| Millist Western Digitali meediamängijat omad või plaanid soetada? |
| WD TV |
11% |
[ 9 ] |
| WD TV Live |
56% |
[ 45 ] |
| WD TV Live Plus |
7% |
[ 6 ] |
| WD TV Live Hub |
24% |
[ 19 ] |
| hääli kokku : 79 |
04.05.2011 19:37:55
| Syncmahv kirjutas: |
Küsimus Live Hub kohta.
Mida nad mõtlevad selle all: Put your personal media on the high-capacity built-in hard drive and stream it to any screen in the house.
Kuidas streamid pildi suvalisse telekasse majas?? mis valemiga? või on konks selles et igale telekale eraldi WD TV playerit vaja?  |
DLNA + uPnP
196 |
vortex
04.05.2011 19:41:39
Igale telerile eraldi pleier, või teler mis DLNA´d toetab.
Ruuter+kaablid või Wifi adapterid ka muidugi.
| Kommentaarid: 42 loe/lisa |
37 |
Syncmahv
04.05.2011 19:45:52
| Ah muidugi, DLNA unustasin täitsa ära..
102 |
28.05.2011 17:34:58
| Ah muidugi, DLNA unustasin täitsa ära.. |
Antud karbis peaks siis jookseb miniDLNA daemon...mida GUI`st diasblada paraku ei saa...samamoodi siis ka uPnP daemon...
http://sourceforge.net/projects/minidlna/
EDIT: Järjekordselt WD Live HUB uus Firmware...
2.06.10
Supports WD Photos - mobile access application. More information
Supports Picasa - web albums application.
Supports casual games: Cosmox, Memory, Rockswap Adventures and Sudoku.
Supports USB hard drives greater than 2TBs.
Resolved user interface brightness issue introduced with last release.
Resolved Hebrew subtitles not displaying correctly.
Resolved several Facebook user interface issues.
Resolved several TuneIn Radio user interface issues.
Resolved several CinemaNow user interface issues.
Resolved MKV files causing the picture to disappear when subtitles enabled.
Resolved DVD resume is broken if media library is off.
Resolved Deezer green filter hot-key not responding.
Resolved several folder lock issues. |
196 |
Syncmahv
10.07.2011 17:48:22
| Silma hakkas arvutikeskuses WD Elements Play, kas see mingi uus toode ja sarnaneb WD TV'le?
102 |
vortex
10.07.2011 17:54:39
| Amlogicu kivi (peetakse kehvaks); ketas sees, võrgu tugi puudub.
37 |
RaidoR
06.08.2011 15:53:58
| Kui WD Live on LAN-is ja talle väline ketas järgi torgata, kas siis on arvutiga võimalik kettale üle võrgu ligi pääseda?
| Kommentaarid: 52 loe/lisa |
50 |
Skorzeny
06.08.2011 17:42:35
| RaidoR kirjutas: |
| Kui WD Live on LAN-is ja talle väline ketas järgi torgata, kas siis on arvutiga võimalik kettale üle võrgu ligi pääseda? |
Jah.
0 |
07.08.2011 15:47:33
Live HUB' ile siis taaskord uus firmware väljas:
2.07.17
Supports Hulu Plus - content streaming service.
Supports SHOUTcast – music streaming service.
Supports Czech, Dutch, Swedish, Norwegian and Hungarian languages in the user interface.
Supports search - auto complete.
Supports text entry field on web user interface.
Supports user download of photos and videos directly from Facebook.
Supports Facebook photos used in screensaver or as background.
Supports Facebook as a menu source for playing photos and videos.
Resolved Facebook not playing YouTube video from Newsfeed.
Resolved Facebook issue with certain videos causing unit to reboot.
Topitakse seda lõustaraamatut ka igalepoole...
196 |
Syncmahv
07.08.2011 16:30:13
| Keegi neid meediamängijaid on proovinud koos philipsi teleritel oleva natural motioniga? Et kas jookseb koguaeg pilt sujuvalt?
102 |
spezwend
08.08.2011 13:10:03
| Keegi neid meediamängijaid on proovinud koos philipsi teleritel oleva natural motioniga? Et kas jookseb koguaeg pilt sujuvalt? |
Ma pole küll mingeid jõnksutamisi täheldanud...
| Kommentaarid: 67 loe/lisa |
63 |
Syncmahv
26.08.2011 15:36:28
Kuidas oleks kõige targem ühendada Live Hub Teleri taha ja Ressiiveri taha korraga?
Kas HDMI kaabel Hub'ist- telekani ning siis eraldi Hubist optiline ressiiverisse?
Või kasutada teleka ja ressiiveri vahelist coaxiaal ühendust, samalajal kui HDMI on hubist telerisse ühendatud? Või mõni veel parem variant.
Ressiiver lubab ka videot läbi lasta aga ma ei tea kas see kõige parem variant oleks... Hubist HDMI ressiiverisse ja ressiiverist HDMI telerisse.
102 |
vortex
26.08.2011 19:29:55
Parim on viimane variant.
HDMI Hubist ressiiverisse ja sealt HDMI edasi telerisse.
Juhul kui HD heli ei huvita või ressiiver seda ei toeta võib kasutada ka esimest varianti:
HDMI Hubist telerisse ja optiline Hubist ressiiverisse.
Kui ühendad HDMI Hubist telerisse ja sealt optilise või coaxi edasi ressiiverisse, saad ainult stereoheli.
37 |
Syncmahv
21.12.2011 18:36:00
Selline küsimus, et miks Live Hub ennast täiesti välja ei lülita kui teda välja lülitada puldist? Vent jääb ikka tööle vaikselt, nagu oleks võrgus või midagi.
Kuidas saaks välja lülitada, häirib öösel selline sahin.
Ise vastan:
When power LED is on:
- Press the power button to power down the media center.
The internal drive is put in sleep mode and other devices
can still access it.
- Press and hold for five seconds to completely shut down
the device and make the internal drive inaccessible.
EDIT: Uus firmware tuli: Release 3.00.28 (11/17/11)
Supports Vimeo.
AccuWeather supports video news and multi-city favorites.
Supports PlayJam.
Supports media library function for network share folders; SMB/CIFS.
Supports RSS feeds.
Supports Meta-Source Manager.
Supports Auto Get Content Info.
Supports parental control hide option.
Supports screen capture feature.
Supports video information in preview mode.
Supports powered USB hubs. For list of tested USB hubs, please refer to our WD Knowledge Base at http://wdc.custhelp.com/app/answers/detail/a_id/5688/ (Article 5688).
Resolved Picasa unable to download photos to NAS device.
Resolved issue music stops playing when user moves or deletes a file.
Resolved 10 minute skip feature not working.
Resolved several general user interface alignment and functional issues.
Resolved issue get content info with Dutch language causes reboot.
Resolved photo slideshow screen saver stops music playback in Pandora.
Resolved issue playing photo slideshow from USB drive when media library is turned off.
Resolved Spotify song skipped to song track when attempting to play current song.
Resolved Spotify issue playlist not playing continuously.
Resolved several Spotify user interface issues.
Resolved favorite folder via network share under dashboard doesn’t work.
Resolved several user interface and functional issues with Hulu Plus.
Resolved Facebook issue displaying high-resolution photos.
Resolved several Facebook user interface and functional issues.
Resolved several Daily Motion user interface and functional issues.
Resolved issue multichannel PCM is outputted as stereo PCM.
Resolved issue cannot play back video playlist. |
Edit:
Jälle uus uuendus väljas !
Release 3.01.19 (12/20/11)
Supports adding network share folders into "My Media Library" (Use options button).
Supports "WD TV Remote" control application for iDevices (Download Application from iTunes).
Supports Vudu movie service (US only).
Supports SnagFilms indie movies service.
Supports Flixster video movie review and trailer service.
Supports Yota Music streaming service (Russia only).
Supports XOS Digital college sports service.
Supports SEC Digital Network college sports service for Southeastern Conference.
Supports Watch Mojo pop culture and infotainment video streaming service.
Supports ComedyTime stand-up comedians and funny videos streaming service.
Resolved content playback issues with MPEG2 and MPEG4 BluRay ISO, M2TS and .TS.
Resolved issues in Flingo where videos do not fling using Safari web browser.
Resolved AAC audio lag when playing from network share.
Resolved audio lip sync issue if media is paused several times.
Resolved user interface issue of subtitle and audio info not displaying when buttons are pressed on remote.
Resolved issue with Blockbuster and CinemaNow does not reconnect to network share upon reboot.
Resolved issue with user added Meta-Source does not clear after factory reset.
Resolved Auto Play issues.
Resolved NFS issue where it would take 10 seconds to see the IP address.
Resolved issue with resuming music file longer than 15 minutes once file is stopped.
Resolved issue of not being able to select subtitles through options.
Resolved Spotify issue where albums do not play in order.
Resolved Spotify issue where full artist biography does not display. |
102 |
Ra*
| Kommentaarid: 135 loe/lisa |
123 |
25.12.2011 17:15:23
Saigi just veidi aega tagasi uuritud, aga ühtegi "normaalset" lahendust ei paistnud...
196 |
228 |
Skorzeny
26.12.2011 17:41:26
Ega too uus WD ole hakanud toetama ka HD-audioformaate ja kõrgemaid sagedusi kui 48kHz?
0 |
kembadesig
28.12.2011 14:36:37
Pakub mullegi huvi, et mingil ajahetkel katsetamiseks üks korralik meediamängija muretseda. Ise mingit masinat selleks esialgu ehitama ei viitsi hakata.
Mida valida, kui nõudmised sellele masinale oleksid järgmised:
1. Viisakas välimus
2. Kõikvõimalike HD formaatide mahamängimine, samuti Youtube HD (nii heli kui pilt)
3. Võrgutoega ketta olemasolu või võimalus ketta installeerimiseks mängijasse
Need oleks esmalt peamised nõudmised. Siia juurde küsin, et kas ja millised piirid on nendel mängijatel just heli mängimisell? Üle optilise peaks mängima ikkagi seda mida ette antakse, ilma et mängija ise kuskilt midagi pidurdama hakkaks?
_________________ Sounds?... |
| Kommentaarid: 73 loe/lisa |
65 |
m666k
08.01.2012 03:23:52
Olin juba peaaegu ostmas WD TV Live Hubi, aga siis lugesin amazonist palju usaldusväärseid kommentaare, mis väitsid, et indeximine võtab igaviku ja seda peab sageli tegema ning kettale kopeerimise kiirused on üliaeglased ning kasutamismugavus on kehva, kui failide hulk läheb suureks. Lisaks pidavat olema probleeme äsja laetud failide tuvatamisega, mille nägemiseks peab seadet restartima vms. Kui palju sellest on tõsi? Või on uued firmwared osa probleeme lahendanud?
Kas samas hinnaklassis on muidu mingi võrdväärne või parem meediaboks (ei pea olema integreeritud kõvakettaga), mille ostmist kaaluda?
Syncmahv
08.01.2012 12:54:56
m666k, Uuemate firmwaredega teeb see seade ise automaatselt kõik ära, varem oli jah et näha uut pealetõstetud faili siis pidi korra mingi video tööle panema vms, aga nüüd uuendab ennast ise kohe ära.
Iga firmiga läheb aina paremaks
Lisaks leiab pea igale failile automaatselt netist infot selle filmi või siis loo kohta, lisaks veel pilt juurde ja kirjeldus.
102 |
somnambuul
11.01.2012 12:03:30
Sai ka omale see uuem Live Streamer võetud gen 1 playeri asemele. Esimese seadistuse ajal ei suutnud ühenduda WIFI-ga, aitas kui Thompsoni purgist WPA2 asemel WPA panna, siis suutis ära ühendada. Juhtmega võrgu võttis kohe külge.
1. indeximine võttis aega ca 15 min, 2 terane ketas on taga ja seal peal on ca 700 giga asju, selle ajaga tõmbas ka osadele filmidele filmiinfo. Kui töötavale seadmele uusi asju laadida, siis ta need leiab, aga kui kusutada, siis seda ta ei tuvasta, näitab nimekirjas ikka edasi, aga avades ütleb, et item not found vms. Aitab välja-sisse lülitamine, siis korrastab nimekirja ära. Filmi kopimine üle 100megase võrgu võtab ca 5-6 minutit.
Hetkel on probleemiks, et WD ei näe arvuti sharesi (WinXP), arvuti WD ketast näeb ilusti, niiet asjad saab aetud.
Uue firmwarega ilmus valikusse iPlayer, kui selle ka kuidagi Eestis tööle saaks...
| Kommentaarid: 60 loe/lisa |
54 |
Syncmahv
12.01.2012 23:30:43
| somnambuul kirjutas: |
| Kui töötavale seadmele uusi asju laadida, siis ta need leiab, aga kui kusutada, siis seda ta ei tuvasta, näitab nimekirjas ikka edasi, aga avades ütleb, et item not found vms. Aitab välja-sisse lülitamine, siis korrastab nimekirja ära. |
No mul ei kustuta millegi pärast nelja faili ära listist mis on kunagi ära kustutatud... tehtud igast restarte ja proovitud ise kustutada aga ütleb et Delete fail! Read fail. Please check the source device.
Lahti sain nendest sedasi et võtsin arvutist selle kausta lahti kus sees need olematud failid olid ja kohe hakkas hub uuendama. Ja olidki läinud.
102 |
somnambuul
54 |
Syncmahv
03.02.2012 15:06:48
| Tundub nagu mingi kohitsetud versioon youtube leanbackist pandud HUB'i. Aga paistab ka sedasi et mängib automaatselt HD videosi maha, kuigi aru ma ei saa kas 1080p ka mängib(vahest tundub nagu oleks ja teinekord jälle mitte).
102 |
