probleem1
02.10.2010 18:45:04
PayPalilt kiri |
(Lugesin kõik peateemade nimed läbi, ei osanud muud valida, kuhu alla kirjutada)
Nimelt saabus PayPalilt selline kiri:
Unfortunately, your recent PayPal transaction was declined because you do not have a valid payment method attached to your PayPal account.
If you have used PayPal to make a payment before, it may be that the credit or debit card you had attached to your account has now expired.
To update an expired card:
1. Log in to your PayPal account at https://www.paypal.com .
2. Go to Profile and select 'Credit Cards' link in the Financial Information column.
3. Choose the expired card and click 'Edit'.
4. If your credit card number has changed, you must click 'Add a Card' and enter your credit card information.
5. To remove the outdated card click 'Remove'.
If you do not have a credit card added to your PayPal account and would like to use it, please follow the steps below to add your information.
Add a payment method to PayPal:
1. Log in to your PayPal account at https://www.paypal.com to go to your Account Overview page.
2. Go to Profile and select from the list, to add a debit or credit card.
3. Follow the instructions to add your chosen payment method to your PayPal account.
Log in now to add a payment method
Once you have added a valid debit or credit card to your PayPal account, you will be able to complete safer, faster transactions with PayPal.
The PayPal team |
PayPali peaks ju saama kasutada ka ilma debeet- või krediitkaardita.
Keegi ehk täpsemalt seletaks, mis üldse juhtus? Kas minu eelmine makse PayPalis tühistati lihtsalt seepärast, et ma pole mõnda kaarti sidunud PayPaliga? Kõik toimingud näitavad ise PayPalis "Completed".
Või on kiri lihtsalt soovituslik, et seo kaardiga ja on tuvalisem ja oled usaldusväärsem.
Tiim
02.10.2010 20:18:15
kuskil liikus teema et see on petukiri, mul ei tule ette kas siisn foorumis või mujal...võid oma probleemi googeldada (endal pole aega) saad koheselt teada kui spämm on
_________________ mida sa vahid mu allkirja, AHV raisk |
| Kommentaarid: 49 loe/lisa |
43 |
A.S.
02.10.2010 20:28:50
Eks see sõltub sellest, kas see kirjas olev link (seal https://www.paypal.com all) viib tõesti õige koha peale või kuhugi mujale.
| Kommentaarid: 34 loe/lisa |
34 |
probleem1
02.10.2010 20:33:06
Mõni väga hea googeldaja võiks välja uurida kindluse mõtles, kas tegu ikka on pettusega.
Kust need spämmerid siis nii kiiresti minu info (õige nime, emaili) saavad, kui alles veidi üle nädala PayPali kasutaja.
A.S.
02.10.2010 20:36:46
Kirjas on ju lingid. Nüüd vaatadki, kuhu need lingid sind juhatavad (viid lihtsalt hiirekursori sinna peale). Kohe tead, kas on petukiri või mitte.
Äkki sul ei olnud ülekande sooritamiseks vajalikku summat arvel?
34 |
probleem1
02.10.2010 20:43:28
Viimati tegin makse üldse esmaspäeval ja paypali enda kohto peal oli ilusti summa olemas ja jäi ülegi. (lisaks. see makse on ka "Completed")
Kirja sees on vee linke, kuid kõik hakkavad algusega https://www.paypal.com/...
Ülipikad lingid. Aga samasugused lingid. Igaksjuhuks pole peale klikkinud.
Keegi osav googeldaja võiks ikkagi järgi uurida. Ise väga ei tea, kuidas uurida, mida eristada neist vms.
A.S.
02.10.2010 20:54:45
Aga mida me peame guugeldama? Meil kellelgi ju seda kirja ei ole, kiri on sinu käes.
Ma katsun veel üks kord selgitada, sa millegipärast ei soovi asjast esimese korraga aru saada.
See https://www.paypal.com mida sa näed, EI OLE LINK, see on suvaline tekst. Link asub selle teksti all (viid hiirekursori selle teksti peale ja vaatad). Kui selle teksti all olev link suunab sind https://www.paypal.com , siis on asi õige kui suunab kuhugi mujale (mingi imelik algus või lõpp sellel lingil), siis on tavaline petukiri.
34 |
probleem1
02.10.2010 21:04:39
https://eai0.paypal.com/servlet/ ja hästi pikk kood edasi
Samas on kirja all ka need Forgotten password, Help, Your security, Contact us. Minnes kursoriga peale on kõikide link täpselt samasugune sellega, mis kirja seeski on.
A.S.
02.10.2010 21:06:43
| See on kindlalt petukiri, kuidagi tuleb lihtsameelsete käest ju raha kätte saada.
34 |
probleem1
02.10.2010 21:25:29
Olen saanud kokku neli erinevat kirja paypalilt (alguses registreerudes, siis mingi õpetus, kellegilt tuli raha mulle ja siis veel minu ülekanne) ja kõik on tulnud samalt aadressilt.
Aga see kiri tuli üldse muult aadressilt "paypal2@info.paypal.com"
kpihus
02.10.2010 21:36:03
Ma ei saa nüüd aru, mida te siin leiutate. Loeb hoolega seda kirja uuesti, esimene rida ütleb: "Unfortunately, your recent PayPal transaction was declined because you do not have a valid payment method attached to your PayPal account. "
Ei ole ju raske minna ja oma paypali accounti sisse logida, ning kontrollida, kas on valid payment method olemas või mitte. Samuti saad paypalist üle vaadata kas kõik sulle teadaolevad maksed on õnnestunud või mitte.
Suhteliselt ebaoluline on see juures kas see kiri on spämm või mitte. Kui kõik maksed ja krediitkaart on OK, siis võid selle kirja rahulikult kusutada ja kaasuse unustada.
| Kommentaarid: 26 loe/lisa |
25 |
A.S.
02.10.2010 21:42:00
Aga mõni inimene läheb kirjas oleva lingi kaudu ja toksib seal oma parooli sisse. Ikka juhtub. Pärast nutab, et "koolituskulud" olid väga suured.
Aga suvaline inimene võib saata suvalise kirja täiesti suvaliselt aadressilt.
viimati muutis A.S. 02.10.2010 21:46:59, muudetud 1 kord |
34 |
probleem1
02.10.2010 21:46:30
| kpihus, kõik tehingud on ilusti Completed, kuid mu kasutaja pole seotud ühegi krediitkaardi vms. asjaga.
kpihus
02.10.2010 21:57:51
| probleem1 kirjutas: |
| kpihus, kõik tehingud on ilusti Completed, kuid mu kasutaja pole seotud ühegi krediitkaardi vms. asjaga. |
Ok, kuidas sa siis makseid teostad ?
| A.S. kirjutas: |
Ühekorra läheb, teistkorda enam ei lähe. Sedasi targaks saadaksegi.
25 |
probleem1
02.10.2010 22:08:26
| kpihus kirjutas: |
Kui PayPali kontol on raha, saab selle eest ka ostu sooritada. Aga see oleneb müüjast kah, mitmed soovivad, et konto oleks seotud ka krediitkaardina või paypali konto oleks verified.
AKE
04.10.2010 10:57:40
Saada kiri edasi aadressile spoof@ebay.co.uk - ja nemad saadavad sulle üsna kiirelt vastu kinnituskirja, kas tegu on petuskeemiga või mitte.
See ilmselgelt on.
kpihus
04.10.2010 23:30:26
| AKE kirjutas: |
See ilmselgelt on. |
Milliste näitajate põhjal sa seda väidad ? Hetkel sellest kirjast ei loe seda küll välja. Lingid viitavad õigesse kohta, muud petuskeemi samuti siit kirjast välja ei ole. Kirjas soovitatud sammud vastavad täpselt paypalis krediitkaardi registreerimisele sammudele.
Algne postitaja võiks siia postitada kirja päised (enda e-posti aadressi ja muid isikuandmeid puudutava info soovitan esmalt muidugi eemaldada) siis oleks üsna üheselt selge kas kiri on tulnud õigest kohast või mitte.
Mina hetkel väidan, et tegemist on õige kirjaga.
25 |
A.S.
05.10.2010 08:04:33
See viitab õigesse kohta vä?
34 |
AKE
05.10.2010 11:02:32
| kpihus kirjutas: |
| AKE kirjutas: |
Milliste näitajate põhjal sa seda väidad ? ---
Mina hetkel väidan, et tegemist on õige kirjaga. |
Palju õnne siis tulevikuks Loodetavasti oled ka juba Sierra Leonest miljonilise päranduse omale kontole kandnud
Tehes Paypaliga abil pidevalt erinevaid tehinguid tean ma väga hästi, millised on igasugu spoof-kirjad, neis ALATI nõutakse krediitkaardi andmete või konto paroolide sisestamist, lisaks on selles keissis juba üks väga läbinähtav trikk selles, et kehtivuse kaotanud kaardist informeerib paypal ALATI tehingu tegemise REAALajas, mitte paar päeva hiljem, pärast tehingu edukat toimumist. Paypal mitte kunagi ei nõua MEILIS linkidele klikkimist vaid mistahes asju saab ajada vaid ja ainult oma Paypal kontole secure'lt sisselogides.
See kiri kubiseb ju tüüpilistest petuskeemidest
kpihus
06.10.2010 08:50:28
| AKE kirjutas: |
| kpihus kirjutas: |
| AKE kirjutas: |
See kiri kubiseb ju tüüpilistest petuskeemidest  |
Üldiselt ei ole mõtet jalgratast leiutada. Kirja päisest on näha kirja teekond, ning lehele jõudes on seal olemas sertifikaat, mille autentsust saab kontrollida väljaandja juures. Ahjaa serdi kontrollimiseks linki klikates peaks seda tegema keskonnas, kus on pisut turvalisuse peale mõeldud.
Ahjaa, e-mailid ei pruugi alati reaalajas liikuda. Tuleb ka paaripäevaseid delaysid ette.
| A.S. kirjutas: |
My bad, see postitus jäi kahesilma vahele, lähtusin esimesest postitusest siin teemas. Siiski jään enda juurde, kui klikkad linki ja target ei ole https sait, siis ilmselgelt on tegemist jamaga. Kui sait on https, siis kontrollid serti ja asi korras. Oletamine on kõifi p****e keeramiste ema. Kontrollida tuleb, aga kontrollida tuleb ettevaatlikult.
Aga algselt postitajalt tahaks saada seda urli, koos seelle hästi pika koodiga.
EDIT:
Ilmselt url seal algse postitaja e-mailis ikka: https://email0.paypal.com/servlet/kood
See masin omab muuseas täesti adekvaatset verisigni poolt paypalile välja antud serti, seega võiks asi õige olla.
25 |
