uus teema   vasta Tarkvara »  Linux & UNIX »  Ubuntu 10.04 & resolutsioon märgi kõik teemad loetuks
WagaBond
sõnum 03.06.2010 10:29:24 Ubuntu 10.04 & resolutsioon vasta tsitaadiga
probleem siis selles, et nvidia paneelist määran resoks 1280x1024, peale restarti paneb tagasi 1152x864. Monitori HorizSync ja VertRefresh on käsitsi muudetud.
Omal käel ei julge enam confi rohkem muuta, eelviimane kord läks paar tundi, enne pildi tagasi saamist "musta lina" tagant.
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (buildd@palmer) Fri Apr 9 10:35:18 UTC 2010
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-1"
HorizSync 30.0 - 82.0
VertRefresh 56.0 - 76.0
Option "DPMS"
# HorizSync source: builtin, VertRefresh source: builtin
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
Option "AddARGBGLXVisuals" "True"
Option "TwinView" "0"
Option "metamodes" "1152x864 @1280x1024 +0+0"
DefaultDepth 24
# Removed Option "metamodes" "nvidia-auto-select @1280x1024 +0+0"
# Removed Option "metamodes" "1152x864_60 @1280x1024 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Module"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
# generated from default
EndSection
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Device"
Identifier "Device0"
VendorName "NVIDIA Corporation"
BoardName "GeForce 7300 GT"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
vankriga mäest alla 16,3 km tunnis.... ai fakk puu... jalad maha.. hoog ei peatu.. vastu puud ja kaarega heinakuhja icon_smile.gif
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 35
xpander
xpander
sõnum 03.06.2010 11:34:04 vasta tsitaadiga
aga kui muudad System -> Preferences -> Monitor alt, kas siis salvestab?[/b]
Linux Gaming Videos: Xpander69
WagaBond
sõnum 04.06.2010 07:49:44 vasta tsitaadiga
ikka salvestab, kuid peale restarti on ikka sama jama tagasi icon_rolleyes.gif
Täna hommikul proovisin uuesti ja kui tegelik resolutsioon oli 1152x864, näitas ubuntu monitori utiliit, et olen õiges resolutsioonis 1280x1024@50Hz,
muutsin selle 52Hz peale, sain õige pildi ette ja peale restarti oli ka kõik korras.
P.S. üks sümptomitest oli veel see, et töölaud oli suurem, kui ekraanile ära mahtus, ning seda sai kerida üles-alla ja paremale-vasakule.
ykshuntka
ykshuntka
sõnum 04.06.2010 08:01:37 vasta tsitaadiga
Minu masinal on Linux Mint 9.
Kui määrasin riistvara draiverite alt nvidia(soovitatav) peale,
siis ubuntu enda kuvari seadistamise programmi käivitamisel teavitas,
et see ei ole õige programm ja käivitas nvidia seadistus programmi.
Sealt sain teise monitori pildi paika pusimise peale.
Nvidia seadistus programm laseb nüüd salvestada conf faili, varasemad ubuntud minul ei lasknud.
Kommentaarid: 54 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 48
hv_foorum
sõnum 18.09.2010 13:10:01 vasta tsitaadiga
tere! ubuntu 10.04 installisin suurema (22 tolli ja laiekraan) kuvariga, ise tundis ära, midagi ei pidanud sättima vms, töötas nii nagu peab (1900 x midagi punkti) kõik oli OK!
Panin masina väiksema, 19 tollise kuvari taha tööle LG L1952T-BF kuid maksimum mida annab on 800x600 (valides arvuti->eelistused->kuvarid saan valida ainult 640x480 ja 800x600). Ütleb, et tundmatu kuvar. (LG lehelt ei leia ka draivereid, mida ette võiks sööta, tootmine lõppend ... icon_redface.gif ) "tuvasta kuvarid" nuppu pressimine midagi ei muuda...
kuidas saada tööle native resulutsiooni? Native (Recommended) Resolution 1280 x 1024 .
toetab lisaks (Resolutions supported 1024 x 768 ; 1152 x 870 ; 1152 x 900 ; 1280 x 1024 ; 640 x 480; 720 x 400; 800 x 600; 832 x 624; 640 x 350 )
xpander
xpander
sõnum 19.09.2010 11:48:09 vasta tsitaadiga
mis videokaardiga tegemist?
võimalik et vaja siis käsitsi xorg.conf file natuke mudida kui automaatselt ära ei tuntud.
selle kohta peaks google'st leidma üht-teist.
hv_foorum
sõnum 19.09.2010 19:10:44 vasta tsitaadiga
xpander kirjutas:
pean kasti lahti rebima ja uurima...
või kas saab seda mingi "diagnostika" utiliidiga järgi küsida?
obundra
obundra
sõnum 19.09.2010 19:28:44 vasta tsitaadiga
hv_foorum kirjutas:
xpander kirjutas:
Kirjuta konsooli lspci ja ongi selge mis rauda arvutikast sisaldab.
Hold the heathen hammer high!
Kommentaarid: 27 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 25
hv_foorum
sõnum 20.09.2010 20:31:02 vasta tsitaadiga
obundra kirjutas:
hv_foorum kirjutas:
xpander kirjutas:
sain graafika kohta lspci-ga seda teada:
01:00.0 VGA compatible controller: Matrox Graphics, Inc. MGA G400/G450 (rev 04)
aga xorg.conf tundukse ilgelt keeruline olema...
leidsin midagi sellist... https://wiki.ubuntu.com/X/Config/Resolution#Setting%20resolution%20changes%20in%20xorg.conf
eks proovin ja kas ma saan sellega pihta, kuigi oleks jõle hea kui see autodetect ikke tööle läheks... icon_razz1.gif
xpander
xpander
sõnum 21.09.2010 01:01:26 vasta tsitaadiga
Sarnase kaardiga:
http://ubuntuforums.org/showthread.php?t=878780
paistab et kui depth on 24 siis kaart ei vea kõrgemaid resosid välja.. proovi seda muuta.
hv_foorum
sõnum 29.10.2010 11:08:39 vasta tsitaadiga
hv_foorum kirjutas:
et siis 1680x1050 oli siiski see 22'' ekraani reso millega install sai tehtud ja pilt häste toimis. sega reso kõrgem kui see lg 19'' , mis ei pela... et siis viga milleski muus ... seda va värvisugavust 24 seda ma ei ole muutnud ja ei teagi kust seda muuta saaks icon_smile.gif
nüüd aga, panin uue vana ati graafikakaardi, see eelmine 16mb sai 32mb kaardiga asendatud(01:00.0 VGA compatible controller: ATI Technologies Inc Rage 128 PF/PRO AGP 4x TMDS).
panin 22'' taga LG native reso peale (töötab ilusti ka 22'' native resoga 1680 x ...). aga peale restarti, lg yhendatud, ei näita see lg kuvar suuremat kui 800x600. küll käivitamise ajal pahandas -
x server does not support size requested.
nüüd otsisin xorg.conf faili, seda etc/x11 kohas pole... et siis pole ka midagi ümber mudida... täitsa lõpp lugu. seega on sutsu segane kuda seda olukorda lahendada. näikse siis, et probleem on pigm selles monitoris, kui videokaardis.
