The wait is almost over! Futuremark has just announced that 3DMark 11 will officially launch on November 30th. For those of you who want all the bells and whistles, you can pre-order the Advanced Edition today for just $19.95. In addition to this awesome news, FM has also released a new teaser trailer which offers details on the Advanced Edition and shows off some of the graphical improvements they've made to the Deep Sea and High Temple scenes. Definitely worth watching!
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik
nii väikesed skoorid küll vist head ei tähenda..
tuleb veel hullem lagfest kui vantage omal ajal?
grafa keskpärane aga jookseb killer raual paar kaadrit sekundis
Küll ta 4x GTX 580 ja SR-2-ga jookseb. _________________ Ära siia kliki
mid range kaartide kohta tõesti vähe, eks ülemine ots teeb kuskile 10k ümber nagu iga markiga on alguses olnud.
30 pidi välja tulema, seega pole kaugel
7900GT ju jooksis omal ajal täpselt samuti 06s 2000p ringi. Pole siin midagi imelikku. Vantage oligi liiga suureskooriline. Vahel võis 2 järjestikust samade settingutega runni, üksteisest 300+punni erineda. _________________ Liitu Z.ai coding plaaniga ja saa 10% soodust! Liitu Wise'ga!
Exclusive Interview With Futuremark,3DMark 11 Activation Key Giveaway Contest! Expreview
Futuremark will release 3DMark 11 officially on November 30th.And the pre-order service is under-way.Many our readers may still remember the activity "3DMark Vantage Advance version giveaway contest" held by us the year before last year.
This time we continue to cooperate with Futuremark to have exclusive interview with its vice president Olive Baltuch.It is really a great honor to have this chance,and we want to share this chance with our readers,you.
In this activity,you can feel free to leave your question here,the question can focus on the topic like 3DMark product line of FutureMark, its gaming design team or even the future product plan,etc.
If your question is good enough to impress Mr.Baltuch or us,you will get one 3DMark 11 activation key free of charge.
However,it is noteworthy we have only got ten copies of 3DMark 11 activation keys,and all the question should be in English as this is a worldwide contest.Thank you for your cooperation!The contest starts from today and will end in December 3rd.
Don’t forget to leave your E-mail in the comment system or else we can not sent the activation key to you.Good luck!
_________________ Küsige mida tahate, me vastame mida tahame.
See 3D Marki Online teraapja minu kõhule hästi ei sobi. Test-Scoor-Print Screen=volaa Tahaks proovida juba uut 3d marki ehk on parem kui Unigine Benchid kuna nood olid graafikalt sellised ruumilised kuid kvaliteet oma pilli põhja toppimisega ei andnud eriti midagi Tahaks ikka et textuurid muutuks ikka paremaks. Crysis on ka näiteks üks vähestest mis on parema textuuri kvaliteediga. Oleks see uus bench selline et saab panna nii põhja et pilt oleks küllalt sellise iluga et arvutis mängimine oleks nagu reality show. Kuid huvi oleks teada millist imelooma peab protsessoriks kasutama et seda benchi jooksutada? Ehk AMD punnitab see kord ehk hea proze, nimi BULLDOZER näib küll isu äratav, aga tuletab meelde seda 06 marki kus oli bench artic Freezer Ehk nad ikka ei astu ämbrisse oma innovatsiooniga. _________________ Celeron inside and idiots outside. Mängur: Kumb on parem kas AMD või NVIDIA? Lagger: Ühed Piixud mõlemad.
tomorrow, tava juuserid saavadki netis oma skoori, või sul pole veebi!
hc mehed vajavad kõige väiksemaid muutujaid ning saavad offline, et pange ei paneks, 230.- on muidugi palju
mitte markides, pole mõtet üle pingutada unes, intel on kiirem igast asendist, va spets ülessanded vastavalt tuumadele.
alati jääb versioon et ei lase lihtsalt Marki, samas 19.99$ pole teab mis ikaldus isegi meie palkade juures
Hah. Ma ei vihjanud isegi mitte intelile. Kus unes sa seda intelit minu postis nägid. Mulle ei meeldi kui minu magusaid tudulandi seiklusi kritiseerib keegi. Minu ootus on uuele prosele selline et kui see suudab ilma pudeli korgi effectita kasutada potentsiaalselt 4 protsessorit ja kui näiteks Super Micro suudab hakkama saada järje korde hea emaplaadi mis toetaks tavalisest veidrates PCX-ide asemel näiteks SLI või midagi millel oleks ikka 3D töötlus jõudu mehe moodi ehk kas või PCI-Ex 2.0 16x kanti(või ehk juba siis uuema generatsiooni siiniga). Aga pealegi ma ei unista sellest protsessorist ega näe seda unes nagu sulle see tundub vaid pigem ma planeeriks selle protsessori jõudluse kasvu puudutavate teemade ja informatsiooni läbimist enne selle müügi letilt ostmist. Toodet saab kiruda või kiita kui see väljas on. Ja see et sa räägid igas testis nu oleks asjalik olnud juurde kirjutada Benchides muidu mõni ehk hakkab tõesti tõe pähe igas testis teda paremaks pidama. Ja mulle tundub et sinu arvates sobiks AMD läbi kukkumine enne prose välja laskmist? Vaata asi on selline et kui AMD uue generatsiooni prose läbi kukub siis ega sinu armastatud intel kah palju paremaks ei muutu kuna pole konkurentsi või pole midagi millest uut asja leiutada kuna ega jahu ei saa kunagi head kui on kaks kõva kivi üks peab vahest teisest parem olema et saaks korralikku kraami.
Ja ma hinna kohta ei maininud et see ei tea mis hirmus kallis on. Pigem oli minu point selles et kui ma näiteks väljas tahaks homme OC teha ja seda DX11 Benchiga siis peab mul arvutil perses neti uss olema või siis WIFI et saaksin hakata oma tulemust uudistama. Ja kui server on umbes või mis iganes neti probleem on võin seal näiteks enda uuest OC saavutusest ennast vihaseks vinguda või Tahad Benchida ilma võrgu kaardtita kuna näiteks on huvi teada Chipsi ja võrguka performancit et kui palju annab perfi see kui sul pole võrgu sätteid üleval et hoida näiteks WIN registri mahtu võimalikult väiksena. Aga jama selle online postiga ka et ega ükski 3D Marki tõsisem tegija ei taha ju kasutada Viiruse tõrjet ja kui nagu tavaliselt WIN on selline pisikute maius palake siis ju kepp kui mingi kerge viirus sul jõudluse maha võtab See läbi neti värk võib väga raske lõpuga olla näiteks naaber vaatas öösel isuga porri ja siis nüüd on talviirused ja jagab koos sinuga oma mandasid läbi arvuti. Pole just tore omada paha vara. Ja see läbi neti jooksutamine sisaldab ekstra igasuguseid putukaid BUGE et teed benchi ära ja net jookseb kokku või vähemalt loodan et ADOBE FLASHi pole selle Tark varaga kasutatud kuna kui FLASH andme rakendusi kanda siis on kokku jooksmised kerged tulema.
20.$ pole sinu arvates mingi raha meie palkade juures Ega me ei tea mis hinnaga meil siin seda müüakse või pead otse tellima selle originaal allikast. Pole veel teada meie EEK ja EURO muutustest kuna poeski nii mõnigi asi selle EURO Buumiga on kerkinud 10-60% see propaganda et hinda ei tõsta reaalsuses eriliselt ei mõju. Aga jah kõik on näha siis kui asi kätte jõuab ja vähemalt pole palju oodata. Aga jah AMD BULLDOZERIT uudistan ma edasi eks näeb kui selgelt sa asju nägid. Andke andeks kui midagi solvavat millegi või kellelegi vihjasin kuna mulle ei meeldi et minu kapsapeadele keegi kas või puuksu laseb. _________________ Celeron inside and idiots outside. Mängur: Kumb on parem kas AMD või NVIDIA? Lagger: Ühed Piixud mõlemad.
Avalance, üsna pikk jutt läbilugemiseks aga need kaks lauset olid lihtsalt selgituseks mis sind ees ootab
kui 20$ on palju (raha on raha muidugi) siis jääb alati osta riistvara kus bench on täis versionis bundles kaasas, hetkel võid osta GTX580 graafikakaardi ja saad fulli kaasa kus näitab ka offline skoori 100%
Nu oleksin saanud lühema jutuga ka hakkama aga selgitasin veits pikemalt välja kuna ei meeldi kui mu kapsastele liiga tehakse.
Ei nu ega 20 ikka kokku ajab kui asi ilus ja asjalik on. Hoiab õlle pealt nati aega kulusid kokku ja olemas 580 oleks enda arust küll ilus ost kuid oleks tore teada kas seda ka kaheGPUlisena tehtaks (valmis saadakse)(tore oleks GPU dual core või midagi sellist millega BIT laius suurendataks) et veits kõhn see tri SLI. Tean jah et päris kulukas kuid eks kui midagi vaja on küll siis ka raha leitakse. Ma muidugi ei tea kas ma endale 580 ostan kuna plaanis ikka Väike ja mõnus mootorratas osta kuid ega kodusest meelelahutusest kolmemonitori peale max out ja 3D vision ning rool ja muu et näiteks GRIDI, DIRT 2 või midagi sellist pelada. Aga jah 3D HD virtual GIRl saab siis jooksutada ka Saab 3D porri kah ehk vaadata Hea snäkk tuleviku õlle kõrvale Tore oleks Directx 11 marki 3D-s jooksutada kui muidugi seda lähi aastatel võimalik kuna vantage ja 06 olid koomas _________________ Celeron inside and idiots outside. Mängur: Kumb on parem kas AMD või NVIDIA? Lagger: Ühed Piixud mõlemad.
Siin varem üks poiss suure suuga rääkis, et 3DMarke jagatakse siin foorumis tasuta soovijatele, mitte ei müüda, et siis paluks kah kõigile soovijatele tasuta võtmeid kaasaarvatud mina. _________________ Minu Youtube - HDTanel
PlatoonSgtElias, kes jagab? Tahan ka
2003, 2005, 2006 ja Vantage ostetud. 11 võiks vahelduseks tasuta saada küll
Mul on aint 2001, 06 ja vantage. Kuid tasuta kraamist ära ei ütleks. Kui keegi jagama hakkab ma olen isegi nõus väikse õlle välja tegema. Kui keegi annaks näiteks GTX 580 millega saab DX 11 Marki kaasa siis ma isegi sebiks naisi õlle kõrvale. _________________ Celeron inside and idiots outside. Mängur: Kumb on parem kas AMD või NVIDIA? Lagger: Ühed Piixud mõlemad.
no nende treilerite poolest küll asi midagi erilist ei olnud, veelvähem peaks asi killer raual 4fps jooksma.
sepad teevad meelega mingi õnnetusehunniku mis üldse ei jookse.
