kaupmees
03.05.2012 10:15:36
Excel pdf |
| Kuidas teha excelisse nuppukest mida vajutades salvestaks kõik sheet'id kindlaks määratud kausta pdf failidena, iga sheet eraldi fail.
HA
03.05.2012 13:50:17
Excel
Click the Microsoft Office Button, point to the arrow next to Save As, and then click PDF or XPS.
In the File Name list, type or select a name for the workbook.
In the Save as type list, click PDF.
If you want to open the file immediately after saving it, select the Open file after publishing check box. This check box is available only if you have a PDF reader installed on your computer.
Next to Optimize for, do one of the following, depending on whether file size or print quality is more important to you:
If the workbook requires high print quality, click Standard (publishing online and printing).
If the print quality is less important than file size, click Minimum size (publishing online).
To specify various options for the file, click Options. (Find links to more information on these options in the See Also section.) Click OK.
Click Publish.
If you want to make changes to the PDF after saving it, return to your original 2007 Microsoft Office system file in which you created it and save the file as PDF again. To learn more, see Learn about PDF and XPS file formats. |
Niipalju kui proovisin praegu, saab teha iga sheeti eraldi leheküljele...aga eraldi faili ei õnnestunud
121 |
warwas
03.05.2012 15:12:49
| suure tõenäosusega aitab siin hädast välja väike VBA's kirjutatud macro.
224 |
alfreedo
kaupmees
04.05.2012 13:24:20
| Excel suudab ja mul teha pdf, aga mul vaja korraga teha üle 30 sheet'i pdf vaile. Üks haaval jama teha.Saaks ühe nupuvajutusega kõik lehed teha.
alfreedo
04.05.2012 14:54:24
See ju teeb ühe nupuvajutusega.
Kas sul on need "sheedid" erinevates failides?
A.S.
04.05.2012 15:34:41
Inimene tahab seal macros ilmselt näha midagi sellist:
For Each Worksheet In Worksheets
SuvalineSheet.ExportAsFixedFormat Type:=xlTypePDF, Filename:="kaustanimi" & Worksheet.Name, Quality:=xlQualityStandard (või midagi enamat), IncludeDocProperties:=True, IgnorePrintAreas:=False
Vist? Ega mina ei tea, minu Excel PDF faili ei salvesta.
| Kommentaarid: 34 loe/lisa |
34 |
kaupmees
07.05.2012 08:47:06
| Jah need sheet'id on ühes failis
alfreedo
07.05.2012 20:11:05
| Mida see minu antud kood Sul siis valesti teeb?
A.S.
07.05.2012 20:23:45
| Äkki inimene lihtsalt ei taha üht täiesti mõttetut lisaprogrammi installida? Ei oska paraku arvata, millise kvaliteediga PDF faile see Excel omaenese tarkusest teeb, ehk oleks tõesti PDFGreator parem?
34 |
alfreedo
07.05.2012 23:06:26
Lisatud Exceli fail sisaldab makrot, mille käivitamisel avatakse PDFGreator ja antakse talle käsk Exceli lehtedest: Sheet2, Sheet3, Sheet4 teha ued PDF failid.
Kuna Sheet1 sisaldab "Käsunuppu" siis selle lehe printimist ei toimu.
Testitud ja töötas Excel 2003 ja Excel 2010-s.
Käivitades otse PDFGreatori (mida vist kaupmees püüdis teha) siis jah prinditakse ainult üks - esimene Sheet.
Kohe ei leidnud ja pole ka aega otsida seal seadetest mitme lehe print võimalust.
Samas Excel 2010-s on käsu SaveAs all võimalus salvesteda lehed PDF-ks.
Aga salvestab kõik Exceli faili Sheedid üheks pikaks PDF failiks? (Jällegi pole aega uurida eri võimalusi.)
AS! Millist Exceli versiooni kasutad?
kaupmees
08.05.2012 09:00:40
| Ühes arvutis on 2007 ja teises 2010
alfreedo
08.05.2012 20:03:23
Proovisin ka Excel 2007 lisades eelnevalt Excelisse 40 lehte.
Kood töötas.
Kaupmees.
Seleta üksikasjalikult mida teed ja mis juhtub.
Kas Sa makro ikka käivitad?
