Keijo580
28.02.2011 23:58:59
[DarkEden] Europe & US (Vampire, MMORPG, Horror, Twilight, True Blood) |
DarkEden is a horror MMORPG where you get to choose between 3 races: Vampires, Slayers, Ousters. It is very similar to Diablo - if you liked Diablo, you'll love DarkEden!
Game Type: FREE TO PLAY
The game is based on the day-night system. Vampires rule the night and slayers/ousters rule the day. This means that vampires are stronger when it's night and slayers/ousters are stronger at day.
Max Level: 250
Max Rank: 50
Website: http://www.darkedeneurope.com
Register: http://darkedeneurope.com/register
Download: http://darkedeneurope.com/downloads
Vampires:
Information about the vampire race:
Can move fast (faster than the eye, so it looks like they're gliding on air)
Can drink blood to regain HP, can regenrate from damages such as bullet wounds and blade cuts.
Can transform into a bat, wolf or werewolf (lycan).
Can become invisible or hide under the ground.
Among vampire you can choose between being a melee vampire (close combat) or a mage vampire (requires more strategy to play a mage vamp)
Mage vampires = Most known for their torture skills such as blinding spells, paralyze. They can keep you alive just to play with you till they've had enough. Only then they will kill you.
Melee vampires = Fast & strong beings whose claws can cut through steel plated armor, bullets are rarely enough to stop one of these creatures. You'll need a rocket launcher. But be careful because they're very fast and hard to hit.
Ousters:
[img]http://www.upload.ee/image/1156863/DarkEden018.jpg
Ousters are relatives to fairies, they can use the magic of the nature to create powerful spells. Such as teleportation, prison of water, meteors, hellfire and much more.
There are 4 classes of ousters: Water, Fire, Earth, Wind (combat)
Water = Can control water, and revive/heal other ousters and summon water element that heals you and your friends.
Fire = Can control fire, very powerful offensive magic such as hellfire, magma meteors and fierce flame that burns down every living creature.
Earth = Can control earth, prison others with slow-down effect and summon huge stone-meteors at your enemies.
Wind/Combat = Can control wind elements and use a powerful chakram with a circular blade to slice enemies or summon razor sharp blades that fall from the sky.
Slayer (Human)
Gunner = Uses automatic rifles, sniper rifles, sub machine guns etc. Can call for satelite bombs and XRL rockets to blast enemies to tiny pieces. Can also enter a powerful turret that is unmovable but with insane firepower.
Sworder = Uses sworder & shield, can move really fast and use the power of thunder to strike their enemies.
Blader = Uses a big sword, one swing is enough to create a hurricane and blow away a lot of enemies.
Healer = A powerful magician that can revive & heal other allies. But can also destroy enemies with a lightning bolt from the sky.
Enchanter = A powerful magician that can buff other allies to see invisible vampires, and trap them with strong spells.
This is an interesting game with one rule: survival of the fittest.
villu70
01.03.2011 00:54:07
| See pildi jura topi heaga spoilerisse.
| Kommentaarid: 141 loe/lisa |
121 |
FR3AK
01.03.2011 11:42:59
Darkeden oli küll kunagi väga teemas . Aga siis hakati seda mängu iga nurga alt hackima ja hea mitu aastat oli seda võimatu mängida. Vahepeal tekkis uuesti huvi mängima hakata ja siis oli ka mingi 100 jama, ei saanud regada või ei saanud klienti tõmmata või ei saand serveriga ühendust(ei mäletagi enam )
Kui nüüd need vead parandatud, siis võiks isegi uuesti üle vaadata.
| Kommentaarid: 42 loe/lisa |
40 |
falkriz
01.03.2011 13:18:49
Hehe...DarkEden. VÄGA hea mäng kusjuures. Samuti väga vana kah, aga kunagi oli see ikka tõesti väga mõnus mäng. Peaks seda serverit kah siis proovima. Vanade aegade mälestuseks.
FR3AK
01.03.2011 20:05:32
Regasin ära, tõmbasin mängu ära, proovin sisse logida ja saan errori (connection dropped vms).
Veebilehel ka miski teadaanne
We're sorry for the disconnects, the host is currently having problems. We are also going to upgrade the server soon to reduce the lag some players have experienced.
Once again, sorry for this and thank you for your patience.
Mnjah, hakkab jälle pihta.
40 |
Metsjeesus
02.03.2011 10:41:28
"tahaks vist küll aga praegu ei saa"
"tydruk tuleb vist siia"
Kunagi sai proovitud officialit, kuigi sellel privaadid ka väga popid.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
FR3AK
02.03.2011 19:18:56
| Metsjeesus kirjutas: |
| Kunagi sai proovitud officialit, kuigi sellel privaadid ka väga popid. |
Eile õhtul tekkis nii suur mänguisu, et hakkasin teisi privaate otsima. No mitte ühtegi ei leidnud (ei viitsi mingi 20 inimeselises serveris mängida, või kuskil, kus on 300x exp vms jura)
Isegi originaali enam mängida ei saa vist (kiiruga kodulehelt vaatasin seda, pole 100% kindel selles).
E: server on üleval, mängima hakates avastasin et exp on kõvasti kõrgem kui originaalis(tund aega mängimist ja lvl 40). Äkki kellelgi soovitada mõnda serverit kus normaalne exp?
40 |
warkriss
14.03.2011 12:03:12
| Keda DE huvitab (ülimalt hea mäng.. aga kahjuks minu jaoks oma aja ära elanud), siis hea foorum, kus aktiivsete serverite kohta infot leiab, on www.leetnetwork.com ja sealt siis DE alafoorum.
| Kommentaarid: 30 loe/lisa |
30 |
Tanel889
05.11.2011 14:59:01
Esmalt tahaks öelda, et teema võiks ümber nimetada üldise darkedeni jutu teemaks, kuna palju huvilisi siin ei ole.
Kohe kohe on algamas Ignited Gamesi Darkedeni closed beta. Rohkem kui aasta on möödas sellest, kui suleti viimane international offical Joymaxi poolt.
http://dk.ignitedgames.com
On teada, et mängu versioon on sama mis arendaja(Softon, lõuna Korea) enda serveris.
Kuidas saada Closed Betasse? Tuleb teha registreerida kasutaja ja kord sisse logida, ja jääda ootama beta võtit.
| Kommentaarid: 15 loe/lisa |
14 |
FR3AK
05.11.2011 15:16:45
Regasin ennast seal ära.
Aga taaskord küsimus, kas praegu on üldse normaalset(kus on originaalsed või võimalikult madalad drop/exp rate) serverit kus mängida?
40 |
Tanel889
06.11.2011 00:38:00
Konkreetsel hetkel ei ole, kui just ei taha proovida päris korea versiooni, samas sealt võib banni saada kui pole korealane, nagu mina sain.
Aga see Ignitedi server peaks tulema low rate ja "normaalne"
Oled ehk mõni vana mängija amphipholise foorumist?
14 |
FR3AK
06.11.2011 11:03:38
| Tanel889 kirjutas: |
Oled ehk mõni vana mängija amphipholise foorumist? |
Ei usu, darkedenit sai mängitud veel enne, kui mingi hetk kõik hackima hakkasid (orig serveris), siis mõnda aega ei mänginud, tehti serverid korda ja siis sai veel natuke mängitud. Aga kuskil fooumis küll ei tegutsenud.
40 |
Tanel889
08.11.2011 09:20:03
Nonii, mäng käib, tuleb saata lisaks registreerimisele ka saata email community@ignitedgames.com
ülejäänud info
dk.ignitedgames.com
14 |
FR3AK
08.11.2011 10:07:14
ülejäänud info
dk.ignitedgames.com |
Lisainfoks teistele, mängu beta key saab automaatse vastusega. Ma isegi vaevusin kirjutama neile paar põhjust, miks ma võiks beta key saada, aga tuli välja et see polnudki vajalik.
40 |
Jhael
08.11.2011 13:10:14
| Millal need haldjad sinna veel ilmusid?
| Kommentaarid: 11 loe/lisa |
Cromaclear
| Kommentaarid: 26 loe/lisa |
23 |
FR3AK
08.11.2011 18:15:16
Panin beta key sisse(tuleb game download aken ette), aga kuna olin töö arvutis, siis mõtlesin et tõmban kodus, tuli välja et kui sellelt lehelt ära läksin, siis enam sinna lehele ligi ei pääse.
Sai uus kasutaja tehtud ja tolle alt tõmmatud, igaljuhul, kui kellelgi sama probleem peaks tekkima, siis siit saab tõmmata
Panin installima, eks näis palju seda mängida viitsib, sest niipalju kui aru sain, siis et kui mäng lõplikult välja tuleb, siis kõik charid resetitakse.
E: Installer ei saa serveriga ühendust, proovisin vist kõike, viirusetõrje välja, tulemüür välja, compability mode ja run as administrator (korraga), aga ikka ei midagi.
40 |
Tanel889
08.11.2011 19:37:23
| FR3AK kirjutas: |
E: Installer ei saa serveriga ühendust, proovisin vist kõike, viirusetõrje välja, tulemüür välja, compability mode ja run as administrator (korraga), aga ikka ei midagi.  |
Mul (win 7 64) ei olnud probleem mängu käima panemisega.
Selle reseti kohta oskan öelda vaid, et enamustes MMORPG'des kus on beta ja closed beta tehakse peale beta perioode reset.
Võta seda positiivselt, sa pole ju kaua aega darkedenit mänginud, palju asju on vahepeal juurde tulnud, näiteks võtame bladeri, kes oli kunagi väga overpowered kuna lvl 95 skill airshield võttis melee dmgi 99% maha, nüüd on see ainult 50%.
Sul on võimalus õppida mängu uuesti tundma, ja ometi mitte kaotades aega kogenumate mängijatele.
14 |
FR3AK
08.11.2011 22:42:20
Huvitav, nüüd hakkas ilusti tõmbama, ju siis oli ikka serveripoolne kala
E: Sain nüüd natuke mängitud, et alguses tundus et xp'd tuleb liiga hullult, aga nüüd natuke kõrgema leveli pealt hakkas nagu normaalselt tiksuma. Et praegu vist xp rate sama mis orig serveris kunagi?
40 |
Tanel889
09.11.2011 00:39:21
Neid ei saa päris võrrelda, too orig server oli õigupoolest mingi test server mis jäeti lihtsalt käima. (ei leitud publisheri kohe)
Seal võttis 1-150 lvldamine kauem aega, sest kollid olid noobimad ja andsid vähem xpi, seal läks lv 70 vampiir tegemiseks 1-2 päeva kuni nädal, siin uute kollide peal tehes tegin 3 tunniga lv 70
14 |
