uus teema   vasta Hinnavaatlus »  HV üritused »  Boinc märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... , 21, 22, 23  järgmine
XeStAiSy
Aeg Maha 2a
sõnum 29.10.2011 08:18:38 vasta tsitaadiga
Kurrat üks uuendus keeras käkerdi sassi. Nende uuendustega peab ettevaatlik olema. Nüüd on jälle korras. Lasin vana uuends pakki tagasi.
Sant, Kust sa võtsid ,et hakkab skoorima nüüd. Ahhjaa no heakene küll.
Nii xtop GPU Linuxis on minuoma 6970.
http://moowrap.net/gpu_list.php
Nojaa wtf
Total
(1.000) AMD Radeon HD 6900 series (Cayman)
(0.941) ATI Radeon HD 5800 series (Cypress)
(0.690) ATI Radeon HD 4700/4800 (RV740/RV770)
(0.337) ATI Radeon HD 5700 series (Juniper)
Windows
(1.000) ATI Radeon HD 5800 series (Cypress)
(0.729) ATI Radeon HD 4700/4800 (RV740/RV770)
(0.358) ATI Radeon HD 5700 series (Juniper)
Linux
(0.890) ATI unknown
Mac
No GPU tasks reported
sant
sõnum 31.10.2011 00:21:41 vasta tsitaadiga
Sicis oli küsitlus gpu failimiste kohta (24\7 crunchimisel siis) ja üllatavalt vähestel oli probleeme old kunagi, põhi fail oli jahutus ventide ärasuremine, sama probleem vaevas ka kunagi Steve.
Tsiteerin cncguru:
WHAT I HAVE HAD PROBLEMS WITH is power supplies and motherboard pcie channels not being able to withstand the constant current with 4 or more cores running OC'd 24/7. I've killed two Asus P6T7's and one P6T6 plus 2 antec 1200's. The antec will happily drive (4) non overvolted 5870's but (4) 6970's @ 950/685/1200 killed them dead after only a few months.
And I even killed a Silverstone ST1500 with (5) MSI Lightning GTX580's running @ 950/1050/+140 on my SR-2(which survived TG)he also ran away from everyone on Primegrid.
Tsitaat minult:
I have had no bad experiences with gpus. Crunched on over 10 different ones over the years and no failures. One gpu did fail (allmost immediately), but that was a faulty one and i rma-d it. Currently runnin on 7 gpus, 5 of them nvidia, all aircooled and all nvidias have their shaders oc-d to max stabile w\o overvolting, been doing that for years and i dont expect failures. They probably will go out of date before failing.
Huvitav info einsteini kohta:
Part of the project is run by the University of Milwaukee and part of it by the Albert Einstein Institute in Hannover. The main database and all CPU work is handled in Milwaukee. All the GPU work is coming from Hannover
Millega tegeleb einstein:
Einstein@Home is a program that searches for gravitational waves from spinning neutron stars (also called pulsars) using data from the LIGO gravitational wave detector. Einstein@Home also searches for radio pulsars in binary systems, using data from the Arecibo Observatory in Puerto Rico.
Einsteinis leiti uus pulsar: http://einstein.phys.uwm.edu/forum_thread.php?id=9150#114698
XeStAiSy
Aeg Maha 2a
sõnum 31.10.2011 09:15:20 vasta tsitaadiga
Ma küpsetasin 4870X2 kaardi maha ventilaator juba pärises ja kaart oli vajunud banaani. Kaart vajus aastaga kõveraks. Peale 2 aastat suri ventilaator. Plärisema hakkas. Intelt stock ventilaator on ikka mehiselt vastu pidanud samuti 5 aastat vana 24/7 olnud PSU TX650 on ka ikka juba klass omaette.
Mina teisi ei osta sest surevad aastaga maha paljukiidetud forton suri aastaga maha + keeras emaplaadi ka nässu ja ilmnesid vead kuigi parandasin ära kasutasin ja ostsin uue PCI-Ex ver 2.0 siine oli vaja.
100 euro eest saab uue psu corsairi oma. Suvel võtangi uue PSU ligi. 700-850w Hetkel ei kanata teist kaarti masinasse toppida. Kui juba siis üks HD7k midagi võtta ligi double power ja sama vooluõgimine. Nice oleleks siis singlegpu kaardiga lasta millel hetkeseisuga double power. Muidu maksa 300 raha teise 6970 eest ja kui 7k tuleb saab palju parema lahenduse sama rahaeest.
Mina teisi tootjaid ei eelista rohkem kui siis ainult Sapphire. Samuti ma ei tegele fläshimise ja kellamisega. Tõesti tore tükk on vähimatki probleemi pole.
Lolli aruga sai linuxis x.org server core uuendatud siis viskas compute errorit. Aga muidu on kõik ok.
Liigapalju uuendusi tuleb linnile pidevalt. Windows ikka ei uuene nii tihti ja seal ka vähem probleeme.
Ma olen oma linni 20 päva kottinud no ei lähe katki nagi win seda teeb 2 kuupärast, eriti asi muutub imelikuks kui voolukatkestus winnis tuleb kohe on ka anomaaliad. cache on kinni väänatud ja ikka ḿuutub naljakaks see win.
sant
sõnum 01.11.2011 02:05:28 vasta tsitaadiga
Margus, ups aitab selle vastu hästi, mul endal on neid kokku 3 et ei oleks pobleeme.
Palju sul neid pci-e siine on muidu mobol? Kui tahad võid soodsa hinnaga mu gts 450 ära osta, saaksid nvidia projcte lisaks\vahelduseks jooksutada ja mina saaksin endale põhjuse 550ti osta. Ati\nvidia mix winni all on mul probleemi vaba, linuxi kohta ei oska öelda midagi.
XeStAiSy
Aeg Maha 2a
sõnum 02.11.2011 10:04:53 vasta tsitaadiga
Nii linn läks peale ati 11.10 driveritega x64 peal segi. Maadlesin tunde ja lõin käega sellele installile panin 32bit peale ja näe imet toimib 11.10 catalyst.
Selline jebla mis x64 peal oli seda 32 peal pole. Linuxis pole vahet kas x64 või 32 mälu on ikka 4GB kasutusel, see pole windows mis selliseid nalju teevad.
vaatame kas purustab linuxi 32 bitine ver 30 päeva ennem kui midagi juhtub. Igatahes catalyst driverid läksid täielikult peale.
Hetkel saab ainult milkywayd kasutada. Niikaua kui 32 bit moo wrapperisse tuleb. Hetkel seal ainult x64.
sant
sõnum 06.11.2011 01:14:06 vasta tsitaadiga
Niih, pg-s nüüd pps sieve cuda wu scoor 2251 punni. Gtx 580 peaks tegema ühe sellise wu 10-ne mindiga või nats alla, kellatuna kiiremini muidugi. Mu gtx 570 nats kellatuna teeb 10 minti 30 secci per wu. Rohkem neil scoori madalamks lasta pole plaanis.
DistrRTgen-nist ei saa juba pikemat aega gpu wu-si, neil on jälle servu probleemid, project on mõnesmõttes ikka veel beeta staadiumis ja paistab et nii jääb mingiks ajaks, cpu wu-si saab aga mind need ei huvita.
Vaatasin huvipärast oma statse, ja siin olen kohal 60: http://boinc.berkeley.edu/chart_list.php
Boinc totali järgi olen esimese 200-ja seas maailmas: http://boincstats.com/stats/boinc_user_graph.php?pr=bo&id=df8a8be23d4c1474e98475e522340a39
Selle järgi ei ole: http://boinc.netsoft-online.com/e107_plugins/boinc/get_user.php?cpid=df8a8be23d4c1474e98475e522340a39&html=1
Sahib
sõnum 07.11.2011 16:21:03 vasta tsitaadiga
sant kirjutas:
Ca 9,05minti. Pisut kellatud jah (core 858, memory 2100. Fan speed 50% ja temp max 77C )
Mõtet harutades võib jõuda mõttetuseni ...
sant
sõnum 07.11.2011 21:49:57 vasta tsitaadiga
Kas sebid ühe kasti juurde, sest miljonit päevas ei tule?
Sahib, ei ole vajadust, praegu jooksutan muid asju. Ei viitsinud kogu rauaga einsteini challengest osa võtta, neid challengeid nii palju viimasel ajal et kopp ees juba. Otsustasin ati driverid järjest ära proovida, praegused toodavad nüüd teist päeva usinasti prahti juba icon_biggrin.gif
XeStAiSy
Aeg Maha 2a
sõnum 20.11.2011 09:38:27 vasta tsitaadiga
sant kirjutas:
Mul ka linni all 11.10 praht, 1.9 praht, 11.8 hea. Windoozas on kõik head.
E:
Sain selle linni bugile jälile miks prahti tuli. Nimelt tavaline ja lihtne bug. Kui näiteks külastada erepublikut ja panna battle, seal tuleb scriptitud java siis seal hakkabki prahti tootma. Ma ei tea ka kuidagi adobe flash ka prahistab. 11.11 catalyst tõi natuke eemale prahist.
Linni stabiilsust võib pidada väga rahuldavaks, nagu ka windows. Boinc võib kuudeviisi müttata ilma ,et peaks mingeid trikke tegema. Sarnaselt foldimisel nagu seda folding@home olid ponnistused igapäev.
Sahib
sõnum 23.11.2011 00:46:16 vasta tsitaadiga
Mingit kummalist on toimumas. Vahepeal viskab tööaja ka kahekordseks icon_rolleyes.gif
sant
sõnum 06.01.2012 03:14:25 vasta tsitaadiga
Sahib, distrtgen muutis wu-d pikemaks ja suuremaks:
WUs will be 7.625 MiB per upload and the chain count is aligned with cuda kernel call sizes.
They should take longer than the current table per WU so the uploads should be less frequent.
Mul jooksevad wu-d pea 2 korda kauem kui enne. Gtx 570 enne ~12 minti, nüüd ~20 minti (runtime 1223 sec\score 7470) See screen mis sul on Sahib, seal on wu-d waiting to run, mul nii ei ole. Huvitav miks sul nii on eusa_think.gif
Edit: uus cpu project on boinci all väljas (kui kedagi huvitab): http://boinc.med.usherbrooke.ca/nrg/
Distrtgen: cuda töö jälle maas:
Cuda work hand out is stopped. CPU hand out continues for the current time. This work stoppage is likely to be 2 weeks or more.
Essentially there is 8 TB worth of completed data that needs perfecting runs. The literal meaning is we are out of space. Planning for when our power supply gets replaced based on unknown time frames and computational growth are items that meant the date and time of hitting this point were not expected this soon.
Having 100 new cuda cards in a week seemed crazy previously but a quick glance at a graph seems to show 200-300 new cuda cards this past week.
At this point even if we found co-location, we now have been blacklisted by 2 payment processors so we cannot even accept donations much less ensure we could pay such a bill.
Teema arutlus siin: https://www.freerainbowtables.com/phpBB3/topic3197.html
Pg-s tuleb pps sieve gpu challenge icon_biggrin.gif :
http://www.primegrid.com/
Seoses sellega:
The WU size was increased by 50% to make it easier on the servers during the upcoming Winter Solstice Challenge. Credit per WU was therefore increase by the same amount.
Kes tahab võtku osa, toetab ka ati kaarte thumbs_up.gif Ei skoori ni hästi kui nvidial, aga töötab.
Eelmine kord jäin 37-le kohale, vaatab palju seekord saab. Seekord võtan ati kaartidega kah osa beer_yum.gif
Edit:
Primegrid challenge läbi ja jäin kohale 72 icon_lol.gif Vähemalt esimese 100-ja sisse siiski icon_razz1.gif
Distrtgen:
WUs for GPU now flowing.
Edit: Ah, fack it, servu mitu päeva maas juba thumbs_down.gif
Aga Moo! annab jõulu boonus crediiti praegu thumbs_up.gif http://moowrap.net/forum_thread.php?id=178#1906
I like that Mill Im getting from 2, 5830's, a day.....
Use to be 450k.
Edit: sain päeva kasutaja olla icon_biggrin.gif , vist esimest korda elus: Sellise profiiliga siis: http://boinc.freerainbowtables.com/distrrtgen/view_profile.php?userid=16722
XeStAiSy
Aeg Maha 2a
sõnum 08.01.2012 19:53:32 vasta tsitaadiga
UUs projekt ati meestele. POEM@HOME http://boinc.fzk.de/poem/ pornu on veel kuid eks areneb veel. Ei kasuta kogu GPUd.
sant
sõnum 16.01.2012 21:22:10 vasta tsitaadiga
Nalja kah:
Renderfarm had done some upgrades lately.
Unfortunately, there are people that are receiving 0 credit for crunching.
I had over 50% of the WUs receive 0 credit.
Suggestion:
Do not crunch unless you don't care..
i don't care... but i don't crunch either.
rofl.gif koomikud koos krt.
Edit:
Margus, varsti proovin seda poem@home värki, pole aega praegu jamada. Aga:
7970 up and running at MW if anyone has one, and you want to stretch its legs, 52-53 seconds per WU. Its solid and runs well.
At present 7970s are running on MW using a NVidia OpenCL app - works well, high utilisation, usual OpenCL speed issue but runs faster on a 7970, than a 6970 runs a native AMD CAL app.
PPS Sieve AMD not running on a 7970. Tried two sessions of two WUs each time.
WUs fall over right at the start around 15-20 seconds and hit computation error. Thats the same behaviour on MW with their AMD Stream app. Moo also falls over similar symptoms.
Collatz runs ok and completes, awaiting to see if they validate against a Wingman
Teema: http://www.primegrid.com/forum_thread.php?id=3921#46481
Margus, palju see 7970 su 6970-st kiirem on MW-s?
Mu kunagine 4870 tegi nats alla 4-ja minuti MW wu.
Sahib
sõnum 17.01.2012 15:01:24 vasta tsitaadiga
580 GTX teeb 2.50-3.00 minutit. Paar päeva käian seda projekti vahelduseks
XeStAiSy
Aeg Maha 2a
sõnum 18.01.2012 07:37:39 vasta tsitaadiga
Ma ei tea palju kiirem on 400€ ei taha hetkel kaardi alla panna. Kui 6k kaob turult peaegu siis langevad ka hinnad. Ma lasen mõned MW wud ja ütlen ajad.
51-54 sek on hetkel. Mul on tuunitud bios arvutil ka. Ma arvan ,et PCI-E läbilase jääb paljudel piirama seda 7970 kaardi x2 versiooni. Umbes 2000 shaderit oli vist, peaks juu kiirem käkerd olema. CPU ei tohiks jalgu veel jääda. Ilmselt siin double p shadereid sama kogus mis minul.
Kes oma ATIde ja idiootide käkerditega tahavad natuke betatestida Siis teile Albert@home samuti boinc kuid see vist einstein@home ristsugutis.
sant
sõnum 19.01.2012 06:15:01 vasta tsitaadiga
Margus, Siis on ju küll sukcs icon_neutral.gif rohkem ei oskagi öelda.
XeStAiSy
Aeg Maha 2a
sõnum 19.01.2012 06:55:17 vasta tsitaadiga
sant kirjutas:
Sukcs võib ainult MW all olla, kuid moo ja teised on kiiremad. Teised DP ei kasuta vist.
sant
sõnum 05.02.2012 16:52:54 vasta tsitaadiga
Nonii icon_biggrin.gif täna panime siis meie oma väikse Eestimaaga suurest maast nimega Mehhiko mööda: http://boincstats.com/stats/boinc_country_stats.php?pr=bo&st=0#37 beer_yum.gif
Järgmine suur maa millest me väiksed ja väetid Eestlased mööda paneme on Türgi icon_lol.gif
Edit: pg-s hakkab cpu challenge ~20 tunni pärast: http://www.primegrid.com/
Cpu only thumbs_down.gif võtan osa ikka.
Edit: pg run läbi ja jäin esimese 300-saja sekka icon_biggrin.gif Sinna ma ka sihtisin. Tarmo Ilves jäi samuti esimese 300-saja sekka icon_biggrin.gif Kõrgema koha sai krt:
http://www.primegrid.com/challenge/2012_1/top_users.html
Täna õhta saan siis poemi proovida.
Edit: milkywaylt uudist:
A few weeks ago, we ran double credits in order to make up for a database error that occurred earlier in 2011. Unfortunately, the server crashed with just 12 hours left until the make-up credits were finished. Now that the new server is up and running (and stable! very stable!), and everyone here is back from travels and winter break, we are ready to finish running those last 12 hours of double make-up credits. If there are no significant objections, we'll run the double credits on St. Valentine's Day (February 14), from 10:00 am until 10:00 pm, US Eastern time (EST). This corresponds to 3pm (Feb14)-3am (Feb15) UTC. Happy crunching!
The old CAL version is gone; it's replaced with the OpenCL application. On AMD/ATI GPUs (older than 79xx) it is using some hackery to use the same IL kernel as before so it should be as fast. However this also means the Radeon 38xx cards aren't supported with new stuff. - Radeon 79xx stuff should work - The occasional validate errors from empty / truncated stderr should stop - AVX will be used if available on Linux and Windows (64 bit only for Windows) - I've increased the default GPU target frequency so GPU stuff should make things less laggy on average. You can now also configure this with the web preferences now so you don't need to use app_info stuff if you want to play with that. - Partial workaround with high CPU usage with recent Nvidia drivers. It should cut down on the CPU usage a bit while not sacrificing too much. There are options to change the polling mode if you want to lower the CPU usage further while not slowing it down. (--gpu-wait-factor and --gpu-polling-mode work similarly to how they did with the old CAL one, but slightly different)
viimati muutis sant 09.02.2012 02:51:48, muudetud 1 kord
Sahib
sõnum 08.02.2012 19:10:40 vasta tsitaadiga
Mina aga langesin koha võrra icon_cry.gif Ega ühe kaardiga teile vastu või vähemalt tempot hoida ei saa.
Hea uudis on see, et DistrRTgen elustus.
Generalized Fermat Prime Search (GFN) on keegi jooksutanud? Poob kaarti hirmsasti, aga temp on madal
Saan uhke märgi rinda ja siis pensionile - ehk keegi mäletab veel seda
sant
sõnum 13.02.2012 15:29:43 vasta tsitaadiga
Ei, ja ei jooksutagi kuna skoor vilets.
Sahib,
Saad küll thumbs_up.gif Tarmo Ilves ja Margus, neil mõlemil üks kaart mis samaväärne sinu omaga. No mina ja Aants paneme hunniku gpude pealt, aga see on ka kõik. Sa oled ju ikkagi eesti tipptegijate hulgas thumbs_up.gif
Kui oled väsind pane pausi beer_yum.gif Ja hiljem lase edasi. Sa ei pea ju 24\7 laskma. Mul endal üks kast 24\7 ei lase praegu, lasen tal puhata, teisega lasen 24\7 edasi. Muidu oleks mill+ päevas koguaeg. Kui sa vaadand oled siis ka Aants paneb pikalt pausi vahel, ja kogu rauaga ta 24\7 ei lase niikuinii.
Edit: päris huvitiva scooriga wu-si saab distrtgen-ist vahel - runtime 431.39 sec ja scoor 8,665.00 icon_razz1.gif
Sahib
sõnum 13.02.2012 19:32:08 vasta tsitaadiga
Üldiselt on neid seinast seina, aga väga palju ei kõigu.
Ühel päeval tuleb 7,470.00 (run time jääb alla 1000de) ja siis teine päev otsa 8,665.00.
XeStAiSy
Aeg Maha 2a
sõnum 17.02.2012 08:56:46 vasta tsitaadiga
MW Ati opencl app küpsetab 51-52 sekiga 100% wu valmis ja siis uimab kuni 57-58 aja välja. Hetkel ei prae GPUd ka nii hullult kui oli CAL. Ei kooma ka nagu ei oleks midagi toimumas. Parem surfamine netis kui seda oli Moo.
sant
sõnum 04.03.2012 22:03:21 vasta tsitaadiga
Poolel teel: http://boincstats.com/stats/boinc_user_stats.php?pr=bo&st=0&co=30#1
Edit: einsteinis leiti jälle pulsareid: http://einstein.phys.uwm.edu/forum_thread.php?id=9317
Krt, mingeid asju uuendasin 23-ndal ja nüüd pooled gpu wu-d teevad erroreid ja invalid wu-si icon_neutral.gif Hui mäletan mida uuendasin, polegi ammu juhtund midagi sellist, uus win vaja jälle peale panna kopp.gif
Edit:
Margus, Poem@home vajab beeta boinci ja sellega osad projectid ei tööta korralikult. Ootan siiski final releasi ära enne kui saan proovida, Poem on peal muidu aga gpu wu-si ei saada sunnik, saab aru et pole beeta boinc icon_biggrin.gif
Milkyway run tuleb, kel dp toega ati võtku osa (eriti sina Margus icon_wink.gif pole ammu üheski runnis näinud sind), mul MW certified rauda pole seega pass. Pg-s cw gpu runnis jäin 27-ndaks icon_razz1.gif asi seegi thumbs_up.gif http://www.primegrid.com/challenge/2012_2/top_users.html
Name The March Milky Way
Project MilkyWay@home
Issued by Crystal Dream
Start time 2012-03-09 00:00 GMT
End time 2012-03-16 00:00 GMT
XeStAiSy
Aeg Maha 2a
sõnum 08.03.2012 14:48:22 vasta tsitaadiga
Ma teen need mõned pävad kuid olukord on sucks. 12 tundi veel ja läheb lahti. CPU omadest ei võta osa jah. Ma ei jõua igale poole korraga. Ilmselt venis aeg pikkaks.
sant
sõnum 05.04.2012 21:34:10 vasta tsitaadiga
Margus kirjutas:
Cpu omad ongi sucks icon_biggrin.gif Ma ise ka igast challengest osa ei võta icon_razz1.gif Mw challengest pole ühestki osa võtnud kuna pole rauda. Ma mõtsingi et sa võtaks minu eest nagu osa icon_biggrin.gif Su kaart teeb wu mingi 55 sec, mul gtx 570 teeb mingi 9 minti wu ja gts 450 teeb umbes pool tundi icon_lol.gif pole nagu pointi lolli mängida mul. Cpu pealt ei lase keegi gpu runni niikuinii beer_yum.gif
Edit:
MW run läbi. ja Margus, sai koha 36 thumbs_up.gif Nagu Moon* ütles:
...or Estonia wouldnt been represented in this challenge - and that
would be a shame, or course.. International is supposed to mean International. So hurray for Margus! (and all the rest of us)
http://www.arizonamoon.eu/cs/Milkyway-09-03-2012-TM.html
Moo! run tulemas:
Name: The March Titans Moo! Wrapper
Project: Moo! Wrapper
Issued by TitanesDC
Start time: 2012-03-19 00:00 GMT
End time: 2012-03-26 00:00 GMT
Edit: Eesti on seljatand vahepeal sellise suure riigi nagu Türgi: http://boincstats.com/stats/boinc_country_stats.php?pr=bo&st=0#36 thumbs_up.gif
Edit: Pg run tuleb, cpu only: http://www.primegrid.com/forum_thread.php?id=4191#51745
Marie-Sophie Germain Challenge:
Start: 1 April 2012 18:00 UTC
End 3 April 2012 18:00 UTC.
Length: 2 day (48 hours)
Subproject: Sophie Germain Prime Search (LLR)
Edit: run käib juba thumbs_up.gif
Tsitaat Mankkalt:
can't afford any more 1500 euros monthly electrical bills, so cutting down here, 9 GPU's & around 30 CPU's will still be running, but count me out for the next challenges, not stopping, but taking it easy for a while.
Tsiteerides teisalt:
With great power, comes great electric bill.
Edit: run läbi, jäin kohale 204 icon_biggrin.gif Krt tahtsin esimese 200-ja sisse saada icon_lol.gif http://www.primegrid.com/challenge/2012_3/top_users.html
Edit: lõpuks ometi sain ati mälu kiirused alla lasta (thanks to Rob*):
To ease up on the temps and power use I have also downclocked the memory speed of my card through Catalyst. Here's how:
Exit Boinc.
Go into Catalyst and make a preset for the speeds you want to use. I called mine 900-300 (GPU speed 900MHz/Memory speed 300MHz).
Close Catalyst.
You need to find and edit the profile for this preset file. Catalyst put it here: c:/users/computername/appdata/local/ATI/ACE/profiles/900-300.
If you cant find it, check your folder options - show hidden files etc... windows has to show everything.
There you will see an xml file with the file name you named it in the Catalyst. You will edit this file in Notepad.
Approximately midway down this file you will see a section that looks something like this:
(First gpu (gpu 0) or only gpu: )
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="50000" />
<Property name="Want_1" value="90000" />
<Property name="Want_2" value="90000" />
(Second gpu (gpu1): )
<Feature name="MemoryClockTarget_1">
and so one...
Change each of the values to 30000 where the first three digits is the new lower memory speed you want. Save the file and exit.
Open Catalyst again and go to Presets.
Click on the name of the preset file you created.
Now go to Overdrive. You will see the new lower memory limit displayed to the left of the Memory Speed slider. Move the slider to the new lower speed.
Click the name of the preset file name again to set the new speed.
Restart Boinc.
I give full credit to Zydor from the MW forum for his patient assistance in getting this to work.
Distrtgen testib ati beta appi:
Here are the time / wus for AMD ATI and NVIDIA DistrRTgen.
HD 7970 = 10 minutes
HD 6990 = 35 minutes (2 WUS)
HD 5770 = 1 hour and 35 minutes
GTX 590 = 23 minutes (2 WUS)
GTX 580 = 19 minutes
GTX 295 = 60 minutes (2WUS)
Lisaks:
Times are estimates...
HD 7970 = 10 min
HD 7950 = 16 min
HD 6990 = 35 min
HD 6950 = 40 min
HD 5870 = 51 min
HD 5830 = 85 min
HD 5770 = 95 min
GTX 680 = 17 min
GTX 590 = 23 min
GTX 580 = 19 min
GTX 570 = 24 min
GTX 560 TI = 35 min
GTX 560 = 44 min
GTX 460 = 51 min
GTS 450 = 73 min
GTX 295 = 60 min
GTX 275 = 77 min
Not bad thumbs_up.gif ise veel ei käpi seda samal põhjusel nagu Poem beeta gpu appi - vajab boinc beetat yawn.gif ma ei viitsi beetadega jamada.
Edit: lisasin põhikastile mälu juurde pärast poolteist aastat mõtlemist icon_lol.gif http://www.upload.ee/image/2229537/nfs_at_home.jpeg
Nüüd saab nfs @home normaalselt jooksutada thumbs_up.gif Kuigi põhieesmärk on siiski neuronat proovida, sel 1 wu per 1cpu core võtab kuni 6giga rammi. Sisse saab invitationiga, ma mingi koodi sain aga servu on praegu maas kahjuks. Eks ta üks eliidi project ole eusa_think.gif
Edit Distrtgen run tuleb paari päeva pärast:
Rainbow Resurrection: 2012-04-07 16:00:00 GMT - 2012-04-10 16:00:00 GMT
This 72 hour challenge will feature Primegrid style user and team statistics and only work handed out after the start time and returned before the completion time will be counted. In addition all WUs that are part of the challenge will receive 1.25x the credit that is received ordinarily.
The reason for this challenge is two fold:
1) The new hardware has been performing excellently and is averaging less than 20% utilization
2) An ATI/OpenCL app version is in early alpha stages and this challenge will be helpful in seeing if we can handle full 24/7 CPU+GPU where ATI will be added in the future.
sõnum 06.04.2012 12:25:12 vasta tsitaadiga
Vaatasin siin et keerate endal videokaartidel kellasid ringi jne, aga keegi ei tundu muutvat GPU pinget, mida võib samuti usinalt alla tõmmata kui default kellal seda jooksutada. Endal näiteks default 1.0375V pealt toodud alla 0.950V peale kellasid muutmata (ei oskale küll @home asjades, aga mängudes ja burn-in testides ei mõjutanud mitte mingil viisil negatiivselt). Sellega peaks ka usinalt alla saama ülemisest tipust temperatuuri, enda näitel 10 kraadi.
Nvidia meestele Nvidia Inspector pinge muutmiseks, saab startupi tekitada shortcuti, mis asja ära teeb. AMD meestele hetkel soovitada ei oska, aga kindlasti on võimalused olemas.
sant
sõnum 07.04.2012 21:03:29 vasta tsitaadiga
mikk36, Üsna huvitav idee iseenesest, aga mul on gpudel shaderid suht piiripeale kellatud ilma overvoltimiseta, nii et mulle selline tegevus ei sobi icon_biggrin.gif
Mälu kiirused on mul alla lastud, see kompenseerib shaderite klokki.
Kas muidu mäludel saab ka eraldi pinget alla lasta? Pole kunagi videode over või under voltimisega tegelend.
bbad
bbad
sõnum 08.04.2012 18:15:48 vasta tsitaadiga
Paar aastat jäi vahele, nüüd asusin ka jälle vaikselt boinci jooksutama...
Kommentaarid: 105 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 98
sant
sõnum 08.04.2012 20:51:45 vasta tsitaadiga
bbad kirjutas:
Tore, mis projecte muidu jooksutada plaanid?
Vaatasin su profiili kasti ja cpu peal väga midagi jooksutada ei soovitaks, rohkem gpu peal soovitaks jooksutada beer_yum.gif
XeStAiSy
Aeg Maha 2a
sõnum 09.04.2012 13:09:59 vasta tsitaadiga
Ma tulen suvel tagasi runnima. Saaks faking boileri kuskile valguse patarei taha. Vaatamata sellele ,et ma pole pikemalt lasknud midagi on elektri arve juba üle 100€
Raibe iga kuu tõuseb 10€ Oli aasta tagasi 60€ suvel, talvel 70-80€ nuud ilma runnimata on ikka tõusu teel arved.
Meil eestis elavad ainult miljonärid kõik kes peavad maksma ulme arveid.
sant
sõnum 13.04.2012 02:30:24 vasta tsitaadiga
Margus, eks sul õigus ole, hinnad tõusevad ja jäävad tõusma - selle nimi on kunstlik inflatsioon + muidugi kunstlik hindade tõstmine. Näiteks elektri hinda tõsteti kunstlikult (enegia kvoodid mingid) co2 maksuga, maksame küll tühja aga nõutakse.
Praegu käib distrtgen run, boinc 7 beeta (nõmedad bugid, aga valikut pole) on endal ka peal et ati pealt jookseks, 6870 jookseb 67 minti score 10 947 punni, 7970 teeb 10 minti. Runtimed erinevate ati kaartide ja driveritega on seinast seina. Sinu kaart peaks jääma 45 ja 25 mindi kanti icon_lol.gif pole võimalik ennustada.
Edit: distrtgen run läbi ja: position 47.....sir sant............5,243,852.50 points thumbs_up.gif esimese 50-ne sekka siiski icon_biggrin.gif
http://boinc.freerainbowtables.com/distrrtgen/challenge/2012_04/top_users.html
Osavõtt oli päris korralik, umbes 1,6 petafloppi roamis, see siis umbes 1\4 boinc maailmast icon_biggrin.gif
Steve, kes on top cruncher maailmas oma mammut gpu pargiga, ei saand esikohta näiteks icon_eek.gif
Meie team sici sai uue liikme, imsaguy:
I use my gpus (7970) to make a living. Patrick asked me to help for this challenge. I dont mind helping out for the challenges, but long term boinc generating costs me real money. (I have >50 gpus)
Tea kui ta kõik gpu-d tulele laseb, kas ta saaks ka esikoha mõnes runnis eusa_think.gif
Edit: lasen endiselt distrtgen ati beetat, nüüd on boinc 7 esimene stable release väljas - 7.0.25.
Peaks mainima et kaardid on väga jahedad ja vaiksed endiselt, ja watte läheb aint 380 kogu kasti peale 12.2 ja 12.3 driveri all (need ei tõmba cpult tuumasi ati gpule).
Praegu lasen 11.8 kuna 11.3 ei tööta lihtsalt ja 11.8 tõmbab 1 cpu core per 1 ati gpu: http://www.upload.ee/image/2255328/distrtgen_ati_beta.jpeg
Scoor on veits parem kui collatzi lastes, ja kast võtab 100 watti vähem kui collatzi lastes ja nii 150 watti vähem kui moo!-d lastes.
Nii et soovitan proovida Margus icon_wink.gif Vähemalt nädala lõppudel thumbs_up.gif
XeStAiSy
Aeg Maha 2a
sõnum 15.04.2012 07:17:38 vasta tsitaadiga
Su kast teeb 380w. Minu 240 idle 420-480w loadis. 6970 tarbib rohkem kui 4870x2. Single gpu rebib voolu igalpool isegi netis surfates.
sant
sõnum 21.06.2012 17:23:27 vasta tsitaadiga
Margus kirjutas:
Ma pidasin silmas et distrtgen ati võtab vähe voolu, moo!-d lastes võtab 6870 2tk rohkem voolu kui 1 6970. Proovi järgi distrtgen ati, siis saad aru icon_wink.gif
Võid vaadata mu poste sici foorumis, ja kui viitsid osa võtta beta appi testimises.
Margus, 5870 teeb distrtgen ati wu-d umbes 45 minti, huvitav paljuga su 6970 teeb icon_biggrin.gif
Mu 6870 teeb stockis 70,4 minutit.
Edit: boinc maailmas on toimunud väike muutus, team sici on võtnud esikoha boinc totalis: http://boincstats.com/stats/boinc_team_stats.php?pr=bo&st=0#1
Edit: pg run käib (gfn - Generalized Fermat Prime Search
nvidia gpu): http://www.primegrid.com/
Kui äkki keegi soovib osa võtta.
Sahib
sõnum 06.07.2012 23:21:33 vasta tsitaadiga
sant
sõnum 01.10.2012 00:10:01 vasta tsitaadiga
Distrtgen run hakkab varsti kui kedagi peaks huvitama:
http://boincstats.com/en/stats/challenge/team/chat/247
Edit: jäin ikka esimese 50-ne sisse thumbs_up.gif
Edit:
BTW I can confirm what willy says (average times):
distrrtgen v3.48 (cuda23) 2,290.57 GTX 560Ti (266.66)
distrrtgen v3.52 (openCL) 1,880.00 GTX 560Ti (266.66)
distrrtgen v3.52 (openCL) 1,175.45 GTX 560Ti (301.42) 1cpu
distrrtgen v3.48 (cuda23) 1,362.58 GTX 570 (301.42)
distrrtgen v3.48 (openCL) 1,415.45 GTX 570 (301.42) 1cpu
http://www.freerainbowtables.com/phpBB3/viewtopic.php?f=4&t=3496&sid=f27458fb89a74bcf50ae3c176cfeb732
See on nvidia opencl app-i tulemused distrtgenis, kui tööle saab, siis jookseb kiiremini kui cudat lastes, kui ei saa tööle siis kiiremini ei jookse. See veel testimisel, ehk siis kõigil tööle ei hakka nii et perf oluliselt paraneb, aga kes tahab võib proovida.
Gtx 570 ja 670\660 (non-perfect) ei pidand perf paranema. 550ti ,560ti ja 580 (perfect) peaks kõik saama rohkem perfi, ehk siis kaardid mil pole 1 või enam shaderit lukus (non-perfect). Väga huvitav statistika Willy poolt iseenesest.
Edit: primegridis hakkab run 5-ndal octoobril: http://www.primegrid.com/forum_thread.php?id=4535&nowrap=true#57489
The challenge will begin 5 October 2012 18:00 UTC and end 6 October 2012 18:00 UTC. Application builds are available for Linux and MacIntel 32 bit and Windows 32 and 64 bit. Only work units issued AFTER 5 October 2012 18:00 UTC and received BEFORE 6 October 2012 18:00 UTC will be considered for credit.
davidco
sõnum 01.10.2012 01:33:54 vasta tsitaadiga
Keegi mind selle üritusega kiiresti kurssi viitsib viia, aitaks ka eestit väheke. icon_lol.gif
Kommentaarid: 92 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 87
sant
sõnum 31.10.2012 00:56:56 vasta tsitaadiga
davidco kirjutas:
Üritus käib nii: iga mingi aja tagant korraldavad erinevate projectide pidajad või cruncherite tiimide kaptenid tiimide vahelise võistluse.
Pärast seda kui korraldaja on ürituse ja selle toimumise aja välja kuulutanud, peavad tiimide kaptenid nõu oma tiimi liikmetega millisest challengest osa võtta, ja kui kokkulepe on saavutatud, siis kapten regab tiimi ära, ja niipalju tiimi liikmeid võtab sellest challengest osa, kui soovib osa võtta. Mitte kunagi pole osavõtt 100% .Kohustuslikkust pole.
Võistlemine ei käi riikide või eraisikute vahel, vaid käib meeskondade vahel. Iga koha eest mis meeskond võistlusel saab, saab ta cup punkte, ja aasta lõpul jagatakse esikohad välja nendele tiimidele kes kõige rohkem cup pointe kogusid.
Üksik isik võib teha oma tiimi näiteks, ja liituda selle tiimiga challengesse, ja siis üksi lasta. Nii iseenda kui ka tiimi maa mida sa tahad esindada saab valida. Pole üheski challenges näinud team estoniat, seega eeldan et keegi ei halda seda tiimi.
Minu meeskond on määratud rahvusvaheliseks (iga tiim võib esindada mistahes maad, või olla rahvusvaheline), tiimi liikmena esindan mina Eestit, tiimi võidu punktid lähevad tiimile ja minu pc-de tehtud töö eest saadud punktid lähevad Eestile.
Edit: PG run läbi, ja jäin esimese 300-saja sisse (lootsin küll 200-saja sisse pressida). Peale minu torkas veel üks eestlane silma: Tarmo ILves thumbs_up.gif Äkki oli veel keegi, aga ei pand tähele, kui nii siis võite ju siin märku anda icon_biggrin.gif
Mina Ja Tarmo: positon 231 sir sant ja position 245 Tarmo Ilves http://www.primegrid.com/challenge/2012_7/top_users.html
Praegu hakkab Kohe collatz run, kui keegi tahab osa võtta: http://boincstats.com/en/stats/challenge/team/chat/254
Edit: collatz run ammu läbi, jäin kohale 33: http://boincstats.com/en/stats/challenge/user/list/254/credits
Testivad seal collatzis usinasti uusi cuda appe ja gpu tööd ei tule praegu: http://boinc.thesonntags.com/collatz/forum_thread.php?id=914&nowrap=true#15241
Edit: collatzis fixiti probleem ära:
It was a scheduler problem related to the new CUDA WUs. It is fixed and there is ATI work now.
Edit: pg run hakkab 2-he päeva pärast: http://www.primegrid.com/
An 8 day Challenge is being offered on PrimeGrid's 321 Prime Search (LLR) application. To participate in the Challenge, please select only the 321 Prime Search (LLR) project in your PrimeGrid preferences section.
The challenge will begin 1 November 2012 18:00 UTC and end 9 November 2012 18:00 UTC.
http://www.primegrid.com/forum_thread.php?id=4584&nowrap=true#58281
viimati muutis sant 02.12.2012 15:23:37, muudetud 2 korda
Sahib
sõnum 01.11.2012 00:02:03 vasta tsitaadiga
Mõtlesin sellest isegi osa võtta, aga ei oska kuhugi "kirja panna" ennast icon_smile.gif
sant
sõnum 01.11.2012 01:16:31 vasta tsitaadiga
Sahib kirjutas:
Kui sa hakkad jooksutama seda pg alam projecti ise (ilma tiimita), ja laed töö alla peale runni algamist ja repordid enne lõppu, siis saad tabeli koha niikuinii - unustasin selle ennem mainida icon_redface.gif
Einsteini cuda bugi lahedus:
Just an FYI for any NVIDIA folks trying to use Einstein cuda apps and getting 'computation errors' almost immediately after starting the wu:
If you have a 2nd or third gen Intel chip that has the integrated video (even if it is not the active gpu), and you recently updated the driver, Intel snuck in a HD xxxx OpenCL driver for the card that is the likely cause of the error (I spent volumes of time troubleshooting this). Uninstall the Intel xxxxx OpenCL driver, reboot and voilà, Einstein runs again.
I saw many other users on other forums downgrading BOINC and changing permissions -- not preferable stuff -- and it is not necessary.
Phil
ps - My system is a Win7 Ultimate SP1 (64-bit), BOINC 7.0.28.
Sahib, kuda sul muidu distrtgen gpu wu-de runtimed on? Mul on kõik paar minti pikemaks läin paar päva tagasi.
Sahib
sõnum 01.11.2012 01:32:55 vasta tsitaadiga
v3.49 (cuda40) ja v3.48 (cuda23) laseb praegu mõlemat vaheldumisi. Kuna mul on CPU ka kogu aeg koormatud (PrimeGrid), siis see mõjutab pisut.
Vaatasin et mul on ainult üks error ja seda siis 30 Oct 2012 (distrrtgen) v3.48 (cuda23)
sant
sõnum 04.11.2012 16:06:54 vasta tsitaadiga
Sahib, paistab et sul ei läind pikemaks runtimed.
Challenges on pobleemid, keegi laseb vigase hostiga ja genereerib julmalt prahti icon_biggrin.gif
At about 3 seconds per WU, this host could burn through ~20 "challenge qualified" WUs per core (and it's a quad core) in the last minute of the challenge. If this host was offline, these units most likely would not have been issued until after the deadline. But sorry, now they will have to be re-issued and completed before the challenge is "final". Extend this argument to the last 2, 5, 10, or more minutes of the challenge. Who's left to clean up this mess? Hosts like this MUST be banned (in whatever way technically possible, if any, in the BOINC world) as soon as they are recognized. FYI as of 1600 UTC Saturday this host has more challenge "credit" than the other 19 of the top 20 *combined*. And it is getting worse. How long will it take to work it all off?
I'd generally applaud an effort to contact the user, though I realize there is a fear of "big brother" intrusion, language barriers, and so on.
the bizarre thing is that it looks like only 1 of the 3 cores he's running is doing this as 2 of his tasks have been there for some time. Either way, I agree it's going to take a long time to clean up his mess - there's already several thousand tasks that will need to be checked.
http://www.primegrid.com/forum_thread.php?id=4584&nowrap=true#58981
Edit: nüüd laseb juba 3 matsi vigaste hostidega ja genereerivad veel julmemalt prahti icon_lol.gif
Näis millega seekordne üritus lõppeb.
Edit: paistab et probleemi olemuse aluseks on win8 mis nendel hostidel on ühine nimetaja icon_biggrin.gif
Eks nad uuri mis on täpsem probleem. Mingi 10 kilo wu-d on juba praht ja kõik tuleb teistel kasutajatel üle crunchida. Need on siis wu-d mis jooksevad 15-50 tundi cpu peal, normaalne. Ennem muidugi challenge punktid lõplikku kinnitust ei saa kui kõik wu-d on üle kontrollitud okse.gif lisaks ka need mis on valid tuleb üle kontrollida.
Sahib
sõnum 04.11.2012 16:15:38 vasta tsitaadiga
Mõni mainis vist ka kellamist ühe põhjusena?
sant
sõnum 14.12.2012 23:46:31 vasta tsitaadiga
Sahib kirjutas:
Jah mainiti küll, aga tõsised kellajad teavad et selline ebastabiilsus, kus ükski wu pole valid ja wu on vigane paari secundiga, lõppeb kroonilise bsodiga. Imo on see ebareaalne et probleem on oc-s, aga eks mingi aja pärast ole vastus teada icon_biggrin.gif
Edit: Sahib,
Qazwaplol also increased his memory from 1333MHz to 1866MHz, which made a 2 hour difference per task !!
In his post he said:
321LLR on a Intel Core i5 2500K, @ 4.5GHz:
- with 1333MHz RAM it takes around 9,5 hours per task
- with 1866MHz RAM it takes around 7,5 hours per task
Sul intel, sul on mõtet proovida kui huvitab, mu PII hexa 3,2ghz (ddr3 1600mhz cl9)tegi wu-si lõpus (algul olid veits lühemad wu-d) umbes 19,5-e tunniga icon_biggrin.gif See project on inteli peal oluliselt efektiivsem.
Pg 321llr challenge läbi ja jäin kohale 126.
Tarmo Ilves jäi kohale 228.
Sahib jäi kohale 355.
http://www.primegrid.com/challenge/2012_8/top_users.html
Rohkem eestlasi ei silmand.
Edit: Praegu käib einsteinis challenge, servu kukkus nüüd küll maha kahjuks, ja võib juhtuda et ma ei pressigi esimese 50-ne sisse icon_razz1.gif Praegu kohal 52: http://boincstats.com/en/stats/challenge/user/list/263/credits
Edit: challenge läbi ja sain ikka esimese 50-ne sisse icon_biggrin.gif http://boincstats.com/en/stats/challenge/user/list/263/credits
Uue\vana 12core opteron servu kasutusele võtmine lõi mul elektri arvele eelmine kuu 10 euri otsa. Arve on siis 93 euri, ootan juba huviga mis siis jaanuari arve tuleb, kui total tuleb minimaalselt +50% nagu lubati eelmine aasta siis tõmban crunchimisel kõvasti tagasi ja pean hakkama vaatama millisesse riiki kolida lähitulevikus icon_biggrin.gif
Ma peaks jaanuari kuus kenasti oma sihi - Miljard punkti - boinc totalis täis saama, mis ei tähenda küll seda et ma tahan crunchimisest 100% loobuda koheselt icon_biggrin.gif
Edit: Distrtgenis läksid ikka wu-d pikemaks:
* There is increased run time however credits were inreased as well. Here are the scaling factors we are currently employing for credits where NTLM is the baseline:
CPU multiplication factors:
ntlm = 1.0
md5 = 1.16
sha1 = 1.21
mysqlsha1 = 1.80
GPU multiplication factors:
ntlm = 1.0
md5 = 1.10
sha1 = 1.56
mysqlsha1 = 2.49
cuda40 windows version was released and it performs much poorer than the cuda23 version (I tested this on *nix and this is why I didn't release such a version) *but* I don't think Martin tested this well. The cuda40 windows version has been marked obsolete so hopefully new WUs will go back to targetting cuda23 with the old app.
Edit: Gpugrid run hakkab homme kui keegi osa võtta tahab:
Name: December of the living dead
Project: GPUGRID
Start time 2012-11-27 13:30 UTC - End time 2012-12-04 13:30 UTC
http://boincstats.com/en/stats/challenge/team/chat/275
Edit: gpugrid run läheb hästi, server püsib töös ilusti, team on ilusti esikohal, ise olen top 50-s icon_biggrin.gif ja seda ainult ühe kaardiga- ti560 448c. Kerge oc peal ja paistab et tuleb umbes 200 tuhat punni päevas, seda siis long runne lastes. Short runnidega tuleb vähem punne ööpäevas. Short runnidega pole mul kunagi interface lagi old, aga long runnidega osadel kasutajatel on lag, kõhklesin kas lasta neid, siis otsustasin et proovin ikka ja panin endal 2 päeva tagasi long runnid jooksma ja ennäe imet, polegi interface lagi icon_biggrin.gif
Minu runtimed vs credit:
long run: runtime - 28,707 sec vs credit - 90,000.00 Long runs v6.16 (cuda42).
long run: runtime - 30,793 sec vs credit - 60,900.00 Long runs v6.16 (cuda31).
Short run: runtime - 7,020 sec vs credit - 11,250.00 ACEMD2: GPU molecular dynamics v6.16 (cuda42).
Short run: runtime - 12,531sec vs credit - 11,250.00 ACEMD2: GPU molecular dynamics v6.16 (cuda31).
Cuda 42 wu-d jooksevad kiiremini kui cuda 31 wu-d, seega cuda 42 scoorib paremini, vähemalt mul:
win7 pro64, boinc 7.0.28(x64), ti560 448c väike oc, nvidia driver 301.42.
Valida neid vist ei saa, aga enamus wu-si mis servu saadab mulle on niikuinii cuda 42. Valida saab short run, short run beta ja long run vahel. Pole betat proovinud icon_biggrin.gif nii igaks juhuks, praegu käib run ka nagu.
Vaatan et ti560 448c kerge oc-ga scoorib sama mis stock gtx570 - nii 200 kilo ööpäevas. Normungel oc-ga gtx 580 peaks siis 250 kilo ööpäevas tõmbama icon_biggrin.gif
Edit: gpugrid run läbi ja jäin kohale 44 icon_biggrin.gif ja seda ühe kaardiga icon_razz1.gif
Siin mu gtx 560 ti 448c host gpugridi laskmas: http://boincstats.com/en/stats/45/user/detail/29535/lastDays
Mälu on stock kiirusel, shaderid 1600 mhz, kui kedagi peaks huvitama.
Edit: ootamault läks lahti milkyway run: http://boincstats.com/en/stats/challenge/team/chat/289
Just nägin icon_biggrin.gif ise ma osa võtta ei saa sellest.
Käib nfs challenge ,aga mul seekord kastid üldse sellega ei töötanud, ja tööd on mul nii palju et pole aega süveneda sellesse probleemi thumbs_down.gif
Varsti hakkab primegrid run: http://www.primegrid.com/
Pps sieve only, toetab gpud (ati ja nvidia) ja cpud, cpu pealt mõttekas jooksutada pole imo.
Sahib
sõnum 17.12.2012 19:10:34 vasta tsitaadiga
Mötlesin ka primegrid run osa võtta, aga juba mitu päeva ei ole sealt mitte ühtegi WU-d saadetud gpu-le. CPU töötab kenasti icon_rolleyes.gif
sant
sõnum 14.01.2013 03:21:37 vasta tsitaadiga
Sahib kirjutas:
Ühel kastil on boinc 6.12.34 (x64) ja teisel kastil on boinc 7.0.28 (x64) ja mõlema kasti nvidia driverid on 301.42.
Ausalt öeldes ei mäleta et poleks primegridis tööd saand gpule eusa_think.gif
Uuemat boinci oli vaja einsteini challenges, muidu tööd ei saatnud gpule, ja vist uued seti ati appid vajavad samuti neid beeta versioone millest ma nii kaua kui võimalik eemale hoian.
Edit: Primegrid run läbi ja jäin napilt esimese 100-ja sisse - 99-s koht icon_biggrin.gif http://www.primegrid.com/challenge/2012_9/top_users.html
Tarmo jäi kohale 241, rohkem eestlasi ei silmand.
Minu tiimist jäi Ross kõrgeimale kohale: 3-s
Rauaks tal:
For those that are interested I run 8 3930s and 4 980s and for this last challenge 14 580s ,2 570s and 1 590 plus 2 EVGA 660 TI sig 2.
Tried to run my 4 7970s but they kept crashing.
Edit: Sain oma pci e extender kaablid eelmine nadal katte: http://www.upload.ee/image/2933206/pci_e_extenders.jpg
Pildil siis 6tk pci e x16 kaablit ja 1tk x8 to x16 kaabel. Testisin x16 kaablid 1 haaval ja minu yllatuseks 2 kaablit tootasid aint x8 kiirusel icon_neutral.gif Ma tellisin kaableid rohkem kui vaja, nii igaks juhuks icon_biggrin.gif kokku maksis 23,5 euri umbes.
Edit: Primegrid run hakkab tana: http://www.primegrid.com/forum_thread.php?id=4760&nowrap=true#61012
Welcome to the Year of the Snake Challenge
Special Note: This is the second ever GFN challenge and probably the last, so for those who are not familiar with GFN we are searching for exceptionally large prime numbers. If a prime is found during the challenge it will be the 11th largest prime number ever found. In fact, we found a new GFN prime just two days before the start of the challenge! Let's find one or two more!
A 13 day Challenge celebrating the start of a new year is being offered on PrimeGrid's Generalized Fermat Number (GFN) application. Only SHORT Work Units may be used in this challenge. To participate in the Challenge, please select only the Generalized Fermat Prime Search project and also select Short tasks in your PrimeGrid preferences section.
See siis gpu ja cpu, kuigi ise ma seda ei ole lasknud cpu pealt icon_biggrin.gif See jookseb gpu peal nii krdi tublilt.
Edit: run laheb hasti peaks mainima icon_biggrin.gif Sahib, sa oled minust eespool ma vaatan thumbs_up.gif
Sahib
sõnum 15.01.2013 12:55:36 vasta tsitaadiga
Kus sa seda jooksvat tabelit näed ?
sant
sõnum 04.03.2013 01:49:49 vasta tsitaadiga
Sahib kirjutas:
Siit naen: http://www.primegrid.com/challenge/2013_1/top_users.html
Jooksvalt ei vaata ma mingit tabelit.
Said must korgemale thumbs_up.gif Sul koht 97.
Edit: nii 35-e tunni parast hakkab pg run: http://www.primegrid.com/
A 1 day Challenge is being offered on PrimeGrid's Sophie Germain Prime Search (LLR) application. To participate in the Challenge, please select only the Sophie Germain Prime Search (LLR) project in your PrimeGrid preferences section. The challenge will begin 14 February 2013 18:00 UTC and end 15 February 2013 18:00 UTC.
Edit: challenge ammu labi, ja unustasin siia kirjutada icon_biggrin.gif heh.
Ise sain mingi aeg tagasi oma miljard punni boinc totalis: http://boincstats.com/en/stats/-1/user/list/0/0/Estonia#1
Tehtud icon_cool.gif siht saavutatud, tiksun niisama nüüd...
Sahib
sõnum 22.03.2013 21:55:07 vasta tsitaadiga
Equinox Challenge on siis läbi. Tulemused:
Tarmo Ilves 158
sir sant 172
Sahib 466
Lennupiletid.ee 671
sant
sõnum 11.06.2013 18:29:45 vasta tsitaadiga
No nii icon_biggrin.gif pole ammu midagi kirjutand:
Varsti hakkab PG run: http://www.primegrid.com/
To participate in the Challenge, please select only the SR5 (LLR) project in your PrimeGrid preferences section. The challenge will begin June 15th 2013, 18:00 UTC and end June 18th 2013, 18:00 UTC. Application builds are available for Linux , Windows and MacIntel 32 bit and 64 bit. CPU's with AVX capabilities will be significantly faster than the ones without, as this instruction set allows for more computing power.
Sahib
sõnum 20.06.2013 18:39:31 vasta tsitaadiga
Sir sant: koht 157
Tarmo Ilves: koht 164
Sahib: koht 371
uus teema   vasta Hinnavaatlus »  HV üritused »  Boinc mine lehele eelmine  1, 2, 3 ... , 21, 22, 23  järgmine
