libe
kvaliteetne mees
22.07.2011 11:07:27
see gingeri klaver pole argument, kuna anyway on mõistlik marketist mingi lokaliseeritud klaver hankida
copy paste on ka froyos olemas
ning algselt lubati juuni lõpuks gingerbreadi, samas telefonid olid juba aprillis saadaval
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
iDemon
22.07.2011 11:27:31
libe, mõistlik võib see küll olla, kuid point on et see default klaviatuur vahetub välja.
Siin on nimekiri muutustest. Veidi enam kui lihtsalt visuaalne külg, või mis?
* System: Updated user interface design for simplicity and speed
* Display: Support for extra-large screen sizes and resolutions (WXGA and higher)
* Internet calling: Native support for SIP VoIP telephony
* Virtual Keyboard: Faster, more intuitive text input, improved accuracy, better suggested text. Voice input mode
* Copy/Paste: Enhanced. Select a word by press-hold, copy, and paste.
* Near Field Communication lets the user read an NFC tag embedded in a poster, sticker, or advertisement.
* New audio effects such as reverb, equalization, headphone virtualization, and bass boost
* System: Improved power management with a more active role in managing apps that are keeping the device awake for too long.
* Download Manager gives the user easy access to any file downloaded from the browser, email, or another application.
* Camera: Access multiple cameras on the device, including a front-facing camera, if available.
* Media: Support for WebM/VP8 video playback, and AAC audio encoding
* System: Enhanced support for native code development
* Audio, graphical, and input enhancements for game developers
* Concurrent garbage collection for increased performance
* Native support for more sensors (such as gyroscopes and barometers)
* Switched from YAFFS to ext4 on newer devices
Ja esialgu käis jutt siiski Mai kuust.
LG to update Optimus 2X this May, fix bugs and stuff
LG Optimus 2X Gingerbread upgrade in May
LG Optimus 2X to be upgraded to Gingerbread in May
| Kommentaarid: 122 loe/lisa |
104 |
erkin
22.07.2011 13:41:05
Mingil määral võib arvata, et LG lasi 2.3 kiiresti välja selle case pärast, millele siin eespool viidatud. Suht stock ja tavalise Google kaameraga. Natukenegi rahvast rahustada, sest 2.3 oodatakse väga. Loen T-Mobile foorumit ja seal kasutajad päris närvilised. Iga päev postitatakse teemasid "Kuna uuendus tuleb" ja tehakse nalja by summer jne.
Pole nii väga oluline mis 2.3 annab või miks ta hea on. LG võiks kasutajatega suhelda, anda infot asjade käigust, mis probleemid on, et uuendus venib nendel ja nendel põhjustel(Nvidia riistvara).
Teine asi on, et kui praegu poest arvuti osta siis pole mõeldav, et seal on peale installitud Windows XP.
SE(Arc) ja Samsung(SII) tuli samal ajal välja oma telefonidega kui LG. Need ja järgmised mudelid tulevad Gingerbreadiga.
Tegelikkus on, et praegu O2X ja Black ostes tuleb kaasa vana android.
Froyo pole paha aga hetkel võiks see jääda juba nõrgemate mudelitele.
| Kommentaarid: 34 loe/lisa |
29 |
libe
kvaliteetne mees
timok
120 |
libe
kvaliteetne mees
27.07.2011 10:33:10
kuidas kõige kindlam viis oleks bseband ära uuendada, mul on mingid uuemad smartflashi driverid masinas, kui seal modaco juhendis lingitud - tea kas need töötavad
keegi seal rääkis, et win7 x64'ga olevat probleeme
edit:
sain tehtud
krt selle blazing romiga elab tiitliriba oma elu
seal näitab, et on GPRS, samas aga about screenil on HSPA ja speedtest teeb ~2Mbits
mingi updatega on tulnud ka native MKV tugi ja suudab nüüd ka high profile 720p'd normaalselt maha mängida
-FoX-
07.09.2011 19:51:48
Kas see LG kaamera ongi nii "shit"?
Pidevalt tuleb kuidagi udune ja mitte terav pilt.
Kas asi tarkvaras või kaameras endas? Olen puhastanud jne. klaasid kõik puhtad.
_________________ Aita suve, söö lund! |
| Kommentaarid: 367 loe/lisa |
6 :: |
307 |
libe
kvaliteetne mees
Hive
26.10.2011 23:52:52
Olen telefoni ostu ees , ning valikusse on jäänud 3 telefoni : LG optimus 2x , SE xperia Arc S ja odavamast hinnaklassist samsung i9001 galaxy s plus , olen lugenud erinevaid reviewe kuid ei suuda siiski otsust teha , kripeldama on jäänud LG kohta käivad jutud ( nagu ka siin teemas ) ,et telefon läägab,jookseb kokku ja teeb sada imet , aga samas jällegi riistvara poolelt tundub lg näiteks arc Sist niipalju üle olevat,et ei raatsi nagu Arci eest samat hinda välja käia ,
Et ongi küsimus kumb telefon siis võtta ,arc või optimus ? ja kas selle custom romide ja rootimisega saab optimuse probleemidest lahti ??
| Kommentaarid: 6 loe/lisa |
-FoX-
27.10.2011 01:30:39
arc s võta kindlalt
6 :: |
307 |
qdwin
27.10.2011 09:45:45
Olen sama valiku ees.
Miks Arc? Miks mitte LG? LG probleemid olid seotud mu meelest väljatulemise hetke vigase softiga, või on LG 2x jätkuvalt probleemne?
iDemon
27.10.2011 09:48:51
qdwin, probleemne see pole juba pikemat aega.
Ise ostsin siis kui välja tuli ning selle aja jooksul on teinud kaks (juhu) restarti laadides esimesel kuul. Peale selle on masin korralikult töös olnud enam kui pool aastat juba.
104 |
timok
27.10.2011 09:54:33
LG probleem on see, et ta ei suuda originaal FW välja lasta. Muidugi on lootus et nad ei jauragi väga selle Gingeriga, vaid tegelvad hoopis Ice Creamiga . Aga sama lootus on kevadest saadik GB-ga olnud, et kohe tuleb.
Samas on riist nii võimekas, et custom ROM-e tehakse päris agaralt, CM7 isegi töötab nigu õlitatud välk, pisivead küll on aga LG suurte vigade kõrval on need väikesed.
Väga head originaali baasil ROMid on MoDaCo´l ja Topogigil.
Hea ekraan, riistvara (tegra), full HD korralik video, kaasasolev mini HDMI kaabel jne. Pole väga viga selle raha eest. Samas Arc´i pildid on hoopis teisest klassist, kui fotokas oluline.
120 |
qdwin
timok
27.10.2011 10:12:07
See ei olene ROMist, vaid teemast. GO Dialer küll võimaldas näiteks. Ja originaal LG teemaga customid on välimuselt samasugused nagu originaal . Nii et võimaldavad. Sisu on lihtsalt puhtam ja kiirem.
Custom Topogigi Rom ülekiirendatult 1,4GHz skooris mul quadrandis mingine 4300 punkti, kui viimati proovisin Igapäevaselt muidugi nii ei kasuta.
120 |
Hive
27.10.2011 12:02:11
| Otsutasin siiski Arc Si kasuks,kuna tehti viimasel hetkel veel 70 euri alet
tiitise
iDemon
30.10.2011 14:26:06
tiitise, ei ole vaja loota. Asi on official.
Update: LG Mobile posted a reply to the same question in Facebook with the following:
We do have a plan to update Ice Cream Sandwich. Now we are working on it! When the date is set we will let you know through Facebook! Please check our wall regularly! Cheers. |
104 |
timok
30.10.2011 14:49:28
| iDemon kirjutas: |
Sama möla ajasid nad ka oma Guinnessi rekordiomaniku väljatulekul, et kevadeks, hiljemalt suve alguseks saab püss omale Gingeri! Hetkel on peaaegu november ja Gingerbreadi netu
120 |
iDemon
31.10.2011 17:43:54
Juttude järgi peaks homme tulema Gingerbread.
Nii on ka LG FB lehel.
104 |
libe
kvaliteetne mees
31.10.2011 20:04:12
siis pole kaugel ka ametliku baasil modaco
erkin
31.10.2011 22:31:38
Homme on jah rõõmupäev
29 |
tiitise
iDemon
02.11.2011 23:47:24
| Ise pole vaevunud uuendama veel, kuid XDA järgi on nüüd enamustes riikides GB uuendus tiritav.
104 |
erkin
03.11.2011 17:02:57
Uuendasin. Vers. 2.3.4. Midagi erilist pole, kernel vana. Mõned värvi muudatused ja animatsioonid
Baltikumis veel läbi software updateri pole saadaval, mõned üksikud riigid. Sellest ka palju nurinat, järjekordselt. Mõni regioon võib saada alles kuu lõpus hiljemalt.
29 |
