MacAivar
05.12.2011 14:48:57
Paistab et CM7 arendus on lõppenud, sest kogu CyanogenMod tiim ragistab Ice Cream Sandwitch ROMiga.
Modaco foorumis on tekkinud ka vastav jututeema...
Kommentaarid: 71 loe/lisa |
68 |
martin366
05.12.2011 14:51:50
MacAivar kirjutas: |
Modaco foorumis on tekkinud ka vastav jututeema... |
Bladeile on ka ICS oodata ?
Kommentaarid: 185 loe/lisa |
172 |
MacAivar
05.12.2011 14:57:53
Sain aru, et ICS tuleb ainult sellisel fännide poolt kokkunikerdatud kujul...
CM9 Progress Update
We’ve been hard at work on CM9 since Google released Android 4.0 (Ice Cream Sandwich) into the wild last month, and things are slowly starting to come together. Google did a great job with ICS and added some really awesome features which in some cases replace or deprecate functionality that we had in CM7, so we are reevaluating all of our customizations. A number of devices are already up and running with CM9, and the focus is currently on getting as many devices ready as we can. The first devices (besides the Nexus S, which you can already get from Koush’s section on ROM Manager) that we’ll have ready will mostly likely be devices based on OMAP4, MSM8660/7X30, and Exynos. We also have some Tegra2 tablets in the pipeline such as the Galaxy Tab 10.1 and Asus Transformer. Our goal is to provide continued support to all CM7 devices back to the QSD8250 series of devices such as the Nexus One. I don’t want to make any promises at this time, but that is the plan. And sorry Droid1 owners, we’re dropping support for you. Time to upgrade
There are a number of challenges that we are up against. Google has made some pretty major changes to the Android framework that break compatibility with older proprietary camera and graphics drivers in order to achieve some pretty insane performance, but I am confident that the team will be able to overcome these issues like we have in the past.
For those of you who like to build CM from source yourself, you probably know that the spin-up time when starting a CM7 build is absurdly long due to the high number of devices in our repository. Koush and Arcee have put together a solution to this problem that adds new devices on-demand to your local repository, saving on both bandwidth and the long startup time. Some other great enhancements are coming too, like a completely overhauled music app, a new file manager, and a new launcher based on stock 4.0.
If you have a Nexus S, you can check out the code and build for yourself today. More devices are on the way, and I’ll send out these status updates as we make more progress.
68 |
ninzor
05.12.2011 23:34:09
Modaco's on saadaval ICS Blade'ile, mis käivitub aga muud ta ei teegi.Bluetooth, gps, wifi, 3g, 2g, sensorid, kaamera,heli, jne. jne. ei tööta.
Kommentaarid: 220 loe/lisa |
190 |
yxkala
Kommentaarid: 6 loe/lisa |
martin366
06.12.2011 12:01:19
ninzor kirjutas: |
Modaco's on saadaval ICS Blade'ile, mis käivitub aga muud ta ei teegi.Bluetooth, gps, wifi, 3g, 2g, sensorid, kaamera,heli, jne. jne. ei tööta. |
Xperia X10-l on sama asi olemas Väga tore, et ikka arendus käib, tahaks küll juba ICS proovida
172 |
chesm6mmi
14.12.2011 22:45:47
Kui kedagi peaks huvitama siis üks zte blade üle, algusest peale olnud kummist ümbrises ja ekraanil kile, niiet väljanägemine on tutika lähedane, vanust tsipa alla aasta
Kommentaarid: 107 loe/lisa |
102 |
Metsjeesus
14.12.2011 22:57:10
Räägime rahast ka.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
Kommentaarid: 108 loe/lisa |
94 |
panic
Kommentaarid: 33 loe/lisa |
30 |
vortex
21.12.2011 01:07:49
Häkitud versioon.
Ja sellise raua peal tõeline piin.
Kommentaarid: 42 loe/lisa |
37 |
panic
21.12.2011 23:36:48
vortex kirjutas: |
Häkitud versioon.
Ja sellise raua peal tõeline piin. |
piin jah aga paar olulist lehte j2i selleta n2gemata.
30 |
MacAivar
24.12.2011 21:18:46
Häid jõule kõigile!
Kas keegi on juba proovinud ICS ROMi (ehk CyanogenMod 9), mis on praegu alles alpha staadiumis?
Ise lasin eile peale, on asju mis toimib ning palju mis pole veel üldse käima saadud, või töötab aeglaselt.
Aga kellel on huvi midagi uut proovida ja tutuvuda uue softiga, siis uurida täpsemalt saab selle ModaCo lehe pealt
Ütlen veel, et vajalik on /system partitsiooni suurus 160 Mb (ainult ROM) või 215 Mb kui google apps pakk peale lasta.
68 |
Chaza!
25.12.2011 05:11:24
Proovisin ka just üleeile sama asja. Minu jaoks tundus see android 4 küll ootamatult kasutajasõbralikum ja ilusam. Lasin enda vana backupi tagasi, kuna praegu veel asi väga toores.
Kui seal kõik asjad jooksma saadakse, siis lähen kindlasti sellele üle.
_________________ Linux - Future
1984 was not supposed to be instruction manual |
Kommentaarid: 58 loe/lisa |
53 |
MorRAW
Ei ole Guru
28.12.2011 21:50:52
Endal hakkas vana nightly ootamatult akut sööma - max 24h peab vastu, imeb rsk vilinal tühjaks.
Samas uusi Cyanogenmodi nightlysid peale ei tule ning viimastega pole rahvas rahul - mis alternatiiv oleks?
Päris alpha'sid ei taha näppida, asi võiks ikka stabiilselt töötada
_________________ https://www.instagram.com/morrowshoots/
http://www.morrowshoots.com |
Kommentaarid: 372 loe/lisa |
314 |
martin366
28.12.2011 21:58:48
MorroW kirjutas: |
Päris alpha'sid ei taha näppida, asi võiks ikka stabiilselt töötada  |
http://forum.xda-developers.com/showthread.php?t=1382014
172 |
MorRAW
Ei ole Guru
314 |
-JaNiiOngi
11.01.2012 22:46:40
Räägiks jah selle blade hinnast natuke rohkem.
Kommentaarid: 4 loe/lisa |
martin366
09.02.2012 00:24:46
Mis on hetkel kõige kiirem ROM ?
172 |
Mario.
Kommentaarid: 274 loe/lisa |
6 :: |
217 |
ninzor
16.02.2012 17:38:27
Nii vana ROM siiani kiireim?
190 |
tets1
16.02.2012 18:28:02
kas kedagi näiteks põltsamaa või viljandi kandis on, kes vahetaks zte blade originaal tarkvara uuema vastu, et see wifi hotspot tööle hakkaks?
MacAivar
16.02.2012 18:44:01
tets1, kui Tartu kanti satud, võin aidata
68 |
tets1
16.02.2012 20:01:56
tets1, kui Tartu kanti satud, võin aidata  |
eks ma jätan meelde, kaua see aega umbes võtab?
äkki viitsid mulle privasse tel numbri visata, saaks operatiivsemalt ühendust, kui tartusse satun.
yxkala
16.02.2012 22:27:04
tets1 kirjutas: |
kas kedagi näiteks põltsamaa või viljandi kandis on, kes vahetaks zte blade originaal tarkvara uuema vastu, et see wifi hotspot tööle hakkaks? |
Tallinnas võin kah aidata, see suht lihtne max. 30min. töö.
Samas mul endal natukene kiire momendil aga äkki viitsib mõni teine foorumikasutaja teha talle puust ja punasega step-by-step õpetuse. Selle ROM'i installiga saab pmst igaüks hakkama ju
MacAivar
16.02.2012 23:48:44
Mul oli nagu meeles, et keegi tõlkis Blade custom ROMi paigaldamise õpetuse eesti keelde....kogu jutt käib GEN1 Blade-dest
Lordlesta kirjutas: |
Tegin natuke tõlketööd, ehk on mõnele abiks.
Kuidas Clockwork'i paigaldada
- Laadime alla vajalikult tööriistad telefoni mälukaardile
- Kontrollime faile
- Paigalda ASTRO File Manager
- Ava ASTRO File Manager ja otsi üles recovery-clockwork-blade-3.0.0.5.img
- Hoia sõrm selle peal ja vali Details - Kontrolli kas MD5 Sum on 24e5f51e0541c865f6b3232f30a0e6ee - kui pole, siis sikuta uuesti
- Paigaldamine
- Paigalda UniversalAndroot-1.6.2-beta5 läbi ASTRO File Manager'i
- Käivita Universalandroot
- Vali Go Root
- Paigalda ZTE-Blade Recovery Manager läbi ASTRO File Manager'i
- Käivita ZTE-Blade Recovery Manager
- Luba SuperUser õigused sellele
- Vajuta Recovery
- Nüüd vajuta ekraani all olevat Menu nuppu ja sellest menüüst vali Update database
- Peale uuendust vajuta Install Recovery
- Kui sul on rohkem kui üks .img laiendiga fail, tuleb sulle ette list - sealt vali recovery-clockwork-blade-3.0.0.5.img
Edaspidi kui tahad Clockwork'i minna, siis taaskäivituse ajal hoia helitugevuse nuppu all
Uue ROM'i paigaldamine kasutades Clockwork'i läbi Recovery Manager'i
- Otsi omale sobiv ROM mis toetab Clockwork'i - näiteks siit (see peaks olema .zip fail suurusjärgus 90MB)
- Kui leitud, pane see telefoni mälukaardile
- Paigaldamine
- Ava ASTRO File Manager ja navigeeri oma ROM-i juurde
- Hoia sõrm selle peal ja vali Details - Kontrolli kas MD5 Sum klapib - kui ei, siis sikuta uuesti
- Ava ZTE-Blade Recovery Manager
- Vajuta Firmware
- Kui tahad teha täielikku koopiat oma praegusest ROM'ist, siis vajuta Backup Current Firmware - salvestab selle mälukaardile kasuta nimega /clockwork
- Vali Install Firmware - mitte update
- Kui sul on rohkem kui üks .zip fail mälukaardil, siis vali see ROM mida sa laadisid alla - vajuta OK
- Telefon automaatselt taaskäivitab ennast Clockwork'i ja teeb järgmiseid asju
- Paigaldab uue ROM-i
- Kustutab kõik andmed ja vahemälu
- Taaskäivitab ennast värskelt paigaldatud ROM-i
Tehtud! Esimest korda käivitades võib aega võtta ligikaudu 6 minutit
Praegused custom ROMid on enamuses GEN2, seega tuleb telefon ka GEN2-ks konvertida.
Ingliskeelset lugemist sellel teemal leiab GEN1 kohta siit ja GEN2 kohta siit.
Eelevalt on siis vaja kindlaks teha, kas on tegemist GEN1 või GEN2 telefoniga.
Kui telefon on lõpuks rooditud ja clockworkmod olemas, käib custom romi install ~10 minutiga.
NB! Oluline on alati kontrollida MD5 hash enne üle. Praegu mina olen aga nii laisk et seda enam ei tee, aga siiski ma hoian alati tagavaraks mõnda vanemat CM7 versiooni alles juhuks kui mingi kala peaks installi ajal tekkima...
68 |
