pohmakas,
käed värisevad
26.09.2010 14:56:47
Hetkel olen Virgini tiimis sõitnud ja sain nüüd Red Bullilt pakkumise, jee
| Kommentaarid: 164 loe/lisa |
136 |
K3ndu
26.09.2010 15:02:47
| Mitmendast sõidust alates te pakkumis saanud olete?
| Kommentaarid: 127 loe/lisa |
117 |
libe
kvaliteetne mees
26.09.2010 15:07:07
| K3ndu kirjutas: |
| Mitmendast sõidust alates te pakkumis saanud olete? |
sõltub rep'ist, kui sul mingi 20 rep, siis on juba sauberi leping taskus
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Hive
26.09.2010 15:50:24
| hockenheimis sõitsin igatahes 10sek kiirema aja kui tegelikkuses Alonso sõitis hockenheimis seeaasta , ja singapuris sõidavad 1.50 kanti mehed praegu telekas
| Kommentaarid: 6 loe/lisa |
Scart
26.09.2010 16:58:46
| libe kirjutas: |
üheski mängus sul AI ei sõida reaalselt
kõik on puhtalt arvud ja väike juhuslikkuse moment - see mis su vaateväljas toimub, see on ainuke reaalne sõit |
CodeTardide F1s polegi ju AId, seega natuke raske võrrelda
When you are racing the other drivers you see are placeholder graphics.
When you need to make that decision to overtake etc . it does not matter - your are not racing a programed driver on the track you simply see a graphic codemasters has placed there to add immersion.
You end up overtaking Lewis Hamilton on the last bend of the race after spending 2 hours fighting and using all your skill to actually race a math calculation that is not real.
This happens in ALL racing games but the difference is with the vast majority of games the graphic car etc. you are racing is properly timed and provides a fairly accurate indication of that programed cars position relative to you on the track.
What codemasters have apparently done is simply calculate ALL the timings then thrown the other cars garphics around your car with all those timings having no relevance other than to make you think your overtaking him with skill.
The fact of the matter being your 10 seconds behind him in actual REAL TIME is irrelavant.
101 |
Cleanaway
26.09.2010 18:07:27
Kahju, et mootoririkkeid ja muid elementaarseid rikkeid ei ole, üsna kõva oli nt täna kui Kovalaineni auto põlema läks.Täiesti imelik, et sellist asja ei ole, kasvõi mootori suitsema minekuid või piduriprobleeme.Lisaks veel see, et ringiajad on täiesti ebareaalsed, ei pea tegelikkusega üldse paika, mõned väga olulised asjad on codemasters jätnud kahesilmavahele-niipalju kui olen lugenud mängijate tagasisidet.Muidugi peamine graafika, fun ja juhitavus on väga head, võib arusaada inimeste kommidest.
F1 2011 võiks nad ka fännide arvamusi kuulata, mida võiks lisada ja olulisi asju juurde orgunnida.
Ise peaksin selle nädala sees konsoolile kättesaama, läppar jäi PC peal jänni sellega:(
Juba pikalt pikalt ootan ja toitun siin teiste gameplayde vaatamisest ja tagasisidest:)
Mõni vana siin juba pea nädal laseb sellel hea maitsta:)
| Kommentaarid: 11 loe/lisa |
HDTanel
Overclocker
26.09.2010 18:09:11
| võtas-uxu kirjutas: |
Olen ma pusinud mis ma olen aga alla 1:43 aega singapuris sõita ei suuda.
Ei hakka enam oma aegasid siia panemagi, nagunii sõidate kõik 3-4 sek. üle.
Monacos üks koht on jah suht raske. Peale nõelasilma järgmine kurv on eriti maias spinni tegema.
oojaaa, see kurv on ajuvaba! F1 06-s ka tegi haiget viha see kurv, kõik läks perfektselt aga seda oli võimatu võtta. Mis seal aitas oli auto tõstmine, et curbe paremini võtaks, siis e tekkinud absull mingit probleemi ja 1:14 oli keskmine ringiaeg mul lõpuks.
Täna proovisin kaks ringi Monacos Ferruga ja default seadega ning 1:21, noo väga sitt masin oli sessuhtes piduriklotsid olid väikesed ilmselt, ei pidurdanud pea kunagi välja..
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
KrisVr
26.09.2010 19:00:51
AI teeb vahest mõne korraliku vea ka! Just sattusin peale sellele, kuidas Jenson läks Hamiltoniga murule mängima.
| Kommentaarid: 30 loe/lisa |
NeroEST
26.09.2010 21:26:17
See ai jutt, mida angel rääkis, on suht õige kahjuks.
Kui tase on expert või mis iganes kõige raskem, siis esiotsa AI sõidab ringiaegu umbes 2 sekki kehvemini kui lap record, mis pole üldse väga suur möödalask.
Codemastersi foorumis on kõik kirjas, mis katki on, kes julgeb oma tuju rikkuda, võib lugema minna.
Paariks kuuks tuleb mäng kõrvale panna, kui patchid väljas, vaatab üle, kui ei tehta, siis õnn, et ma eelnevalt "demo" proovisin.
_________________ Winter is coming... |
| Kommentaarid: 38 loe/lisa |
37 |
angel
26.09.2010 21:49:19
ei usu et seda korda tehakse, sedasi on see AI tehtud ja tehti väike "kärab kah" töö ja ei usu et seda keegi enam parandama hakkab. Oletati et keegi ei märka ja ei viitsi süveneda asjasse.... Osad pakuks ka välja, et sedasi saadi cpu jms arvuti/konsooli pealt koormust vähemaks mille tõttu sai kõige tähtsama asja tarvis ressursse raisata -> graafika. See ongi ju kõige tähtsam. Graafika korda ja oi kui kena ja särab. Siis natuke lihtsat gameplay'd ja keda ikka see "expert" ja "legend" game mode huvitab kus kõige rohkem vigu välja, tundub, hakkab tulema.
Samas võivad nad alati võtta oma eelmiste mängude AI ja selle sinna visata, peaks ju idee poolest võimalik olema. Laisaks jäänud Codemasers. Tundub et mida suurem ja kuulsam firma seda rohkem asi piixu läheb. Kahju, et mängus ei ole nn "nascar" sugust ringi (formelis, tean ei ole sellist jura aga võiks olla kuna hea kerge rada). Siis saaks kohe näha mida AI teeb kui teda "jälgitakse".
157 |
libe
kvaliteetne mees
26.09.2010 22:19:24
ei tea milles kära
kvali sõidad lootuses, et rada puhas ja hea aeg tuleb - sitta sellest, kas teised arvutatakse või mitte
algul pitis passid, mis aegu vastased sõidavad ja siis tead enda aega teha - see poleemika, mis siin aetakse on täiesti tühi asi
race puhul aga kehtib see, et kui mehest möödas oled, siis sa oled koha võrra üleval
angel
27.09.2010 10:34:41
http://www.youtube.com/watch?v=lEZ6InjuYGk&feature=player_embedded
tõesti täiesti savi... mis sest et AI sõidab nähtamatult su ees. Ise pole sellist asja isegi codemasters'i mängus enne näinud et AI sõidab parema aja su taga tolgendades. Mingi timer calc vist täiesti peeti sellel mängul läinud ja loodetavasti bug.
kerige 2:15 vms peale.. alguses lihtsalt mögiseb.
157 |
asdasd
27.09.2010 13:27:05
| Suht wtf moment oli kui esimesel ringil race's ma juhin ja raadios öeldakse "Webber just set the fastest time".
| Kommentaarid: 14 loe/lisa |
HDTanel
Overclocker
27.09.2010 14:03:12
asdasd, kas seal mitte ei loe see, mis kohalt stardid ja kui kiiresti jõuad ringi läbida??? noh tähendab, et sai parema kiirenduse seljatagant ja üldkokkuvõttes läbis ringi kiiremini? hmm, krt segane värk
Enivei eile tegin esimest korda karjääri ja Virginiga sain Q3 suht kergelt aga sealt edasi kõrgemale tõusta ei suutnud, tulin siis tagasi main menüüsse ja nägin intervjuud.. mõtleisn, et hiljem räägin nendega, läksin trailerisse ja siis veel proovisin kas ikka saan race alustada nüüd või pean Qualy algusest taas alustama, sain... tulin tagasi, et intervjuud anda aga polnud enam Tähendab, nii kui trailerisse lähed siis enam intervjuusi ei näegi. Eks teen uuesti Qualy täna vedas et nii vara sellele pihta sain
496 |
KrisVr
27.09.2010 14:07:22
Esimene ring on alati selline, et kes esimesena joone ületab, sellel ka parim aeg. Sest kõigil läheb aeg ühel ja samal ajal käima.
Albert4584
27.09.2010 14:07:57
| oot kas kuskil Euronicsis on keegi näinud seda müügil ka? sai kunagi ette tellitud, aga ei kipu ega kõppu, millal järgi võiks minna... ainult kiri "laos" ilutseb Euronicsi lehel...
NATAS999
27.09.2010 14:08:07
kas keegi siin mölisejatest reaalselt formelit jälginud ka on ve? suht tavaline asi, et kaks tüüpi sõidavad silma järgi sama vahega sama kiirelt ja taga tolgendaja saab kiirema ringi-/sektoriaja.
_________________ "Kuidas on see hea?"
-Auto kirurgia kliinik |
| Kommentaarid: 41 loe/lisa |
39 |
angel
27.09.2010 14:39:30
see oli vast vaid üks näidetest... mine codemasters foorumisse seal veel põhjalikumalt seda AI'd lahatud... aga kui ikka mõlemad alustavad ringi ühel ja samal ajal siis tea... mingi mustad augud vist mängus, et see kes tagumine sõidab sust kiiremini aga ei möödu sinust Kui päris formulas kah sedasi tehakse siis respekt neile kes sõidavad nii kiirelt, et lausa aeg ja ruum muutub nende ümber
157 |
asdasd
27.09.2010 15:06:46
| NATAS999 kirjutas: |
| kas keegi siin mölisejatest reaalselt formelit jälginud ka on ve? suht tavaline asi, et kaks tüüpi sõidavad silma järgi sama vahega sama kiirelt ja taga tolgendaja saab kiirema ringi-/sektoriaja. |
Kui F1'te ei jälgiks, siis seda mängu vast poleks nii ruttu ostnud. Fakt on, et esimesel ringil juhtiv sõitja saab kiireima esimese ringi. Pole kuidagi võimalik ajavõttu läbida enne esimesel kohal olevat autot. Võid siin ennast vigaseks sõimata meid mölisejateks, kuid vigast mängu see ei paranda.
Pealekauba vaatasin ruttu ümberringi ka tol hetkel, et mis toimub.. ja ei näinud ühtegi masinat läheduses.
metallika
27.09.2010 15:13:26
kuidas saaks kõiki neid assiste maha võtta
ma mõtlen eelkõige brake assist jms
muidu suht ok mäng tundub - kuigi jahm graafiline pool on lausa öökima ajav minu mega niru läpaka video tõttu
| Kommentaarid: 388 loe/lisa |
313 |
Anisse
27.09.2010 15:24:21
sai ostetud Logitech Driving Force GT rool. Kas peabki olema, et rool käib raskelt? (tava elus ka auto rool käib kergemalt kui see)
ja miks rool püüab end ise keerata otseks kui rajalt välja sõidad.
Settingud ja helperid valed?
-Kaivo-
27.09.2010 15:25:55
| FF seade alt peaks ju saama seda tugevust muuta.
| Kommentaarid: 16 loe/lisa |
15 |
libe
kvaliteetne mees
27.09.2010 15:26:35
| angel kirjutas: |
see oli vast vaid üks näidetest... mine codemasters foorumisse seal veel põhjalikumalt seda AI'd lahatud... aga kui ikka mõlemad alustavad ringi ühel ja samal ajal siis tea... mingi mustad augud vist mängus, et see kes tagumine sõidab sust kiiremini aga ei möödu sinust Kui päris formulas kah sedasi tehakse siis respekt neile kes sõidavad nii kiirelt, et lausa aeg ja ruum muutub nende ümber  |
ringiaeg läheb stardijoonelt käima
võistlusaeg hakkab käima stardituledest
Kemmukas
| Kommentaarid: 13 loe/lisa |
vaherna
27.09.2010 19:21:03
kas keegi on ka sellepeale mõelnud et miks ei Ferrari ja RB peeglid kere küljes? minu meelest oli neil piisavalt aega seda muuta. Aga tundub tõesti et tuleb patchi oodata ja kui see tuleb siis ei imesta kui see muudab mängu pilti kardinaalselt
_________________ Ega käsi kännust kaugele kuku! |
| Kommentaarid: 10 loe/lisa |
10 |
