| Kaua oled WoT-i mänginud? Täpsusta teemas. |
| 12-10a |
42% |
[ 27 ] |
| 10-8a |
17% |
[ 11 ] |
| 8-6a |
11% |
[ 7 ] |
| 6-4a |
7% |
[ 5 ] |
| 4-2a |
4% |
[ 3 ] |
| Vähem kui 2a |
15% |
[ 10 ] |
| hääli kokku : 63 |
MorRAW
Ei ole Guru
07.05.2012 23:13:57
http://forum.worldoftanks.eu/index.php?/topic/112792-us-promocode-works-for-eu-too/
Tankers!
In honor of Victory Day and the ongoing Military Month specials we are pleased to offer you a fantastic bonus code: ENDWAREU
Extra Combat Rations - x5
Case of Cola - x5
Chocolate - x5
Improved Combat Rations - x5
Strong coffee - x5
1 day Premium Time
The Victory Day Promo code will remain active from May 8, 2012 through May 15th at 16:59 PDT (23:59 UTC).
Only during these days will you be able to activate this one time use code:
ENDWARNA
(USEe caps only). If you need more information on how to activate the promo code, please read the instructions.If you already have a premium account, after putting in the promo code you will receive a 24h extension to your premium play time.
We hope you and your crewmen enjoy all the food and drink!
| Kommentaarid: 376 loe/lisa |
317 |
hmekk
08.05.2012 00:07:50
Type vist ei jõuagi kohale ... oeh
_________________ Fotoblogi / Flickr |
8 :: |
68 |
Marx112
08.05.2012 00:13:21
| Ostan ka type ikka ära. Mõtlesin, et peab juba mingi heavy omale võtma, aga ei viitsi nendega jaurata. Type ei too küll niipalju sisse, aga vähemalt on temaga fun mängida.
Cyberlord
08.05.2012 00:28:06
| Krt mul 1h juba möödas ja pole veel saanud.
| Kommentaarid: 546 loe/lisa |
449 |
qlimax2008
08.05.2012 00:34:53
| Endal just tulid boonuskoodiga asjad kohale paar minutit tagasi.
hmekk
08.05.2012 02:53:02
Tulid kohale yeh. Suhteliselt pull asi kui mitmekesi suusatada ja olenevalt mapist. Ammorack on kohutavalt nõrk ja trackid lendavad ka kergelt maha. Aga noh, rammer, stabi ja gun laying ning saab kenasti suusatada ja lasta.
8 :: |
68 |
Sandra
08.05.2012 06:55:37
Sai natuke müratud...
Minu krediidi rekord siiani -
| Kommentaarid: 32 loe/lisa |
31 |
Ritsard
08.05.2012 09:46:07
Kas need premium tankid teenivad siis nii palju rohkem hõbedat? 143k on päris ulmeline summa. Ma olen ise vist kõige rohkem 50-60k saanud.
Kommentaariks SU-8 teemale, see arty on väga ok, kui mehed 100%. Ehkki autasusid nii palju ei ole saanud, kui SU-5ga (aeglasem laadimine), siis dämmi teeb hästi ja saab kõrgemate tierite mängus ühtteist ära tehtud. Statistiliselt mul u 200 mängust u 300 killi, võidupross u 60.
Vahetasin hiljuti SU-14 vastu, millega olen ikka püstihädas. 14 on korralik liikuv kirst, jõle aeglane, peamine probla täpsus, mida pole ollagi. Ei ole uurinud, äkki uus toru on täpsem. Niiet üleminek SU-8 SU-14 peale on hetkel väga valulik.
| Kommentaarid: 37 loe/lisa |
MorRAW
Ei ole Guru
08.05.2012 10:08:12
| Ritsard kirjutas: |
| Kas need premium tankid teenivad siis nii palju rohkem hõbedat? 143k on päris ulmeline summa. Ma olen ise vist kõige rohkem 50-60k saanud. |
Type59 tundub olevat kõige kasulikum premium tank. Suhteliselt lõbus mängida ka võrreldes näiteks KV-5'ga
317 |
kalluka
08.05.2012 10:33:15
| Kas premium tankiga saab kohe sõita või peab sinnamaani arendama?
| Kommentaarid: 16 loe/lisa |
12 |
gemini
08.05.2012 10:34:13
| Kohe saad sõita, aga meeskond on alguses ikkagi 50%.
| Kommentaarid: 75 loe/lisa |
61 |
kalluka
08.05.2012 10:36:22
On mötet ka osta? Selle pisikese jublakaga millega hetkel rallib on ikka jube nüri
12 |
crazyxman
08.05.2012 10:40:23
ostsin ja täitsa meeldib.
imho peaks kohe mehed 100% ostma (praegu -50% ka), samuti ka ammo rack'i kaitse ja vent väga vaja. kolmas asi nii nagu kellelgi enda mängustiiliga sobib.
| Kommentaarid: 30 loe/lisa |
28 |
masmre
08.05.2012 10:43:16
Ostsin kulda kiiruga ja ei pannud tahele, et olen worldoftanks.com lehel. nüüd selline kysimus, et kas see kuld jáábki usa servusse vói saab selle kuidagi ka eu servu alla kanda?
Markasin alles párast oma paypali kontol, et maha láks dollarites, nüüd on suur hirm, et papp lánnu ja kulda ka ei saanud...
Ei tea, kui kaua see uuenduse asi kestab, milla oma accounti vaadata saaks?
| Kommentaarid: 83 loe/lisa |
77 |
Scart
08.05.2012 10:58:20
| Ritsard kirjutas: |
Premium tankidel on hõbeda jaoks kordaja. See oli kas 2 või 2.5. Mõistlik Tüübi matš toob kätte 45-55 kilo hõbedat, mis on ikka palju rohkem kui sarnane mäng tavalise T8 mediga.
101 |
gemini
08.05.2012 11:00:39
| Scart kirjutas: |
Premium tankidel on hõbeda jaoks kordaja. See oli kas 2 või 2.5. Mõistlik Tüübi matš toob kätte 45-55 kilo hõbedat, mis on ikka palju rohkem kui sarnane mäng tavalise T8 mediga. |
Sama võib ka KV-5-e kohta ütelda - seda siis sissetuleku koha pealt.
61 |
kalluka
08.05.2012 11:08:26
| t59 on hea siis?
12 |
Scart
08.05.2012 11:17:00
| gemini kirjutas: |
Sama võib ka KV-5-e kohta ütelda - seda siis sissetuleku koha pealt. |
Ikka jah, KV5 ka prem ikkagi. Löwe teenib tüüpilise mänguga 70-80k ning sellest läheb maha tubli 30k repairi ja ammo peale. Tüüp teenib 50-60k, kuid repair ja ammo on Löwega võrreldes kopikad ning KV5 läheb samasse auku Löwe numbritega.
101 |
Valvejoodik
08.05.2012 11:25:23
| kalluka kirjutas: |
| Kas premium tankiga saab kohe sõita või peab sinnamaani arendama? |
Premium tankid on "stock" tankid, seal midagi arendada ei saa...
15 |
kalluka
08.05.2012 11:27:56
| Hmm , aga pointi osta on? Kumb kas kv5 või see t59?
12 |
Scart
08.05.2012 11:32:04
| kalluka kirjutas: |
| Hmm , aga pointi osta on? Kumb kas kv5 või see t59? |
Tüüp on tüüpiline Vene medium elik kiire, mõistliku toruga ja tankib ka enam-vähem. KV5 on üliraske koloss, mis venib aeglaselt üle välja, tankib nagu loom aga ise tõsiselt kahju teha ei suuda. Sõltub sellest, missugune mängustiil sulle meeldib. Mul on endal olemas nüüd Löwe ning Churchill raskema veeremise jaoks ja Tüüp, kui on vaja lõbusalt paugutada.
101 |
Ertai
08.05.2012 12:09:45
| kalluka kirjutas: |
võta t59 for süre. Paaril viimasel päeval on nad kõrgete tieride mängus ainsad ohtlikud asjad olnud. Liiguvad nii kiiresti ja julmalt peale ja lasevad juppideks kõik.
Löwesid ei kardeta nii palju, nad on aeglased ja vahivad ringi ja lihtne sisse piirata. Peavad küll vastu kenasti, aga kui juba tagumikku vopse saavad, siis on ai ai.
t59 ainult nädal ka müügis, väga eksklusiivne asi.
Ise masinat ei oma, aga nähes, kuidas mängitakse, siis tundub väga FUN olevat + teenib raha ka kõvasti. Pea iga lahing võtab keskmine-hea type'i mängija vähemalt mõne masina maha ma eeldan.
Fun factor on WoTi puhul ka ikka väga oluline ja miks mitte just premium tankiga.
| Kommentaarid: 52 loe/lisa |
47 |
Marx112
08.05.2012 12:12:52
| Tahaks juba osta tüüpi, aga mängu uuendus vist ja pealeht maas. Kaua see olla võib? Varsti tööle, peab siis öösel ostma.
crazyxman
08.05.2012 12:17:33
| minul juba vaikselt tirirb järgmist patchi. kirjas oli, et vist 1 ajal meie aja järgi saab läbi uuendus.
28 |
Gil-Harris
08.05.2012 12:20:21
Nüüd peale uuendust on garage vene tanke täis, ei tea enam mida nende kõigiga pealegi hakata
| Kommentaarid: 36 loe/lisa |
33 |
Ertai
08.05.2012 12:26:33
Täna on funcup. max to T4 siis. SPGd ja TDd mitte.
Mõtlesin esimest korda osaleda.
Mida soovitate võtta, kes ei osale või karda konkurendile kogemust jagada.
t-28 le võiks selle kurja kahuri peale panna oli mu üks variant. Või mõne täpsema ja kõrgema RoFiga.
Teine variant oli mul M3Lee, lihtsalt naljapärast, et kas saan circle'imise vastu või ei.
viimati muutis Ertai 08.05.2012 12:33:13, muudetud 1 kord |
47 |
vipu
08.05.2012 12:32:10
mingit uuendust tirib...
tahtsin selle käärpiksilma kohta küsida, kas on asjal mõtet, tankile panna?
marder 2 oli üli hea nägemisega, aga praegune tank on suht pime. 25% nägemisala seistes juurde annaks mingi 60-70 meetrit.
viimati muutis vipu 08.05.2012 12:34:02, muudetud 1 kord |
Ertai
08.05.2012 12:59:32
| vipu kirjutas: |
| mingit uuendust tirib |
7.3. ju
Mäng ise üleval tagasi ka, sain just sisse.
| vipu kirjutas: |
marder 2 oli üli hea nägemisega, aga praegune tank on suht pime. 25% nägemisala seistes juurde annaks mingi 60-70 meetrit. |
Mis tankiga tegu?
Kui oled passive scout või ambushid, siis ikka tasub vast.
Mis sul veel peal on ?
47 |
vipu
08.05.2012 13:20:23
Tank on VK 3601H Käärpiksilma saab kullaga nagunii edasi tõsta.
Automaatlaadija on kõigil peal, killukaitse ja ventilaator on sellel mudelil.
oh jeee, selle kupongiga saab 3 preemium päeva
Marx112
08.05.2012 13:29:06
| Nüüd on pilt sitaks puhas ja ilus nagu. Muidu oli nagu tuhm selline. KV2 on sama rea peal mis KV1, aga ikka on kv2 tier 6 :S. Tüüp on ikka räige pill. Esimene mäng ja kohe terasmüür.
tondu
08.05.2012 13:33:52
Tere!
Nokin seda ajaviiteks aga tahaks midagi paremat, kui hetkel tasuta saab.
Arendan mikide medium to heavy. (level 4 peal hetkel).
Mida SAAB raha eest hetkel ja on fun. (mikid mulle meeldivad, sest keegi teine ei sõida nendega)
Ehk mille eest peaks maksma? Igasugu jama peale ei tahaks raisata. Lisaks mõtlesin et teen kingi ka sõbrale
Tändu ette!
| Kommentaarid: 17 loe/lisa |
14 |
Ritsard
08.05.2012 13:36:25
Peale uuendust tõesti terve garaaž vene KV-sid täis...
Kohati on täiesti arusaamatu expi hulk antud, nt KV-3 upgrade KV-4 on 54k; arendasin just T29 - T32 ja see oli 100k. Samas tuleb tunnistada, et ei pidanud 100k jaoks väga punnitama, T29 päris äge masin.
Ertai
08.05.2012 13:56:14
| tondu kirjutas: |
Tere!
Tändu ette! |
oleneb palju sul raha kulutada on
tyoe 59 on u 26euri ja päris äge.
võid ka osta churchill või valentine'i, ka funid imho.
miskid asjad olid veel funid ja hetkel gift shopis 5-6 euro ringis (+ saad kulda ka)
47 |
gemini
08.05.2012 14:18:59
| tondu kirjutas: |
Tere!
Tändu ette! |
Giftshopist osta kohe siis paar Type 59-t ära: http://worldoftanks.eu/news/2286-special-gift-shop-offers/
EDIT:
Kas KV-5 saigi nüüd rear-armor buffi ehk 140mm rear platel?
61 |
Ertai
08.05.2012 14:20:01
Oskate soovitada nüüd 100% KV2-le crew perke vmt?
Mõtlesin veidi, esialgu selline idee siis:
komandör : kuues meel
sihtur: snaiper
juht: siduriga keeramine? tangi pöördekiirus suureneb) või siis remonditööd (kiirem parandamine) või maastikusõitja ?
radist: olukorrataju või siis relvavennad
laadija: relvavennad või remonditööd
laadija2: sama ?
47 |
AC7
08.05.2012 14:23:40
Kurat hommikul ei tasu ikka neid ostuvärke teha (olen õhtuses vahetuses ja ärkan hilja). Ma ei tea, kust ma selle idee sain, et T59 on 2000 kulda(mõtlesin küll, et kuidagi liiga odav, aga noh... ). Ja ostsingi 2500kulda 10€ eest ja siis mõtlesin, et kust ma selle T59 nüüd saan, mängusiseses poes ei olnud. Siis läksin tagasi gift shopi ja etskae 29.95€
MorRAW
Ei ole Guru
317 |
Yankuonu
08.05.2012 14:45:36
| AC7 kirjutas: |
Kurat hommikul ei tasu ikka neid ostuvärke teha (olen õhtuses vahetuses ja ärkan hilja). Ma ei tea, kust ma selle idee sain, et T59 on 2000 kulda(mõtlesin küll, et kuidagi liiga odav, aga noh... ). Ja ostsingi 2500kulda 10€ eest ja siis mõtlesin, et kust ma selle T59 nüüd saan, mängusiseses poes ei olnud. Siis läksin tagasi gift shopi ja etskae 29.95€   |
Relvavennad esimeseks kõigile siis kui saad kohe 100%
Relvavennad töötab vaid siis kui kõigil meeskonna liikmetele see 100% muidu istuvad tühja. Teiseks panen ise enamus tankidel ikka paranduses sest ei viitsi mängu lõpuni lint maas kusagil passida
Edit: Morrow the Ninja
_________________ "You cannot judge me. I am Justice itself!" |
Valvejoodik
08.05.2012 14:57:28
Oot, kas Venelased said omale premium TD? (SU-100Y)
15 |
| Kommentaarid: 85 loe/lisa |
gemini
08.05.2012 15:09:05
| Valvejoodik kirjutas: |
Oot, kas Venelased said omale premium TD? (SU-100Y)  |
Hetkel veel mitte. Seda tanki pole isegi veel Tankopedias kirjas.
Samas - kas varem olid EU Tankopedias kirjas Hiina premiumid Type 62 ja WZ-111? Mu meelest oli eelmise patchi ajal seal listis ainult Type-59... seega võiks eeldada et lähiajal kavatseb WG rahamasinale veelgi tuure juurde lükata ja Type 62 & WZ-111 EU-s müüki lükata.
61 |
vipu
08.05.2012 15:18:54
vaatasin et selle kupongiga on kõik lisad poole odavamad, 250k saab siis co2 kütusepaagi osta.
neid pesasid võiks juba rohkem olla kui 3. ostaks kõik lisad tankidel ära
Dumbass
08.05.2012 15:30:33
See, et vastast ammorackides nüüd damage kõrvale vastav märk tuleb, on vahva
EDIT: Ja see *ping* käib ajudele, neil oli vaja oma organisatsiooni kõige kellimat ja olulisemat masinat, mis teeb *ping*.
_________________ Fortuna non penis in manu non recipe.
Mitme arvuti vahel failide syncimiseks kasuta lihtsat ja mugavat Dropbox-i (ning toeta minu ja sinu dropboxi 500 megabaidise boostiga ).
viimati muutis Dumbass 08.05.2012 15:51:35, muudetud 1 kord |
| Kommentaarid: 8 loe/lisa |
erick
08.05.2012 15:50:16
| Scart kirjutas: |
Hiinakas on müügis ja just ostsin  |
Sama siin. Täna vist Type-uputus serverites.
96 |
Ertai
08.05.2012 15:58:15
| vipu kirjutas: |
neid pesasid võiks juba rohkem olla kui 3. ostaks kõik lisad tankidel ära  |
asi pole kupongis, vaid venemaa pühadega.
11ndani peaks saama kõik lisad poole hinnaga
47 |
-Vertigo-
08.05.2012 16:35:11
Suht huvitav on vaadata, kuidas osad mängivad IS-4jaga millel on 122-D25t
Yankuonu
08.05.2012 16:39:37
| -Vertigo- kirjutas: |
Suht huvitav on vaadata, kuidas osad mängivad IS-4jaga millel on 122-D25t  |
kerge saak mu loltractoritele
K3ndu
08.05.2012 16:40:10
Mida eelistate?
KV-2 või T-150?
122 |
vipu
08.05.2012 16:51:45
| Dumbass kirjutas: |
EDIT: Ja see *ping* käib ajudele, neil oli vaja oma organisatsiooni kõige kellimat ja olulisemat masinat, mis teeb *ping*. |
see märk on koguaeg olnud, seadetes sai valida.
käärpikpsilm on väga hea asi, kohe teravam nägemine.
hannes36
08.05.2012 17:14:22
Type on loom siis kui tal 100% mehed peal, liikumiseks vajalikud skillid olemas ja moodulid küljes. Enda omal on vent+rammer+vert. stabil. Skillidest on meeles siduriga pööramine. 3 tüüpi platoonis suruvad enamik olukordi ära. Nukatagant nokimiseks ta ei kõlba ja esimene ammorack on vastik asi. Viimasel ajal on põlema kaa lastud väga kergelt Minu silmis parim prem tank
_________________ minu lugupeetus |
| Kommentaarid: 121 loe/lisa |
111 |
