praegune kellaaeg 20.11.2026 12:16:23
Metsjeesus
06.12.2010 19:10:47
W7 BSODid, dump failid olemas - mõistu pole |
Niisiis on minu käsutuses masin, mis tegutseb aeg-ajalt omasoodu.
Minidumpe on mituteist olemas ent neid lugeda ma ei oska.
TUNDUB, et probleem on driveris, kuigi minu jaoks on musta maagiaga tegu.
Näide1:
MODULE_NAME: win32k
FAULTING_MODULE: 82a53000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 0
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt+25274d
82ca574d 663b4702 cmp ax,word ptr [edi+2]
TRAP_FRAME: a6f8aa38 -- (.trap 0xffffffffa6f8aa38)
ErrCode = 00000000
eax=a6f8000c ebx=00000164 ecx=a6f8ab74 edx=00000020 esi=a6f8ab04 edi=00000000
eip=82ca574d esp=a6f8aaac ebp=a6f8aae0 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246
nt+0x25274d:
82ca574d 663b4702 cmp ax,word ptr [edi+2] ds:0023:00000002=????
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x8E
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 824766ea to 82ca574d
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
a6f8aae0 824766ea a6f8aafc a6f8ab04 00000000 nt+0x25274d
a6f8ab0c 8244a931 fe601574 a6f8ab74 00000020 win32k+0xc66ea
a6f8ab2c 8244aa77 a6f8ab58 00000000 00000000 win32k+0x9a931
a6f8ad18 82a9657a 0027b89c 00000164 00000000 win32k+0x9aa77
a6f8ad34 77076544 badb0d00 0027b870 00000000 nt+0x4357a
a6f8ad38 badb0d00 0027b870 00000000 00000000 0x77076544
a6f8ad3c 0027b870 00000000 00000000 00000000 0xbadb0d00
a6f8ad40 00000000 00000000 00000000 00000000 0x27b870
STACK_COMMAND: kb
FOLLOWUP_IP:
win32k+c66ea
824766ea ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: win32k+c66ea
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: win32k.sys
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
Näide2:
MODULE_NAME: nt
FAULTING_MODULE: 82a3f000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4a2480e6
FAULTING_IP:
nt+288df8
82cc7df8 8b4d08 mov ecx,dword ptr [ebp+8]
TRAP_FRAME: 9b137ae8 -- (.trap 0xffffffff9b137ae8)
ErrCode = 00000000
eax=aa9b284e ebx=aa98f003 ecx=aa98f000 edx=00002108 esi=00000fff edi=85db92f0
eip=82cc7df8 esp=9b137b5c ebp=00000fff iopl=0 nv up ei pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010206
nt+0x288df8:
82cc7df8 8b4d08 mov ecx,dword ptr [ebp+8] ss:0010:00001007=????????
BUGCHECK_STR: 0x8E
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 82cc7fa8 to 82cc7df8
STACK_TEXT:
9b137b60 82cc7fa8 827f5000 5f230000 c0413fa8 nt+0x288df8
9b137b9c 82cc7da2 85db92f0 5f230000 00000001 nt+0x288fa8
9b137bc0 82af33c0 85db92f0 00000000 00000842 nt+0x288da2
9b137c30 82aeb032 869275dc 9b137c58 869b95a0 nt+0xb43c0
9b137c94 82ac73a0 869b95a0 6fa72450 86927549 nt+0xac032
9b137d1c 82a85748 00000000 6fa72450 00000001 nt+0x883a0
9b137d34 6e5705a0 badb0d00 6fa72450 00000000 nt+0x46748
9b137d38 badb0d00 6fa72450 00000000 00000000 0x6e5705a0
9b137d3c 6fa72450 00000000 00000000 00000000 0xbadb0d00
9b137d40 00000000 00000000 00000000 00000000 0x6fa72450
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+288df8
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt+288df8
IMAGE_NAME: ntkrnlpa.exe
Näide3:
MODULE_NAME: nt
FAULTING_MODULE: 82a0c000 nt
FAULTING_IP:
nt+2324e1
82c3e4e1 8b4110 mov eax,dword ptr [ecx+10h]
TRAP_FRAME: 8aaef8f0 -- (.trap 0xffffffff8aaef8f0)
ErrCode = 00000000
eax=000000a0 ebx=84a0da60 ecx=00000000 edx=84a14800 esi=84a14800 edi=b5b19a00
eip=82c3e4e1 esp=8aaef964 ebp=8aaefbc8 iopl=0 nv up ei pl nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010202
nt+0x2324e1:
82c3e4e1 8b4110 mov eax,dword ptr [ecx+10h] ds:0023:00000010=????????
BUGCHECK_STR: 0x8E
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 82c3e362 to 82c3e4e1
STACK_TEXT:
8aaefbc8 82c3e362 00000008 8aaefc10 00000001 nt+0x2324e1
8aaefd18 82a4f57a 00000008 0a95f83c 00000001 nt+0x232362
8aaefd34 77c86544 badb0d00 0a95f7e4 00000000 nt+0x4357a
8aaefd38 badb0d00 0a95f7e4 00000000 00000000 0x77c86544
8aaefd3c 0a95f7e4 00000000 00000000 00000000 0xbadb0d00
8aaefd40 00000000 00000000 00000000 00000000 0xa95f7e4
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+2324e1
SYMBOL_NAME: nt+2324e1
JUHUL, kui on tegu mingi driveri kalaga, siis võimalikest on ehk masinas mingi vana ja poolkõva SB Live! kaart installitud (driver 8.04.2002), kuna mingi kala oli emaplaadi enda audioga. Too on ka BIOS'st disabletud.
Masin ise on vana ahtlon 64 3200+
System Information
Time of this report: 12/6/2010, 19:07:20
Machine name: MINA-PC
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7201) (7201.winmain_win7ids.090601-1516)
Language: Estonian (Regional Setting: Estonian)
System Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
System Model: MS-7100
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3200+, ~2.0GHz
Memory: 1024MB RAM
Available OS Memory: 1024MB RAM
Page File: 1306MB used, 741MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7201.0000 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6600 GT
Manufacturer: NVIDIA
Chip type: GeForce 6600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0140&SUBSYS_2A20107D&REV_A2
Display Memory: 376 MB
Dedicated Memory: 120 MB
Shared Memory: 255 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SyncMaster
Monitor Id: SAM027E
Native Mode: 1680 x 1050(p) (59.883Hz)
Output Type: HD15
Driver Name: nvd3dum.dll
Driver File Version: 8.15.0011.8618 (English)
Driver Version: 8.15.11.8618
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 6/10/2009 05:03:00, 7611904 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4200-11CF-6752-2B0A02C2C535}
Vendor ID: 0x10DE
Device ID: 0x0140
SubSys ID: 0x2A20107D
Revision ID: 0x00A2
Driver Strong Name: oem3.inf:NVIDIA_SetB_Devices.NTx86.6.0:Section001:8.15.11.8618:pci\ven_10de&dev_0140
Rank Of Driver: 00F62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Creative SB Live! Series (WDM))
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0006&SUBSYS_10031102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: P16X.sys
Driver Version: 5.12.0001.0203 (English)
WHQL Logo'd: Yes
Date and Size: 9/22/2003 11:43:06, 1330048 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Microphone (Creative SB Live! Series (WDM))
Default Sound Capture: Yes
Default Voice Capture: No
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line-In (Creative SB Live! Series (WDM))
Default Sound Capture: No
Cap Flags: 0x1
Description: TAD-In (Creative SB Live! Series (WDM))
Default Voice Capture: Yes
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC50C
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x005A
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 6/2/2009 04:07:08, 258560 bytes
| Driver: usbd.sys, 6/2/2009 04:06:08, 5888 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 6/2/2009 04:00:15, 28160 bytes
| Driver: kbdclass.sys, 6/2/2009 07:37:08, 42560 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 6/2/2009 03:27:18, 80896 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 6/2/2009 04:00:14, 26112 bytes
| Driver: mouclass.sys, 6/2/2009 07:37:08, 41552 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 6/2/2009 07:36:47, 51776 bytes
| Driver: sermouse.sys, 6/2/2009 04:00:15, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 67.0 GB
Total Space: 152.5 GB
File System: NTFS
Model: ST3160813AS ATA Device
Drive: D:
Model: _NEC DVD_RW ND-3500AG ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7201.0000 (Estonian), 6/2/2009 03:27:18, 108544 bytes
System Devices
Name: Creative SB Live! Series (WDM)
Device ID: PCI\VEN_1102&DEV_0006&SUBSYS_10031102&REV_00\4&22A608F1&0&3848
Driver: C:\Windows\system32\drivers\P16X.sys, 5.12.0001.0203 (English), 9/22/2003 11:43:06, 1330048 bytes
Driver: C:\Windows\system32\P16Xres.dll, 5.12.0001.0104 (English), 6/30/2003 11:35:18, 34304 bytes
Driver: C:\Windows\system32\P16X.dll, 1.00.0000.0015 (English), 7/8/2003 13:41:48, 47616 bytes
Driver: C:\Windows\system32\A3d.dll, 80.00.0000.0003 (English), 7/3/2009 20:02:20, 65536 bytes
Driver: C:\Windows\Live.ico, 8/15/2001 09:24:00, 4398 bytes
Driver: C:\Windows\Live.bmp, 8/17/2001 08:36:00, 3126 bytes
Driver: C:\Windows\system32\drivers\ctoss2k.sys, 5.12.0001.0172 (English), 9/22/2003 07:47:38, 178672 bytes
Driver: C:\Windows\system32\drivers\ctsfm2k.sys, 5.12.0001.0172 (English), 9/22/2003 07:48:06, 130192 bytes
Driver: C:\Windows\system32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 13:35:46, 36864 bytes
Driver: C:\Windows\system32\sfms32.dll, 5.12.0001.0172 (English), 9/22/2003 07:51:52, 172032 bytes
Driver: C:\Windows\system32\ct2mgm.sf2, 7/3/2009 20:02:20, 2167684 bytes
Driver: C:\Windows\system32\drivers\drmk.sys, 6.01.7201.0000 (English), 6/2/2009 04:53:23, 80896 bytes
Driver: C:\Windows\system32\drivers\portcls.sys, 6.01.7201.0000 (English), 6/2/2009 04:06:08, 177152 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005B&SUBSYS_71001462&REV_A3\3&2411E6FE&1&11
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7201.0000 (English), 6/2/2009 04:06:19, 41472 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7201.0000 (English), 6/2/2009 04:06:19, 284160 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7201.0000 (English), 6/2/2009 04:07:08, 258560 bytes
Name: Mass Storage Controller
Device ID: PCI\VEN_1095&DEV_3132&SUBSYS_710A1462&REV_01\4&572563F&0&0060
Driver: n/a
Name: NVIDIA GeForce 6600 GT
Device ID: PCI\VEN_10DE&DEV_0140&SUBSYS_2A20107D&REV_A2\4&1501045F&0&0070
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_x86_neutral_03d0c587d1ed19ca\NvCplSetupEng.exe, 14.00.0000.0162 (English), 6/10/2009 05:03:00, 16829581 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 4224 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 9899296 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 6/10/2009 05:03:00, 795104 bytes
Driver: C:\Windows\system32\nvapi.dll, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 989696 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 1704960 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 1317408 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 678432 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 7611904 bytes
Driver: C:\Windows\system32\nvdisp.nvu, 6/10/2009 05:03:00, 10060 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 8.15.0011.8618 (English), 6/10/2009 05:03:00, 10379264 bytes
Driver: C:\Windows\system32\nvudisp.exe, 1.03.0028.0006 (English), 6/10/2009 05:03:00, 457248 bytes
Driver: C:\Windows\system32\nvcod.dll, 1.05.0005.0050 (English), 6/10/2009 05:03:00, 151552 bytes
Driver: C:\Windows\system32\nvcod155.dll, 1.05.0005.0050 (English), 6/10/2009 05:03:00, 151552 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_005A&SUBSYS_71001462&REV_A2\3&2411E6FE&1&10
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7201.0000 (English), 6/2/2009 04:06:18, 20480 bytes
Name: AMD Miscellaneous Configuration
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&1&C3
Driver: n/a
Name: NVIDIA nForce4 HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_005E&SUBSYS_71001462&REV_A3\3&2411E6FE&1&00
Driver: n/a
Name: NVIDIA nForce Networking Controller
Device ID: PCI\VEN_10DE&DEV_0057&SUBSYS_71001462&REV_A3\3&2411E6FE&1&50
Driver: C:\Windows\system32\DRIVERS\nvm62x32.sys, 1.00.0001.0210 (English), 6/2/2009 02:18:40, 347264 bytes
Name: AMD DRAM and HyperTransport(tm) Trace Mode Configuration
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&1&C2
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&1&70
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7201.0000 (English), 6/2/2009 07:36:58, 153664 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_0055&SUBSYS_71001462&REV_F3\3&2411E6FE&1&40
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7201.0000 (English), 6/2/2009 07:36:55, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7201.0000 (Estonian), 6/2/2009 07:37:10, 42576 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7201.0000 (English), 6/2/2009 07:37:13, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7201.0000 (Estonian), 6/2/2009 07:37:05, 133184 bytes
Name: AMD Address Map Configuration
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&1&C1
Driver: n/a
Name: Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4362&SUBSYS_058C1462&REV_15\4&247B58F0&0&0058
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&1&68
Device ID: PCI\VEN_10DE&DEV_0054&SUBSYS_71001462&REV_F3\3&2411E6FE&1&38
Name: AMD HyperTransport(tm) Configuration
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&1&C0
Driver: n/a
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_086C0574&REV_46\4&22A608F1&0&6048
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7201.0000 (English), 6/2/2009 04:06:56, 163328 bytes
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&1&60
Device ID: PCI\VEN_10DE&DEV_0053&SUBSYS_71001462&REV_F2\3&2411E6FE&1&30
Name: Game Port for SB Live! Series
Device ID: PCI\VEN_1102&DEV_7004&SUBSYS_10031102&REV_00\4&22A608F1&0&3948
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&1&58
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0052&SUBSYS_71001462&REV_A2\3&2411E6FE&1&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_005C&SUBSYS_00000000&REV_A2\3&2411E6FE&1&48
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0050&SUBSYS_71001462&REV_A3\3&2411E6FE&1&08
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7201.0000 (English), 6/2/2009 07:36:56, 13888 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7201.0000
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7201.0000
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7201.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7201.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7201.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7201.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7201.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7201.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7201.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7201.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7201.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7201.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7201.0000
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7201.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7201.0000
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7201.0000
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7201.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7201.0000
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7201.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7201.0000
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7201.0000
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7201.0000
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7201.0000
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7201.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7201.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7201.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7201.0000
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7201.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7201.0000
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7201.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7201.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7201.0000
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7201.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7201.0000
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7201.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7201.0000
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7201.0000
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7201.0000
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7201.0000
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7201.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7201.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7201.0000
File writer,0x00200000,1,0,qcap.dll,6.06.7201.0000
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7201.0000
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7201.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7201.0000
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7201.0000
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7201.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7201.0000
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7201.0000
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7201.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7201.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7201.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7201.0000
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7201.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7201.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7201.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7201.0000
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7201.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7201.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7201.0000
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7201.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7201.0000
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7201.0000
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7201.0000
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7201.0000
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7201.0000
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7201.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7201.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7201.0000
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7201.0000
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7201.0000
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7201.0000
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7201.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7201.0000
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7201.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7201.0000
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7201.0000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7201.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7201.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7201.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7201.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7201.0000
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7201.0000
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7201.0000
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7201.0000
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7201.0000
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7201.0000
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7201.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7201.0000
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7201.0000
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7201.0000
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7201.0000
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7201.0000
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7201.0000
Audio Capture Sources:
Microphone (Creative SB Live! S,0x00200000,0,0,qcap.dll,6.06.7201.0000
Line-In (Creative SB Live! Seri,0x00200000,0,0,qcap.dll,6.06.7201.0000
TAD-In (Creative SB Live! Serie,0x00200000,0,0,qcap.dll,6.06.7201.0000
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7201.0000
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7201.0000
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7201.0000
Midi Renderers:
Creative SB Live! External MIDI,0x00200000,1,0,quartz.dll,6.06.7201.0000
Creative SoundFont Synth,0x00200000,1,0,quartz.dll,6.06.7201.0000
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7201.0000
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7201.0000
WDM Streaming Capture Devices:
,0x00000000,0,0,,
Creative SB Live! External MIDI,0x00200000,2,2,ksproxy.ax,6.01.7201.0000
Creative SB Live! Series,0x00200000,3,2,ksproxy.ax,6.01.7201.0000
WDM Streaming Rendering Devices:
Creative SoundFont Synth,0x00200000,1,1,ksproxy.ax,6.01.7201.0000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7201.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7201.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7201.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7201.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7201.0000
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7201.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7201.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7201.0000
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7201.0000
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7201.0000
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7201.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Creative SB Live! Ser,0x00200000,1,0,quartz.dll,6.06.7201.0000
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7201.0000
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7201.0000
DirectSound: Speakers (Creative SB Live! Series (WDM)),0x00200000,1,0,quartz.dll,6.06.7201.0000
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
Cyberlord
06.12.2010 19:19:23
| Tundub, et erinevad asjad crashivad, kõige lihtsamini tuvastatav ja üldlevinuim viga oleks mäludes. Kas memtesti oled teinud ikka?
| Kommentaarid: 546 loe/lisa |
449 |
A.S.
| Kommentaarid: 34 loe/lisa |
34 |
06.12.2010 20:47:42
Ja kui korras selle vanakese masina toiteplokk on . Kui toide on vanadusest nõrgukeseks muutunud, ka siis lendab arvuti kräshi, nii et vähe pole...
211 |
Metsjeesus
06.12.2010 20:59:44
Memtest jookseb hetkel, Pass1 Test#5 on 33 errorit.
Leidsin väheke juttu, et ei pruugi automaatselt tähendada viga ramis, vaid mõnel juhul vales timingus/voldis. Hetkel 2,5-3-3-7, proovin hiljem panna 3 ja kaeda siis tulemust.
Toide on vast 3, äkki 4 aastat vana Chieftec GPS-350EB-101 A.
94 |
Cyberlord
06.12.2010 21:07:06
| BIOS`ist kõigele default panemine peaks üldiselt pädema.
449 |
06.12.2010 21:07:26
Metsjeesus, Lükka Dump fail kuskile ülesse...
196 |
A.S.
06.12.2010 21:22:50
Mälu seaded ja pinged võivad tõesti paigast ära olla ja probleeme põhjustada. Probleem võib olla ka vigases emaplaadis.
Mälud välja, BIOS-le resett, arvuti käima (piiksub veidi), arvuti välja, mälu sisse ja jälle käima. Ehk aitab.
34 |
Metsjeesus
06.12.2010 21:30:17
Enne memtesti tegin cmosi, seega see võibolla välistab A.S. pakutud variandi?
Panen dumpid ka üles varsti.
94 |
A.S.
06.12.2010 21:36:09
| Metsjeesus kirjutas: |
| Enne memtesti tegin cmosi |
Mõnikord aitab kui lisaks sellele korra üldse ilma mäludeta arvuti käima panna, aga see aitab siiski üsna harva.
34 |
Cyberlord
07.12.2010 11:02:10
| Kaugele jõudsid oma asjadega?
449 |
Metsjeesus
07.12.2010 14:27:29
Panin timingud 3-3-3-8 (2.5 asemel, muutis -7 ka 8'ks ise) ja 5't testi jooksma. Lasin 11 passi vigadeta ja nüüd alustasin fulli.
Ilma mäluta booti ei katsetanud.
E: Tundub, et sellega on korras selleks korras ja mälu timingute muutus aitas. Full testi tegid nad läbi igal juhul ja windowsi siseseld bsodi ei saanud tunni-kahe jooksul.
Kas mõni hea inimene oleks nõus kaema ka teise masina, mis on profiilis, dumpid üle?
ENAMUS on ndis.sys. Kuna ta miskit diskiga seotud, siis mõtlesin, et ehk on IOBit Smartdefrag programmiga seotud või mõne driveriga, programmiga?
Ära olen muutnud pagefile suuruse, ram x1,5 peale ehk min-max on mõlemad 6139MB.
Pakkisin viimased dumpid kokku.
http://www.upload.ee/files/969759/112910-13884-01.zip.html
Aitäh!
94 |
07.12.2010 17:02:37
E: Tundub, et sellega on korras selleks korras ja mälu timingute muutus aitas. Full testi tegid nad läbi igal juhul ja windowsi siseseld bsodi ei saanud tunni-kahe jooksul. |
Kas need timingud vastavad ka mälu enda SPD-le? Kui ei vasta, siis võiks öelda, et mälud ikkagi on vigased, st ei vasta tootja poolt paika pandud parameetritele.
Ketta ja failisüsteemiga seotud vigade puhul tuleks esmalt failisüsteemile chkdsk teha. Täieliku kontrolli tegemiseks on võti /r
Sama võiksid teha ka selle esimese masinaga, sest pärast neid BSOD-e poleks mingi ime kui failisüsteem vähem või rohkem viga sai selle tõttu.
A.S.
07.12.2010 17:57:47
| Mälud ei pruugi vigased olla, lihtsalt ei saa ehk piisavalt pinget peale.
34 |
07.12.2010 18:25:29
| A.S. kirjutas: |
| Mälud ei pruugi vigased olla, lihtsalt ei saa ehk piisavalt pinget peale. |
Täiesti võimalik.
Metsjeesus
07.12.2010 20:45:01
Dogbert, kus/kuna ma seda /r sisse toksin?
Panin hetkel schedulema selle checkdiski buutimisel.
94 |
07.12.2010 20:48:40
Panin hetkel schedulema selle checkdiski buutimisel. |
Starе->Run->cmd
ja sinna siis kribad chkdsk /r
196 |
07.12.2010 23:55:49
Võid ketta tähise ka ära täpsustada. Ilma selleta läheb kontrolli ketas, millel asub sinu Windowsi kasutajaprofiil. Tavaliselt on see küll samuti süsteemiketas, aga mitte alati
chkdsk c: /r /v
/v = verbose
Nõustu kontrolliga pärast rebooti ja tee reboot.
