uus teema   vasta Raud »  Protsessorid »  AMD Bulldozer/Piledriver arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 10, 11, 12 ... 210, 211, 212  järgmine
Ho Ho
Ho Ho
sõnum 24.01.2011 17:58:25 vasta tsitaadiga
Olen ma ainus kes kahtlustab, et neil on seal pigem tegu 8 bloki ehk 16 int tuumaga? Muidugi tore oleks kui oleks 8 int tuuma kuid see läheks vastuollu nende varasemate ütlustega prose jõudluse kohta
Ühtlasi oleks huvitav teada kas see "estimates and predictions" eeldab, et cinebench-3dmark porditakse AVX'i peale
kalluka
sõnum 24.01.2011 18:21:00 vasta tsitaadiga
hmm huvitav on ka see ,et kui juba engineering ja product samples väljas ja avalikustatakse andmeid siis on tõenäosus ,et saame näha neid ikka enne suve nagu plaanitud?Ma usun ,et juba toodetakse neid.
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 12
sõnum 24.01.2011 21:12:06 vasta tsitaadiga
Winterwind kirjutas:
Close to two weeks ago, reports surfaced about AMD claiming that its upcoming "Zambezi" 8-core desktop processor based on the company's new Bulldozer architecture is expected to perform 50% faster than Intel's Core i7 and its own Phenom II X6 processors. The slide forming the basis for the older report surfaced, and it's a little more than a cumulative performance estimate.
Slide #14 from AMD's Desktop Client Solutions presentation to its industry partners reveals that the company went ahead and provided a breakdown on which kinds of applications exactly does its new 8-core chip perform better compared to present-generation processors. The breakdown provides an interesting insight on the architecture itself. To begin with, AMD's 8-core Bulldozer "Zambezi" processor is 1.5X (50%) faster overall compared to Intel Core i7 "Bloomfield" 950, and AMD Phenom II X6 1100T. Breaking down that graph, the processor performs similar to the other chips in media applications, but features huge gains in gaming and 3D rendering, which is where most of its gains are coming from.
No selle vastu pole küll midagi kui mängudes asi hea oleks icon_biggrin.gif .Niigi ei kasuta mängud tuumi korralikult ära ja kui AMD omalt poolt kaasa aitab, siis 5+
Huvitav oleks kui lõppseis oleks selline aasta lõpus, et Zambezi oleks mängude ja 3D jaoks üldiselt parim(odavam kah kui intel v.a FX mudelid) ja SB domineeriks jälle üldises kasutuses ja oleks kallim.
Ho Ho
Ho Ho
sõnum 24.01.2011 21:21:34 vasta tsitaadiga
tomorrow kirjutas:
Testiti ju 3dmark'i cpu testi, see on elu aeg osanud ära kasutada kõiki tuumi mis masinas eksisteerib. Reaalsete mängude puhul paraku siiski on 2-4 kiiret tuuma veel lähiaastate jooksul parem kui 8+ aeglasemat.
sõnum 24.01.2011 21:40:55 vasta tsitaadiga
Ho Ho kirjutas:
tomorrow kirjutas:
Sõltub mängust...
BC2 puhul on paraku 4 "aeglast" (3,6Ghz) parem kui 2 "kiiremat" (4Ghz+).
Kogu füüsika tehakse seal CPU peal, seega on minu FPS näiteks tunduvalt madalam, kui lahjema GPU`ga i5/i7 omanikel isegi madalamal CPU stock kellal.
Seega kui mängutootjad "multitheradingu" tõsiselt käsile võtavad...siis... on "vanade" arhidektuuridega nii-ehk naa kööga... icon_rolleyes.gif
Samas Atoomiku killer tuleb fusionist kindlasti... Serveriamaailmas lööb ilmselt samuti Buldooser laineid, desktop kasutajad...aga...ostavad Inteli? icon_lol.gif
viimati muutis Etz 24.01.2011 21:43:20, muudetud 1 kord
ricom2ger
ricom2ger
sõnum 24.01.2011 21:42:59 vasta tsitaadiga
Mis Inteli prose on üldse selliste näitajatega?
Kommentaarid: 123 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 111
Braien
Braien
sõnum 24.01.2011 21:44:38 vasta tsitaadiga
Core i7, ja 950 vist isegi.
ricom2ger
ricom2ger
sõnum 24.01.2011 21:48:45 vasta tsitaadiga
braien334 kirjutas:
Socket ei sobi ju
One
sõnum 24.01.2011 21:55:18 vasta tsitaadiga
See on seal slaidil kalane jah. Eks kevadel selgub kuidas asjad tegelikult on.
kalluka
sõnum 24.01.2011 22:04:47 vasta tsitaadiga
Optimist
Optimist
sõnum 25.01.2011 11:08:49 vasta tsitaadiga
Ho Ho kirjutas:
See ikka 4 mooduliga. Mõtle loogiliselt:
-8 väikest tuuma ehk +25% rohkem threade
-ilmselt kõrgem takt
-kiirem mälukontroller ja mälu
-per thread parem IPC osades rakendustes
Asi see siis pole praegu X6 1100T 50%ga ideaalsetes tingimustes ära omada. 32nm OC faktor sisse ja vahe peaks veelgi suuremaks minema. i7 950 jõudlus oleneb testide valikust aga X6 1100T'ga võrreldes peaks ikka natuke kiirem olema. Mingeid üllatusi ma nagu siin ei näe, marketing as usual. Väikeste threadide teste lihtsalt ei arvestata icon_smile.gif
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
kalluka
sõnum 25.01.2011 16:25:18 vasta tsitaadiga
Kui seda saaks kellata nagu Sandit siis oleks ikka ulme püss.Eriti kui hinnad odavad nagu alati icon_smile.gif
pohmakas,
käed värisevad
pohmakas,
sõnum 25.01.2011 17:22:38 vasta tsitaadiga
Sandy ei ole kellamise poole pealt midagi head ju.
Takti võib sellel Bulldozeril ehk kõrgeks ajada, aga eks näha ole kas perf kah vastav on.
Kommentaarid: 166 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 137
WäntWõll
make.believe
WäntWõll
sõnum 25.01.2011 17:54:43 vasta tsitaadiga
sõnum 25.01.2011 19:43:06 vasta tsitaadiga
Lauri Kiissel kirjutas:
Seda küll jah.
WäntWõll kirjutas:
One
sõnum 25.01.2011 20:29:50 vasta tsitaadiga
MSI E350IA-E45 Motherboard Review
http://www.hardwareheaven.com/reviews/1102/pg1/msi-e350ia-e45-amd-fusion-motherboard-review-introduction.html
Jaan
sõnum 25.01.2011 23:20:17 vasta tsitaadiga
Täitsa tore ja toimiv.
Ma peaks varsti saama selle testimiseks:
http://www.gigabyte.com/products/product-page.aspx?pid=3681#ov
edit:
selline kõlakas Buldooseri kohta- uus AMD 8-tuumaline prose (AMD Vision Black FX) on 1,5X kiirem 3d-s(mängudes) Intel i7 950-st.
Prose saabub müüki suve algul.
Kommentaarid: 143 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 123
Braien
Braien
sõnum 25.01.2011 23:22:37 vasta tsitaadiga
Winterwindi postis kui täpsem olla.
Ho Ho
Ho Ho
sõnum 25.01.2011 23:24:42 vasta tsitaadiga
Too jõudlusgraafik jooksis siit natuke aega tagasi läbi. Kurb, et seal pole kirjas masina üldist speci. Eelkõige huvitaks mis taktil too FX tiksub ning mis taktil saavad olema tava prosed.
Jaan kirjutas:
Varem räägiti suve lõpust. Või oli lõpp ainult serveri variantidele?
Jaan
sõnum 25.01.2011 23:43:28 vasta tsitaadiga
Ho Ho kirjutas:
Jaan kirjutas:
...125 watts running at 3GHz + with 8-core processors...
muud ei öelda.
siit:
link teisel lehel, esimesl on juttu 10-tuumalisest sandy bridge-st 30MB cachiga icon_eek.gif
See hea perf mängudes saavutatakse arvatavasti tänu turbo-le.
Ho Ho
Ho Ho
sõnum 25.01.2011 23:46:19 vasta tsitaadiga
Jaan kirjutas:
"Mängudeks" oli nähtavasti 3dmark'i CPU testid, iseasi kui hästi need peegeldavad reaalseid mänge.
Muidu samalt lehelt leidsin uudise inteli tulevaste 10 tuumaliste xeonite kohta. Kui säärased ka tava masinaisse jõuavad siis peaks need üsna edukalt konkurentsi pakkuma 8 bloki/16int tuumaga prosedele, kui just buldozer toore taktiga liiga kaugele ära ei lähe.
Optimist
Optimist
sõnum 26.01.2011 14:51:20 vasta tsitaadiga
Jaan kirjutas:
Ho Ho kirjutas:
Kõigil siin on 2010 kevadest võimalus osta socket G34'le 12 tuumane Opteron ja see hiljem (lubatud 11Q3) 16 tuumase Bulldozeri vastu vahetada. Huvitav ainult et keegi ei tahagi endale soetada vinget nelja mälukanali toega emaplaati või überkallist prose icon_biggrin.gif Socket G2012 saab 20 tuumase Bulldozeri toe. Tavakasutajat huvitab see täna sama palju kui 2005 välja tulnud 8 tuumane UltraSPARC T1, mis 32-threadi korraga suudab jooksutada. Serverimaailmas on muidugi teine teema ja siin näen kuidas näiteks Bulldozeri suur L2 cache muudab nad andmebaasiserverites ilmselt korralikeks loomadeks SB'ga Xeonidega võrreldes. Jutu point on muidu see, et 10/20 tuumased prosed + nende komponendid on praegu liiga kallid, et tavakasutajale lähiaastatel üldse huvi pakuks. Eks niisama ilsatada võib muidugi ikka nagu ka >1MW lennukimootoreid vahtides ja kõrvalt oma auto peale mõeldes icon_lol.gif
Ho Ho
Ho Ho
sõnum 26.01.2011 19:04:19 vasta tsitaadiga
http://www.semiaccurate.com/2011/01/17/amds-bulldozer-orochi-wafer-pictured/
Üks vahvli pilt. b3d's keegi arvutas et kivi suurus peaks jääma kusagile suts üle 300mm^2.
Optimist
Optimist
sõnum 27.01.2011 00:47:25 vasta tsitaadiga
Sai ennustatud et 4 moodulist Orochit võiks X6 Thubanist odavam toota olla ja tundub et see võib nii isegi minna, kui see ~320mm2 jutt paika peab.
45nm 6-tuumane Thuban on 346 mm2
32nm 6-tuumane Gulftown on 239 mm2
Esimesega võrreldes hea, teisega võrreldes priskem L2 cache ilmselt teeb vahet suuremaks. 4 tuumase SB 216mm võistlemiseks peab BD ikka tõsist jõudlust näitama.
sõnum 01.02.2011 14:14:45 vasta tsitaadiga
emaplaatide kohta on mingit infot, et kuna tulevad?
Huvitaks variant mingi muidu juust, aga korraliku emaplaadiga arvuti osta - paneks odavaima AM3 prose peale ja vähemalt tuleviku kindlus oleks hea thumbs_up.gif
uus teema   vasta Raud »  Protsessorid »  AMD Bulldozer/Piledriver arutelu mine lehele eelmine  1, 2, 3 ... 10, 11, 12 ... 210, 211, 212  järgmine
