• Koduleht: http://www.worldofwarplanes.com/
• Arendaja: Wargaming.net(World of Tanks)
• Stiil: Flight Combat MMO, Free-2-Play
• Väljalaske kuupäev: TBA
World of Warplanes is the flight combat MMO action game set in the Golden Age of military aviation. The game continues the armored warfare theme marked in the highly-acclaimed World of Tanks and will throw players into a never-ending tussle for air dominance.
Based purely on aircraft setting, World of Warplanes will allow players to build full-scale careers of virtual pilots offering machines of several key eras, staring from 1930’s with biplanes and up to Korean War jet fighters that led the way to modern air forces.
World of Warplanes will feature a wide range of warbirds, each of them unique in their effectiveness and behavior. Virtual pilots will choose from three main warplane classes — single-engine light fighters capable of engaging enemies in close dogfights, heavy fighters with their deadly straight attacks, and strafing aircrafts, the fearsome threat for ground targets.
Every plane will feature multiple variations of ammo types, engines, and other crucial modules, and their various combinations will allow to pick the optimal configuration for the most effective behavior in combat.
Isegi kui ta tuleb väga sarnase ülesehitusega, erinevusega, et tankide asemel on lennukid, on tegemist juba väga hea mänguga:) _________________ Winter is coming...
It's time for the next big World of Warplanes reveal, and this time around, Wargaming.net is focusing on its fearsome collection of German fighters.
Following on the heels of its American fighters release, the company is showing off its German tech tree, a new screenshot gallery, and a new trailer. The tech tree boasts 19 flyable models which are broken into two groups -- fighters and heavy fighters. Notable aircraft include the Bf109 and the jet-powered Me262, both marvels of World War II-era German engineering.
World of Warplanes' German fighters feature "fast altitude climbs and power dive attacks," and you can get a preview of each machine via the gallery below and the trailer after the cut.
[Source: Wargaming.net press release]
??? tulevad mingisugused pommitamise missioonid kus siis hävitajad peavad kaitsma? lahe oleks see WoT-iga kokku pista ja siis tankidele õhutõrje kahureid jagada
Igal juhul proovimas kindlasti kui võimalus avaneb _________________ "You cannot judge me. I am Justice itself!"
Mingi developer vms rääkis, et suures plaanis kunagi kauges kauges tulevikus hakkavad need kolm mängu (lennukid, laevad tankid) üksteist mõjutama. Täpsemalt klanni lahinguid siis
crazyxman Tegu on teise mänguga! World of Planes(Nüüdsest siis War Thunder: World of Planes) on tehtud sellise stuudio nagu Gaijin Entertainment poolt, World of Warplanes aga Wargaming.net pool!
Eks ta selle pärast olegi, et näha kes üldse viitsib nii paljugi kodutööd teha
natuke vale mõtlemine neil - tõsine huvi tankide vastu tekkis mul ka alles pärast WOT mängimist ning samas võiksid nad ka arvestada ju asjaoluga, et ma olen wot`is mitte vähe kulda ostnud ning ilmselt teeksin seda mängu sobivusel ka selles uues mängus + ehk jätkaksin sama ka wot`is...
WOT betas sai ka mitu pikka kuud vägagi aktiivne oldud ja minumeelest nad võiksid pigem selliseid aspekte vaadata kui seda, et kes googeldada oskab (mida ilmselt meist oskab igaüks).
Asi eriti random ikka, klassivend kes WOT'i suht vähe mängind sai kutse järgmine päev. Klassivend kes Wot'i tahhuijaa mänging pole siiamaani saanud. See kes kutse sai märkis ,et tal Joystick, kuigi tegelikkuses pole, sellepärast ilmselt ka sai, usun.
Jah, sest mul on joystick ja pole veel kutset tulnud. Rääkige kuida lennata on? On seal joystickuga üldse midagi teha või asi klaviatuuri peale üles ehitatud?
Ootan ka kutset. Saaksin sõbralt tähtajatult endale lennuki pedaalid, kangid jmt set'i laenata... äkki oleks isegi hea mängida siis sellist asja. _________________ Progemisest: https://byteaether.github.io/
Seisab keldris vana 386-486-Pentium1? Räägime! Ehk saan vanakesele uue elu anda.
Ah mis ikka, kapist vana hea Trusti joystick välja ja proovib lennata
Edit: Päris lõbus kiire mäng on ja lisaks, erinevalt World of Tanks'ist vajab see tõsiselt mänguoskust. Kui ikka ei suuda vastase lennuki eest ära põigelda või teisel korralikult sabas püsida, siis ega ikka kaua ei ela.
mikk36, ma ei tea ise ka praegu, mis värvi ma kadedusest olen... _________________ Progemisest: https://byteaether.github.io/
Jube mäng ikka pohmakaga mängimiseks on lühike mulje.
Samas tegin avalduse 45min-i ootasin ja kutse oli olemas. Erinevalt WoT-st vajab see mäng ikka palju harjutamist ja tier I võib ka hea nolfar ka tier 10 alla lasta. _________________ "You cannot judge me. I am Justice itself!"
Mina pole ka iial WOT-i mänginud ja sain kutse. Aga mulle mäng väga ei meeldi - liiga raske või ütleme võimatu on pihta saada teistele lennukitele. _________________ >OSTA ÕLUT
bush, kui mäng väga ei meeldi ning väga tihti ei mängi siis ehk oled nõus kontot laenama, et saaks ka proovida millega tegu? Avalduse esitasin tegelikult ise kah, kuid ei õnnestunud kutset saada
Kuidas üldse juba siit foorumist nii mitmed on kutse saanud? EES* nimi on nii palju feimi kogunud? Terve Venemaa peaks Global mapis EES käes olema (või vähemalt viimati oli kui vaatasin). Ning kas olen õigesti aru saanud, et WG plaan on jagada seda ühte Clan Wars Map-i nende kolme mängu vahel. Maa peal omad tankidega, õhus lennukitega ning lõpuks meres laevadega?
Hetkel nagu mina eile aru sain siis saad lennukeid vaid osta ja isegi müüa ei saa hetkel, pooled tierid veel ka puudu, masinad kõik stock varustusega kohe ja ei mingit arendust. Mingi ~10 mänguga tier 10 käes ~20 mängu ja kõik lennukid olemas _________________ "You cannot judge me. I am Justice itself!"
