Alvaaro
27.03.2011 00:21:53
| londiste kirjutas: |
ot:
| Alvaaro kirjutas: |
Suht (<font size=-1><i>tegelikult tahtsin kirjutada</font></i> =>)<b>mõ<font color=red>tt</font>etu</b> võrrelda pc ja konsoole.
Pc le peab pidevalt uusi juppe ostma kuna muidu ei vea välja enam.  |
Alvaaro, kao teise teemasse selle väljaütlemisega. |
Sa vaata kes siin hakkas seda teemat ajama.
Nii,et pane oma lont kinni.
| Kommentaarid: 217 loe/lisa |
182 |
filter89
29.03.2011 18:23:50
Selline jama ,et ei saa xboxile teleka taga enam pilti ette , arvuti monitori küljes tuleb kohe ette ,teleka taga mitte . olen proovinud kahe erineva teleka taga ja proovinud seda resetimist aga ei midagi. nõu ?
Proovisin selle tavalise kolme otsaga kaabliga ka ,sellega sain pildi ette aga hdmi ikka ei midagi
| Kommentaarid: 11 loe/lisa |
S.I.L.L.U
29.03.2011 22:56:50
http://majornelson.com/2011/03/29/xbox-360-system-update-preview/
Quote:
I am happy to announce that we’re doing an Xbox 360 System Update Preview program for our next release, and the opportunity to sign up is now available. We are conducting an open call for US based participants* for a public preview to help us prepare for an updated Xbox 360 disc format. This is an important update as we continually strive to improve our products and we could not do so without the help of our great Xbox community. As part of the preview program, you will receive a copy of Halo: Reach along with other possible rewards.
Much like we did last year, you’ll need to visit the Microsoft Connect site from this link and sign in with your Windows LIVE ID that is connected to your Xbox LIVE Gamertag. Once you complete the survey that is presented to you, the Connect site will provide program related updates and you will receive a mail once the selection process is completed.
A couple of points before you head off to register:
- We’re looking for multiple thousands of participants, so your chances of making it in are good.
- This opportunity is open to Xbox LIVE Members in US region only*.
- To avoid any problems, read the survey carefully and double check all the information you provide.
- While both Xbox LIVE Gold and Silver members can sign up, priority will be given to Gold members in the selection process.
*Due to disc distribution limitations, this beta it will be limited to residents of the United States only.
| Kommentaarid: 96 loe/lisa |
90 |
ArvQ
30.03.2011 08:22:38
Uus piravastane kaitse
| Kommentaarid: 176 loe/lisa |
149 |
Rudolf112
30.03.2011 14:06:03
ma saan aru, et mkv mängimine xboxile on lootusetu üritus.
kas mingit subtiitrite tuge xboxil on? |
Ise ootan seda updatet nii mkv-le kui subidele juba aastaid, ilmselt kui siiani pole tulnud, siis ei tulegi. GOTSenti kasutamine on küll väga käe sees, aga no krt, kaua võib?
| Kommentaarid: 57 loe/lisa |
55 |
S.I.L.L.U
30.03.2011 16:44:13
Kasutage TVersity stemimiseks ja saate oma subid ja mkv mängima, mida te ikka sellest MS ootate
90 |
ArvQ
30.03.2011 17:22:16
| S.I.L.L.U kirjutas: |
Kasutage TVersity stemimiseks ja saate oma subid ja mkv mängima, mida te ikka sellest MS ootate  |
Või serviio't
149 |
rebane84
31.03.2011 16:16:54
mul selline jama, et kui tahan seda kinect Adventures mängida siis käseb mul PAL 60Hz peale seadest panna aga sellega kaasneb ka kehvem pilt milles võib teema olla?
| Kommentaarid: 4 loe/lisa |
31.03.2011 16:34:24
S.I.L.L.U, Jackinthex, lihtsam ja korduvalt efektiivsem on teleka vaatamiseks sel juhul juba arvutit kasutada
_________________ - londiste
217 |
Skull-Tx
31.03.2011 16:49:23
| Mul selline jama, et xbox ei loe mänge, kui mitmeid kordi proovida siis hakkab lugema aga muidu viskab ette, puhastaksin diski ning teeksin restardi konsoolile (olen teinud aga ei midagi). Oskab keegi aidata?
nah
31.03.2011 18:14:49
| Skull-Tx, laser hakkab õhtale minema, kas teed pot calibrationi, vahetad laseri või paned üldse uue drivei sisse.....
| Kommentaarid: 150 loe/lisa |
141 |
Skull-Tx
31.03.2011 18:18:16
| nah kirjutas: |
| Skull-Tx, laser hakkab õhtale minema, kas teed pot calibrationi, vahetad laseri või paned üldse uue drivei sisse..... |
mida tähendab pot calibratoni?
nah
31.03.2011 18:21:25
Skull-Tx, keerad laseri takistust vähemaks ehk annad rohkem särtsu laserile.
141 |
Skull-Tx
31.03.2011 18:22:28
| nah kirjutas: |
Skull-Tx, keerad laseri takistust vähemaks ehk annad rohkem särtsu laserile.  |
Kumb kasulikum teha?
nah
31.03.2011 18:27:57
| Kõige kasulikum on garantiisse viia
141 |
biomehanik
31.03.2011 18:49:06
| Kas laser lihtsalt ei või must olla, targem äkki algul proovida lihtsalt puhastada ja kui ei aita, siis juba ekstreemsemad lahendused.
| Kommentaarid: 260 loe/lisa |
227 |
S.I.L.L.U
31.03.2011 19:15:12
| rebane84 kirjutas: |
mul selline jama, et kui tahan seda kinect Adventures mängida siis käseb mul PAL 60Hz peale seadest panna aga sellega kaasneb ka kehvem pilt milles võib teema olla? |
See mäng tahab lihtsalt 60Hz saada ja ongi kõik.
Ühenda HDMI´ga ära, kui võimalik ja siis pole muret.
90 |
rebane84
31.03.2011 20:24:55
Ühenda HDMI´ga ära, kui võimalik ja siis pole muret. |
et ostan HDMI juhtme ja korras?
S.I.L.L.U
31.03.2011 20:54:41
et ostan HDMI juhtme ja korras? |
Eeldusel, et su telekas seda ka toetab
90 |
Okman
| Kommentaarid: 429 loe/lisa |
367 |
rebane84
31.03.2011 21:15:28
Eeldusel, et su telekas seda ka toetab  |
No telkul on HDMI mulk täitsa olemas aga imelik on see, et nagu mis kuradi sitta juhet nad mulle kaasa pakivad siis:D
Okman
31.03.2011 21:33:26
rebane84, pannakse see mis on kõige odavam et sa ikka peaksid midagi juurde ka ostma...
Ma ostsin enda Elite-i veel siis kui pandi palju nodi kaasa, kaasa arvatud ka HDMI kaabel. Hiljem kaotati see komplektist ära :S
_________________ https://steamcommunity.com/id/okman_est/ |
367 |
rebane84
31.03.2011 21:36:58
| Okman kirjutas: |
Ma ostsin enda Elite-i veel siis kui pandi palju nodi kaasa, kaasa arvatud ka HDMI kaabel. Hiljem kaotati see komplektist ära :S |
KRT ma juba põdesin, et telekas on pask
Rudolf112
01.04.2011 09:12:56
Tundub asjalik, pole teemaga ennast kursis hoidnud, kodus proovin järele.
55 |
j2mm
01.04.2011 10:32:18
TVersity subakad: siin, siin ja siin.
Miinuseks olid minu puhul kohati päris pikad buffering'ud keset videot...
| Kommentaarid: 88 loe/lisa |
72 |
