19.06.2012 12:04:27
Fujitsu murdis 923-bitise krüpto |
link :: The Register
Fujitsu on püstitanud uue krüptograafia-alase rekordi, murdes ligi 150 päevaga lahti seni murdmatuks peetava 278 numbrilise (923-bit) krüpteeringu. Eelmine rekord pärines aastast 2009, kui murti lahti 204 numbriline (676 bit) krüpteering. Koostööd tehti Kyushu ülikooli ja Jaapani info-ja kommunikatsioonitehnoloogia Instituudiga (NICT).
| We were able to overcome this problem by making good use of various new technologies, that is, a technique optimising parameter setting that uses computer algebra, a two dimensional search algorithm extended from the linear search, and by using our efficient programing techniques to calculate a solution of an equation from a huge number of data, as well as the parallel programming technology that maximises computer power. |
Loe lähemalt meetoditest Fujitsu lehelt.
_________________ HV-s ID-kaardiga autentimine
HV valuutakalkulaator
viimati muutis Tanel 20.06.2012 08:20:55, muudetud 1 kord |
7 :: |
360 |
anubis
19.06.2012 12:42:29
Tegelikult ei läinud vaja superarvutit
New Achievements
As for a security evaluation of cryptographies, we succeeded with the cryptanalysis of the pairing-based cryptography of 278 digits (923 bits) by using 21 personal computers (252 cores) in 148.2 days. The cryptanalysis is the equivalent to spoofing the authority of the information system administrator. As a result, for the first time in the world we proved that the cryptography of the parameter was vulnerable and could be broken in a realistic amount of time.
Paneb mõtlema, mida küll hiinlased oma uute superarvutitega teevad/suudavad...
283 |
madest
19.06.2012 12:48:07
No more secrets, Marty.
| Kommentaarid: 13 loe/lisa |
neros
19.06.2012 13:41:00
Et siis... kas kusagil mingi list on üleval mis algoritmid veel turvalised on nüüd?
_________________ GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt. |
| Kommentaarid: 48 loe/lisa |
40 |
anubis
19.06.2012 14:16:52
| madest kirjutas: |
+1
283 |
19.06.2012 14:24:04
| madest kirjutas: |
setec astronomy?
aga pairing-based cryptography peaks olema suhteliselt üldine mõiste või ma eksin?
milliseid reaalseid algoritme või vahendeid see mõjutab?
_________________ - londiste
216 |
Ho Ho
19.06.2012 14:42:10
| seni murdmatuks peetava 278 numbrilise (923-bit) krüpteeringu |
bullshit
Ühtki krüptolahendust ei pea keegi murdmatuks. On lihtsalt erinevad murdmiskeerukuse astmed.
86 |
anubis
19.06.2012 14:49:43
Proof of concept. Eks kõige hullem ole selle juures see, et eeldati brute force laialilammutamist paari(saja)tuhande aasta jooksul. 142 päeva ühe räkitäie off-the-shelf riistvaraga...nojah.
283 |
Rebel_
19.06.2012 14:56:44
Ho Ho,
Seda pole Üksik krüptolahenduste pakuja kunagi väitnudki.
piisab, et oleks nii turvaline info väärtus ei ületaks murdmiseks kasutavate ressursside kulu.
| Kommentaarid: 10 loe/lisa |
10 |
iguaan
20.06.2012 00:45:13
| kõik inimloodud on "loetav" teise poolt.
| Kommentaarid: 83 loe/lisa |
71 |
-vodafone-
20.06.2012 01:13:07
Aga kuidas on lood näiteks 128it SSL lahtimurdmisega?
Ärge näkku lööge! Pole asjaga väga kursis, aga kui "nii lihtsalt" 923bit krüpto lahti murtakse siis miks mitte näiteks online pokkerilauas ei suudaks teiste kaarte lahti krüptida.
217 |
neros
20.06.2012 05:30:26
| -vodafone- kirjutas: |
Ärge näkku lööge! Pole asjaga väga kursis, aga kui "nii lihtsalt" 923bit krüpto lahti murtakse siis miks mitte näiteks online pokkerilauas ei suudaks teiste kaarte lahti krüptida. |
Nii palju kui ma lugesin, siis mitte ei 'krüptitud lahti' vaid bruteforceti. Lahtikrüptimine on selliste algoritmide puhul suht võimatu, ainuke lootustandev lahendus ongi ainult toores jõud, mida ka siinkohal kasutati. Ja selleks kulus päris mitu kuud esiteks.
Tesieks, online pokkerilauas ei saadeta teiste kaarte üle interneti laiali. Kaardid on serveripoolel, neid saad ainult siis teada, kui sa otse serverit ründad, ning teoorias on korralike pokkerisaitide turvalisus samal tasemel "päris" kasiinodega, a la sul on internal struktuurile ligipääs vaid füüsiliselt või läbi turvatud SSH kaudu, edu selle murdmisel kui default seaded on muudetud
40 |
siinus
20.06.2012 05:49:44
madedog, paar viga on su jutus. Kaardid võivad serveris "istuda", aga selleks, et inimene oma kodus nende edasist saatust otsustada saaks, peab mingi info neist ju ka lõppkasutaja arvutisse jõudma.
Kõige lihtsam näide on youtube videod.
Kas sa käid tihti pokkerisaitidel läbi ssh?
_________________ suck less | ANNA MU SAI!
| Kommentaarid: 70 loe/lisa |
63 |
neros
20.06.2012 07:22:08
Jutt käib _teiste_ kaartidest. Mitte su enda omadest. Otse loomulikult kui sa tead kes teised mängijad füüsiliselt on, võid nende vahele ju snifferi panna . Point ongi selles, et mängijana sa ei saa teiste kaarte enne kätte kui nad ümber keeratakse. Mitte mingil juhul ei tahaks uskuda, et pokkerisaidid saadavad kaardid laiali ja panevad lihtsalt juurde lipukese "hidden" ja usaldatakse klienti, et nad neid ümber ei pööra.
Lisaks: SSH oli "serveri internalile" ligipääsus, mitte pokkerisaidile endale. Eriti viletsa turvalisusega server peaks olema, kui keegi suudaks serverimälu läbi veebibrauseri lugeda.
40 |
madest
20.06.2012 07:54:29
| enamus https saite on ainult 128 bit ?
WAV
20.06.2012 08:02:53
| Lihtsal brute force murdmisel oleneb kulunud aeg eelkõige sellest, kui ruttu jõuti otsast alustades juhuslikult juba õige võtmeni. Kõige ideaalsemal juhul saab see toimuda ju lausa silmapilkselt, siis kui esimene proovitav kood ongi kogemata täpselt see õige. Nagu loto jackpoti tabamine. Seega lahtimurdmise ajarekordid on ka nagu rohkem juhusliku vedamise asi.
| Kommentaarid: 7 loe/lisa |
anubis
20.06.2012 08:03:29
Mitu kuud jah, aga of-the-shelf riistvaraga (21 masinat).
Viska selle probleemi kallale ntks hiinlaste petaflop supercomputer...
283 |
madest
20.06.2012 08:40:51
Kas seda aega ei mõõdeta siis nii et võetakse kõige pikem tee ja siis välistuste abil lühendatakse ehk kui anda mõni reaalne shrift dekrüptimiseks siis oleks aeg ilmselt veel lühem kui see 150 päeva.
Teadlased laboris ei bruteforce mingit suvalist et oih jee lahti saime .. 1 päev läks miljon bitti decrüptiks see ei käi nii !
Ho Ho
20.06.2012 08:41:51
SSL ning nonde 21 aparaadi poolt muugitud krüptoalgoritm on kardinaalselt erinevad. Viimane kusjuures katsejärgus ning selle murdmise üks eesmärkidest oligi näidata, et algoritm on puudulik.
86 |
degreal
20.06.2012 09:23:08
| Aga kuidas on lood näiteks 128it SSL lahtimurdmisega? |
256bit võtme kohta selline huvitav arvutus: http://everything2.com/title/Thermodynamics+limits+on+cryptanalysis
Even sucking all the energy from a supernova would be just enough to pass through all states of a 219-bit counter... So, it is clear that a 256-bit key (which, just to be represented while we brute-force it on our ideal computer, would require the energy that 400.000.000.000.000.000.000 suns like our sun radiate in a year...) seems errrr... kinda difficult to brute-force...
| Kommentaarid: 27 loe/lisa |
25 |
soomer
20.06.2012 14:44:23
hmm |
See arvutus tundub küll väga imelik olevat.
Ei saa aru kas seda energiat on vaja selleks et need võimalikud biti jadad läbi vaadata või samaaegselt mingis mälus hoida?
Teiseks, selleks et 256 bit võtit lahti murda, pole sul vaja läbi proovida kõik võimalikud väärtustused. Näiteks RSA murdmiseks saab kasutada võtme faktoriseerimist, mis ka kõige aeglasema algoritmiga vajaks vaid ruutjuur võtme suurusest läbivaatus samme. (128bit)
| degreal kirjutas: |
-vodafone-
20.06.2012 21:30:10
| madedog kirjutas: |
Lisaks: SSH oli "serveri internalile" ligipääsus, mitte pokkerisaidile endale. Eriti viletsa turvalisusega server peaks olema, kui keegi suudaks serverimälu läbi veebibrauseri lugeda. |
Huvitav. Kui mulle ju jõuavad kaardid kätte (samamoodi teistele, aga neid me ei näe) siis mingi info ju tuleb ikkagi sisse. Samuti pokkeri "chatis" dealer ju isegi kuvab sinu kaardid plain tekstina.
217 |
kazzka
20.06.2012 21:42:27
| madedog kirjutas: |
Huvitav. Kui mulle ju jõuavad kaardid kätte (samamoodi teistele, aga neid me ei näe) siis mingi info ju tuleb ikkagi sisse. Samuti pokkeri "chatis" dealer ju isegi kuvab sinu kaardid plain tekstina. |
Teiste mängijate kaartide info saadetakse alles showdownil sinu arvutisse, enne seda istub kõik info turvaliselt serveris. Sind on lihtsalt eksitatud tagurpidi olevate kaartide piltidega?
neros
21.06.2012 05:26:41
| madedog kirjutas: |
"mängijana sa ei saa teiste kaarte enne kätte kui nad ümber keeratakse". Jah, seni on ainult pildid.
40 |
HacaX
24.06.2012 16:48:56
| Rebel_ kirjutas: |
Ho Ho,
piisab, et oleks nii turvaline info väärtus ei ületaks murdmiseks kasutavate ressursside kulu. |
Ole nüüd, "100% murdmatust" väidetakse stabiilselt (ja siis longitakse saba jalge vahel minema kui päris krüptograafid programmi pihuks ja põrmuks teevad). Ja vähemalt üks süsteem on 100% murdmatu - one-time pad, seda nii teoorias kui praktikas. Lihtsalt praktika jaoks on ta äärmiselt ebapraktiline, seetõttu teda suurt ei tarvitatagi
Muidu uudis ise IMO suht lahja. Ei ole algoritmi X lahtimurdmist, vaid näide sellest, et üks printsiip mida võidakse algoritmi loomisel kasutada on praktikas küsitava väärtusega (kuna ta saaks lahti riistvara ja ajaga mis on ka tavainimesele vastuvõetavad). 128bit AES on jätkuvalt turvaline, rääkimata 256bit Twofishist või 4096bitisest RSAst.
| Kommentaarid: 24 loe/lisa |
22 |
