Viilutaja
13.02.2012 14:54:49
Võibolla on siit juba läbi jooksnud, kuid väga vinge lahing on kokku mixitud.
| Kommentaarid: 226 loe/lisa |
196 |
troglodyte
13.02.2012 17:15:08
Lahing on vinge, kahju ainult et lõpus mingi tobeda anime mõõgaga vehkima hakati.
_________________ ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn |
| Kommentaarid: 34 loe/lisa |
34 |
Viilutaja
13.02.2012 17:37:54
Ega need kahe käe mõõgad siin mängus paremad pole, mulle see just meeldis.
196 |
thenoob
14.02.2012 10:27:15
| troglodyte, tegelikult on see mõõk pärit mängust "Darksiders".
kuri orav
14.02.2012 14:58:26
Mõõk oli, jah, nagu leivalabida moodi rohkem.
_________________ “Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life.” -- Terry Pratchett |
lopes39
| Kommentaarid: 10 loe/lisa |
Leinö
33 |
lopes39
Leinö
15.02.2012 08:17:10
lopes39, kuhu lossi, mis quest? Kasuta kohanimesid ja questinimesid, muidu läheb aitamine keeruliseks.
Kiire googeldamine ütles mulle järgmised asjad:
How To Cure Vampirism
- If you’ve contracted the disease, you won’t become a vampire for three days. Until then, you can get rid of the disease with any common disease-curing potion.
- You can also use the Shrine to Talos outside Whiterun or Dragonsreach, activating the shrine will cure you of all diseases.
- Before speaking to anyone, make sure you’re no longer a Stage 4 vampire. Stage 4 vampires are attacked on sight, to avoid this, wait until night and drink the blood of a sleeping person. Even sleeping beggars will do. Just crouch/sneak and interact with a sleeping NPC to drink their blood.
- If you’re still having trouble drinking blood, remember that you have two useful abilities as a Stage 4 vampires — Embrace of Shadows, and Vampire Seduction. Embrace of Shadows turns you invisible, while Vampire Seduction will make an NPC calm and cease wanting to attack you.
- Once you’re a Stage 1 vampire, normal diseas cures will no longer work. You’ll need a better way.
- To begin your quest, speak with any Inn Keeper or Bartender about rumors. They’ll tell you that a man named Falion in Morthal is studying vampires.
- Find Morthal east of Fort Snowhawk. Once there, talk to Falion and he’ll discuss how to cure vampirism.
- He’ll tell you to get a Black Soul Gem. If you don’t have one, Falion will sell you one. Before being cured, you’ll need to fill the Black Soul Gem.
- To fill a Black Soul Gem, you’ll need to cast a Soul Trap spell on a human, then kill them. Any human will work, including bandits and enemies.
- You’ll need to obtain a Soul Trap spell, sold by any magic vendor. If you’re really desperate, try the College of Winterhold, or explore Whiterun to find a shop. If you don’t have high magic skills, just purchase a Soul Trap scroll. NOTE: The Mage for the Jarl of Whiterun, the Jarl’s Court Mage, should have a Soul Trap spell.
- With a filled Black Soul Gem, return to Falion and talk to him to complete the ritual.
You’re now cured of vampirism!
33 |
lopes39
Leinö
15.02.2012 18:31:35
With a filled Black Soul Gem, return to Falion and talk to him to complete the ritual. You’re now cured of vampirism!
33 |
lopes39
15.02.2012 22:18:41
on selles mängus võimalik muuta kella aega AM pealt PM peale ? kui ei ole siis kas selles mängus on mingi kindel kella aeg mis ajast mis ajani on öö ja mis ajast ajani inimesed magavad ?
loodan et see ei spoili kedagi
alustasin mingi paar päeva tagasi otsast peale et teha rohkem mängu ja vähem peamissioone ja hetkel on shout aintul need 2 esimest õppitavat aga level on 21
kusti85
Tavaline kasutaja
15.02.2012 23:13:06
Erm...alustasin eile. Olen level 2. AM/PM peale muutmine käib nii, et ootad mingis kohas (vajutad T tähte) ja teed valiku, mitme tunni võrra soovid aja edasinihkumist (nt 12). Ja kõigis ES mängudes minu arust tegelased magavad ikka öösiti ja päeval on üleval. Eranditega (vargad, bandiidid, mingid kindlad NPC-d). Öö on nagu ikka öösel ja päev päeva ajal. Muidu Oblivioniga võrreldes kõva saavutus see mäng. Veidi lihtne algus muidugi (masterina) Oblivioniga võrreldes.
_________________ Rockmuusikateemaline viktoriin Tallinnas - https://www.facebook.com/groups/rocktoriintallinn/
Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER |
| Kommentaarid: 220 loe/lisa |
184 |
thenoob
16.02.2012 00:16:14
| lopes39, kui mäletan, siis kas mitte "t" tähte vajutades ei tulnud ootamismenüü ette, kus valid aja kaua ootad. Ehk siis ntks kell on 9 hommikul, paned 12h ja siis on kell 9 õhtul jne.
lopes39
16.02.2012 01:15:52
| thenoob kirjutas: |
| lopes39, kui mäletan, siis kas mitte "t" tähte vajutades ei tulnud ootamismenüü ette, kus valid aja kaua ootad. Ehk siis ntks kell on 9 hommikul, paned 12h ja siis on kell 9 õhtul jne. |
no jah seda värki tean ma suht mitu päeva ja kasutand olen ka väga palju aga AM pealt ei sa PM peale üle et kella aeg oleks 13:00 kuni 23:59 ... vahepeal ei saa aru kas on hommik või õhtu
pidevalt vaja seda kasutada 24 tunni kaupa kuna see e**** and shadow värki saab korra päevas kasutada mis mul kadus valikute seast ära peale mingit missiooni
need controls teemad võiks ka ära save-da mängus mitte ei pea iga kord kui mängu alustada neid sättima mis on eriti tüütu ... näitab küll et save aga ikka nagu kui mängust välja minna ja sisse tagasi siis on paigast ära jälle
shout nuppu vahetan aint sest see on Z nupp mis asub väga ebamugavas kohas ja mugavam on mouse4
rainisk
16.02.2012 11:30:10
mul väike mure, et pean investigate bards college tegema aga ei ole seda valikutki sellel tüübil kellelt pean seda küsima.
_________________ ( -_・) ︻デ═一 ▸ |
| Kommentaarid: 23 loe/lisa |
18 |
16.02.2012 13:09:33
lopes39, ametlik versioon ikka? Mängu seaded on muidu salvestustest täiesti eraldiseisvad ning salvestuvad alati peale nende muutmist.
rainisk, aga mine sinna lihtsalt kohale ja aja tüüpidega juttu nendega ühinemise suhtes?
158 |
rainisk
16.02.2012 14:44:32
Ma olen nendega ühinenud juba ammu
Ja kuidas ma sellelt Forswonilt hearti kätte saan?
18 |
Hazar
16.02.2012 18:33:35
Eelmine nädal lasti creation kit välja, praeguses seisundis sellega eriti midagi teha ei saa (tõsiseid buge otsast otsani täis)
| Kommentaarid: 29 loe/lisa |
28 |
lopes39
Leinö
33 |
kaabakas
16.02.2012 22:25:14
Bugiseid queste leiab üldse palju, harju workaroundide otsimisega ära.
96 |
lopes39
libe
kvaliteetne mees
16.02.2012 22:29:42
selle vastu aitab järgmine fix
| Esbern's voicelessness can be fixed by getting a Voice mod for Esbern. Download the zip file here: ftp://ftp.gamesdot.org/mods/estbern-fix-sound.zip and then Extract it to your desktop so that you can Copy and Paste it in to the Data folder (within folder The Elder Scrolls V Skyrim. This will fix all Esbern's voice issues. |
endal oli sama jant, kuid selle fixiga töötas korralikult
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
lopes39
16.02.2012 22:52:53
mind väga ei sega et tal häält pole sest kirja tuleb ikka mida ma üldiselt loen rohkem kui kuulan
aga mingid mode võiks küll peale panna mis relvi ja maagiat juurde paneks
mingi mod oli kuskil 3.15GB mida selle suuruse pärast väga uurida ei viitsind
hetkel veel tegemist küllalt seal mängus
