Martiini
16.05.2011 12:21:21
odavalt ära anda rikkis WD usb hdd |
rikkis hdd ära anda paari euro eest
WD 2500BEV External hdd (Model: WDC WD2500BEVS-22UST0)
arvatavasti (ise arvan) et kettal on "bad sectorid"
iseseisva diagnostika tulemused:
Windows:
"disk management" dialog "initialize disk"
"The request could not be performed because of an I/O device error."
ubuntu:
"disk utility" SMART data - "disk is healthy"
root@dell:/home/martin# badblocks -v /dev/sdc
output - hunnik numbreid
root@dell:/home/martin# dmesg | grep usb
[ 0.318308] usbcore: registered new interface driver usbfs
[ 0.318364] usbcore: registered new interface driver hub
[ 0.318474] usbcore: registered new device driver usb
[ 1.468124] usb 1-2: new high speed USB device using ehci_hcd and address 3
[ 1.760080] usb 1-3: new high speed USB device using ehci_hcd and address 4
[ 4.296120] usb 2-1: new low speed USB device using uhci_hcd and address 2
[ 13.684478] scsi2 : usb-storage 1-3:1.0
[ 13.708135] usbcore: registered new interface driver usb-storage
[ 322.948162] usb 1-8: new high speed USB device using ehci_hcd and address 5
[ 323.083724] scsi3 : usb-storage 1-8:1.0
dd if=/dev/zero of=/dev/sdc
dd: writing to `/dev/sdc': Input/output error
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.00968133 s, 0.0 kB/s
tel: +372 56386762
walwur
16.05.2011 17:47:59
2.50+post
Teeme siis otsa lahti
92 |
lokuta
16.05.2011 17:56:47
Tere
Sul teema vales kohas, see peaks olema müügi teemas!
| Kommentaarid: 92 loe/lisa |
80 |
walwur
16.05.2011 20:48:44
| Hehh on jah,ei pand isegi tähele,äkki keegi ringi tõstab?
92 |
725 |
Martiini
17.05.2011 13:50:26
| laurx kirjutas: |
| wd tehasegarantii ei ütle selle kohta miskit? tehasegarant on 3 aastat. |
Kindel et 3 aastat garantii?
selle mudeli kohta näitab 1 aasta garantii WD lehel.
SurfData
17.05.2011 13:54:15
| laurx kirjutas: |
OEM ketastel muideks on ainult 1 aasta (neid eestis üldiselt pole) ja välistel ketastel on enamasti 2-5 aastat, sisestel ketastel on 3-5 aastat.
| Kommentaarid: 84 loe/lisa |
74 |
725 |
Martiini
17.05.2011 15:01:29
| walwur kirjutas: |
2.50+post
Teeme siis otsa lahti |
5eur soome sampopankki.fi / paypal arvele ja panen hdd posti,,
walwur
17.05.2011 17:39:57
| PS!
92 |
gunn271
20.05.2011 06:00:37
kas veel alles pakuks 6 post sees
_________________ (y)remondin arvuteid läpakaid ja samas ka müüa sülearvutite juppe ,ekraane.laadijaid , mälud, prosed jne..:::küsige ehk leidub miskit  |
| Kommentaarid: 230 loe/lisa |
206 |
