Braien
14.06.2011 15:34:01
Huawei U8500 |
Kuna mina teemat ei leidnud, siis teen.
EMT-sse selline isend tekkinud:
https://www.emt.ee/sisu/-/eshop/productinfo/52980086
Kas keegi oskab öelda ka tema kohta midagi?
Andmed:
GENERAL 2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 900 / 2100
Announced 2010, June
Status Available. Released 2010, 3Q
SIZE Dimensions 112 x 58 x 12.8 mm
Weight 115 g
DISPLAY Type TFT capacitive touchscreen, 256K colors
Size 320 x 480 pixels, 3.2 inches
- Accelerometer sensor for auto-rotate
- Proximity sensor for auto turn-off
- Optical trackpad
SOUND Alert types Vibration, MP3 ringtones
Loudspeaker Yes
3.5mm jack No
MEMORY Phonebook Practically unlimited entries and fields, Photocall
Call records Practically unlimited
Card slot microSD (TransFlash) up to 32GB, buy memory
DATA GPRS Class 10 (4+1/3+2 slots), 32 - 48 kbps
EDGE Class 10, 236.8 kbps
3G HSDPA, 7.2 Mbps
WLAN Wi-Fi 802.11 b/g/n
Bluetooth Yes v2.1 with A2DP
Infrared port No
USB Yes, microUSB v2.0
CAMERA Primary 3.15 MP, 2048x1536 pixels
Video Yes, 352x288@15fps
Secondary No
FEATURES OS Android OS, v2.1 (Eclair)
Messaging SMS(threaded view), MMS, Email, IM
Browser HTML
Radio FM Radio
Games Yes
Colors Black
GPS Yes, with A-GPS support
Java Yes, via Java MIDP emulator
- Digital compass
- SNS integration
- Google Search, Maps, Gmail, Talk
- MP3/WMA/eAAC+ player
- MP4/H.263/H.264 player
- Organizer
- Photo viewer/editor
- Voice memo
- Predictive text input
BATTERY Standard battery, Li-Ion
Stand-by Up to 300 h (2G) / Up to 350 h (3G)
Talk time Up to 5 h (2G) / Up to 4 h 10 min (3G)
90 |
kfl
14.06.2011 17:50:51
Re: Huawei U8500 |
kaevandaks keegi prose andmed
vaatasin oma huviorbiidis olevate telefonidega võrdlusi:
vers Blade - väiksem lcd resu
vers ACE - viletsam lcd pealisklaas
vers Spica minujaoks esmapilgul samaväärne
sellise ekraaniresuga telefoni kohta hea hind!
ps. ühe vana huawei telefoniga positiivne kogemus, idioodikindlalt vastupidav korpuseraam, niiskuskahjustused üleelanud kerge kuivatusega
_________________ Müügis: YARIS! ja FOCUS Tel: 1214*5100741*100 |
| Kommentaarid: 111 loe/lisa |
107 |
Braien
14.06.2011 18:19:01
nonii, leidsin youtubest ühes videos oli:
CPU Qualcomm MSM 7225 600MHZ
Internal Memory RAM 256MB,ROM 512MB
90 |
villu70
29.06.2011 14:18:07
| Kui telefonil ei ole 3,5mm jack-i (tänapäeval) siis võib sellega ainult lutsu visata.
122 |
tomz
29.06.2011 15:26:23
| braien334 kirjutas: |
Internal Memory RAM 256MB,ROM 512MB |
EMT andmetel on 528 MHz
Igatahes olen reaalselt katsunud ja proovinud üks 5 mintsa.
Ise oman ZTE Blade.
Huawei on defaultis kole aeglane ja lahja. Näeb välja väga odav ja ebakvaliteetne ning ka käes tundub odav.
Blade näeb välja tunduvalt esinduslikum ning töötab oluliselt kiiremini.
Samas kui hakkab custom rome tulema (ilmselt juba miskit on ka), siis peaks ka selle asja lippama saama - ise olen siiski negatiivselt meelestatud.
| Kommentaarid: 68 loe/lisa |
30.06.2011 08:51:21
| tomz, kas talle kõrvaklappe/handsfreed ei saagi külge panna? St 3,5mm pole jah aga äkki on mingi enda "auk"?
147 |
rex
30.06.2011 10:50:26
| võtas-uxu kirjutas: |
| Kui telefonil ei ole 3,5mm jack-i (tänapäeval) siis võib sellega ainult lutsu visata. |
No on ju küll. Googeldage ka pisut mingi konveiermeetodil koostatud andmelehe pimesi usaldamise asemel. See, et mõlemad pesad jälle idiootlikult üles serva ja voluuminupp parema käe pöidla alla on topitud, on muidugi nõme.
Välimus pildi järgi mustana isegi päris ok.
| Kommentaarid: 248 loe/lisa |
227 |
30.06.2011 10:51:46
rex, . Siis on selle raha eest täiesti asine pill kui softi annab mudida.
147 |
villu70
30.06.2011 11:26:19
122 |
rex
30.06.2011 11:40:04
No anna kohtusse. Easy money.
227 |
Braien
30.06.2011 14:23:54
võtas-uxu, kuskil youtube reviewis oli kirjas, et on olemas.
90 |
Nipi1000
30.06.2011 14:43:25
3,5mm jack ei ole minu jaoks j2llegi mingi n2itaja, pigem eelistaks siis juba m6nda bluetooth headseti, kui handsfree vajalik v6i siis mp3 m2ngijat...erinevaid kasutajaid on samapalju kui erinevaid maitseid...
n2iteks mina viskaks enamus uuemate nuti-fonidega lutsu(ka need k6ige kallimad), kuna neil puudu elementaarne asi nagu taskulamp ehk siis kaamera valgustus, 22rmiselt vajalik asi minu jaoks
| Kommentaarid: 21 loe/lisa |
20 |
SirVorkars
13.07.2011 02:15:22
Seisab demomasin laual ja on olemas see 3,5mm jack..... tundub et gsmarenal inf vale.... ja youtubes muusikavideo mänigb praegu normaalselt. Metallica- Nothing else matters esitab ilma probleemideta . Samas kui Samsung GS-ga harjund siis see huawei on 10 astet tagasi redelil. Jumala aeglane ja vahest midagi tehes nagu lagib kõvasti võrreldes GS-ga. Kui esimene android, siis OK, aga kui varem mingit karmimat pilli kasutanud ( GS või Desire vms) või nõudlikum kasutaja, siis nagu tõesti, et kiviaega tagasi sattunud. Samas 119 eurtsi eest on androidi rohkem kui küll ( meilid, mussid särgid värgid... facebookid jne ). Ootaks huviga custom romi sellele mis kiirust parandaks.... aga elame näeme
56 |
Matuuu
20.10.2011 22:49:01
Ise oman seda telefoni ja pole veel ühtegi halba sõna öelda.
Äkki keegi oskab öelda miks navigatsioon ei tööta, avan navigatsiooni ja jääb mõtlema midagi kiri ees: "Navigeerimise võimalikkuse kontrollimine" ja sellest edasi pole saanud?
Igaljuhul julgen soovitada, selleraha eest nalja kui palju.
rex
21.10.2011 09:12:39
| Seadete alt on sputnikute otsimine lubatud? Millise navigeerimisprogrammi sa avad?
227 |
Matuuu
21.10.2011 17:01:41
SEadete alt lülitasin sisse Kasuta GPS-sateliite.
Navigeerimis programmi nimi telefonis ongi "Navigeerimine"
Braien
21.10.2011 17:05:28
Ilmselt siis google enda oma, mis eestis ei tööta vist.
90 |
rex
21.10.2011 17:48:27
| Google Maps töötab igal pool, kaarti tirimiseks on lihtsalt andmesideühendust vaja.
227 |
Braien
21.10.2011 18:44:57
rex, Me ei räägi google mapsist, vaid sellisest appsist nagu "navigation", mis Eestis ei tööta veel.
Mul ütleb, et "not available yet in your country" vms.
90 |
Priido
21.10.2011 18:56:11
| Sai ka ostetud odav nutikas tööl kasutamiseks. Tolm koguneb kergesti klaasi ja displey vahele, esineb muid anomaaliaid (lülitab end vahel välja kui nats kõvemini lauale paned). Telefon on aeglane. Üldiselt ei soovita kellelegi, natuke raha juurde ja saab juba mõistliku telefoni. Aga noh eks ta ole oma 100 euri väärt. 3.5 mm väljund on küll olemas kuid suvalist kõrvaklappi sinna sisse ei topi
| Kommentaarid: 17 loe/lisa |
Matuuu
21.10.2011 22:05:04
Vb tõesti ei toeta eestis see navigaatori süsteem, kuna google maps võtab lahti ja toimib, ise avastasin ka täna, et tolm ekraani all... välja ise ei lülita ja aegluse kohta eriti ei kurda, kuna vb pole ka varem mingit kiiremat püssi omanud
rex
22.10.2011 11:57:19
| Matuuu kirjutas: |
...eriti ei kurda, kuna vb pole ka varem mingit kiiremat püssi omanud  |
See ongi tegelikult võtmeväljend väga paljude asjade puhul. Oluline on mitte lasta end parematest asjadest ära hellitada.
227 |
Matuuu
27.11.2011 12:47:46
Oskab keegi kogenum öelda, mis moodi ma kaameraga zoomida saan ?
Pildistamisel all olemas Zoom sellega saan hakkama, aga videoga zoomimine minujaoks müstika.
rex
27.11.2011 16:36:14
| Mis vahet seal on, kuidas seda digizoomi kasutada? Unusta ära parem, kuna täpselt sama asja saad (palju paremate algoritmide abil) arvutis pilditöötlustarkvaraga teha. Video puhul zoom'i jalgadega, jääb tulemus oluliselt parem.
227 |
Tsfs21
04.12.2011 15:42:29
Sai siis antud telefon ostetud, kõik on muidu okei, aga ka lihtsalt stand by režiimil olles kestab aku max 1 päeva ? Paljud rakendused mis akut söövad olen välja lülitanud ja ikka sama jama. On see normaalne ?
| Kommentaarid: 6 loe/lisa |
Matuuu
11.12.2011 22:54:51
Tekkis siis küsimus, kas sellele praegusele Android 2.2.1 on võimalik ka midagi uuemat peale installida, mis oleks ka eestikeelne?
Kui Jah, siis äkki kusagil mingi õpetus vms.
taggens
06.01.2012 21:18:04
Ma siis ka üks neist "õnnelikest" kellel see Huawei.
Ka minul olnud kõik need eelnimetatud probleemid (tolm, navigeerimine jne).
Tolm on siiani klaasivahel, aga navigeerin ise navigoni-ga. toimib kenasti, vähemalt pärnu linnas.
Aeglane on ta krt küll, kohati ikka jube uim.
Ahjaa, see probleem oli mul ka kunagi, et laua peale panna ei saanud. Viisin garantiisse ja siis tehti softi vahetus. Hetkel toimib, aga jube aeglaselt. Kui ennem sain lapsele anda seda talking tomi mängida, siis nüüd ei kannata seda väga enam.
Otsisin kohta, et kust saaks uuemat androidi peale ajada, aga paraku jäävad oskused ilmselt vajaka leidmisel.
rainisk
14.01.2012 17:18:16
| Olen ka tänasest selle omanik. Tahtsin teada et kuskohast saaks sellele mänge ja asju peale tõmmata ja kuidas muusikat lisada saab nagu, peab olema siis mälukaart ka või?
| Kommentaarid: 23 loe/lisa |
18 |
Priido
14.01.2012 18:24:33
| Jah
taggens
14.01.2012 21:07:17
| rainisk kirjutas: |
| Olen ka tänasest selle omanik. Tahtsin teada et kuskohast saaks sellele mänge ja asju peale tõmmata ja kuidas muusikat lisada saab nagu, peab olema siis mälukaart ka või? |
Mänge asju leiad kui googeldad android market. Seal neid oksendamiseni.
Vähe tuhnid, siis internet neid APP-se täis.
Mälukaart ja hea kui on ka usb kaabel. aga saab ka kaart+adapter
rainisk
17.01.2012 11:04:29
Mis mälukaart sellele sobib üldse?
_________________ ( -_・) ︻デ═一 ▸ |
18 |
| Kommentaarid: 85 loe/lisa |
rainisk
23.01.2012 13:05:37
Mingit sellist navigeerimist ei saa sellele lutsule peale mis ei taha internetti v?
18 |
23.01.2012 13:27:51
| rainisk, saab ikka. Illegaalsena on võimalik paigutada sinna iGo, kuid Marketis on ka mitmeid teisi saadaval.
rainisk
23.01.2012 13:33:27
On nende mälukaartide class 4 ja nt class 10 mingi vahe ka või?
18 |
taggens
23.01.2012 22:40:53
Niih, lasin oma U8500 -le peale uue softi ja peale seda enam mikker ei tööta
Keegi taibukas oskab ehk aidata?
rainisk
25.01.2012 14:34:12
Mis GPS töötaks sellel telefonil ilma internetita ja tasuta nagu?
18 |
taggens
rex
26.01.2012 13:27:56
| rainisk kirjutas: |
| Mis GPS töötaks sellel telefonil ilma internetita ja tasuta nagu? |
GPS töötabki vaikimisi tasuta ja ilma internetita. Annab sulle sinu asukoha koordinaadid ja aja. See, mida sina küsid, on juba sellel põhinev navigeerimisprogramm.
227 |
rainisk
01.02.2012 13:45:16
Jah navigeerimisprogrammi mis töötaks ilma netita, ainult sateliidi peal.
E: Kuidas lülitada välja seda et ta tasulisse internetti ei läheks??
18 |
taggens
01.02.2012 22:40:54
| rainisk kirjutas: |
E: Kuidas lülitada välja seda et ta tasulisse internetti ei läheks?? |
Kas andmeside rändliust keelata ei saa?
Priido
04.02.2012 14:10:10
| menüüs oli jah selline variant olemas, täpselt ei mäleta kus, aga üles ta leidsin. Kusjuures välja pidi ka lülitama appide andmeside eraldi. Ise lasin seda kõiki telefoni ostes EMT esinduses teha, mille tagajärljel tuli esimeseks mobiiliarveks üle 200 euri. Siit moraal, kontrolli alati kõik seaded ise üle sest hiljem teenusepakkujaga vaielda on suhteliselt lootusetu.
Evw5
06.02.2012 20:04:29
Kuidas sellel telefonil mänge kustutada saab? Tõmbasin netist mänge alla ja siis installisin telefonisse ära aga nüüd ei saa enam neist lahti... proovisin ka läbi arvuti kustutada aga seee ebaõnnestus.
rainisk
07.02.2012 09:12:13
seaded ja rakenduste haldamine
18 |
taggens
08.02.2012 20:19:39
| Ei tea, kas kellelgi emti poolt pandud "backup" ei ole tehtud?
Number47
18.02.2012 20:19:13
| taggens kirjutas: |
| Ei tea, kas kellelgi emti poolt pandud "backup" ei ole tehtud? |
Keerasid enda softi pekki?
Mul suhteliselt "süütu" 8500 hetkel, kui vaja, saan backupi teha.
| Kommentaarid: 138 loe/lisa |
110 |
taggens
19.02.2012 21:23:35
| Number47 kirjutas: |
Mul suhteliselt "süütu" 8500 hetkel, kui vaja, saan backupi teha. |
kle suht jah, hetkel töötab mingi netist sikutatud versiooniga. aga tagavaraks võiks olla korralik backup. Kui Sult see suurt pingutust ei nõua ja kusagile ülese saad, siis võid teada anda.
Tänan juba ette.
Number47
110 |
taggens
22.02.2012 21:31:13
Hanguma on ta jah meister. Nagu mingi ma ei tea mis asi. Proovisin isegi kõige uuema selle android icecreami ära. Nu vat on uimerdis. Peab ise pedaale sõtkuma jne. Kaamera sellel ka siis ei töötanud.
Aga seda ka, et suured tänud Sulle. Proovin end ka nüüd stockiks muuta
Number47
26.02.2012 19:46:08
Nii... vahepeal veel paar custom ROM'i proovitud. Praeguse seisuga on siis nö isiklikus blacklistis järgmisete nimedega modid:
LeWa rom (täielik prügi, enamus asju ei tööta)
Adrenaline 2.3.5 (ei tööta mikker, wifi, gps, market, kaamera)
CyanogenMod 7.1 by $aNek011 v.3.5 (ei tööta wifi ega gps)
CyanogenMod 7.2 RC8. Viimane on seni üks kiiremaid ja stabiilsemaid, kuid... KUID oeh: ei tööta wifi ega gps. Market teeb kah vahel krässi.
Olen jällegi tagasi oma stocki juures.
_________________ Ärifoorumi tehingud alaealistega vaid vanemate kirjaliku nõusoleku esitamisel! |
110 |
