| Palju aega võtaks sinu steam kontol olevate mängude läbimine? |
| 1-10 tundi |
4% |
[ 21 ] |
| 10-25 tundi |
3% |
[ 18 ] |
| 25-100 tundi |
9% |
[ 43 ] |
| 100-200 tundi |
10% |
[ 48 ] |
| 200-500 tundi |
8% |
[ 39 ] |
| 500-1000 tundi |
12% |
[ 55 ] |
| Rohkem kui 1000 tundi |
50% |
[ 228 ] |
| hääli kokku : 452 |
Ollaz
05.11.2011 12:10:23
Kui keegi CS-i ostab, siis ärge makse täishinda vaid võtke minu käest Complete pakk 7€ eest
| Kommentaarid: 83 loe/lisa |
57 |
eShelobik
11.11.2011 00:39:01
Dear Steam Users and Steam Forum Users:
Our Steam forums were defaced on the evening of Sunday, November 6. We began investigating and found that the intrusion goes beyond the Steam forums.
We learned that intruders obtained access to a Steam database in addition to the forums. This database contained information including user names, hashed and salted passwords, game purchases, email addresses, billing addresses and encrypted credit card information. We do not have evidence that encrypted credit card numbers or personally identifying information were taken by the intruders, or that the protection on credit card numbers or passwords was cracked. We are still investigating.
We don’t have evidence of credit card misuse at this time. Nonetheless you should watch your credit card activity and statements closely.
While we only know of a few forum accounts that have been compromised, all forum users will be required to change their passwords the next time they login. If you have used your Steam forum password on other accounts you should change those passwords as well.
We do not know of any compromised Steam accounts, so we are not planning to force a change of Steam account passwords (which are separate from forum passwords). However, it wouldn’t be a bad idea to change that as well, especially if it is the same as your Steam forum account password.
We will reopen the forums as soon as we can.
I am truly sorry this happened, and I apologize for the inconvenience.
Gabe. |
| Kommentaarid: 295 loe/lisa |
262 |
11.11.2011 07:45:27
Tublid... nio ei suudeta andmeid turvata
200 |
Ho Ho
11.11.2011 08:32:25
| Magic kirjutas: |
Tublid... nio ei suudeta andmeid turvata  |
Kuna krediidi-passwordi info oli krüptitud-soolatud pole häkkeritel sellega midagi peale hakata.
86 |
11.11.2011 11:05:30
Ho Ho, niipalju kui mina aru saan, siis paroolist oli hash ainult baasis (mis tundub mõistlik), samas krediitkaarti info oli siiski krüptitud kujul seal baasis (sest seda vajatakse lahtisel kujul tehingute tegemise juures). Nüüd sõltub kõik sellest, kas krüpteering murtakse või mitte.
Arvan, et mitte, samas oma Steami parool ja salaküsimus oleks vist soovitav sellegipolest ära muuta.
158 |
Ho Ho
11.11.2011 11:12:42
| bladerunner kirjutas: |
| samas krediitkaarti info oli siiski krüptitud kujul seal baasis (sest seda vajatakse lahtisel kujul tehingute tegemise juures). |
Ei. Sääraste ettevõtete puhul ei salvestata reaalset krediitkaardi infot vaid kaardi tootja annab vastavale ettevõttele vastava ID iga kasutatud krediitkaardi kohta mis kehtib ainult tolle konkreetse ettevõtte jaoks. Reaalset krediitkaardi infot ei talletata ning toda ID'd ei ole võimalik kasutada väljaspool Valve't.
A'la kui ma toksin oma krediitkaardi numbri Steami siis too saadab selle otse edasi mastercardile kes siis saadab vastu näiteks ID=1. Kui luban Steamil oma krediitkaardi info salvestada, siis hoopis saadab ta mastercardile tolle 1'e, mitte mu reaalse krediitkaardi info.
86 |
11.11.2011 11:26:23
Ho Ho, võibolla tõesti. Samas IMHO sain ma oma sisestatud krediitkaardi andmeid tehingu juures ka näha justkui? Pole hetkel Steami käepärast et kontrollida...
158 |
Ho Ho
11.11.2011 11:29:09
Sa näed kõike peale reaalse krediitkaardi numbri ja kontrollkoodi. Numbrist ei tohi ettevõtted salvestada rohkemat kui viimast nelja numbrikohta. Selle infoga pole absoluutselt mitte midagi peale hakata.
86 |
EvilKatarn
diivanilill
11.11.2011 11:36:12
| Miks Steam mult kontrollkoodi kunagi siis ei küsi ja ostu mitte midagi trükkimata läbi viia saan?
81 |
Ho Ho
11.11.2011 11:46:35
EvilKatarn, loe mu seda posti uuesti kuid seekord mõtle kaasa ka.
[edit]
Märgin ära, et see 4 numbrikoha salvestuse piirang kehtib USA's, mujal maailmas ei pruugi see nii olla.
86 |
ertr2
11.11.2011 11:53:54
| Kui sa vajutad nuppu "save my credit card info" vms siis salvestab ta selle ainult sinu arvutisse, teisest arvutist ostu sooritades on kõik väljad tühjad.
| Kommentaarid: 67 loe/lisa |
65 |
Gap
11.11.2011 12:30:21
Ostan ka steamist vahest kuid mitte krediit kaardiga vaid tavalise SEB deebetkaardiga kas peaksin muretsema või pole põhjust ?
Ma ei tea tänapäeval varastatkse sind netis paljaks ennem kui seda et tänaval röövitakse või korteris käiks vargad. Mis inimestell viga on ma ei saa aru Niisugune koht nagu Steam peaks olema samahästi kaitstud nagu mõni panga server vms
| Kommentaarid: 21 loe/lisa |
17 |
Ho Ho
11.11.2011 12:32:41
Steam on lausa nii hästi kaitstud, et isegi kui käidi sees siis pole sealt saadava infoga muffigi peale hakata "röövlitel"
86 |
Gap
11.11.2011 12:33:27
noo siis pole hullu ju
17 |
Draax
11.11.2011 12:49:09
| Gap, jutt siiski Steami foorumitest, mitte Steamist endast. Need peaks olema täiesti erinevad andmebaasid. Muidugi kui foorumi parool on sama mis Steami parool, siis tasub kindlasti mõlemad ära vahetada.
| Kommentaarid: 29 loe/lisa |
29 |
nuubik
11.11.2011 12:50:33
| Ho Ho kirjutas: |
Steam on lausa nii hästi kaitstud, et isegi kui käidi sees siis pole sealt saadava infoga muffigi peale hakata "röövlitel"  |
Kõik TF2 mütsid varastatakse ära
| Kommentaarid: 10 loe/lisa |
10 |
Valdars
11.11.2011 12:53:58
| Draax kirjutas: |
| Gap, jutt siiski Steami foorumitest, mitte Steamist endast. Need peaks olema täiesti erinevad andmebaasid. Muidugi kui foorumi parool on sama mis Steami parool, siis tasub kindlasti mõlemad ära vahetada. |
Ka Steami enda andmebaasi saadi sisse.
| Kommentaarid: 47 loe/lisa |
44 |
Timo1337
11.11.2011 14:58:42
| Keegi reaalselt ei pääse su steam kontole ligi, sisselogides steami uues arvutis tahab mingit turvakoodi ja selle saadab emaile, ei ole võimalik et keegi su acci üle laseb, kui su emaili ja pw'd ei tea
| Kommentaarid: 49 loe/lisa |
46 |
Valdars
11.11.2011 15:41:29
| Ning paroole ning muid tundlikke andmeid ei ole võimalik kätte saada, kuna need olid krüpteeritud.
44 |
11.11.2011 15:50:13
Valdars, paroole üldjuhul süsteemides ei hoitagi, hoitakse parooli hashi/räsi. Krüpteeritud andmeid on õige võtme korral võimalik lahti saada, hashi/räsi korral pead sa õiget parooli teadma, et sama hashi/räsi saada.
158 |
eShelobik
11.11.2011 16:42:10
| hashist saab passwordi taastada üsna lihtsalt. selleks on nii mitmeidki toole olemas.
262 |
Ho Ho
11.11.2011 16:45:06
| eShelobik kirjutas: |
| hashist saab passwordi taastada üsna lihtsalt. selleks on nii mitmeidki toole olemas. |
näita kasvõi ühtainust mis suudab seda soolatud passwordidega teha.
Samuti ootan viidet krüpto lahti murdmise kohta.
86 |
216 |
Aavo
13.11.2011 19:24:14
Vabandan kui juba on olnud. Leidsin ühe lehe kust saab põhimõtteliselt tasuta mänge, ning asi ei tundu pettuse järgi olevat.
www.steamgifts.com
Põhimõtteliselt käib nii:
1)Logid sisse läbi Steami kasutaja.
2)Saad endale 20 punkti. Neid punkte võib kasutada sisenedes mängu äraandmistele, millel on erinevad punktide kogused vajalikud et osa võtta.
3)Kui on piisavalt punkte, siis vali sobiv äraandmine ning looda, et sa võidad. Võimalused võita ei ole eriti suured aga ikkagi proovida võib. Midagi sellest ei kaota.
Muide. Süsteem on selline, et iga kord kui keegi lisab uue äraandmise siis lisandub iga lehe kasutajale 1 punkt. Nii neid kogutaksegi. Maksimum punkte hoiustada on 300.
Kui sa äraandmises ei võida, siis kaob see punktide kogus ära palju kasutasid osa võtmiseks.
Edu!
| Kommentaarid: 30 loe/lisa |
29 |
Ho Ho
13.11.2011 19:29:17
| Aavo kirjutas: |
| 1)Logid sisse läbi Steami kasutaja. |
Sellest peaks piisama, et sealt kaugele eemale hoida.
86 |
