| Palju sul sääste on? (Säästude hulka lugege ka investeeringud välja arvatud praegune eluase ja pensioni II sammas) |
| pole mul midagi, elan palgapäevast palgapäevani või ei oma regulaarset sissetulekut |
11% |
[ 29 ] |
| vähem kui ühe kuu netosissetulek |
6% |
[ 17 ] |
| 1 kuni 2 kuu netosissetulek |
19% |
[ 50 ] |
| 3 kuni 4 kuu netosissetulek |
13% |
[ 35 ] |
| 5 kuni 6 kuu netosissetulek |
9% |
[ 23 ] |
| 6 kuni 12 kuu netosissetulek |
11% |
[ 28 ] |
| rohkem kui 12 kuu netosissetulek |
27% |
[ 70 ] |
| hääli kokku : 252 |
MatchMaker
16.09.2011 09:06:03
Mingi kreeklase kommentaar asjale:
| Forgive me for stating the obvious, but German officials are upset only because their deeply amateurish austerity plan has failed with a thud. Your claim that a Greek exit is the only option is beyond ridiculous. Greece, like any other country in its place, needs temporary access to cheap credit in the order of 2-3%. Once it can stand on its own feet then it can repair its economy and such temporary measures will no longer be needed. You can accomplish reasonable credit costs via a Eurobond or a unique mechanism to provide Greece with the appropriate cost of funds needed. German responsibility in ruining the Greek economy is undeniable and instead you need to put the blame on ignorant politicians and your unbelievable obstructionism. Talking about children that they need discipline! Shame on you! |
HV valuutakalkulaator |
| Kommentaarid: 472 loe/lisa |
13 :: |
7 :: |
359 |
Taux007
16.09.2011 09:54:56
Päris mihkel on valmis lahendusi pakkuma, et oma tagumiku head elud säilitada.
| Kommentaarid: 47 loe/lisa |
46 |
fallout3
16.09.2011 14:17:48
| Taux007 kirjutas: |
| fallout3, huvitav oleks ka võib-olla võrdlus nn graafikualuse pinna kohta pärishinnal ja eeldataval hinnal. (S.t. et mis osa siis mida ületab) |
Kuna eeldatava hinna sain naftahinna ja pärishinna keskmisest erinevusest, siis on see eeldatav hind ja pärishind identse aritmeetilise keskmisega, ja nii palju kui mina aru saan, siis on sellisel juhul graafikualune pind ka täpselt sama. Ma suurem integreerimise meister muidugi ei ole, nii et võisin valesti aru ka saada.
Aga jah, see eeldatav hind on lihtsalt samade andmete kombineerimisel saadud konstruktsioon, et asju graafiliselt arusaadavamaks teha.
| Kommentaarid: 27 loe/lisa |
26 |
MatchMaker
16.09.2011 20:33:59
Schiff haris valitsust.
_________________ "We're doing the studies to make the proof" - RFK Jr. |
313 |
19.09.2011 10:00:51
Küsitlus I kvartali majanduskasvu kohta
Tegelik tulemus 9,5%
Küsitlus II kvartali majanduskasvu kohta
Tegelik tulemus 8,4%
Nagu küsitluse tulemustest näha, on päris kõvasti mööda pandud.
Tuleb uus küsitlus, palju tuleb III kvartali majanduskasv
Ise hääletasin 5-6%, sest eelmise aasta III kasvuga põhi on juba all ja edasised kasvud tulevad aeglasemad.
13 :: |
7 :: |
359 |
19.09.2011 10:21:19
7-8%
Kui rahade kasutamine ei takerdu.
200 |
Taux007
19.09.2011 12:11:48
Tanel, pole ju midagi mööda pandud. Kui kirjas on "Üle 3%" ning tulemus on 8,4%, siis õigus oli sisuliselt kõigil. Vastusevariandid olid lihtsalt halvasti sõnastatud. Sedakorda on vastusevariandid head, samas võiks olla variant "9% +" ka
viimati muutis Taux007 19.09.2011 12:13:20, muudetud 1 kord |
46 |
19.09.2011 12:14:49
Noh, sõnamäng sõnamänguks, sisuliselt pandi ikka mööda. Mäletan väga hästi seda aasta alguse pessimismi.
Sõnastasin uue küsitluse natuke paremini.
Lisasin ka selle, omast arust oligi see pandud, ju tegin sisestamisel mingi vea.
13 :: |
7 :: |
359 |
gemini
19.09.2011 13:01:36
| Hääletasin kah 5-6% variandi poolt kuna selle kasvu peaks välja vedama küll...
| Kommentaarid: 75 loe/lisa |
61 |
fallout3
19.09.2011 17:44:55
http://www.postimees.ee/569356/saksa-loetavaim-ajakiri-eestlased-on-euroopa-naidisrahvas/
Eestlased on Saksa ajakirja Spiegel arvates kriisidest raputatud Euroopa näidisrahvaks.
Riigi loetavaima majandus-poliitilisese ajakirja sõnul on eestlased peaaegu võlavabad, säästavad ilma nurinata ja on veel pealegi Euroopast vaimustuses.
«Nad elavad täielikult võrgustatud digitaalvabariigis ja on kõigele lisaks veel välja mõelnud, kuidas tasuta üle kogu maailma helistada,» seisab ajakirja värskes numbris. |
26 |
mTim
19.09.2011 18:59:47
| fallout3 kirjutas: |
No ja ongi Eesti leidnud oma nokia - väike riigivõlg
_________________ "I have never followed a rule. That is my rule. Do you follow? I don't." The Joker
Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad |
| Kommentaarid: 45 loe/lisa |
40 |
greaper
19.09.2011 22:13:06
Eesti meenutab mulle yht kunagist töökaaslast, kui ise ei viicinud mingit liigutust teha, siis sai toda venda pisut kiidetud a´la stiilis, et kuule sul tuleb see asi jumala hästi välja või et näita kuidas sa seda teeksid. Tyyp ajas rinna ette ja rahmis töö ära teha, ise irvitasin pihku ja vötsin raha vastu too aga käis nagu kukk ringi, et vaadake kui tegija mees ma olen, mis siis et kukkur tyhi ja vaev nähtud.
_________________ Psychologists usually attribute belief in conspiracy theories to a number of psychopathological conditions such as paranoia, schizotypy, narcissism, and insecure attachment, or to a form of cognitive bias called "illusory pattern perception". |
| Kommentaarid: 25 loe/lisa |
24 |
Scart
101 |
fallout3
19.09.2011 23:50:20
| mTim kirjutas: |
No ja ongi Eesti leidnud oma nokia - väike riigivõlg  |
Ja miks ka mitte. Meil on see tee juba käidud, millest enamus arenenud maailma praegu veel kõrvale põigelda üritab. Isegi kui olemasolevast võlast ennast välja trükkida, on reaalkulude vähendamine kõigil ikkagi ees. Minu arust teeme meie, hoolimata õpetajate palgatõusu aktsioonidest ja muust, juba väljakul sooja, samal ajal kui teised alles reegleid läbi loevad, kuigi mäng on vältimatu. Ansipi üle võib ju naerda, aga 10 aastat on veel selle kuulsa hüüdlause tähtajani veel aega ja see saab ilmselt rohkem tõeks kui see väljaütleja ise ka arvata oleks võinud.
26 |
20.09.2011 07:29:36
| greaper kirjutas: |
Eesti meenutab mulle yht kunagist töökaaslast, kui ise ei viicinud mingit liigutust teha, siis sai toda venda pisut kiidetud a´la stiilis, et kuule sul tuleb see asi jumala hästi välja või et näita kuidas sa seda teeksid. Tyyp ajas rinna ette ja rahmis töö ära teha, ise irvitasin pihku ja vötsin raha vastu too aga käis nagu kukk ringi, et vaadake kui tegija mees ma olen, mis siis et kukkur tyhi ja vaev nähtud. |
Ma pole eriline kiitja, aga teatud inimestele tõesti see mõjus. Muidugi noomimine mõjus palju hullemalt...2 päeva norutasid ja iseseisvalt ei suutnud midagi teha - parem vaikisid asja maha ja tegid hiljem ööbimiskohas pitsi Jäägerit
Kõige hullem teatud sellidega see, et kui rahanumber teada, mis töö eest saab, siis loodetakse ka ise seda saada - 3-le tuttavale pakkusin tööd 5€/h...polnud nõus kuna ühe objektiga said ~15€/h (tükitöö). Ütlesin no ok, pakun edaspidi nende lähedal seda hinda... nüüd on vennad mingi kohaliku tegija juures 2€-ga juhutööl
Geeniused...
Samas arvan ma, et pikemas plaanis Eesti võlavabadus hea, aga inimesed vaatavad ikka enda elujärge. Kui see oluliselt ei parane või on kusagil 2001a tasemel, siis pigem minnaksegi mujale.
Mujal inflateeritakse hüvedest riik välja, aga see pikem protsess.
200 |
20.09.2011 07:31:53
link :: Investeerimisriskiga hoiuste tootlus
"Finantsinspektsioon analüüsis turu läbipaistvuse eesmärgil investeerimisriskiga hoiuste ehk investeerimishoiuste turgu, sealhulgas hoiuste tootlust ajavahemikul 1. jaanuar 2009 - 30. juuni 2011. Investeerimishoius on tähtajaline hoius, mille intressimäär sõltub finantsinstrumentide või muu hoiusega seotud vara väärtuse muutusest.
Eeltoodud perioodil lõppes kokku 62 377 investeerimishoiuse lepingut, mis jagunes 426 erineva hoiuse emissiooni vahel kogumahuga ligikaudu 274 miljonit eurot. Investeerimishoiuse teenust pakkus kuus krediidiasutust.
Investeerimishoiuse turuülene kaalutud keskmine tootlus kujunes vaadeldud ajavahemikul negatiivseks: - 0,46%. Kõikidest investeerimishoiusesse paigutatud rahalistest vahenditest teenisid kliendid 16% osas positiivset tootlust, 51% hoiustest olid nulltootlusega ja 33% negatiivse tootlusega."
| Kommentaarid: 182 loe/lisa |
146 |
fallout3
20.09.2011 14:39:08
Selle investeerimishoiuse kasutamine on kogu aeg paras lollus olnud.
| Väidetavalt plaanib Kreeka peaminister George Papandreou referendumi korraldamist, et otsustada, kas minna kärbetega edasi või väljuda euroalast ja seega ka Euroopa Liidust. |
Kuna streikide jms näol on vastuseis igasugustele reformidele suur, siis tundub et see referendum oleks ehk kõige õigem samm. Küll aga tekib probleem siis kui referendumi tulemusena otsustatakse ikkagi kokkuhoiupoliitikat edasi viia. Need praegused streikijad võivad siis asja päris kiiresti kodusõjani viia.
26 |
greaper
20.09.2011 20:42:08
Küll aga tekib probleem siis kui referendumi tulemusena otsustatakse ikkagi kokkuhoiupoliitikat edasi viia. Need praegused streikijad võivad siis asja päris kiiresti kodusõjani viia. thumbs_down.gif
kui seda asja vaadata numbrite ja majanduse pilguga, siis jah streikijad . Samas aga kui seda vaadata lihtsa inimese seisukohast, siis saan neist täielikult aru, rahvas on ju väidetavalt loll (ka siit teemast korduvalt läbi jooksnud), kui sellele lollile rahvale on vöimaldatud igati 10+ äraelamine ja palk (näidake mulle lolli, kes keeldub suurest palgast pöhjusel, et riigi majanduspoliitika pole jätkusuutlik, kui sina seda palka ei vöta vötab keegi teine, lihtne) ylevöimete elamise hinnaga ja siis see tahetakse korraga ära vötta, siis saan aru 100% miks inimesed protestima hakkavad. Meie oma apaatia ja tuimuse juures muidugi ei suuda möista nende temperamentsete inimeste käitumist. Ei öigusta löhkumist ega laamendamist, kuid saan aru miks inimesed möllavad, nemad ei ole töesti selles syydi, et nende valitsus on nad sinna s*ta sisse vedanud ja tunnevad nüüd et neid karistatakse.
24 |
fallout3
20.09.2011 22:37:02
| Valitsus on rahva poolt valitud - kui rahvas on loll, siis on ka valitsus loll, isegi kui see on koostatud tarkadest inimestest. Kes see oleks ikka 5 aastat tagasi mingit säästuparteid valinud kui praegu silmnähtavalt kehvas olukorras ja sundseisus ka mõistliku poliitika vastu mässatakse. Põhimõtteliselt jõuab kogu see asi ikkagi selleni, et lollid on olnud ka laenuandjad, kes ei ole rahapakkumist õigel ajal piiranud või siis on olnud lollid need, kellelt pärit info põhjal laenuandjad oma otsuseid vastu on võtnud. Kumbki neist seltskondadest ei ole Kreeka rahva poolt valitav, ja neil oleks pidanud olema parimad võimalused sellise olukorra ära hoidmiseks. Paraku on asi aga nii, et kuigi finants- ja pangandussektori süü suhtes on lihtne üksmeelele jõuda, on kõik neist ikkagi sõltuvad ja kõigi kulude ühe korraga nende kaela keeramine teeks kõigi jaoks olukorra veel hullemaks. Ja see viitab sellele, et nende samade sektorite regulatsioon on olnud puudulik, kuna selline olukord on üldse saanud tekkida.
26 |
21.09.2011 06:35:24
Kui uksest ja aknast laenu sisse ajada, siis vaevalt keegi keeldub.
Ka kõrgemast palgast ei keeldu keegi - ka meil peeti masust rääkijaid lolliks. Nagu Neivelt ütles, et ta sai 2006 selle eest sõimata. Kui 90% massist ei usu sündmuse toimumist ja rahvaesindajad kaagutavad kuni krahhi 1/5 läbimiseni suurest edust on vaja ikka ülipaindlikku rahvast.
Meie õnn oli see, et me polnud 10a selle auru all olnud...aga siin tegi ka see 2a kurja - 2008 ikka kuulis väga palju, et mina küll selle raha eest tööd ei tee. 2009 oli jutt juba vaikselt muutunud...
Seega nagu immigrandid telekas ütlesid - ei ei me küll tööd ei tee
Kreekas sama teema - seda alumise otsa töö ei taha kohalik teha ja seega läheb raha mujale.... ja linnas üksi elada ei saa tolle palgaga. 15-20km kaugusel küll.
Aga kohalik elab pigem 2-3X suuremast esivanemate pensionist
Kuni seda sotssüsteemi ei lõhuta pole näha ka et 10a plaanis Kreeka maj. positiivseks läheks... EL'i all jääme me sinna ilmselt igavesti peale maksma.
200 |
greaper
21.09.2011 20:50:20
http://chartsbin.com/view/2484 Meie palju kiidetud IT riik ikka ysna hale seal tabelis.
24 |
21.09.2011 21:00:08
greaper, sellest ju pikalt-laialt juttu olnud, Kõu ja muu mobiilse neti kasutajad tõmbavad taset alla.
Teistes riikides pole nii palju mobiilseid kasutajaid. Kui neid ei oleks, oleks meie tase oluliselt kõrgemal.
Aga kas me tahame mobiilsest netist loobuda pelgalt ühe tabeli pärast? Ma arvan et mitte.
13 :: |
7 :: |
359 |
Fukiku
21.09.2011 21:24:35
Ja olgem ausad - igasugused tabelikohad on ikka ka selgelt üle tähtsustatud. Uudiseid on hea treida neist, aga sisulist väärtust nad tihti ei kanna.
_________________ Foxic is just a simple fox
Enne kui sa küsid oma küsimuse - küsi seda vannipardilt! Rangelt soovitatav enne programmeerimise alafoorumisse uue teema tegemist. |
