praegune kellaaeg 11.10.2026 11:23:14
sakunne
28.07.2011 07:23:09
Latitude 420 mälu suurendamine ? |
| Kas on teada mingi trikk, kuidas saab Dell Latitude 420 mälu suuremaks, kui 1,5 GB (512 Mb onboard + 1 GB in slot)
afex
28.07.2011 08:40:39
Lühidalt: osta 2gb pulk ja saad 2.5
link
_____________________________________________________________________
System/Device Specifications:
The information below describes the basic configuration of your system/device.
System InfoBank SchemaUpgrade PathWarrantySupportShow All
Standard Memory: 512 MB (Non-removable)
Maximum Memory: 2.5 GB
Expansion: 1 Socket(s)
CPU & ChipSet: Intel Core Solo 1.06 GHz Intel 945GMS
Bus Architecture: PC Card; USB
Mfgr's System P/N's: N/A
Comments This system is configurable and can ship with either DDR2-533 (KTD-INSP6000A/xx) or DDR2-667 (KTD-INSP6000B/xx). When mixing DDR2-533 and DDR2-667 modules, the system will default DDR2-533 speed.
attrs
28.07.2011 08:54:13
Ise lisasin D420le 2gb pulga ja süsteem näitab vaid 2gb mälu. Sisemine 512 on kuhugi kadunud. Põhjus siis järgmine:
| notebookreview.com kirjutas: |
| Memory is extremely important in today's computing. The D420 offers up to 2GB of DDR2-4200 (533mhz). This, however, is an extremely expensive option. 2GB is achieved by using a 2GB stick in addition to the 512MB soldered onto the motherboard. Due to motherboard limitation only 2GB instead of 2.5GB is addressable. A more realistic upgrade is 1.5GB of RAM. |
Amperloom
28.07.2011 14:32:37
| attrs kirjutas: |
Minu D420 näitab kenasti 2,5gb
_________________ TehnikaUudised - VirtuaalRuum |
attrs
28.07.2011 15:19:14
| Amperloom, mis bios sul kasutusel?
sakunne
04.08.2011 12:08:42
| attrs kirjutas: |
| Amperloom, mis bios sul kasutusel? |
Sama küsimus siin
attrs
08.08.2011 13:13:19
| attrs kirjutas: |
Endiselt huvi.
E: Suhtlesin kasutajaga Amperloom PS teel ja kokkuvõte endiselt selline, et bios näitab 2,5gb kuid winnis käepärast vaid 2.
Amperloom
12.08.2011 00:23:14
| attrs kirjutas: |
| attrs kirjutas: |
Endiselt huvi.
E: Suhtlesin kasutajaga Amperloom PS teel ja kokkuvõte endiselt selline, et bios näitab 2,5gb kuid winnis käepärast vaid 2. |
Jeps, vastab tõele.
Lugesin välja, et see on kiibistiku piirang ja mingit lahendust vist pole.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=RC957119&l=en&s=gen&docid=DSN_1E0AF545A1D4BA8CE0401E0A55175975&isLegacy=true
Siin ka natuke juttu!
http://en.community.dell.com/what-do-i-buy/f/3510/t/18642754.aspx
| the additional memory is being used as a system resource for other devices and services. The amount of memory the video card uses is dependent on the amount of system memory the BIOS reads. This isn't a BIOS limitation, it's the way Windows reports memory so a BIOS adjustment would do no good. Because you have over 512MB the system allocates the full amount of video memory to the card. |
Minu poolest võib see 512MB mälu puudu ka olla, ei usu, et see oluliselt kiiremaks süsteemi teeks.
Ise kasutan peamiselt office ja neti kasutamiseks, seega piisab tõesti 2GB mida windows näeb ja kui
isegi süsteem oskab seda puuduvat mälu videole suunata....seda parem.
