11.03.2011 08:48:50
Muide kes ei taha RC1 installida läbi installeri (vaikimisi tahab def panna ennast), siis pakkisin nii inglise kui ka eesti installerid lahti ja tegin .zip failid nagu Nightly-de puhul:
ENG: http://www.mediafire.com/?8bk3hewa3qy4nmx
EST: http://www.mediafire.com/?unygu0cj6wf511v
Peale lahtipakkimist ei maksa siis kohe jooksutada firefox.exe vaid desktopile väike shorcut teha kus target real kirjas lisaks tavalisele ka:
| -profile "C:\Program Files (x86)\Mozilla Firefox Next\MyProfile" -no-remote |
Kogu õpetus siin:
1 - Download a Zip-Archive build of the version you want to install - available in http://ftp.mozilla.org/pub/mozilla.org/firefox/nightly/latest-trunk/
2 - Create a folder for that version of Firefox, like C:\Program Files (x86)\Mozilla Firefox Next
3 - Extract the Zip file into the folder that you created.
4 - Go to the folder and rightclick on the firefox.exe file and Send to > Desktop (create shortcut)
5 - Create an empty folder where you want the new Profile for this version to be located, like maybe C:\Program Files (x86)\Mozilla Firefox Next\MyProfile\ to keep it near the Firefox program files.The name of that Profile would be "MyProfile"(without quotes).
6 - Rightclick on the new desktop shortcut and modify the Target line like this:
~firefox.exe" -profile "C:\Program Files (x86)\Mozilla Firefox Next\MyProfile" (there has to be a space between .exe" and -profile and if your profile path contains spaces then the path must be enclosed in quotemarks.).When done then click apply.
7 - If you want to run this version simoltaniously with your regular profile then add "-no-remote" to the end of Target line(without quotes).
8 - Doubleclick that Desktop shortcut to launch the new version you just installed and a new Profile will be created upon Startup. |
Kui lõppversioon tuleb, siis saab kergesti RC1 maha lasta lihtsalt vastava kausta kustutamisega ja mingit muud jälge ei jää
| Kommentaarid: 92 loe/lisa |
simpanzzz
12.03.2011 02:03:40
kas kellelgi pole viimasel viimase Firefox'i (3.6.13 vist) ja Snow Leopard'i (10.6.6) vahel probleeme olnud ?
mul tuleb pidevalt ette seda, et linki vajutades ei juhtu midagi või tuleb tühi tab ette ja vahel ei mängi videoid. Pluss, vahel ei tunnista üldse internetiühendust.
nõme on
edit: okei, sain lõpuks vaevaga uuendatud viimasele Firefox'ile (3.6.15) ja nüüd kõik pelab
| Kommentaarid: 58 loe/lisa |
55 |
bitCON
12.03.2011 20:27:17
| kuidas MX518 hiirel need back/forward nupud disableda firefoxis? mul on need setpointis määratud heli muutmiseks aga kui firefoxi aken on aktiivne siis muutuvad need back/forward nuppudeks
12.03.2011 20:37:16
| Nitrub kirjutas: |
| kuidas MX518 hiirel need back/forward nupud disableda firefoxis? mul on need setpointis määratud heli muutmiseks aga kui firefoxi aken on aktiivne siis muutuvad need back/forward nuppudeks |
Vb see:
K3ndu
12.03.2011 20:37:40
On kellelgi ennem sellist probleemi olnud, et osadel lehtedel lööb lehe valgeks ja paremasse nurka tuleb Skip This Ad, tõsiselt häirib see ja olen firefoxi reinstallind ja pole tolku olnud.
122 |
12.03.2011 20:39:34
| K3ndu kirjutas: |
On kellelgi ennem sellist probleemi olnud, et osadel lehtedel lööb lehe valgeks ja paremasse nurka tuleb Skip This Ad, tõsiselt häirib see ja olen firefoxi reinstallind ja pole tolku olnud.  |
See pole error ja seda ei saa Firefoxi reinstalliga parandada
Vb mingi greasemonkey skriptiga saab mööda neist.Eriti nt IGN.com on silma jäänud need asjad.
bitCON
12.03.2011 21:48:28
| tänud tomorrow
K3ndu
12.03.2011 22:25:39
Sa said vist natuke valesti aru, tegemist ei ole mingi kindla lehega seotud probleemiga vaid täiesti lampi tuleva asjaaga, lööb su lehe valgeks ja paremasse ülemisse nurka tuleb Skip This Ad, kui peale klikkida tuleb leht uuesti ette ja probleem lahendatud, kui Adblock maha võtta lööb sellele valgele lehele ka reklaami peale. Mis kõige huvitavam on see, et ainult ühes arvutis see anomaalia juba pikemat aega ja teises arvutis pole kunagi seda olnud.
122 |
13.03.2011 01:51:55
| K3ndu kirjutas: |
Sa said vist natuke valesti aru, tegemist ei ole mingi kindla lehega seotud probleemiga vaid täiesti lampi tuleva asjaaga, lööb su lehe valgeks ja paremasse ülemisse nurka tuleb Skip This Ad, kui peale klikkida tuleb leht uuesti ette ja probleem lahendatud, kui Adblock maha võtta lööb sellele valgele lehele ka reklaami peale. Mis kõige huvitavam on see, et ainult ühes arvutis see anomaalia juba pikemat aega ja teises arvutis pole kunagi seda olnud. |
Kontrolli oma arvuti üle siis.Tundub nagu miski pahavara möllab ja viskab reklaami ette sulle
Ands
17.03.2011 11:14:09
| mingil põhjusel ei lase firefoxiga pangatehinguid allkirjastada, räägib midagi Java konsoolist.....Loll probleem, aga oskab keegi ehk nõu anda, mida näppida?(probleem kusjuures eri arvutitega, varem pole seda olnud). Pinnid ja sertifikaadid korras
| Kommentaarid: 354 loe/lisa |
301 |
17.03.2011 15:57:36
| ID-kaardi tarkvara versiooni 3.3'ga toimis brauseripõhine allkirjastamine kenasti.
| Kommentaarid: 85 loe/lisa |
AJ
17.03.2011 23:43:15
Mozilla schedules Firefox 4.0 for March 22
TechSpot
Mozilla plans to launch Firefox 4.0 on March 22, 2011. The news comes straight from the horse's mouth: the new release date was posted on the Mozilla Wiki and on mozilla.dev.planning.
Mozilla has found problems in the current RC1 build, but it has decided that those issues aren't critical. RC1 will be released as the final version and a 4.0.1 release will be issued instead. The company will enable users to update Firefox versions 3.5 and 3.6 to 4.0 without the need to navigate to a download page.
Mozilla was originally planning on having Firefox 4 out by the end of last year, but it has had to delay the release multiple times. The company has fixed more than 7,000 bugs in the 12 betas. Last week, the company put out an RC build and now all that's left is the final release.
Mozilla has been struggling to get Firefox 4.0 out the door. As a result, the company has announced that in 2011, not only will we see Firefox 4.0, but we will also see Firefox 5.0, Firefox 6.0, and Firefox 7.0. The first 5.0 builds are already in the making; the next version is targeted for a late June 2011 release.
All,
Firefox 4 RC1 has received a very warm welcome; it's time to make a decision to ship. As of now, there are no known issues that would stop us from shipping RC1 as final. At the conclusion of our regular 11:30AM triage session on Wednesday, March 16th, release drivers will decide whether to ship RC1 as Firefox 4.
March 22nd is the day we would ship. Both IT and Marketing have indicated that March 22nd is an acceptable final launch date. If at any time we discover issues that would block final release, we would issue an RC2 as soon as possible, reset the ship date, and communicate to everyone.
All my best,
Damon
| Kommentaarid: 37 loe/lisa |
36 |
mhei
18.03.2011 00:46:57
mul FFiga enam ID kaart ei funka.....
GC ja IEga töötab....
jama tekkis alles nüüd
_________________ ツ |
18.03.2011 08:27:14
| AJ kirjutas: |
TechSpot
All,
All my best,
Damon
Väga hea.Paraku midagi ei fixita lõppversioonis vaid lihtsalt relabeldatakse RC1 --> RTW
Igatahes täna teen veel viimased ettevalmistused ja testimised üleminekuks.
Lisadega on üllatavalt hea olukord .Hetkel plaanin üle viia 37 lisa.Neist 5 on nö "hüljatud" (addons.mozilla.org neid kah enam pole) ehk siis need töötavad aga vajavad käsitsi mudimist.2 viimast mitteühilduvat peaksid kohe-kohe uuendiused saama ja ülejäänud töötavad .Seega 5/37 on päris hea aga kõik töötavad.Mäletan 3.6 tuli, siis oli kümneid lisasid mida ma kasutasin mis polnud ühilduvad isegi kuu aega pärast väljalaset
18.03.2011 09:51:12
| tomorrow, nii käibki ju RC -> Release. Kui tahetaks fixida, peaksid välja laskma RC2'e.
prtv
| Kommentaarid: 82 loe/lisa |
73 |
18.03.2011 12:03:13
| tomorrow kirjutas: |
| mikk36 kirjutas: |
| tomorrow, nii käibki ju RC -> Release. Kui tahetaks fixida, peaksid välja laskma RC2'e. |
Mozillal kahjuks jah.Siiski ootan uuendatud buildi ära. |
Aga uuenda siis otse 5.0 peale... selleks ajaks saavad 4.x bug`id vast fixitud
196 |
rocky-b
18.03.2011 12:08:24
Mul selline loll küsimus, et kuidas saab seda lehte muuta kui uue kaardi lahti teen ( ma ei mõtle avalehte ) .
EDIT: Probleem lahendatud .
viimati muutis rocky-b 18.03.2011 16:19:26, muudetud 1 kord |
| Kommentaarid: 13 loe/lisa |
bitCON
18.03.2011 12:49:37
| kas te paroole ka "sync"ite, mingit turvaohtu pole?
18.03.2011 16:08:33
| mikk36 kirjutas: |
Eksid, nii peakski kõikidel käima. Sa vist ei tõlgenda õigesti väljendit "Release Candidate".
18.03.2011 22:03:30
| tomorrow, signatuurid on kasvõi seepärast erinevad et ühel on kirjas RC, teisel RTM (about infos jne).
Celos
19.03.2011 03:25:49
| mikk36 kirjutas: |
| tomorrow, signatuurid on kasvõi seepärast erinevad et ühel on kirjas RC, teisel RTM (about infos jne). |
Jah aga RTM tõi mõningaid featuure kah juurde .Samas ma saan aru, et mozilla ei taha nii hilises staadiumis enam midagi eriti muuta ja kõik fixid (kui pole just kriitilised mis RTW blokeerivad) lükatakse 4.0.1 peale. |
See, et üks firma nii tegi ei tähenda, et RC peakski olema mingi tühi sõnakõlks. Asja mõte on ikkagi tekitada versioon programmist, mis bugide ilmumiseta ka lettidele lüüakse.
| Kommentaarid: 17 loe/lisa |
16 |
gandalf
19.03.2011 04:01:32
| tomorrow, otseloomulikult pole installitav fail täpselt sama, mis RC. nimetused on vaja muuta kasvõi. küll aga pole funktsionaalsuses mitte mingit erinevust. Kui Sa mõtled natuke selle peale, mis on Release Candidate'i mõte peaks see iseenesest mõistetav olema. Ja nii töötab see igal pool.
bitCON
19.03.2011 19:45:56
| mis plugin või addon installida et URL complete töötaks täpselt nagu chromes
Jüri Öö
21.03.2011 00:15:13
| Kuidas saab Firefoxi Chromest järjehoidjaid importida?
Anti112
21.03.2011 03:01:30
File > Import?
115 |
mhei
21.03.2011 11:57:41
minu teada seadete alt peaks see olema, aga pead ei anna...
kahjuks pole hetkel FFi käepärast, et uurida
Märt.
21.03.2011 14:03:10
mhei, Anti112 juba ütles õige vastuse.
| Kommentaarid: 29 loe/lisa |
23 |
mhei
21.03.2011 14:09:07
sry
bitCON
21.03.2011 15:28:26
| kuidas "browser.urlbar.autocomplete.enabled" korralikult tööle saada, et oleks nagu chromes. enamustel lehtedel tuleb "www." ette trükkida et see korralikult töötaks mis käib suht pinda.
21.03.2011 15:43:02
Nitrub, sa kirjuta, mismoodi ka käituma peaks, mitte et 'nagu chromes'. Mõni äkki pole Chrome kasutaja... Siis teaks aidata.
"browser.urlbar.autoFill" seadmine ei aita käitumise muutumises soovitud suunas kaasa?
_________________ Experience is what you get when you don't get what you want.
viimati muutis bladerunner 21.03.2011 15:51:50, muudetud 1 kord |
160 |
bitCON
21.03.2011 15:48:25
| bladerunner kirjutas: |
| Nitrub, sa kirjuta, mismoodi ka käituma peaks, mitte et 'nagu chromes'. Mõni äkki pole Chrome kasutaja... Siis teaks aidata. |
no kui trükin näiteks esmakordselt sisse omgubuntu.co.uk ja järgmisel korral kui hakkan trükkima "omgubun..." siis ta ei täita mitte midagi, tuleb trükkida "www.omg..." ja siis töötab, aga ma ei viitsi www ette toppida sel pole mingit mõtet siis
21.03.2011 15:52:23
"browser.urlbar.autoFill" seadmine ei aita käitumise muutumisele soovitud suunas kaasa?
http://kb.mozillazine.org/Browser.urlbar.default.behavior
viimati muutis bladerunner 21.03.2011 15:54:37, muudetud 1 kord |
160 |
bitCON
21.03.2011 15:59:55
okei leidsin alternatiivi, addon nimega "Enter Selects" selekteerib automaatselt soovitustest esimese vaste ja tuleb ainult enterit vajutada
160 |
AJ
21.03.2011 21:41:42
| mikk36 kirjutas: |
RC2 lasti välja, ilma kisa ja kärata, 18.03.2011.
Mozilla releases Firefox 4
TechSpot
Mozilla has released Firefox 4. The final build comes less than two weeks after Release Candidate 1. The company originally found no major problems in the RC1 build, and decided to release RC1 as the final version, but then changed its mind. An RC2 build was quietly pushed out on March 18, 2011 with a few fixes, and today the final bits appeared on Mozilla's servers.
If you're already running a previous build of Firefox 4 you should see an automatic update starting tomorrow. Alternatively, you can download the final build directly for Windows, Mac OS X, and Linux 32-bit/64-bit. The final version supports 83 languages.
Mozilla is letting users update Firefox versions 3.5 and 3.6 to 4.0 without the need to navigate to a download page. Firefox 4.0 was supposed to be released tomorrow, and while the download links are up, we expect that the official launch will be announced in the next 24 hours. For more information on what's changed throughout the development of version 4.0, check out the release notes.
Mozilla was originally planning on having Firefox 4 out by the end of last year, but it has had to delay the release multiple times. The company has fixed more than 7,000 bugs in the 12 betas and a few more in the two RC builds.
Mozilla has been struggling to get Firefox 4.0 out the door. As a result, the company has announced that in 2011, not only will we see Firefox 4.0, but we will also see Firefox 5.0, Firefox 6.0, and Firefox 7.0. The first 5.0 builds are already in the making; the next version is targeted for a late June 2011 release. |
36 |
160 |
peab meeldima.
21.03.2011 22:17:58
Kas FF3 end ise ära ei uuenda 4ja peale?
_________________ Arbeit macht frei. |
| Kommentaarid: 63 loe/lisa |
61 |
21.03.2011 22:24:35
peab meeldima., mingil hetkel kindlasti hakkab ta (FF 4) end sulle pakkuma.
160 |
AJ
21.03.2011 22:33:53
Tundub olevat kiirem kui 3.6.15
36 |
AJ
21.03.2011 22:48:20
| AJ kirjutas: |
Tundub olevat kiirem kui 3.6.15 |
That's an understatement of the year
Asi teeb isegi Chrome-le ära kiiruses siin-seal ja 3.6.15 tundub nagu tigu selle kõrval. |
Sellegi poolest ma kasutan ilmselt Opera-t edasi. Inimene on harjumuste ori.
36 |
bitCON
21.03.2011 22:55:09
no mul firefox käivitub pool tundi kui chromega võrrelda, kindlasti kõige aeglasemini käivituv brauser, aga väga ei häiri mind
viimati muutis bitCON 21.03.2011 22:56:18, muudetud 1 kord |
Vahur
21.03.2011 22:55:34
| Kas asi minu silmanägemises või kasvõi nt. siin foorumis läks font väiksemaks FF4-ga?
388 |
