05.06.2011 22:27:05
Skype protokoll pöörd-teisendatud |
link :: Torrentfreak
Väidetavalt on Skype koodile tehtud pöördprojekteerimine (reverse-engineering), ning see kood on üles pandud Pirate Bay-sse.
“Skype protocol reverse engineered, source available for download,” reads an interesting torrent comment on The Pirate Bay.
The rest of the post, which comes from freelance researcher Efim Bushmanov, explains his aim of making Skype open source.
“While ‘Wall Street Journal’ makes politics and Skype today’s trend, I want to publish my research on this,” the post continues in broken english.
“My aim is to make Skype open source. And find friends who can spend many hours for [sic] completely reverse it.”
“Now, most of hard things already done(for 1.x/3.x/4.x versions of Skype). Including rc4 and arithmetic compression.
“You have unique chance to take a look on Skype internal protocol and encryption. You will see that it uses strong AES and RSA encryption with public key infrastructure.”
The files, which weigh-in at just over 147mb, currently have a couple of hundred seeders.
The news follows hot on the heels of an announcement by Microsoft that it will acquire Skype for $8.5 billion in cash.
Microsoft would love to have The Pirate Bay take the torrent down but unfortunately for them that’s not going to happen. |
HV valuutakalkulaator
viimati muutis Tanel 06.06.2011 08:29:25, muudetud 1 kord |
7 :: |
360 |
Mihkel^^
05.06.2011 23:27:06
päris hea, tõmbasin ka
| Kommentaarid: 39 loe/lisa |
Unholy
06.06.2011 00:41:35
| Mihkel^^ kirjutas: |
päris hea, tõmbasin ka   |
Ja mis sa sellega peale hakkad? Ah?
| Kommentaarid: 47 loe/lisa |
lokuta
06.06.2011 00:59:27
| Haiged inimesed
| Kommentaarid: 91 loe/lisa |
79 |
Laurikre
06.06.2011 01:10:11
Vahel on lihtsalt huvitav ka teiste koodi vahelduseks lugeda.
Lauri Kreutzwald
_________________ Need: Windows, .Net, Sharepoint, Exchange, Dynamics, Visual Studio, XNA, Expression, Silverlight, SQL and many other skills? Talk to me
Rohkem IT uudiseid iga päev BattleIT lehelt |
131 |
sirius4k
06.06.2011 04:05:29
Jumal tänatud, et ma Skype'i kasutan....
oot krt
| Kommentaarid: 56 loe/lisa |
55 |
Mario.
06.06.2011 06:56:36
| Positiivne.
6 :: |
217 |
lokuta
06.06.2011 07:08:57
| Ma kujutan ette, et see on sama hästi, kui sa ostad hirm kalli auto, kuid mingi tark arvab, et ta varastab selle ära, tõmbab algosadeks laiali ja saadab sulle sellest pildid ! Põlema võiksid ennast panna sellised ajukääbikud!
79 |
Mario.
06.06.2011 07:18:53
Auto sai ta siiski legaalsel teel, aga ta teeb selle tõesti algosadeks ja jagab materjali teistelegi, arutlemaks ning mõistmaks, kuidas need osad omavahel töökorra saavutavad.
Tulemuseks on võimalus igal kodanikul anda enda panus teenuse e. toote kvaliteedi parandamisele, lihvimisele ja eelkõige kujunemisele just vastavalt kasutajate vajadustele. Kollektiivsus on hindamatu väärtus, mida ei kaalu suurt miski üle - sellel on tänases maailmas suur nišš. Open source on pigem filosoofiline käik.
viimati muutis Mario. 06.06.2011 07:21:46, muudetud 2 korda |
6 :: |
217 |
tonism
06.06.2011 07:21:25
| lokuta kirjutas: |
| Ma kujutan ette, et see on sama hästi, kui sa ostad hirm kalli auto, kuid mingi tark arvab, et ta varastab selle ära, tõmbab algosadeks laiali ja saadab sulle sellest pildid ! Põlema võiksid ennast panna sellised ajukääbikud! |
See ei ole absoluutselt midagi sellist. Auto puhul sa tahad konkreetset füüsilist toodet, mitte märga unenägu sellest.
Skype source puhul on tegu ei millegi muu, kui turvalisusega tegelevate inimeste huvidega, kes saavad seda ennekõike kasuta õppematerjalina. Lisaks võimaldab avatud lähtekood luua tulevikus paremat tarkvara justnimelt selle läbi, et on võimalik Skype häid külgi kastuada ning halbu külgi täiustada. Loomulikult ei ole tavainimestel sellega suurt midagi teha.
Mõistmata asjade tegelikku kasutust ei ole just kõige arukam hakata kohe asja laimama. Ma ei oska kommenteerida selle tegevuse legaalsust, kuid ma näen palju positiivseid külgi, mis sellega võivad kaasneda.
EDIT: MarioA jõudis ette
viimati muutis tonism 06.06.2011 07:22:42, muudetud 1 kord |
lokuta
06.06.2011 07:22:30
| Ok varastamise asemele siis laenas. Selle asja juures pole midagi seadusliku, ega isegi mitte õigustust väärivat. Igasugustel tegelastel lihtsam lihtsalt jälgida teie kirjavahetus ja kuulata peal kõnesid muud midagi.
79 |
Mario.
06.06.2011 07:30:57
lokuta, palun tee endale selgeks, mis on sellise tegevuse idealiseeritud eesmärk ning kuidas opensource projektide protsess kulgeb.
Loodetavasti siis ka mõistad, mis väärtus antud teol on.
6 :: |
217 |
lokuta
06.06.2011 07:35:59
| Ok eks siis hakkama neid julgustama kõiki koode lahti muukima, win, fotopood, CAD jne ühesõnaga teeme kõik tarkvara opensource projektideks, mis sest, et see kellegi omand.
79 |
Mario.
06.06.2011 07:45:31
Enamustele on alternatiivid olemas.
Kas sa ei arva, et mainitud kollektiivne ja ressursirikas arendamine on produktiivne ja inimlikum viis läheneda tarkvarale, mis tagab sama funktsionaalse ligipääsu pea samaväärsetele toodetele ja väldib ka ettevõtete dikteerimist?
6 :: |
217 |
lokuta
06.06.2011 07:49:42
| MarioA. kirjutas: |
Kas sa ei arva, et mainitud kollektiivne ja ressursirikas arendamine on produktiivne ja inimlikum viis läheneda tarkvarale, mis väldib ka tarkvarafirmade dikteerimist? |
Põrutada oled saanud? Nagu aru saan, siis sa oled see mees kes kahekäega pooldab piraatlust ja suured pahad tarkvarafirmad on kurjad, minu teada hipide aeg on läbi ja lepi sellega, korraliku asja sa pead ostma, mitte torrentit kurja ajama. Arvad, et tänu sellisele sigadusele on skype turvaline koht kus kõnesi pidada.
79 |
Mario.
06.06.2011 07:52:02
| Palun loe uuesti, mida ma küsisin ning mida sina kirjutasid.
6 :: |
217 |
lokuta
06.06.2011 07:57:46
Sorry, ei pannud küsimärki tähele.
Ma sellise asjaga ei nõustu, kui keegi vabavaralise alternatiivi välja ise mõtleb ilma teiste koodi piilumata, see oleks igati positiivne. Kuid nii kaua kui pole selle turvalisus ära tõestatud ma seda ei kasuta. Siiani tead ainult käputäis vabavaralist tarkvara mis kannatab kriitikat, sest tulebki kasutada suuremalt jaolt tasulisi või piiratud õigustega tarkvara mille koodi lahti kiskuma ei hakka. Huvitav miks ei ole fotopoe koodi lahtikisutud, seda kasutavad ka paljud ja see on mõttetult kallis?
79 |
Mario.
06.06.2011 08:07:40
Tasulised tooted pole halvad ja tihti õigustavad ka oma hinda, kuid me ei saa hurjutada iga ettevõtmist tuua turule alternatiive ja kasutajate modifitseeritud tarkvara, olgu selle tagamaaks lihtsalt kibe vastuseis või puhas huvi näppida ja arendada.
Igasugune revers-engineering on iseenesest väga ropp töö.
Kindlasti ei ole see väga aus ja eks igal ole omad põhimõtted - skype'ile ei ole head alternatiivi ja olgu selle sügavamaks ajendiks misiganes hirm (ala reklaamid, mida lubati kunagi sisse tuua) - aga antud momendil on suur töö ettevõtte poolt ette ära tehtud.. elame me majanduses, kus millegi loomiseks läheb vaja ka monetaarseid hüvesid ja see on iseenesest omakorda ebaaus nende suhtes, kellel on ideid ja tahtmist, kuid mitte võimalust.
6 :: |
217 |
Ho Ho
06.06.2011 08:14:03
Kogu see teema on suurepärane näide sellest kuida valesti valitud pealkiri võib kogu asja mõtet kardinaalselt muuta. Kodaik lokuta on musternäide kuidas algset teadaannet lugemata võib vale pildi ja kamaluga eelarvamusi saada.
| lokuta kirjutas: |
| Ma sellise asjaga ei nõustu, kui keegi vabavaralise alternatiivi välja ise mõtleb ilma teiste koodi piilumata, see oleks igati positiivne |
Täpselt nii tehtigi. Skype'i koodi tolle reverse-engineeringu tegijad silmaotsagagi näinud. Mingit vargust pole olnud, mingit seaduserikkumist või turva lõhkumist pole olnud. Lihtsalt suudeti skype'i poolt kasutatavast protokollist aru saada ja see on ka kõik.
86 |
06.06.2011 08:16:09
MarioA.: Ja ära unusta seda väikest asja, et "vabavara programmeerijad" käivad täiskohaga tööl firmades, kus programmeeritakse tooteid, mida pärast kalli raha eest müüakse.
Ja sellest müügirahast tuleb siis see summa, mille progeja palgapäeval enda taskusse saab.
Pole veel kohanud ühtki progejat, kes 365 päeva aastas näljas on ja siis muudkui progeb ja progeb. Ainus asi, mida see progeja siis sel juhul kindlasti teeb, on see et otsib omale töökoha kus võimalikult palju raha makstakse talle tema tehtud töö eest.
Kui ei usu - proovi järgi, kaua suudad elada ilma igasuguste sissetulekuteta.
211 |
Unholy
06.06.2011 08:27:35
| tahanteada kirjutas: |
Kui ei usu - proovi järgi, kaua suudad elada ilma igasuguste sissetulekuteta.  |
Ja mida täpselt see skype lähtekoodi teadmine annab mingile teisele ettevõttele? Loovad konkureeriva toote? Veidi hilja ja kui kujutame ette, et ei olegi hilja, siis kui leitakse mingeid vähegi kattuvaid asju, mida annab vähegi ära tõestada, et need on Skype'lt varastatud siis küll Microsofti legal team sellest ettevõttest kohtus jagu saab ja peo kinni paneb.
Skype on nagunii tasuta ju, ei ole võimalust nagu muude toodetega, et antakse kellegi tasulist tööd tasuta välja, ei..
Ma ei näe, et sellega mingit erilist kahju Skype'le tehtud oleks. See kas see kuidagi turvalisust vähendaks, selle kohta ma kommenteerida ei oska, aga vaevalt, kuna avaldati ju vanemad build'id, ning alati annab patchida.. Vaevalt see mingeid uusi turvaauke juurde lõi.
06.06.2011 08:32:48
| Õiguskaitseorganitele ja luuretegelastele võib see huvi pakkuda. Pidevalt kurdavad, et kurjamid kasutavad suhtlemiseks Skype'i, mida nad endiselt pole võimelised pealt kuulama. Ja kas isegi mõned riigid ei nõudnud Blackberry'lt ja Skype'ilt lähtekoodide avaldamist?
562 |
Ho Ho
06.06.2011 08:40:31
| Betamax kirjutas: |
| Õiguskaitseorganitele ja luuretegelastele võib see huvi pakkuda. Pidevalt kurdavad, et kurjamid kasutavad suhtlemiseks Skype'i, mida nad endiselt pole võimelised pealt kuulama |
Avaliku võtme krüpto kasutamine garanteerib, et ka kogu koodi nähes ei ole võimalik kõnesid pealt kuulata. Vaja on ka vastavaid võtmeid.
86 |
Anton
06.06.2011 10:12:29
| Usun, et peale Skype omandamist Pisipehme poolt projekteeritakse edaspidi sinna sisse suure venna "abimees", mille tulemusena saab suur vend kõiki ka Skypes pealt kuulata. Ega muidu Pisipehme seda hingehinna eest ära ostnud. Skype väärtus polnud kaugeltki nii suur, kui maksti. Siin olid ka suure venna rahad ja huvid mängus!
| Kommentaarid: 87 loe/lisa |
81 |
Ho Ho
06.06.2011 10:17:44
Pigem otsiti korralikku suhtlusplatformi mida nad saaksid kasutama hakata nii pc, moblade kui (tulevaste) konsoolide peal. MSN'il baseeruv värk pole just teab kui asjalik kui jutt käib helikvaliteedist ning tava-telefonidele helistamisest.
86 |
