7 :: |
362 |
Go Kane!
| Kommentaarid: 1842 loe/lisa |
1345 |
7 :: |
362 |
7 :: |
362 |
Go Kane!
20.06.2011 13:47:47
| Tanel kirjutas: |
68 544 8-tuumalist protsessorit tähendab 548 352 tuuma
672tk sellist rakki koos, igas ühes 816 tuuma
Energiakulu on ca 10 miljonit dollarit aastas. |
Kas seda võimsust ka reaalselt kasutatakse kuskil? Kui jah siis milleks?
_________________ Vajad midagi Würthist , küsi julgelt 😉 https://eshop.wuerth.ee/et/EE/EUR/
taavi.jahu@wuerth.ee +37258309618 |
1345 |
SinineSiil
20.06.2011 13:49:49
| Milleks seda kasutatakse?
| Kommentaarid: 20 loe/lisa |
19 |
7 :: |
362 |
äss
20.06.2011 13:50:45
tea kas bf3e veab välja?
päris haige "arvuti"
Energiakulu on küll hea
| Kommentaarid: 29 loe/lisa |
23 |
20.06.2011 13:59:45
Protsessorist endast lähemalt juttu siin: http://www.fujitsu.com/global/about/tech/k/whatis/processor/
Fujitsu SPARC64 VIIIfx 2GHz 8-cores, 45nm, 128-gigaflops, built-in memory controller.
Wiki: http://en.wikipedia.org/wiki/SPARC64_VI#SPARC64_VIIIfx
Specifications
Registers: 192 integer, 288 floating point (32 single precision, 256 double precision), 3 interrupt.
Address range: 41-bit (up to 1FFFFF00000h).
Cache:
L1: 32KiB 2-way data, 32KiB 2-way instruction (128 byte line), sectored
L2: 5MiB 10-way (128 byte line), index hash sectored
Translation lookaside buffer: 16 fetch + 256 4-way store instruction, 512 4-way store data, no victim cache
Page sizes: 8KiB, 64KiB, 512KiB, 4MiB, 32MiB, 256MiB, 2GiB
Translation storage buffer: Not supported in hardware
SIMD: Max 2 parallel calculations, supports max 8 floating point values per cycle. Double precision floating point register can be used for single point calculations. Operands can be single or double precision floating point values.
Protsessori presentatsioon: http://www.hotchips.org/archives/hc21/3_tues/HC21.25.500.ComputingAccelerators-Epub/HC21.25.51A.Maruyama-Fujitsu-Octo-Core-VIIIfx.pdf
Üldisemalt K Computer kohta infot: http://www.fujitsu.com/global/about/tech/k/
_________________ Erakopeerimistasu tõstmise ettepaneku tagasilükkamine
HV-s ID-kaardiga autentimine
viimati muutis Tanel 20.06.2011 14:01:30, muudetud 1 kord |
7 :: |
362 |
Mario.
20.06.2011 14:05:04
Eks tal omad plussid ole (on-demand lokaalne eelis), aga...
Pool miljonit tuuma ei ole midagi võrreldes BOINC'iga (millele võib liita paljusid teisi platvorme), mida kasutab momendil 2+ miljonit kasutajat (loe= min 2 miljonit tuuma) - aasta tagasi märgitud võimsuseks 5PF
Ei saa ühelselt võrrelda, aga taas.. kõik, mis ei ole aegkriitline (loe: pea reaalajas, mis ei kannata viidet tulemuste kandmiseks üle võrgu), nagu simulatsioonid.. :
Igasugused lokaalsed superarvutid on ressursiraisk ja mõnes mõttes ebapraktiline lähenemine, kui meil on iga päev tarbijatele jagatav ja suuresti realiseerimata arvutusjõud lihtsalt toanurgas seismas.
Jagatud arvutusjõudlus on kiire mõttelähenemisega keskeltläbi vähemalt 3x vägevam ükskõik missugusest superarvutist.
6 :: |
217 |
7 :: |
362 |
Mario.
20.06.2011 14:08:51
BOINC on küll üllas ja altruistlik projekt, aga põhineb vabatahtlikkusel.
Täpselt - http://www.amazon.com/No-Contest-Case-Against-Competition/dp/0395631254
Keegi ei keela GPU'd klastrisse lükata ja TÜ enda superarvutile 15k€ eest kandu näidata.
TÜ vs <DIY ( 2,5 milj. EEK vs 200k EEK )
..eks siin mõningaid komplikatsioone ole, aga oma silmaga olen näinud 2x2m nVidia taru, mis toanurgas sumises ja välismaale arvutusjõudlust müüs.
viimati muutis Mario. 20.06.2011 14:15:30, muudetud 2 korda |
6 :: |
217 |
7 :: |
362 |
Mario.
20.06.2011 14:12:08
Ebaefektiivne, nähtavasti.
6 :: |
217 |
20.06.2011 14:42:21
MarioA.: Ja näita mismoodi need "netiarvutid" siis arvutavad, kui:
1. Nett maas on
2. Kui arvutimanikul elekter ära läheb.
3. Või kui arvutimanik oma arvutiga midagi muud parajasti teha tahab ja ta ei saa võrku ressurssi pakkuda.
Nii, et kriitilisi servereid ei saa kuidagi püsti panna olukorras, kus arvutusvõimsus võib iga hetk tagant ära kukkuda.
Kui ei usu, tee rollimäng ja mis tunne Sul on kui Sul näiteks nett paariks nädalaks kokku lendab, kuna netiserver maas on...
211 |
Ho Ho
20.06.2011 14:43:07
| MarioA. kirjutas: |
| Keegi ei keela GPU'd klastrisse lükata ja TÜ enda superarvutile 15k€ eest kandu näidata. |
GPU klaster vs harilikud prosed on "suts" erinevad klassid siiski. Asi läheks umbes sama mõttetuks kui omal ajal laiasid sony-MS et küll ühel on 1TFLOPS, teisel 2 oma karpi surutud ehkki reaalselt kasutatavad numbrid olid paari suurusjärgu võrra madalamad. Näiteks GPU klaster naljalt terabaitide jagu mälu ei adresseeri ilma hunnikuga vahekihti kama lisamisega mis kogu seda lõbu manageeriks. Lisaks veel on distributed computing'u puhul praktiliselt võimatu lasta eri node'del omavahel suhelda ja kordineerida. SETI laadseks andmeanalüüsiks pole seda loomulikult vajagi kuid kui on eesmärgiks näiteks ühe konkreetse asja emuleerimine-simuleerimine (a'la kogu Maa kliima, tuumaplahvatus, miski keemiline reaktsion, ...) kus on vaja eri punktide kokkupuute kohtades toimuvast infot naabritele saata siis läheb asi katki.
87 |
7 :: |
362 |
Ho Ho
20.06.2011 14:46:13
Lisaks on võimalik omale tagavaraks tõmmata üsna mitme ööpäeva töövaru mida offlines olles vaikselt läbi närida.
87 |
Nokia
Serverid.ee
20.06.2011 14:51:18
Will it blend?
_________________ Web3 | ERC721A |
| Kommentaarid: 44 loe/lisa |
43 |
Mercury
20.06.2011 15:13:03
| But can it run Crysis?
| Kommentaarid: 61 loe/lisa |
60 |
bush
20.06.2011 15:13:07
kas tahanteada käibki igas teemas " aga mis siis saab kui netti enam ei ole" juttu ajamas?
_________________ >OSTA ÕLUT |
| Kommentaarid: 31 loe/lisa |
30 |
ufo56
| Kommentaarid: 79 loe/lisa |
67 |
olc
20.06.2011 15:44:29
Kas masina tööaega rentida saab? Mitu raha maksaks huvitav
130 |
Wusses
mehine eesti muffin
20.06.2011 15:45:57
| olc kirjutas: |
Kas masina tööaega rentida saab? Mitu raha maksaks huvitav  |
Mis sa sellega tegema hakkad ?
toa kütmiseks on ka odavamaid lahendusi
_________________ Tegelen tööriistade hoolduse ja remondiga ning pakun 3D skaneerimise ja 3D printimise teenust. Valmistan prototüüpe, varuosi ja erilahendusi vastavalt kliendi vajadustele. |
| Kommentaarid: 345 loe/lisa |
282 |
20.06.2011 17:28:46
| olc kirjutas: |
Pressiteatest:
| RIKEN and Fujitsu have been working together to develop the K computer, with the aim of beginning shared use by November 2012, as a part of the High-Performance Computing Infrastructure (HPCI) initiative led by Japan's Ministry of Education, Culture, Sports, Science and Technology (MEXT). |
Hinna kohta infot pole, kuid tõenäoliselt see odav ei saa olema.
Jaga kasvõi aastane energiakulu 10 000 000 ära 365 päevale, saad 27397 dollarit päevas
7 :: |
362 |
Maska
20.06.2011 18:27:58
Re: Fujitsult maailma kiireim superarvuti |
| Tanel kirjutas: |
Koostöös firmaga RIKEN on Fujitsu ehitanud maailma kiireima superarvuti jõudlusega 8,2 petafloppi. 68 544 Fujitsu SPARC64 VIIIfx 2GHz 8-tuumalist protsessorit sisaldav "K-Supercomputer" nime kandev monstrum on umbes 3 korda kiirem senisest kiireimast superarvutist Hiinast. Väidetavalt saab süsteemi tulevikus vajadusel laiendada.
Hiina on superarvuti? Fujitsu arvuti on kiirem, kui kogu Hiina?
Ega ma ei tea - pole ise Hiinas käinud.
| Kommentaarid: 32 loe/lisa |
Ho Ho
20.06.2011 18:29:26
Superarvuti on pärit Hiinast
87 |
7 :: |
362 |
kontakt321
24.06.2011 18:40:44
| Sellega mängitakse runet .
Me-Gusta
25.06.2011 00:11:00
Kui juba 68 544 proset siis oleks võinud ka panna 68 544 AMD 6990-et ehk 137 088 tuuma ja 342 720GB GDDR-5-te
Siis oleks juba normaalne
muidu mõttetu mis teed sellega ei jooksuta Metrotki ära
