uus teema   vasta Tarkvara »  Tarkvara »  Mozilla Firefox arutlus/probleemid. märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 178, 179, 180 ... 422, 423, 424  järgmine
sõnum 21.10.2010 20:43:16 vasta tsitaadiga
Mul ei mõtle isegi kaua.
Tiiger15
Tiiger15
sõnum 21.10.2010 22:42:04 vasta tsitaadiga
Olen tarkvara otsimises üsna taibukas ma arvan, aga b8pred ma ei osanud kuskilt alla sikutada icon_neutral.gif Et koduleht pakub b6-te
My choices, my life - don't judge me, just try better!
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 15
sõnum 21.10.2010 23:13:11 vasta tsitaadiga
Tiiger15 kirjutas:
http://ftp.mozilla.org/pub/mozilla.org/firefox/nightly/latest-trunk/
Sealt siis firefox-4.0b8pre.en-US.win32.installer.exe või firefox-4.0b8pre.en-US.win32.zip kui tahad jooksutada parraleelselt vanema versiooniga:
1 - Download a Zip-Archive build of the version you want to install - available in http://ftp.mozilla.org/pub/mozilla.org/firefox/nightly/latest-trunk/
2 - Create a folder for that version of Firefox, like C:\Program Files\Mozilla Firefox Next
3 - Extract the Zip file into the folder that you created.
4 - Go to the folder and rightclick on the firefox.exe file and Send to > Desktop (create shortcut)
5 - Create an empty folder where you want the new Profile for this version to be located, like maybe C:\Program Files\Mozilla Firefox Next\MyProfile\ to keep it near the Firefox program files.The name of that Profile would be "MyProfile"(without quotes).
6 - Rightclick on the new desktop shortcut and modify the Target line like this:
~firefox.exe" -profile "C:\Program Files\Mozilla Firefox Next\MyProfile" (there has to be a space between .exe" and -profile and if your profile path contains spaces then the path must be enclosed in quotemarks.).When done then click apply.
7 - If yoy want to run this version simoltaniously with your regular profile then add "-no-remote" to the end of Target line(without quotes).
8 - Doubleclick that Desktop shortcut to launch the new version you just installed and a new Profile will be created upon Startup.
Pärast paigaldamist uuendab iga päev juba ise uusima buildi peale thumbs_up.gif
EDIT:
Tegelikult siit saab kah.See lingib lihtsalt samadele failidele mis eelneval lingil: http://nightly.mozilla.org/
AJ
AJ
sõnum 23.10.2010 22:31:52 vasta tsitaadiga
Mozilla pays 12-year-old $3,000 for finding critical Firefox flaw
TechSpot
sõnum 23.10.2010 23:01:08 vasta tsitaadiga
AJ kirjutas:
TechSpot
AJ
AJ
sõnum 26.10.2010 16:29:50 vasta tsitaadiga
Firefox extension makes Facebook 'sidejacking' easy
TechSpot
mhei
mhei
sõnum 28.10.2010 00:21:22 vasta tsitaadiga
on siis viimasel ajal FFiga jama tekkinud :
vahet pole mis adrele minna ürita, ikka sama jama....
pean paar kaks kolm korda refreshi tegema enne kui saan lehele icon_evil.gif
sõnum 28.10.2010 12:07:56 vasta tsitaadiga
mhei, uue puhta profiiliga proovisid? Äkki cache vms pihta saanud.
Kommentaarid: 168 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 157
AJ
AJ
sõnum 28.10.2010 17:17:53 vasta tsitaadiga
Firefox 3.6.12 väljas.
http://www.mozilla.com/en-US/firefox/3.6.12/releasenotes/
Firefox 3.6.12 fixes a critical security issue that could potentially allow remote code execution.
mhei
mhei
sõnum 28.10.2010 20:14:20 vasta tsitaadiga
bladerunner kirjutas:
ei ole veel proovinud, ex kohe saab proovida
bingo
bingo
sõnum 30.10.2010 12:06:50 vasta tsitaadiga
Millegipärast peale uuendamist ei tööta enam Gmail Notifer, "failed to log in", otse lehele minnes olen kohe sees. Panin vanema Firefoxi ja sellega ka ei töötanud. Ei aidanud ka Notiferi reinstall.
sõnum 30.10.2010 14:04:18 vasta tsitaadiga
bingo, http://www.nexgenmedia.net/extensions/ lehelt 0.6.4.3 tirimine ei aita?
Tundub, et Gmail on mingeid sisemisi muudatusi teinud.
Omal muidu sama seis... Kirjutasin ka arendajale, vaatab mis vastatakse.
iguaan
iguaan
sõnum 30.10.2010 16:03:01 vasta tsitaadiga
Gmail notifier 0.6.4.2 ja FF 3.6.12 toimivad kenasti
E:
Current version: 0.6.4.3 (User Guide)
* Login was broken for certain users due to Gmail changes
Contact me at gmn.feedback [at] gmail [dot] com
Kommentaarid: 81 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 69
sõnum 31.10.2010 07:52:31 vasta tsitaadiga
Mozilla delays Firefox 4 until 'early 2011'
http://www.theregister.co.uk/2010/10/27/firefox_4_slips/
Graafik uuendatud: https://wiki.mozilla.org/Firefox/4/Beta#Milestones
Ühtib sellega mis ma poolteist nädalat tagasi juba ütlesin:
tomorrow kirjutas:
peab meeldima. kirjutas:
Millal see FF 4 välja tuleb? Siis peaks vist Win 7 peale ka üle minema, kui ta tuleb ükskord eusa_think.gif
Nagu tavaliselt on Mozilla üli-üli optimistlik oma prognoosides.Algul arvati, et juba novembris aga mina küll kuskilt otsast seda ei näe.
Graafikut pole kah juba sada aastat uuendatud siin: https://wiki.mozilla.org/Firefox/4/Beta#Milestones
Näiteks algselt taheti RC1 saada välja Oktoobri lõpus aga teadagi...graafikust maas: https://wiki.mozilla.org/Releases .Lisaks mulle ehk tundub aga alates Beta 5-st on Peacekeeperis kiirus järjest langenud ja ega Sunspidergi enam mingeid edasiminekuid ei näita.Vähemalt viimases peaks sama kiire olema kui Chrome nüüd: http://arewefastyet.com/
Sunspideris on õnneks nüüd edasiminekuid näha.Siiski on veel mitmeid blockereid mis mitmete benchide skoore tagasi hoiavad nagu nt V8 bench ja Peacekeeper icon_confused.gif
mhei
mhei
sõnum 31.10.2010 12:03:28 vasta tsitaadiga
sai siis ära uuendatud ja siin esimene avamine ( suur pilt ! ):
hetkel olen seda u. 10 minta kasutanud ja teksti trükkides ei jõua sõnad nii kiiresti järgi kui mina kriban, aga see võib mulle ainult tunduda kuna 38 h üleval istunud beer_yum.gif
ja minu arust avab ta lehti ka veidike kauem... aga mis siin vinguda, see ju BETA ver.
virus152
virus152
sõnum 11.11.2010 01:30:18 vasta tsitaadiga
Uuendasin just Beta 7-le ja kohe vaatasin, et midagi on teistmoodi. Kuna mingi viimased kuu aega peamiselt Chrome Canary-t kasutanud, siis mõtlesin, et lihtsalt ei mäleta, aga mingi kümmekonna sekundiga jagasin matsu ära, et FF-l ka nüüd alt statusbar kadunud. Tegelikult oleks pidanud just tuttavlikum ju tunduma icon_smile.gif
Ausalt öeldes tundub Chrome 9-st väledam ka thumbs_up.gif Täitsa kaalun jälle tagasi FF-i peale hüppamist.
mhei
mhei
sõnum 11.11.2010 05:41:55 vasta tsitaadiga
see ei ole kadunud, tuleb lihtsalt teiselt browserilt järjehoidad tõmmata ja koos seelega tulevad eed tagasi
sõnum 11.11.2010 08:02:59 vasta tsitaadiga
Neile kes tahavad on asendus olemas addoni näol: https://addons.mozilla.org/en-US/firefox/addon/235283/ & http://forums.mozillazine.org/viewtopic.php?f=23&t=2001965
Goldec
Goldec
sõnum 11.11.2010 12:27:14 vasta tsitaadiga
Uuendasin ka seitsmendale betale ja olen meeldivalt üllatunud. Toimunud on väga suur edasiminek ja kogu kupatus tundub väga viimistletud.
Statusbari puudumist ei märganudki, sest mul oli ta juba varem ruumi kokku hoidmise mõttes välja lülitatud.
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 7
mhei
mhei
sõnum 11.11.2010 15:12:50 vasta tsitaadiga
Goldec,
KrisVr
sõnum 11.11.2010 19:22:42 vasta tsitaadiga
Beta 7 thumbs_up.gif Oli probleeme flash videotega ja nüüd kõik korras.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
sõnum 11.11.2010 19:55:47 vasta tsitaadiga
Beta 7 parandas 2651 bugi.Tegelikult 1400 neist olid blockerid.Ülejäänud olid nominatsioonid.Seda siis ~10 nädalaga
Hetkel on lõppversioonile 1001 bugi ja aega on ~16 nädalat.Arvutused tehke ise icon_smile.gif
aldios
aldios
sõnum 12.11.2010 10:03:55 vasta tsitaadiga
Üks kasulik addon milleta enam ei suudaks olla, annab pastemise valikusse "Paste and go"nagu operal on
Seline küsimus äkki keegi teab sellist addoni mis tekitaks võimaluse hiirega edasi ja tagasi liikuda nii nagu võimalik operaga ? Miskit leidsin aga pole päris see mis tahaks.
Kommentaarid: 21 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
AJ
AJ
sõnum 12.11.2010 10:05:32 vasta tsitaadiga
"Paste and Go" on jah hea asi. Endalgi see juba pikemat aega kasutuses. thumbs_up.gif
marco
marco
sõnum 12.11.2010 13:15:43 vasta tsitaadiga
aldios kirjutas:
firegestures
Saad ise seadistada ja seda arendatakse ka piisavalt, et töötab ka betadega.
Does "genuine" mean "with the real bugs"?
uus teema   vasta Tarkvara »  Tarkvara »  Mozilla Firefox arutlus/probleemid. mine lehele eelmine  1, 2, 3 ... 178, 179, 180 ... 422, 423, 424  järgmine
