda...
| Kommentaarid: 42 loe/lisa |
Dinkz
08.08.2012 12:27:52
| Gunnar19 kirjutas: |
Oskab keegi öelda ka, et kui mul näiteks Source on olemas, aga soovin osta terve bundle, siis pean selle source hinna ka sinna uuesti sisse arvestama jah?
| Kommentaarid: 26 loe/lisa |
26 |
Anna tooli
08.08.2012 12:28:51
| Maksad ikka bundle hinna
300 |
Dinkz
08.08.2012 12:31:20
| Mis möllad, kirjutas: |
| Maksad ikka bundle hinna |
No siis läheb seekord loosi.
26 |
Diesel157
08.08.2012 12:33:51
| Keegi PAYDAY™ The Heist 4 packi ei kavatse osta?
| Kommentaarid: 162 loe/lisa |
146 |
Rebel_
08.08.2012 13:17:52
| Diesel157, mina oleks käsi
| Kommentaarid: 10 loe/lisa |
10 |
frosty
08.08.2012 13:40:23
| Diesel157, oleks samuti käsi.
chatro
08.08.2012 16:54:15
Ja ma oleksin ka käpp.
E: Kui keegi ära ostab siis õhta annan raha, praegu arvutist eemal
E: Rebel ostis ära
21 |
sireq
08.08.2012 18:59:21
| c20xe kirjutas: |
Oskab keegi öelda ka, et kui mul näiteks Source on olemas, aga soovin osta terve bundle, siis pean selle source hinna ka sinna uuesti sisse arvestama jah? |
minuteada cssi eest extra copit ka ei saa
_________________ Steam
Origin: EP1CNESSS |
22 |
Dinkz
08.08.2012 19:17:40
Extra copy mind ei huvitagi, et kas pean Source eest ka uuesti arvestama raha, kui ta mul juba olemas on?
26 |
Renka
08.08.2012 19:25:23
c20xe, ei pea - sa maksad paki eest - mitte eraldi mängude eest.
61 |
SinineSiil
19 |
Dude .
08.08.2012 22:25:59
Iseenesest on tarkvara juba tegelikult olemas (Source filmmaker jms). Ehk tahavad pakkuda teist võimalust Win8 app store'ile, mis neile ei meeldinud.
_________________ TALUSILDID |
| Kommentaarid: 15 loe/lisa |
15 |
