AJ
02.03.2011 09:33:16
Intel 510 Series 250GB SATA 6G Solid State Drive Review
PC Perspective
| Kommentaarid: 37 loe/lisa |
36 |
02.03.2011 10:20:03
ssd-s cause crisis for digital forensics (slashdot)
| So either SSDs are really hard to erase, or really hard to recover. I'm so confused. |
_________________ - londiste
215 |
02.03.2011 10:24:00
Lihtne ju.Väga raske kustutada, aga kui see ükskord õnnestub, siis igaveseks
| Kommentaarid: 92 loe/lisa |
AJ
02.03.2011 10:32:35
The Intel SSD 510 Review
AnandTech
36 |
Optimist
02.03.2011 11:14:48
| Njah 510 random read iopside arv on kukkunud 35k->20. Mis tähendab et random read ja access time mis paljudes reaalse elu testides omajagu plusse annavad jäävad isegi X-25M'ga võrreldes nõrgaks. Seq read/write mida marketingul meeldib pasundada on muidugi suureks aetud. isiklikult seega uut Marvelli kontrollerit eriti ei fänna. Hetke soovituslike hindadega tundub igatahes Vertex 3 way better bang4buck.
| Kommentaarid: 10 loe/lisa |
AJ
02.03.2011 15:58:20
G.Skill Displays Phoenix II SSDs With Read Speed Of 550MB/s
Expreview
CeBIT 2011 is under way,and G.Skill has shown off its latest 2.5-inch Phoenix II SSDs,which are supposed to deliver read speed of up to 550MB/s.
Phoenix II series SSDs pack SF-2000 main controller chip with capacity of 120GB, deliver read/write speed of 550MB/s and 500MB/s,respectively.
In CeBIT 2011,G.Skill used Phoenix II 120GB hard disk,AMD Phenom II X6 processors and AMD SB850 chips motherboard for the test platform,below was the on-spot detection by ATTO hard disk test software. |
36 |
ozy
| Kommentaarid: 6 loe/lisa |
AJ
02.03.2011 20:57:27
Corsair Force F90 90GB Solid-State Drive Review
Techgage
36 |
sama123
04.03.2011 14:47:48
| C300 64GB on 1,5 kuu kasutuse jooksul andud 2x "sinist ekrrani",kahju,et pilti ei teinud.Peale nupust väljalülitust läheb kõik käima,no problems.Sinine ekraan on tulnud siis kui arvuti on 5-10 koormusega,praktiliselt taustaprogrammidega ja seisnud pikemalt 30-90min.ise pole peale sattunud.Eelmise 120GB SSD kettaga tekkis sama olukord vahe selles,et siis enam ei bootinud.Kurat kas tõesti satutud jälle 2,6% õnnetute hulka?
| Kommentaarid: 23 loe/lisa |
22 |
KillerXP
04.03.2011 17:38:50
| sama123, pole küll kindel kas seoses, ei tohiks nagu olla aga proovi maha võtta turn off hard disk after.... power optionsite alt.
| Kommentaarid: 96 loe/lisa |
91 |
sama123
04.03.2011 18:48:21
| KillerXP kirjutas: |
| sama123, pole küll kindel kas seoses, ei tohiks nagu olla aga proovi maha võtta turn off hard disk after.... power optionsite alt. |
Ka esimes hooga mõtlesin sellele!Tegelikult esimene asi peale win installi tuleb toite täpsemad sätted ülekäia (vabandan,eestikeelne windoosa).
Seaded:uneriiziim nii aku kui võrgutoitel keelatud;ketta väljalülimine akutoitel - 30min,võrgutoitel -keelatud.Siin asi ei peitu. Kindlast saan lähema kuu jooksul ekraanipildi teha:nüüd fotikas ligi
22 |
ASSAA! elektroonika
04.03.2011 22:02:58
| Kui sülearvutiga on tegu, siis osadel rüperaalidel on veel HDD kukkumisekaitse olemas (g-force sensor või midagi sarnast), ehk läheb sellega SSD konflikti?
106 |
ozy
05.03.2011 13:41:19
| endal ka sinist ekraani tulnud. veateade low memory samuti, kui rakendusi palju lahti. tuleneb vist liigsest tweakimisest. aga ei häiri. lisakiirus korvab
Atti
05.03.2011 20:48:58
| Low memory teade tuleb, kui swap (page file) on ära keelatud. Tavaliselt SSD lorral seda soovitatakse. Üsnagi loomulik nähtus. 32 bit systeemi korral kui mälu rohkem kui 2GB pole seda teadet näinud. 2GB või vähema mäluga ikka tuleb ette.
| Kommentaarid: 4 loe/lisa |
sama123
05.03.2011 20:57:16
| ozy kirjutas: |
| endal ka sinist ekraani tulnud. veateade low memory samuti, kui rakendusi palju lahti. tuleneb vist liigsest tweakimisest. aga ei häiri. lisakiirus korvab |
Kuna töömasin siis eriti ei "tweagi",selle jaoks katsetamise pill ja alles selle järgi teise läppari.Kui ka seal fukab nädalakese siis töömasinasse (sain jälle tulemüüridega kõrvetada,oli piisavalt pusimist,et kõik 3 jälle jonksu saada),kukkumiskaitse kohalt aga väga huvitav mõte
22 |
06.03.2011 21:34:49
| Atti kirjutas: |
| Low memory teade tuleb, kui swap (page file) on ära keelatud. Tavaliselt SSD lorral seda soovitatakse. |
Halvasti soovitatakse siis .MS ise ei soovita seda.Swap ei tohi kunagi maha keerata .Ükskõik kas SSD v HDD ja vahet pole palju RAM-i on.Ainus mida võib teha on swap suurus vähemaks keerata aga mingi swap peab alati eksisteerima.
trebla
| Kommentaarid: 65 loe/lisa |
57 |
07.03.2011 08:45:42
kahtlane. indexing, pagefile, hibernate, prefetch/superfetch, windows search maha. seda kõike seletamata milleks.
näiteks pagefile mahakeeramine on kindlasti vastunäidustatud, nagu tomorrow juba eelmises postis ütles.
215 |
07.03.2011 08:47:55
Mitmed soovitused seal on pehmeltöeldes problemaatilised ja võivad omada vastupidist effekti väljakuulutatule.
Näiteks MS ise ütleb:
Should the pagefile be placed on SSDs?
Yes. Most pagefile operations are small random reads or larger sequential writes, both of which are types of operations that SSDs handle well.
In looking at telemetry data from thousands of traces and focusing on pagefile reads and writes, we find that
* Pagefile.sys reads outnumber pagefile.sys writes by about 40 to 1,
* Pagefile.sys read sizes are typically quite small, with 67% less than or equal to 4 KB, and 88% less than 16 KB.
* Pagefile.sys writes are relatively large, with 62% greater than or equal to 128 KB and 45% being exactly 1 MB in size.
In fact, given typical pagefile reference patterns and the favorable performance characteristics SSDs have on those patterns, there are few files better than the pagefile to place on an SSD. |
Ja ei maksa isegi rääkida kirjutussalve puhvri puhastamise kinnikeeramisest (Disable Windows Write-Cache Buffer Flusing).Kui toide äkki tagant ära kaob võib pärast kena hulga corrupt faile leida kettalt kui see kinni on keeratud .Ainult siis kui arvutil on veel UPS küljes võib selle kinni keerata
AJ
07.03.2011 09:12:40
Patriot Torqx XRB 64GB
XSReviews
36 |
Miki-Hiir
07.03.2011 09:55:10
| tomorrow kirjutas: |
Ja ei maksa isegi rääkida kirjutussalve puhvri puhastamise kinnikeeramisest (Disable Windows Write-Cache Buffer Flusing).Kui toide äkki tagant ära kaob võib pärast kena hulga corrupt faile leida kettalt kui see kinni on keeratud .Ainult siis kui arvutil on veel UPS küljes võib selle kinni keerata  |
Sellisel juhul võiks teha ramdiski ja pista swap sinna? Mälust lugemine ja sinna kirjutamine peaks olema nagu kõige nobedam?
| Kommentaarid: 46 loe/lisa |
43 |
AJ
07.03.2011 10:30:04
OCZ 4TB Solid State Drive Pictured At CeBIT 2011
Expreview
In the recent CeBIT 2011,OCZ has showcased the newly 4TB solid state drive,which can go up to 8TB in capacity.
The model number is IBLS XL,and it features 5.25-inch form factor and connects to the system via the company’s patented HSDL interface.
In addition,we can connect four IBLS XL SSDs via a single HSDL PCIe 8x card getting a single RAID volume to form a 32TB RAID array.And each XL is capable of 200K IOPS.
However,the price is not revealed,IBLS XL SSDs don’t target consumer market,but enterprise,so the price must be very very expensive. |
36 |
Ho Ho
07.03.2011 11:00:48
| Miki-Hiir kirjutas: |
| Sellisel juhul võiks teha ramdiski ja pista swap sinna? Mälust lugemine ja sinna kirjutamine peaks olema nagu kõige nobedam? |
Korralikumad opsüsteemid kasutavad vaba mälu failide puhverdamiseks. Swapi sinna panek teeks arvuti muu koha pealt aeglasemaks.
Wini kohta ei oska kommenteerida kuid just paar nädalat tagasi avastasin, et 6G ram'iga linuxi purgis olin unustanud peale kettavahetust swapi aktiveerida. Tugev pool aastat olin ilma swapita hakkama saanud ning pealtnäha mingit kiirusevahet ei täheldanud
86 |
AJ
07.03.2011 11:04:16
ntel SSD 510-Series 250 GB Review: Adopting 6 Gb/s SATA
Tom's Hardware
36 |
sukelduja
07.03.2011 11:07:57
No läptopil näiteks seda muret pole.
| Kommentaarid: 25 loe/lisa |
25 |
