libe
kvaliteetne mees
15.05.2011 13:07:12
too konkreetne ei oma inCPU VGA'd
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Miki-Hiir
15.05.2011 13:33:56
| libe kirjutas: |
too konkreetne ei oma inCPU VGA'd |
Hmm, kindel?
E: Tootja kodulehel on eriti mitte midagi ütlev lõik "GIGABYTE Z68 series motherboards provide all the advanced overclocking features users have come to know and love about the GIGABYTE P67 series motherboards including increasing processor core ratios, increasing DDR3 memory ratios and increasing power and current limits. In addition, GIGABYTE Z68 motherboards also allow users to increase the graphics core clock speed, for even greater graphics performance."
See vist peaks omama:
http://arvutikeskus.ee/est/TOOTEKATALOOG/z68/Gigabyte-GA-Z68MA-D2H-B3-Chip-Z68-2-ch-116930
Selle kohta on ikka kohe konkreetselt kirjas, et "Combining the advantages of the Intel® P67 and H67 platforms in one complete package, the GIGABYTE Z68 series offer the best of both worlds; users can take advantage of the system tuning and overclocking features found in the Intel® P67 platform as well as the built-in visual features of the H67 platforms when combined with 2nd generation Intel® Core ™ processors."
| Kommentaarid: 46 loe/lisa |
43 |
libe
kvaliteetne mees
15.05.2011 13:40:20
| Miki-Hiir kirjutas: |
| libe kirjutas: |
Hmm, kindel?
Selle kohta on ikka kohe konkreetselt kirjas, et "Combining the advantages of the Intel® P67 and H67 platforms in one complete package, the GIGABYTE Z68 series offer the best of both worlds; users can take advantage of the system tuning and overclocking features found in the Intel® P67 platform as well as the built-in visual features of the H67 platforms when combined with 2nd generation Intel® Core ™ processors." |
Z68X on ilma VGA/HDMI pesata, kiibistik toetab, aga plate ei toeta
vähemalt loetelust ei leidnud viidet HDMI, Display port ega muu kohta
http://www.gigabyte.com/products/product-page.aspx?pid=3849#sp
Miki-Hiir
15.05.2011 16:26:47
| Nojah, emaplaadi tagumiste ühenduste pildil ka kõik pildi kuvamiseks vajalik puudub.
43 |
Jaan
123 |
siLc
25.05.2011 18:35:54
Kuna P67A-GD65 ütles üles ja on garantiis juba päris kaua, siis sai ALSO-st omandatud üks siinses mõistes ebaharilik emme - Intel DP67BG, mis kuulub Inteli Extreme seeriasse ja kuuldavasti kannatab kellata isegi.
Esmamulje on positiivne. BIOS on küll EFI baasil aga graafikata, mis ausalt öeldes tundub isegi parem kui MSI kirev virr-varr graafiline lahendus. Loodetavasti peab kauem vastu kui MSI
186 |
Fisher
30.05.2011 11:43:57
| selline küsimus siis, et väike prose upgrade on mõttes ning Intel i5-2500K tundub olevat kõige asjalikum ja taskukohasem valik. Mis mobo-mälud oleks praeguse seisuga(arvutikeskusest ostetavad) kõige asjalikumad, et minusugune keskmiste teadmistega klokkija(ehk siis oskan õpetusi lugeda!) saaks kätte mõnusa ja stabiilse overclocki?
65 |
One
728 |
liivainime
30.05.2011 22:38:17
On olemas, aga peidus:
link
Endal on ka plaanis millalgi lähitulevikus 1155 peale minek, oskad ehk kommenteerida, mille poolest see Gigabyte oma MSI P67A-C45'st parem on, et seda eelistad? Crossfire tugi küll, aga midagi veel, mida esmapilgul ehk tähele ei oska panna?
| Kommentaarid: 17 loe/lisa |
16 |
One
30.05.2011 23:15:09
Eks neil kõigil ole parajalt toored biosid aga Gigal tiba paremini toimiv bios ja parem perf.
Mõlemad tegelikult igati ok valikud.
728 |
-FoX-
31.05.2011 07:53:38
Saan aru ,et P67 kiibil oli see sata pesade probleem?
Mis asi see z68 on vms ... otsin oma soc1155 i5 uut emaplaati ja kõik soovitused oleks teretulnud.
Vähemalt 6 sata pesaga oleks vaja ja vähemalt 2 sata3
_________________ Aita suve, söö lund! |
| Kommentaarid: 366 loe/lisa |
6 :: |
307 |
angel
31.05.2011 08:06:51
intel parandas oma sata probleemid ära uue versiooniga ehk siis probleem oli vaid esimeste emaplaatidega (P67 B3 on siis parandatud versioon). Z68 pms peaks olema P67 koos inteli integreeritud vga kasutus võimalusega.
157 |
One
31.05.2011 08:07:03
| P67-l oli sata2-e kala aga seda pole juba ammu, tuleb lihtsalt B3 versioon(tavaliselt nimes kirjas) osta.
728 |
-FoX-
31.05.2011 13:46:15
Kas see võib olla sata2 kontrolleri viga kui peksab hdd tagant ära.
Siis rescan drive tuleb tagasi ja suht varsti uuesti kadund ...
Sata3 otsas olevad SSD ei kao kusagile.
Hetkel nagu 1 ketas püsima jäänud aga teine HDD ja DVD-rom on kadund jälle ... kõik need sata2 otsas:S
6 :: |
307 |
siLc
31.05.2011 15:42:42
| -FoX-, emaplaat on B3 revisioni oma? See mida kirjeldad on ju P67 kiibi teada viga juhul kui emme pole parandatud B3 revisioni kiibiga.
186 |
-FoX-
31.05.2011 18:55:23
Ei ole B3
Ma vist saan selle ümber vahetada uue vastu?
Aga kas seda peab tegema koht kust plaat ostetud ehk AK või pean saatma MSI-sse tagasi?
Ja kas vahetatakse kohe ümber või oota ja jama sellega?
6 :: |
307 |
libe
kvaliteetne mees
31.05.2011 18:59:27
| -FoX- kirjutas: |
Ei ole B3
Ja kas vahetatakse kohe ümber või oota ja jama sellega? |
mul vahetas AK selle otse letis ära, kogu jama võttis mõned tunnid vaid
seda siis gd55 plaadiga
-FoX-
31.05.2011 22:32:36
Ok tänud ... üritan siis ka ümber vahetada.
Garantii leht kadund kahjuks aga konto väljavõttest on selgitusse arve nr. pandud.
Ei tea kas sellest piisab tõestamaks ,et AK-st olen selle ostnud. Nende arhiivi vist peaks jääma see..
6 :: |
307 |
31.05.2011 23:46:45
Arhiiv ja tegelikult on netis ka arved olemas, kui sul viide alles. Kuigi vist see weebi uuendus pühkis asja minema
200 |
-FoX-
01.06.2011 00:01:14
Ah mul oli see case ,et veerennis anti ettemaksu arve ja siis nende pc taga tegin ülekande.
Aga kuna AK sellest vist suurt ei kannata siis ehk saab asja homme aetud.
Suht masendav muidugi pc laiali kiskuda ... ja uuesti kokku OEH!
6 :: |
307 |
libe
kvaliteetne mees
01.06.2011 00:52:18
sul vähemalt plaat piixus, mul oli tiptop
WAV
01.06.2011 13:19:37
| -FoX- kirjutas: |
| Suht masendav muidugi pc laiali kiskuda ... ja uuesti kokku OEH! |
See ongi asja juures kõige suurem jama. Seda aega ja vaeva ei kompenseeri ju keegi. Pärast uuesti kokkupannes ei pruugi ka masin enam nii hästi jääda (mõned kruvid võibolla ei keera enam korralikult kinni, kleepsud ei kleebi jne.)
Muide mul endal ka B2 plaat. Seni kõik SATA pordid töötavad normaalselt, küsimus ongi, et huvitav kui kaua veel? Või äkki mõnel eksemplaril see tüüpviga ei löögi kunagi välja? Neile küsimustele ei leia kusagilt netist vastuseid...
Aga kui nässu läheb, siis... tõsiselt tuleb kaaluda kas üldse viitsin masinat laiali lammutada ja uuesti kokku panna. Mul MiniITX värk, ülikompaktselt kõik komponendid paigutatud, kaabeldus ka tihedalt kimpudesse seotud ja osaliselt konstruktsiooniliste ribide külge veel kleebitud. Hoolikas kokkupanek võttis aega juba terve päeva, millimeetrite mäng ja täpses järjejorras tuli kõik teha. Nüüd peaks emaplaadi kõige alt kättesaamiseks praktiliselt 100% kõik komponendid enne jälle ära kiskuma... Protsessorit uuele plaadile tagasipannes pean vist lisaks hakkama eraldi termopastat ka siis ostma, originaalne jahuti küljes olnud pasta vaevalt enam teistkordselt kõlblik kokku suruda on (võib-olla)...
Nii et lihtsam siis juba loobuda mõnest SATA pordist, ega nad kõik mulle vajalikud polegi tegelikult.
Kogu selle B2/B3 jama juures kõige jaburam minu jaoks oli see, et ma tegelikult tellisin B3 plaadi, sest ka pikal (bulk) tootekoodil oli ilusti selgelt B3 sees (õiges kohas ka) ja nii ei osanud midagi kahtlustadagi. Plaadil endal otseselt mingit kleepsu selle kohta polnud peal, karpi ka polnud (Bulk versioon, kilekotis lahtiselt nagu ikka). Pärast kui masin juba täiesti kokku pandud ja töötas, alles siis süsteemianalüüsimise utiliitidega detailseid nüansse uurides avastasin tegeliku olukorra. Lisaks sai ka Inteli saidilt pakutud võrdlusinfo alusel kontrollitud paari nende firmasisest kontrollerikoodi tähistust, mille kaudu samuti viis kindlale tulemusele B2.
Plaadi müünud poodi ma ei süüdista, nemad vahendasid hulgilaost saadud toodet ja tootekood oli ju korrektne. Ilmselt kas hulgiladu oli omal kauba ja koodid segi ajanud või oli juba tootja juures see segadus tekkinud.
| Kommentaarid: 7 loe/lisa |
libe
kvaliteetne mees
01.06.2011 15:23:32
plaadi oleks kohe pidanud tagasi ikka viima
ega see vahetusprogramm ka igavene pole
WAV
01.06.2011 16:01:52
| libe kirjutas: |
ega see vahetusprogramm ka igavene pole |
Selles asi oligi, et plaat sai täie hoolikusega juba arvutisse pandud ja alles siis tükk aega hiljem avastasin selle B2 koodi. Toote tellimisel oli ju suurelt kirjas B3, ma ei hakanudki seepärast enne masina lõplikku koostamist midagi lahtiselt laua peal üle testima, no kes oleks taibanud selle mõttega teha!
Ma arvan, et kui ikka selle üldtunnustatud veaga ärasurnud asi on, siis vahetatakse ka kaugemas tulevikus ringi, keegi ju ei vaidlusta, et kelle viga see on!
Samas mul järgmisel kevadel niikuinii juba järgmise põlvkonna plaat hangitud, siis polegi teema enam aktuaalne, kui vaid sinnamaani praegusega kuidagi vastu peaks.
Rahalises mõttes pole ka see ümbervahetamine eriti ratsionaalne. Kogu selle sekeldamise peale kulub siis aega niipalju, et kaotan oma põhitööteenistusest pea sama summa mis see plaat ise maksab.
Aga noh, elame näeme... see viga on kokkuvõttes siiski detail ning mitte primaarne.
Ja kui praegu hakatagi ringi vahetama, siis ega pole endiselt kindel misasja üldse vastu saad! Sest samas laos, sama tooteartikkel, sama koodiga endiselt sees, võib-olla veel seesama partii kah
03.06.2011 23:00:53
kellelgi mõni Inteli(MSI) plaat pinisema on hakanud? Ilmselt ei vedanud ostuga
200 |
