19.04.2011 09:48:37
Fujitsult maailma väikseim ja õhim veenituvastussensor |
link :: Fujitsu
Fujitsu teatas et toob turule maailma väikseima ja õhima veenituvastussensori. Veenimustri tuvastust peetakse oluliselt turvalisemaks ja võltsimiskindlaks, kui sõrmejälgede tuvastust, seetõttu kasutatakse seda mitmesugustes turvalist autentimist nõudvates taristustes, näiteks pangaautomaatides.
Eeliseks on ka see, et erinevalt sõrmejälgede sensorist ei pea kätt seadme vastu panema ning et mõndadel inimestel võib tekitada psühholoogiline vastuseis üliturvalise silmaiirise kontrolli suhtes.
| The sensor includes a high-speed image-capture system that continuously captures the user's palm veins at 20 frames per second, as well as a feature that instantly identifies the best image from among the captured images and automatically verifies it. This allows users to perform authentication by simply placing their palm lightly over the sensor, rather than holding their hand motionless over the sensor, as before, thereby enabling highly-accurate and convenient operation. |
| Compared to finger veins, palm veins are more numerous and create complex patterns, resulting in a higher volume of data. Consequently, the system's recognition accuracy is extremely high, with a false-negatives rate of 0.01% and a false-positives rate of 0.00008%. Furthermore, the fact that the system uses an individual's thicker veins allows for stable operations over time. Lastly, the system is contact-free, helping to reduce any existing psychological burdens placed on users. |
HV-s ID-kaardiga autentimine
viimati muutis Tanel 25.04.2011 13:10:37, muudetud 1 kord |
7 :: |
364 |
raido357
19.04.2011 09:52:09
| Põnev lahendus.
| Kommentaarid: 78 loe/lisa |
7 :: |
364 |
NATAS999
19.04.2011 10:11:18
Tanel, iep, jõudsin läbi lugeda vahepeal ja oma rumalusest tekkinud eelmise posti ära kustutada.
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
| Kommentaarid: 41 loe/lisa |
39 |
Noname
19.04.2011 10:24:53
Ei saa aru miks turvalisuse küsimuses alati räägitakse ühe või teise tehnoloogia kasutamisest, miks mitte kahe korraga. Võiks olla siis ju mingisugune klaasmuna kuhu paned käe peale, loetakse nii veresooned kui sõrmejäljed ära.
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
322 |
Neo/Hmhm
19.04.2011 10:33:21
| Noname kirjutas: |
| Ei saa aru miks turvalisuse küsimuses alati räägitakse ühe või teise tehnoloogia kasutamisest, miks mitte kahe korraga. Võiks olla siis ju mingisugune klaasmuna kuhu paned käe peale, loetakse nii veresooned kui sõrmejäljed ära. |
See võibolla on pigem selle mõttega mõeldud, et kui sul kuskil 100+ inimest niimoodi näiteks raha välja käib võtmas, siis ei levi mingeid haigusi jms, sest kätt kuskile reaalselt peale panema ei pea.
Iseenesest hea idee, võrreldes sõrmejälje süsteemiga on seda süsteemi raskem petta
| Kommentaarid: 48 loe/lisa |
46 |
19.04.2011 11:34:12
| Neo/Hmhm kirjutas: |
Iseenesest hea idee, võrreldes sõrmejälje süsteemiga on seda süsteemi raskem petta  |
Jääh? Mis asi tuvastab, et sensorile näidatakse kätt ja mitte selle pilti? Pilti inimese käe veenidest on tunduvalt kergem varastada kui sõrmejälge - ehitad samasuguse sensori kuhugi baarileti vms sisse ja muudkui korjad jäljendeid
19.04.2011 11:40:47
Dogbert, vaat kus turvaekspert kargas välja, kui see nüüd peen huumor polnud
Sa pead ikka elavat kätt ette näitama.
Loe natuke: http://www.biometricnewsportal.com/palm_biometrics.asp
The deoxidized hemoglobin in the in the vein vessels absorbs the infrared ray, thereby reducing the reflection rate and causing the veins to appear as a black pattern. This vein pattern is then verified against a preregistered pattern to authenticate the individual.
As veins are internal in the body and have a wealth of differentiating features, attempts to forge an identity are extremely difficult, thereby enabling a high level of security. In addition, the sensor of the palm vein device can only recognize the pattern if the deoxidized hemoglobin is actively flowing within the individual's veins. |
7 :: |
364 |
19.04.2011 12:30:03
Pean tunnistama, et pole lugenud
Aga piltidega on teisigi biomeetrilisi turvaseadmeid petta õnnestunud, kui natuke materjale selle kohta otsida (näotuvastus lihtkaameraga kui kõige ilmsem näide).
Sellest lühikesest kirjeldusest küll ei saa otseselt järeldada, et sensor veenide pilti käeks ei tunnista.
Lauset "...can only recognize the pattern if the deoxidized hemoglobin is actively flowing within the individual's veins" võib tõlgendada nii, et surnud kätt ei saa identifitseerimiseks kasutada (kuna vererõhu puudumise tõttu on kapillaarid ahenenud või veri sealt sootuks teistesse kehaosadesse valgunud), aga elavast käest tehtud veenide pildil on vajalik muster täiesti olemas - on see garanteeritud, et pilti käeks ei peeta? Ei leia nagu kohe sellist otsest väidet...
raxz
19.04.2011 12:58:32
| Kust seda sensorit osta ja palju maksab?
| Kommentaarid: 46 loe/lisa |
45 |
19.04.2011 13:04:09
justnimelt, erinevalt sõrmejälje mustri petmisest jäljendiga (on selliseid lugejaid, mida annab petta), on selle puhul eelduseks vere voolamine soontes.
Vastasel korral autentimist ei toimu.
7 :: |
364 |
Metsjeesus
19.04.2011 13:10:22
Nojah tehnoloogia on meditsiinis kasutusel mõnda aega juba, intensiivravi osakonnas mõõdetakse sõrme otsast hapniku saturatsiooni.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
Noname
19.04.2011 13:12:05
Ma just mõtlesin, et asi see siis kellelgi kätt otsast lõigata. Aga huvitav kas sensor suudab tuvastada kui käe vereringlust pumbaga simuleeritakse?
Ma paneks sellele sensorile kehatemp mõõtmise ka peale...
322 |
19.04.2011 13:24:42
| Noname kirjutas: |
Ma paneks sellele sensorile kehatemp mõõtmise ka peale... |
Verd saaks ka ilmselt soojendada
Aga tahaks näha kuidas sa käe maha raiud ja hakkad vereringlust simuleerima pangaautomaadi juures
Kas lihtsam poleks siis juba miski inside job kaudu vajalik informatsioon/raha kätte saada?
Enamik turvaintsidente on ju tegelikult ettevõtte sisemised.
Natuke rohkem infot Tokyo-Mitsubishi panga näitel
http://www.fujitsu.com/global/casestudies/WWW2_casestudy_BTM.html
7 :: |
364 |
jnt
19.04.2011 13:26:58
Noname, infrapuna saadab see asi välja ja loeb, seega üldise fooni (ehk siis keha temp'i) lugemine peaks olema vaid tarkvara küsimus.
108 |
7 :: |
364 |
Jann1
19.04.2011 13:30:22
Küll kõik on targad ikka....
Rauselt selle asja ära petmine pole nii lihtne nagu te arvate.
Enamus siit ei suuda wifitki murda rääkimata uusimast leiutisest.
128 |
margus1000
21.04.2011 09:26:03
Tegemist ei ole põhimõtteliselt uue lahendusega, aga selle petmise kohta - lugege whitepaperit, kuigi jah, sisene on NDA all Juba vana sensor arvestas veenipildil kaht erinevat veresoonte tüüpi. Üks oli hapnikurikas veri, mis lähtus südamest, teine hapnikuvaene veri, mis liikus tagasi. Lisaks võimaldab IR tuvastada vere hemoglobiini taset. Käe otsastraiumine annab negatiivse tulemuse praktiliselt kohe, käsi keha küljes, kuid kandja surnud, annab negatiivse vaste 40 sekundi jooksul. Põhimõtteliselt on võimalik selle sensoriga ära määrata kasutajate elutegevuse parameetrid, mida peetakse normaalseks ja iga kõikumine annab negatiivse vaste või vallandab alarmi. See siis blokeerib teatud tüüpi medikamentide kasutamise kasutajate peal. Muide whitepaperist tuleb välja veel üks huvitav fakt. Nimelt on erinevate rasside esindajatel erinevad parameetrid, seega selle sensori abil on võimalik isegi rassilist kuuluvust kindlaks teha
_________________ God grant me the serenity to accept the things I cannot change, courage to change the things I can, and wisdom always to tell the difference. |
ipredator
ihvike
25.04.2011 12:16:27
| Mitte õheim, vaid õhim.
| Kommentaarid: 12 loe/lisa |
12 |
