11.08.2010 13:56:21
Operation Flashpoint: Red River
•Koduleht:www.flashpointgame.com
•Arendaja/Väljaandja: Codemasters
•Stiil: Modern First-Person Shooter
•Väljalaske kuupäev: 21.04.2011
Mängumootor: EGO 2.0
Multiplayer: Jah, COOP
Set in Tajikistan, nestled between the borders of China and Afghanistan. The player will have the option of playing the campaign co-operatively. However, the game will not feature competitive multiplayer. The player will also be able to explore 200km of terrain. The player will be able to choose between four classes of soldiers to play as, rifleman, grenadier, scout and auto rifleman, each with their own weapons and abilities. The player will be able to purchase upgrades. The game's director Sion Lentonsaid "Operation Flashpoint: Red River is being built around four player co-op online play, complete with a strong narrative, new enemies and combat scenarios to deliver gameplay that immerses players in the reality of war like never before" The enemies will be able to kill the player with a single shot. The single player campaign will be divided into three distinct acts. The game will attempt to be as realistic as possible.
Pildid
Operation Flashpoint: Red River Sion Lenton and James Nicholls Interview
Tahaks täista loota ,et nad midagi paremaks teinud nüüd. Elu sisse toonud maailma jne.
Piltide ja videode peale pole mõtet kõvatada. CM on maailma parim piltide töötleja
Tõsiasi on see et liiga vara tuleb välja...kena aastake võiks veel asi soolas olla.
Kahju aga sama fail tuleb mis esimene osa, mis mulle isiklikult meeldis, lihtsalt üldsuse mõttes fail.
DefXtreme, see oli küll nüüd kole . Rikkusid kõik ära Reklaamivad seda jama ainult ühel mapil, väga koleda graafika ja ilusa jutuga .
Huvitav kui kiirelt MP välja sureb. Eelmine osa kärvas 4-5 nädalaga ära . Teeks mingid panused ?
Endale küll meeldis Dragon Rising, oli selline mõnus hardcore simu ja arcade shooteri vahepealne mäng. Loodetavasti tuleb Red River analoogne.
Tehku mis tahavad aga ärgu kurat talle Operation Flashpoint nimeks pangu, on küll tore kui saad hea IP endale aga teeb enam vähem sama välja kui keegi Doom'i nime ära ostab ja siis sellest COD'i teeks.
Originaal Flashpointi muidugi sai veel isegi päris hiljuti Coop'is lastud, kunagi enda poolt tehtud coop'i map'i peal kus vabalt 6 tundi ringi sai joosta, linnu võtta, kaaslasi otsida ja sildu õhku lasta (kunagi sai isegi OFP scripting selleks selgeks õppida et igasugu vigureid lisada). Bussiga vaenlase tagalasse sõitmine ning sealt pihta hakkamine oli kah omamoodi lahe: Välja arvatatud siis kui AI driver üle silla sõitmise millegi peale ehmus ning sind silla alla sõidutas ja üleval terve kari russe sulle kuuliga pähe tahtsid sõita
Kruvi, hea stoori kamandad AI autosse mis on 5m kaugusel aga AI teeb ikka väikse ringi sisse enne kui potsti autosse maandub _________________ "Mõtle kriitiliselt"
Ei noo parim lause oli ikka: AI in Dragon Rising was too good, so we had to dumb it down
See Sion on ikka üks paras naljamees, ta jutt ja nägude tegemine jne -> EPIC!
Ei... seni kaua kuni Hr. Sion Lenton projekti ees otsas on, ei tule sellest kah midagi head
AI pathfinding (vahest ei suutnud kuidagi "õigest kohast" näiteks masinale pihta saada) ja sõitmine olid jah naljakad, enamasti eelistasid sõitmisel teid aga vastavalt olekule tõmbasid väga hullu vahepeal.
Ehk siis kas nö. casual või alert, tava olekus sõitsid normaalselt aga nigu midagi kuskil kärgatas panid kohe road rage'i
Peaks muidugi huvi pärast selle uue Red Riveri demokese ära proovima kui nad seda jagada julgevad aga kardan et graphics > gameplay
Norm mäng, enamus ajast kuuled neegri möla. Jube ropp mäng on. Fuck, ass jne käib pidevalt.
Maailm on ka selline, et nagu tegevus käiks koomiksis. Kõik on liiga värviline ja kirev. Puhast valgust ei ole.
siinseid kommentaare ei kannata lugeda - uhked HV sõdurid ei suuda eelarvamustest üle olla, vaid massiga koos peab alati kiruma
Eks see " mass" saab aru et Flashpoint on CM poolt tehtud hingetuks lüpsimasinaks.
Aga sa tee oma peas sitast sepikut edasi ja ära unusta sioni FB sõbraks omale panna.
lihtsalt uhked sõdurid internetis ei tunne halltoone, vaid kas kuld või sitt - vahepealset ei ole - emokultuur
piinlik lihtsalt _________________ ☠
hea nali.. hea nali... ei olnud ta ei "simu" ega ka arcade shooteri vääriline asi. Rohkem oli tegemist mingi beta asjaga kus üritati Dirt mootorit käima ajada kui fps vaates asjandust aga failiti ning isegi auto juhitavus oli sitt mis on omaette saavutus firmale kes tegeleb auto mängude loomisega. Vast ajad segamini selle mänguga mis kunagi sama nime kandis aga mis ei olnud marketingu powwaga üle hype'itud ning omas ka mingit "pointi" ja AI olemasolu ning gameplay'd... aga jah eks rahvas tahab propagandat, tsirkust ja mänge mis ei sunni neid mingis suunas arenema või mõtlema. The age of über derp game'ing... -> press a button and something AWESOME happens... every time
ülevaate score'e vaadates õnneks nad seekord kah ei pingutanud üle
Hea mängu kvaliteedi näitas ka muidugi see kui kiiresti ta "säästu korvi" visati ja kuidas seda mitu korda pms "tasuta" üritati ära anda... ning siis vaikselt unustusse vajus. Kellele mäng meeldib siis ostku, varste nagunii mingi kopikate eest müügil.... head asja peabki odavalt ära andma _________________ |--{o,o}-----(\__/)-----------------|
