uus teema   vasta Hinnavaatlus »  Sülearvutid »  Dell n5010 BSOD :( märgi kõik teemad loetuks
Kapitan
Kaevur
Kapitan
sõnum 06.04.2011 08:54:46 Dell n5010 BSOD :( vasta tsitaadiga
Viimasel ajal on mängides hakanud arvuti bsodi viskama. Vahetasin täna windowsi, probleem ikka püsib. Postitan siia logi ka. Äkki keegi targem mees teab mida teha või viia garantiisse?
DUMP:
http://www.upload.ee/download/1249770/28e7e4a59398621fbf6/040511-28657-01.dmp
EDIT:
Saan aru, et videoga probleeme, tõesti mõistus otsas. Ei uskunud, et pean enda Delli garantiisse viima icon_biggrin.gif
DUMP:
Debugging Details:
FAULTING_IP:
igdkmd64+1d8f0
fffff880`0482b8f0 4889542410      mov     qword ptr [rsp+10h],rdx
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x116
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`05dc3a58 fffff880`02ca1000 : 00000000`00000116 fffffa80`04c6d160 fffff880`0482b8f0 00000000`00000000 : nt!KeBugCheckEx
fffff880`05dc3a60 fffff880`02ca0d87 : fffff880`0482b8f0 fffffa80`04c6d160 fffffa80`0642b420 fffffa80`06379010 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`05dc3aa0 fffff880`02d47f07 : fffffa80`04c6d160 00000000`00000000 fffffa80`0642b420 fffffa80`06379010 : dxgkrnl!TdrIsRecoveryRequired+0x21f
fffff880`05dc3ad0 fffff880`02d75d5a : fffffa80`ffffffff 00000000`0036807d fffff880`05dc3c30 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`05dc3bb0 fffff880`02d4329e : fffffa80`06379010 ffffffff`feced300 fffffa80`04419d50 00000000`00000000 : dxgmms1!VidSchWaitForCompletionEvent+0x196
fffff880`05dc3bf0 fffff880`02d6fe7a : 00000000`00000000 fffffa80`04419d50 00000000`00000080 fffffa80`06379010 : dxgmms1!VidSchiScheduleCommandToRun+0x1b2
fffff880`05dc3d00 fffff800`02d35cce : 00000000`fffffc32 fffffa80`0617aa10 fffffa80`03b4d040 fffffa80`0617aa10 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`05dc3d40 fffff800`02a89fe6 : fffff880`02fd3180 fffffa80`0617aa10 fffff880`02fddfc0 fffff880`0122a384 : nt!PspSystemThreadStartup+0x5a
fffff880`05dc3d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
igdkmd64+1d8f0
SYMBOL_NAME:  igdkmd64+1d8f0
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: igdkmd64
IMAGE_NAME:  igdkmd64.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d746480
FAILURE_BUCKET_ID:  X64_0x116_IMAGE_igdkmd64.sys
Followup: MachineOwner
2: kd> !analyze -v
*                        Bugcheck Analysis                                    *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa8004c6d160, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8800482b8f0, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 000000000000000d, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
igdkmd64+1d8f0
BUGCHECK_STR:  0x116
CURRENT_IRQL:  0
STACK_TEXT:
FOLLOWUP_IP:
igdkmd64+1d8f0
ollev
sõnum 06.04.2011 10:19:26 vasta tsitaadiga
Kas proovisid uuesti installida inteli draiveri?
A.S.
sõnum 06.04.2011 11:20:24 vasta tsitaadiga
Läpa seest tolmune?
Kapitan
Kaevur
Kapitan
sõnum 06.04.2011 11:21:23 vasta tsitaadiga
No googeldasin natuke. Sain aru, et praegune driver on bugine ja too mäng ka. Lasin mängule patchi ja installisin graafikale eelviimase uuenduse. nüüd ootan. yawn.gif
A.S. kirjutas:
Läpa seest tolmune?
Arvad, et kuumeneb? Ta mul umbes 6 kuud vana.
A.S.
sõnum 06.04.2011 11:35:03 vasta tsitaadiga
Kui selle aja jooksul pole kordagi puhastanud, siis võib küll tolmuprobleem olla. Läpakad imevad seda tolmu üsna usinasti, nagu tolmuimejad.
Seal vist ei anna seda GPU temperatuuri millegagi mõõta ka mitte?
Kapitan
Kaevur
Kapitan
sõnum 06.04.2011 12:35:48 vasta tsitaadiga
Eks ma kontrollin gpu temeratuure ka siis. Everest peaks asja ära ajama
A.S.
sõnum 06.04.2011 12:44:06 vasta tsitaadiga
Võid proovida ka http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
Kapitan
Kaevur
Kapitan
sõnum 06.04.2011 12:51:04 vasta tsitaadiga
Njah tundub, et kaardil pole sensoreid, et temperatuuri mõõta :S Igatahes GPU-Z ei näita midagi icon_biggrin.gif
A.S.
sõnum 06.04.2011 12:57:18 vasta tsitaadiga
Ega sellistel tavaliselt pole jah.
Amperloom
Amperloom
sõnum 07.04.2011 11:47:55 vasta tsitaadiga
Speedfan äkki leiab mõne sensori.
Kui CPU temp on kõrge, ka sellest võib järeldada, et ajab graafika kuumaks.
TehnikaUudised - VirtuaalRuum
siLc
sõnum 07.04.2011 12:59:43 vasta tsitaadiga
Proovi HWMonitori.
