Kõik Kaspersky 2009/2010 kasutajad võivad 2011 versiooni tasuta installida ja kasutada litsentsi kehtivuse aja jooksul.
Uus Kaspersky 2011:
Granular control of application rules
The product will now use both KSN and WoC (Wisdom of Crowd) ratings, when application information is gathered (including HIPS policies)
The product informs the user of the following:
- Path
- General Information
- Protection Status
- Date the application appeared first (WoC)
- KSN participants who have this application installed (WoC)
- Trust group levels of that application among KSN participants (WoC)
- Geographic information of the application distribution of KSN participants (WoC)
Smart Installer Mode
If the product has detected an error during install:
- The user will be informed of the potential infection and AVPTool download utility will be offered.
- If the product detected previous home version key (for intance KAV found KIS): The product will suggest an alternative code to be installed or convert functionality on the fly (KIS <> KAV)
- Single downloadable executable installer for both x32 and x64 bit versions.
Kaspersky Gadget
- Allows product launch if not started already
- Quick access to the program's main window
- Launch On Demand Task for selected object (file, folder, registry), which dragable onto the gadget itself
- Read Kaspersky Labs news via news agent (linked syndications)
- Access to Safe Desktop
Parental Control -- new features
- Game Control (age rating)
- P2P Control usage
- Email Control usage
- Social Networking Control
- Credit Card payment processor sites
Enhanced Rescue Disk
- The product will verify the image consistency
- Automatic signature update, if not actual
- Support for CD/DVD via built in interface
- Support for bootable USB flash card
- The product now desinfects startup entries, registry, ini files, not only files
Green Zone
- Safe Desktop (alternative mode for all secure user operations)
- Internet Zone (Red = KL reputation dangerous, Gray = No information or not enough data, Green = Safe resource)
- Geo Security (Block resources located in certain geographical areas if the user deems that visiting them is not needed)
- Sandbox v2.0 (will now separate browsers from other programs)
Malware Search
- Idle Scan (is launched when certain criterion are met and the computer is iddle - launch of resource demanding tasks such as updater, rootkit scanner, system area scan, when the user is not present)
System Watcher
- Collects and saves events from different product subsystems and helps perform analysis for suspicious activities.
- Alerts the user by providing the information needed to make an informed decisiom (interactive mode of operations)
Misc Items
- The product will support and differentiate non-latin symbols in URLs
viimati muutis Ezh 20.12.2010 20:55:31, muudetud 9 korda
Eestikeelset pole veel, millal tuleb? _________________ Albert Einstein: "Vaid kaks asja on lõpmatud, universum ja inimlik rumalus, ja selles esimeses pole ma nii kindel."
Ei ole veel proovinud, eks siis vaatab, sobivusel läheb paljudes masinates kohe ka versioonivahetuseks. Sestap maakeelset ootangi, mõned kodus inglismanni keelega hakkama ei saa. _________________ Albert Einstein: "Vaid kaks asja on lõpmatud, universum ja inimlik rumalus, ja selles esimeses pole ma nii kindel."
Antiviiruse osa on endiselt tasemel ja mis veel parem, tulemüüri kasutamine ja seadistamine on nüüd loogiliselt toimiv, peaaegu juba nagu Comodol. Ressurssi sööb küll endiselt vähe, kuid siiski paar korda rohkem kui eelmise versiooniga võrreldes. Kui arendajad suudaksid ressursinõudlikkust taltsutada uutes distrotes, siis oleks igati bro. _________________ Albert Einstein: "Vaid kaks asja on lõpmatud, universum ja inimlik rumalus, ja selles esimeses pole ma nii kindel."
Muidu on kogu kupatus kenasti eestikeelne, aga kui Add/remove programs alt valida Change/Remove, siis viskab uninstalleri vahepeal venekeelseks - seal, kus on aktiveerimise valikud, pärast seda läheb eestikeelsena edasi
Peale litsentsi lõppemist mingi kaitse ikka on või täitsa 0? Krt saan uue võtme alles uuel nädalal ja just sai litsents otsa _________________ LehesFoto - Täis suvaklõpse ja muud
Ma nende päris uute versioonide kohta ei tea, aga varemalt küll kadus vaid uuendamise võimalus ära, st heuristika jääb tööle ja viimatise allalaetud andmebaasi tasemel kaitse tuntud pahalaste vastu samuti.
Litsentsi saab ju väga lihtsalt veebis uuendada, milles probleem? Kuskilt poest antiviiruste karbiversioonide ostmisel, kui just mingit ajutist mega-allahindlust ei tehta, mis hinna tarkvaratootja originaalhinnast allapoole lööb, pole üldjuhul üldse mõtet, pealegi on litsentsi pikendamine kõvasti odavam uue ostmisest. _________________ Tee inimesele lõke ja tal on soe üheks päevaks, pista ta põlema ja tal on soe elu lõpuni. (Terry Pratchett)
Ja ma ostsingi litsentsiuuenduse ox.ee-st. Kahjuks sattus ost reedesele päevale Oleks mujalt võtnud aga sain seal 21€ odavamalt...
Igaljuhul tundub töötavat jah, vaid iga natukese aja tagant peksab teadet et litsents lõppenud. _________________ LehesFoto - Täis suvaklõpse ja muud
mul on selle 2011 selline teema, et kui arvuti on tegevusetult seisnud mingi 10-20 minutit, siis hakkab AVP.exe mingit 40-50% CPU'st ära neelama ja kui uuesti hiirt liigutad, siis olukord normaliseerub. Saan aru, et K teeb midagi samalajal, aga mida ja kuidas seda maha saaks keerata, sest arvuti magamistoas ja suht jama, kui koguaeg undab. _________________ ei ole allkirja
Seadistamine - "Luubi" kujutis - Põhiparameetrid - linnuke ära ridadelt "Kontrolli arvutit jõudeajal" ja "Otsi regulaarselt rootkitte" . Kas peal on 11.0.2.556 kooste? _________________ Tasuta tööriistad juhuks kui viirus kiusab Kaspersky Eestis
