Players who pre-order TERA can create a single character to play in the Open Beta Test and that will carry over through launch. Make sure your perfect character is right there waiting for you when the beta begins.
Open Beta Test
Pre-Order Exclusive Event
Begins: Thursday, April 19 at 12:00 PM Pacific
Ends: Friday, April 20 at 11:59 PM Pacific
Open Event
Begins: Friday, April 20 at 12:00 PM Pacific
Ends: Monday, April 23 at 11:59 PM Pacific
Details:
Characters per Account: 1 per Server
Maximum Level: 32
Servers: TBD
See the game before it launches, including a brand new introduction to the Island of Dawn. Create characters that will carry over through launch. Help us polish TERA until it shines.
Head Start
Begins: Saturday, April 28 at 12:00 PM Pacific
Details:
Characters per Account: 8 per Server
Maximum Level: 38
Servers: TBD
Continue where you left off in the Open Beta Test and become a veteran before others even get their boots wet. Blaze the trails from Velika to Val Kaeli. Be the first to see a new world.
See ei ole uudne combat. Real-time action kui selline on küllaltki vana concept.
Üks vanemaid näited on Phantasy Stari MMORPG. Ning üks hilisemaid on Monster Hunter Frontier.
Combat meeldis küll.
Loodan et endgame meeldib ka, aga eks seda saab mängu käigus teada.
Closed betat sai üks nädalavahetus taotud. OB teen ka kindlasti, siis vaaatab kas ostan. Tundus nats etem olema, oma sihtimise süsteemiga. Graafika poolest väga palju Aionist parem ei olnud. _________________ www.simracing.ee
Selge - MMORPG valdkonnas pole see siis üldse uudne. Huvitav, et enamus MMORPGd mida ma proovinud olen käivad järgnevalt - Vali target klõpsi kõik nupud läbi ja vali uus target + hüppa suvaliselt 2 meetri kõrgusele koguaeg. Reaalselt midagi sihtima pole kunagi pidanud.
Ise arvan, et TERAst tuleb väga korralik MMORPG. kahjuks endal pole ilmselt aega, et tõsisemalt mängida, aga ära tahan kindlsti proovida.
Ma plaanin hetkel NA PvP serverisse Valley of Titans minna, kuhu ise?
Kui keegi siin MMO-sid viimasel ajal jälginud on, siis peaks ikka teadma, et kõik on puhas fail. RIFT-ist on saanud enamvähem asja, teistel on end-game täiesti 0. Pärast launchi ootan juba siin fanboide poste kus tahetakse account maha müüa. Standard.
Juba videodest on näha, et liikumine on ebamugav, milleks seda üldse proovidagi. UI on kohutav. True Action Combat LOL - nagu Age of Conanis oli vibuga laskmine, või Darkfall, mingi väike lag ja gg, või kui siis pigem asi ehitatud nii, et iga lammas saab siiski oma spelle sulle pihta aimida niiet see nn "skill" kaob sellest mängust ära mida siin videodest promotakse. Päris uus feature tõesti, kahju et failib juba.
Mõnusat grindimst
Kurb, et su tops alati pool tühi on. Tasub ikka proovida enne kui laitma hakkad. Ise küll mingite videode põhjal ei otsusta.
Ma pole ise viimane aasta jagu üldse uurind mis sellest TERAst saanud on, aga kunagi ammu kui uurisin tundus endgame päris huvitav. Sellest on muidugu kahju, et nad need "instance"id sisse panid- rikuvad minu arust üsna palju PvP'd. Endale meeldib just see, et pole mingit rasside vahelist sõda vaid kujunevad välja klannid, kas võitlevad võimu üle. Kui mingi castle siege'i moodi asi ka sisse tuleks nagu L2 on siis oleks .
Mõnusat grindimst
Liikumise kohta küll midagi halba ei ütleks. Olen seda mänginud ja liikumine palju mugavam, sujuvam ja arusaadavam kui aion või rift. Kui ringi liigud ja võitled ei ole sul hiire kursorit. Kursor ilmub alles siis kui vajutad escape, avad mingi akna või räägid juttu mõne questionkliga. Kombat oli ka mõnusam, võtad mingi venna sihikule ja annad sinnapoole tuld. Oled liiga kaugel, pihta ei saa, spell haihtub ennem kohalejõudmist. Lased 20m pealt, vend astub sammu kõrvale ja möödas.. Ilmub mingi vend teepeale ette, saab hoopis tema pihta ja nüüd on sul vaja muretseda kahe värdja pärast. Olen mmodes tundnud puudust korralikest aoe spellidest. Tundub, et siis nüüd üks mäng, kus nendest mingit tolku ja saad hakata korraga suuremaid hunnikuid mobe maha võtma. Skillid tundusid ka suht loogilised olema, ja ei olnud nii nagu mujal et iga leveliga saad 5 uut spelli, millega sittagi pole teha. Enamus useless ja ei mahu sul shortcuttidesse äragi. Mana taastumine tundus ok. Aionis nt. pidid 5min. istuma, et full mana saada. End gamest ei oska midagi arvata. 2 nädalaga teed max ära ja siis.... No midagi peab ikka toimuma ka kuna enamus oleks quit ju 2 nädalaga.
Proovisin uudishimust mingit betat paar nädalat tagasi. Jõudsin levelini 15 või 16 suhteliselt kiiresti, edasiseks huvi puudus. Combat... nojah, osad võivad ju väga võlutud olla sellest ilma targetlockita süsteemist ja sellel polegi midagi viga, täitsa tore vaheldus. Samas see üksi ei tee mängu veel piisavalt heaks. Kõik rikub minu jaoks viis kuidas iga skilli kasutamine juurutab su toredasti maa külge kinni. Aastal 2005.. nojah.. ok, aga 2012? Mäletan sarnaseid skille Lotrost ja Aionist, aga seal olid need mõned üksikud, Teras tundub see olema enamus. Ma lepiks sellega, kui ma lihtsalt interruptiks oma skilli castimist liikumisega, aga et see lihtsalt ei lase mul liikuda ja naelutab mu paigale - ei tänan.
UI oli ok ja hästi kohandatav nagu tänapäeva UI'st võiks oodata. Maailm paistis piisavalt suur, graafika ok, aga värvid olid küll üle keeratud. Questid... seal pole midagi kommenteerida, vana nüri "mine laagrisse, korja tapa 10 x-mobi, anna quest sisse, mine räägi tüübiga järgmises laagris" süsteem. Isegi sellise süsteemi puhul olen teistes mmo'des pisut rohkem loovust näinud.
Kui ma tahan endgame ja raidimist, siis Rift on selleks piisavalt kobe, kui ma tahan "voolavat combatit" siis vaataks GW2 suunas, sest seal ei sega ükski skill sinu liikumist ja valdav osa on kasutatavad liikumise pealt.
Aga eks igaühele oma või muidu oleks meil vaid 1 mäng, mida kõik mängiks ja rohkema järgi vajadus puuduks
Mängisin kahel eelneval beta nädalavahetusel ja plaanin omale mängu soetada. Castanic male slayer siis, serveri osas...valin tõenäoliselt serveri mis iganes saab "main pvp" serveriks
Hea kuulda.
Ise teen Human male lancer ja plaanis ka sõbraga koos klanni teha, hetkel meid rohkem pole .
Kui huvi pakub, siis siin meie vana L2 klanni leht. http://clan-inferno.forumclan.net/
Pigem oleks lootnud et saaks püsiva grupi kokku kellega koos leveleid koguda.
Viimane nädalavahetus oli päris mitu üsna meeldivat kogemust grupis koos mängides, üks siis kus koos lanceri ja teise slayeriga kus sain enamuse lvl 22 - 26 questidest ära teha (was kinda tough to fight all those big ass monsters solo) ja hiljem siis leidsin ühe väga laheda grupi Sinestral Manor dungeoni jaoks. Käisime päris mitu korda sealt läbi, iga korraga järjest efektiivsemalt.
Mulle täitsa meeldis Tera juures see, et grupid olid 5 liikmega piiratud. Grupis saaks ka tõenäoliselt kiiremini levelid üles.
Ma arvan, et ma ei ole hetkel piisavalt aktiivne, et püsivat gruppi kellagagi teha.
Kui kõigil grupi liikmetel 3-4 tundi, samal ajal, igal õhtul, aega siis oleks super jah.
1. Log in to your En Masse account.
2. Click the Enter Code button on the right.
3. Enter the Open Beta Test code: TERABETA
4. Click the Submit button.
5. Click the Download Game button under the Account Overview tab.
Ah... mis seal ikka ostan ka selle ära siis. Jalgpallijumal oli täna lahke. Arvatavasti teen Priesti.
Hea kuulda, ise otsin eile ära siis ja plaanis teha siis Jagged Coast serverisse Lancer, üks sõber teeb Mysticu.
Hmm, ma kuulsin et see "JC is the official pvp server!" kampaania oli korraldatud pigem guildide poolt kes ei saanud Valley of Titansis hakkama ja tegelikult kõik suured guildid lähevad ikka VoT serverisse. Nädal veel ju aega alguseni, äkki selgineb see olukord veel veidi. Isiklikult eelistaks praegu küll VoT serverit.
Ja lihtsalt nii huvipärast küsiks, te kõik räägite siin NA serveritest ja plaanin ise ka seal mängida kuid samas on ju ka olemas EU serverid mis lähevad üles enam-vähem samal ajal, miks te seal ei plaani mängida?
Kogu selles teemas olev info on senini olnud NA serverite kohta.
Minul endal on varasem MMORPG kogemus ainult NA serveritega ja Tera puhul otsustasin NA kasuks, sest ameerika omas haldab mängu sama firma kes selle tegi euroopas aga mingi teine firma (kelle kohta olen üsna palju negatiivseid asju kuulnud). + hinnavahe, dollarid on otse üle eurideks tõmmatud. NA omas võib ka kindel olla, et kõik räägivad inglise keeles.
Leidsin ühe yutube'i kanali kus on üsna palju asjalikku infot Tera kohta, panen mõned lingid siia juhul kui kedagi huvitab:
Võtsin Eurogameri closed beta key, regasin antud lingil ära, aga sisse logida ei saa - ütleb "submitting" ja lööb algusesse tagasi. Koodi sisestada ei lase, clienti tõmbamisest rääkimata. Mis jama on?
Ootasin juba ammu, et keegi T.E.R.A. teema teeks. Ise olin selleks liiga laisk . Sai ka beta teste tehtud. Proovisin vibumeest ja warriori. Vibuga oli päris lahe lasta. Ses suhtes oli päris huvitav, et ranged AOE tehes peab ikka distance jälgima ja korralikult sihtima. Muidu graafika on kena, eriti kaugel olevad mäed ja nii edasi, aga see teksti font on küll kole. Võibolla saab seda kuidagi muuta, aga ma ei leidnud üles kuidas seda teha.
Mulle tundub, et AION läks meelega Free2play peale, sest paljud AION-i mängijad ootasid TERA-t juba pikisilmi, aga nüüd on nii mõnigi ümber mõelnud, sest AION-is jälle kõvasti rahvast ja pole enam igav. Nagu teada NCSoft on koguaeg TERAle kaikaid kodaratesse loopinud. Siiamaani kohtucased üleval.
Ega need BETA testid pole koguaeg. need tavaliselt üle 2 nädala reede,laupäev, pühapäev. Seepärast ei saagi tõmmata, ega midagi muud teha. _________________ Värsked mõtted tulevad siis, kui postitus tehtud...
Ma arvan, et sa pole veel seda confirmation maili saanud ja seetõttu ei ole su konto ka aktiiven tera lehel. Ma tegin mõni aeg tagasi seal konto ja nüüd praegu ka kui kood olemas oli. Sain ennem vana konto parooli taastamiseks emaili (kuigi seegi võttis mõne minuti aega) ennem kui uue konto confirmation meili sain...tegelt pole siiani seda veel saanud. Panin koodi sisse ja kõik toimib, laseb alla laadida jne.
Saan proovida kui märgatav pingi vahe on ja vaadata castanic tegelase animatsioonid üle.
Ma usun, et "Valley of Titans" teema tehti lihtsalt algajate lollitamiseks, et nad "Jagged Coast" ei ülerahvastaks, aga eks mängus näha ole, igasse serverisse saab ju 8 accounti teha
Tavaliselt antakse pärast registreerimist confirmation emailist teada, mis saadetakse kas siis kohe või äärmisel juhul paari minuti jooksul. Igatahahes nüüd on juba tund aega möödas, aga vastust pole. Suhteliselt segane värk. Samal ajal oli postkastis küll En Masse Entertainment poolt (mis asi see veel on?) TERA Open Beta game code inside! mail, aga seal sama lugu - palutakse jälle regada ja teine key sisestada:
To start your TERA adventure:
1. Create your En Masse account at https://account.enmasse.com.
2. Use the “Enter Code” feature on the Account Overview page to type in your game code:
3. Download TERA from the Account Overview page and install.
4. Play TERA!
Make sure to start downloading the game well ahead of time so you're ready to play when the Open Beta Test starts on April 20.
1. punkti tegin ära, aga Account Overview lehekülg on siiani mõistatus.
Samas antakse teada, et clienti tõmbamine on koheselt võimalik. Siiani pole ühegi mängu või MMO betaga sellist jama olnud, kõik on toiminud. Aga nüüd on küll sein ees...
4. Play TERA!
Enmasse on see kes on NA tera eest vastutav. EU tera eest vastutab teine firma nimega Frogster. Nagu üleval pool mainisin olen üsna palju negatiivseid asju nende kohta kuulnud(just see kuidas nad klientidega käituvad ja abistavad kui probleeme on) ja see juhus siin on üsna hea näide vist sellest.
Kui ma esimest korda mängisin siis tegin algajavea ja ei pannud esimest Story questi tähele (punased hüüumärgid), neid ei tohi mingil juhul vahele jätte.
haha20 kirjutas:
ehh, kõik suuremad guildid mängisid ju VoT serveris CBT ajal, kui lollitamisest rääkida siis tundub just, et tahetakse VoT serverist rahvast vähemaks saada. Samas suurte guildide koha pealt olen ma ka üsna clueless praegu.
Näiteks Sinistral Swarm guildi ventrinos on selline channel nagu "Jagged Coast", kuigi nad ise mängisid betas VoT.
niiet kõik siit on soetanud usa vers.? aga kas siis ei teki probleeme sellega et ülejäänud serveri rahvas magab samalajal kui me mängime? _________________ www.simracing.ee
Julgen pakkuda, et ameerika serverites on inimesi tunduvalt rohkem kui euroopa omas ja isegi siis kui neid "vähe" serveris on peaks siiski rahvast üsna palju ringi liikuma. Minu eelnev mmorpg kogemus oli 4 a tagasi ja ma olen võibolla out of touch kuid siis ei olnud küll nagu probleeme sellega. Kindlasti leidub ka teisi eurooplasi kes on sinna samadel põhjustel migreerunud. Lõpuks on see siiski su oma valik.
Open beta ajal võib ajavöönd isegi suureks plussiks olla.
haha20 kirjutas:
Probleem ongi praegu see, et ma olen mmorgp maailmast nii kaua eemal olnud, et mulle ei ütle ükski guildi nimi midagi
Kuid üleüldiselt kui olen erinevaid foorumeid lugenud ja inimeste käest küsinud siis tundub siiski, et VoT on see peamine.
Ma mängisin slayerit ja ei kogenud küll otseselt, et see oleks kuidagi seganud. Eks ma see nv saan euroopa oma proovida ja tean täpselt kui suur vahe on. Pidin üsna tihti õigel ajal rünnaku eest ära hüppama ja sellega probleeme ei olnud.
Ma eile soetasin usa vers.
Võib tekkida probleeme jah, et vahel vaja kell 5.00 ärgata, kui tahad mingist evendist osa võtta, nt. praegu "Early character creation" event juba sellisel kellaajal.
Tundub, et neil hetkel suveaeg -7 ja meil +3. seega oleme me 10 tundi eespool hetkel.
Mis muidu PvPst saanud on? Ise lootsin pikalt et tuleb L2 stiilis PvP (ehk siis PK süsteemiga - tapad kõik maha keda tahad, aga pead arvestama tagajärgedega), aga tundub, et PvP on hoopis nii, et võid kõiki tappa, kes vastu tulevad ja sinuga ei juhtu midagi?
Praegu on jama jah, saab PK igalpool ja siis safe zone hüpata.
Ma loodan, et tulevikus ikka pannake PK-mise eest mingi suurem risk, kui lihtsalt see, et teised inimesed ei respecti sind.
Linna guardid võiks ka rünnata PK-jaid, et nad ei saaks safe zones istuda.
http://tera.enmasse.com/game-guide/pvp/
PK is short for "Player Kill," and works exactly like it sounds.
At level 11 (on PvP servers only) you obtain a skill that lets you declare yourself an "outlaw."
You can then try to kill any player above level 11.
However, when you are an outlaw, any player can try to kill you as well.
kuidas sa saad see nv proovida? see nv on ju ainult 1 characteri tegemine võimalik ja preorderitele OB algab alles 19.
euro ja ameerika versioonide closed betad toimuvad vaheldumisi, eelmine nädalavahetus oli ameerika closed beta ja see nädalavahetus on euroopa oma. See on ka esimene kord kui ma sain euroopa oma jaoks ligipääsu.
http://contest.mmosite.com/index.php/activity/sendkey/tera_cbt5_beta_key_giveaway regad ära, lähed seal mingi mängu automaadiga mängima. kõigil vist mingid foorum puntkid mis saad mängu coinideks teha, tõmbad yhe korra kangi. lähed leht tagasi, vajutad finish, teed sellele esimesele lehele refreshi. ja vajutad get key. Jube keeruline oli, võttis aega mingi 10 min aga hakkama sain. 420 keyd alles hetkel.
Tõsine värk Mul kahjuks sel eu betal ei ole aega osaleda.
Aga see PvP serveri valimine on nii segaseks aetud, ei tea ise ka enam kas VoT või JC.
Nüüd tundub juba VoT ikkagi, kuhu organiseeritud klannid lähevad.
Aega on veel, usun et see serveri asi on arusaadavam kui aeg lähemale jõuab. Seniks võid ju tegelase igale serverile omale valmis teha.
EU closed beta serverid on üleval nüüd ja tegin oma tegelase sinna ära ka, serveriks siis valisin esimese pvp serveri, Westonia. Saatke sõnum kui keegi veel seal on.
Üks Eu selle nädalavahetuse cbt kood vedeleb mailil
Eks kes proovida tahab/viitsib se võtku ja andku teada siin ka kui kasutatud : p
3YHMMAMK46YKHXR9YPA5G46TGERRWH6H
This key enables you to take part in the upcoming closed beta weekend from the 13th to 15th April.
HOW TO REDEEM YOUR KEY:
Go to http://account.tera-europe.com _________________ [img:]https://foorum.hinnavaatlus.ee/images/200x40_HV.gif[/img:]
Võtsin võtma ära. Suured tänud
Ei tea kas failidel on suur vahe (EU ja NA) Mul NA 50% tõmmatud.. .kas peaks algusest peale EU tõmbama või lasen NA lõpuni ja siis patchin üle vms?
Hmm, sain siis sealt algajate saarelt ära ja praeguste kogemust põhjal pean üllatunult tõdema, et euroopa omas olen hulga rohkem lagi kogenud. Päris mitmel korral tegelane lihtsalt ei reageerinud või oli hoopis teises kohas kui minu ekraani peal näitas. Isegi igaks juhuks kontrollisin 2x ega mul mingid torrentid lahti ei ole
Kogemata unustasin default hääle ka oma tegelasele ja nüüd see teeb ainult röhitsusi ja sarnaneb Beavis&Buttheadiga, that definitely got annoying fast.
