[Pec]
20.01.2012 14:40:17
Google'i eesmärk ei ole teenida tulu pira jagamise/hostimisega. Megauploadi eesmärk aga täpselt see oligi. Kui natuke süvenenult lugeda, siis tekib palju vähem küsimusi ja tahtmist demagoogitseda.
On or about April 23, 2009, DOTCOM sent an e-mail message to VANDER KOLK, ORTMANN, and BENCKO in which he complained about the deletion of URLlinks in response to infringement notices from the copyright holders. In the message, DOTCOMstated that “I told you many times not to delete links that are reported in batches of thousandsfrom insignificant sources. I would say that those infringement reports from MEXICO of “14,000” links would fall into that category. And the fact that we lost significant revenuebecause of it justifies my reaction.”
On or about April 24, 2009, DOTCOM sent an e-mail to BENCKO,ORTMANN, and VAN DER KOLK indicating, “I remembered the steep drop of revenue at thesame time in 2008 and thought that this might have also been caused by careless mass link deletions. This made me very mad, especially because I told you that such mass deletions shouldbe prevented and sources checked much more carefully. I am sure such mass link deletions arealso contributing to a drop of revenue … In the future please do not delete thousands of links atones from a single source unless it comes from a major organization in the US.” |
| Kommentaarid: 19 loe/lisa |
18 |
Leinö
20.01.2012 14:43:17
Milles probleem on. Puhastagu pirast ja kõik on korras. Milleks selline teatraalsus USA poolt?
Või proovivad konfiskeeritud varade müümisega oma riigivõlga katta?
| Kommentaarid: 34 loe/lisa |
33 |
sakinaga
20.01.2012 14:44:18
Lugesid ka kirjasid, mis post ülevalpool olid? Nende eesmärk oligi piraatluse pealt teenida, plain and simple, nad ei soovinudki faile kustutada.
| Kommentaarid: 159 loe/lisa |
151 |
Ho Ho
20.01.2012 14:47:53
| In the future please do not delete thousands of links atones from a single source unless it comes from a major organization in the US |
Sisuliselt oli ta probleem selles, et töötajad kippusid iga väiksemagi nurina peale asju serveritest eemaldama ilma kontrollimata kas selleks üldse mõjuv põhjus oli.
Muidu kohalikud FTP'd töötavad samal põhimõttel. Mingi aeg sai serveri haldajatega suheldud sel teemal ning nad rõõmsalt rääkisid kuidas sealt asju eemaldavad. Tol hetkel oli suht koomiline näha kui klaabu näitas, et mõnes serveris olid seal seisnud juba mitu aastat.
86 |
Leinö
20.01.2012 14:49:54
maatriks, in this case, trahv plus pira eemaldamine ja hoiatus. Selleks ei pea kogu lehte kinni panema
Seal on ikka väga palju legaalset materjali ka üleval.
FBI pani küll tiba puusse sellega. Sellises riigis, kus minnakse liiga kuuma kohvi pärast ka kohtusse, võiks keegi FBI vastu minna ja mõnusa nõude esitada ilma loata OMA failide konfiskeerimises.
viimati muutis Leinö 20.01.2012 14:52:38, muudetud 1 kord |
33 |
sakinaga
20.01.2012 14:50:07
Ho Ho, pigem oli ta mure selles, et töötajad eemaldasid piraatkraami väikse soovi peale, mitte ei ignoreerinud neid, saamaks suuremat tulu. "major USA organization"id peavad sellist asja menetlema ja aega kulub palju rohkem, lisaks ei jõua need organisatsioonid kindlasti kõikjale.
Kokkuvõtteks: Piraatfaile ei kustutatud suurema kasumi nimel, mingit muud tagapõhja seal ei olnud.
151 |
olavsu1
külaline
20.01.2012 14:51:19
| Bluebull kirjutas: |
Lihtsalt otsi koht, kus linke levitatakse ja on paari minutiga film olemas. |
Nii sain mina toimivaid draivereid. vista oli viimane millele sealt draivereid sai. Nüüd win7 peal peab leppima poolikute, ilma midi ja wavetable võimaluseta draiveritega. Teevad kuuldavaks paugud arvutimängus kuid muusika jaoks ei kõlba. Egas midagi tuli sünt osta, psr-e423 sai valitud. Sellegi draiver on piiratud võimalustega kuid asja heli on parem kui helikaardil.
20.01.2012 14:59:30
Failide hostimisel ja neile viitamisel on suur vahe.
_________________ MÜÜA: Xbox 360 E 250GB (UUS) |
313 |
Ho Ho
20.01.2012 15:00:26
| maatriks kirjutas: |
| töötajad eemaldasid piraatkraami väikse soovi peale, mitte ei ignoreerinud neid |
Et siis oleks pidanud samamoodi käituma nagu YT's tihtipeale nähtud on kus autorite enda poolt stuudiotest eraldiseisvalt loodud nodi ära korjatakse?
| SKG kirjutas: |
| Failide hostimisel ja neile viitamisel on suur vahe. |
Nähtavasti mitte USA seadusandluse järgi
Muidugi pulli hakkab saama alles siis, kui piratebay liigub torrentite hostimiselt magnetlinkidele
86 |
Deadlock
20.01.2012 15:02:11
| olavsu1 kirjutas: |
Nii sain mina toimivaid draivereid. vista oli viimane millele sealt draivereid sai. Nüüd win7 peal peab leppima poolikute, ilma midi ja wavetable võimaluseta draiveritega. Teevad kuuldavaks paugud arvutimängus kuid muusika jaoks ei kõlba. Egas midagi tuli sünt osta, psr-e423 sai valitud. Sellegi draiver on piiratud võimalustega kuid asja heli on parem kui helikaardil. |
Ära nüüd muretse, ega megaupload'i programmeerijad su draivereid ei tootnud.
_________________ "Believe you can, believe you can't; either way, you're right." - Henry Ford |
| Kommentaarid: 8 loe/lisa |
kalluka
20.01.2012 15:06:52
Lihtsalt jube mõelda, mis kõik võib juhtuda kui need aktsioonid läbi lähevad
| Kommentaarid: 16 loe/lisa |
12 |
borru
20.01.2012 15:10:37
Jänkid võiks vähem sõdadele kulutada. Oleks kõigil hea olla seal ja poleks vaja selliseid idiootseid juhtumeid.
300a vana riik on ca 200 aastat sõjas olnud juba.
| Kommentaarid: 13 loe/lisa |
olavsu1
külaline
20.01.2012 15:18:44
Ära nüüd muretse, ega megaupload'i programmeerijad su draivereid ei tootnud. |
vähemalt oli seal korralik arhiiv, kus nad olid olemas.
Deadlock
20.01.2012 15:21:34
Loodus ei salli tühja kohta vms.
ottf
20.01.2012 16:08:00
Kokkuvõtteks: Piraatfaile ei kustutatud suurema kasumi nimel, mingit muud tagapõhja seal ei olnud. |
kõik jutt õige.
aga legaalseid faile nii ära võtta ei tohi - kõik.
SOPA PIPA ja kõik see muu sodi sellisel kujul ei ole lahendus!!!!!
tehku bill mis kohustab teenusepakkujat oma userit välja andma - kas see juba tegelikult ei eksisteer?
Et võetaks vastutusele isikud, mitte teenuse pakkujad.
trademaajauuessaaa sa ju ei pane BMW, AUDI või MB-d kinni ning ei konfiskeeri maailma kõikide inimeste autod kuna mingid debiilikud rullnokad nendega kihutavad ja seadust rikuvad?
see on sama hea ja ei ole mingi demagoogia... fuk it, kõike ei saa näha nii must-valgelt
viimati muutis ottf 20.01.2012 17:50:45, muudetud 1 kord |
| Kommentaarid: 6 loe/lisa |
sakinaga
20.01.2012 16:21:06
Kui teenusepakkuja teadlikult laseb levitada piraatkoopiaid suurema kasumi eesmärgil, siis miks peaks tema puhtaks jätma? Antud juhul ongi teenusepakkuja põhiline süüdlane.
151 |
prtv
20.01.2012 16:26:43
Kui ToS ütleb, et piraatmaterjali ei tohi üles laadida, ning DMCA käsuga MU failid ära kustutab, siis mina ei näe probleemi. Süüdi peaks jääma kasutaja, kes eiras ToS-i.
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
fox98
20.01.2012 16:27:48
youtube ka juba häkivad
20.01.2012 16:37:12
Mul tuleb ilusti lahti... hd taneli videod otse esilehel
HDTanel tähistas lemmikuna 3 tundi tagasi 2:44Lisa
Uncharted Golden Abyss - Nate and Sully Motion Capture FootageWatch as the actors behind Nathan Drake (Nolan North) and Victor "Sully" Sullivan (Richard McGonagle) bring their characters to life in this motion...
IGNentertainment 7,601 vaatamist |
| Kommentaarid: 92 loe/lisa |
79 |
313 |
prtv
20.01.2012 17:04:48
Kim Dotcom tundub vägagi rahul olevat.
_________________ |
73 |
20.01.2012 17:06:18
No ilmselgelt on tal elu lõpuni hea elu garanteeritud... kui juba selline masinapark mehel oli, ilmselgelt on teistest ettevõtmistest tal samasugune hea rahavoog voolamas + arved Šveitsi pankades jne...
79 |
prtv
73 |
MatchMaker
20.01.2012 17:22:25
Tõsi ta on.
Megauploadi reklaam kus esinevad kuulsused, kui keegi pole seda varem näinud.
20.01.2012 18:14:37
Ma tahaks näha, kuna hakkab nendele idiootidele kohale jõudma, et nad raiskavad oma täiesti mõttetu võitlusega rohkem raha kui võidavad.
Krt kui ikka toodad nii sita filmi või sarja, et keegi seda ei osta, siis ei tasu piraatlust süüdistada, vaid ennast.
Senimaani on kõik edukad sarjad/filmid toonud kulu mitmekordselt tagasi. Ja kui ei too, siis järelikult rahvast ei huvita.
| Kommentaarid: 39 loe/lisa |
