* Total Control - 360-degree passing ratio has been enhanced improving the control over every pass, shot, throw-in, through ball and lofted through balls. This allows users to pass the ball into space, and move their play with total freedom. Players must precisely weight their passes and second-guess the runs of their team-mates and exploit their movement. Players even can apply pressure on opponents to force them off the ball.
* Shot and Stamina Gauge - the gauge details the player's exact level of fitness. Constantly sprinting will affect the player's movements and will have an adverse affect on his stats, with passes going awry and a loss of pace.
* New Defender AI - Defenders will now hold their positions naturally, no longer chasing any ball that enters their area; preferring to close down the attacker and force them into a mistake.
* Animation and Player Physics - in-game animation has been totally reworked, with the players enjoying fluid, natural movements, with more realistic acceleration and inertia then previous games. The physicality between players is also improved, which was a priority requested in PES forums. Jostling and blocking now looks stunning, while there is a larger variety of convincing tackling styles. Ambient animation also adds immensely to the in-game atmosphere, as players behave realistically when off the ball, and walk and run with a variety of individual styles.
* Speed of Play - With a new level of control, the pace of play varies depending on situations. The game will burst into life as counter-attacks come into play, but players can dictate the pace via slow build up or exploiting available space to surge forward. It is harder to make long runs from midfield, and successful play will depend on making quick passes to make room.
* Aesthetics - Facial animation has been enhanced from PES 2010. Also, PES 2011 includes over 1000 all-new animations which have been recreated from scratch using over 100 hours of motion captured footage. Every aspect of player movement has been reworked, with more organic runs, turns, throw-ins, tackles, and interaction. The way players speed up and slow down is also more natural, while replays display elements of motion blur that bring your saved goals to vivid life.
* Tactical and Strategy - An all new "Drag and Drop" mechanism that can be used in every aspect of team management, not just substitutions or formation changes. These settings are also animated to promote better understanding of the plays that have been altered.
* Feint settings - PES 2011 allows users to map their favourite move sequences including a wide range of subtle skills, feints and turns, to the right analogue stick.
* Master League Online - For the first time in the series, Master League will be playable online. Users will be able to play against each other with their two built squads.
* Customisable Soundtrack - You will now be able to create a custom soundtrack using your own music.
Nonii ise ootan ,et lõpuks vigade süsteem tuleb normaalne ja penalte ka ikka saaks. 2010 aasta oma oli lootusetu, niideti maha ja ei midagi. Millalgi oli survey ka kus sai enda ettepanekuid kirja panna ja KONAMI proovib nendest kokku panna hea mängu.
viimati muutis K3ndu 17.09.2010 20:04:23, muudetud 1 kord
Tänud lingi eest!
Esmamulje järgi tundub üsna sama mis 2010. Õnneks on vigade ja kaartide süsteem ära parandatud, mõned uued animatsioonid on ka juures mis tundusid üsna head, eriti kukkumised. Menüü meeldib mulle rohkem kui eelmine aasta. Samas on replay'dele tekitatud mingi blur-efekt mis mulle ei meeldi.
Sai ära proovtud ja täitsa meeldis. Menüü kohapeal nõustun Kristo69-ga.
Kahju et kommentaatoreid sees polnud, 2010-s oli see veits vigane IMO ja loodan et nüüd veits paremaks tehtud. Animatsioonid olid ka head jah, kuigi veits vigane oli mõni veel.
Pole jõudnud veel proovida ,aga üritan ka millalgi ära proovida.
EDIT:Installisin ära just ja kohe proovima ühe mängu, õhtu poole proovib vb rohkem.
EDIT2:Mäng on paremaks kenasti kohe tehtud, menüü on etem, füüsika on parem ja vastased teevad lõppudelõpuks vigu ka ja päris tihti rääkimata veel sellest mismoodi palli teema on, kõik nagu reaalsemaks ja paremaks tehtud. Eks nad pidid see aasta asja parandama kenasti kohe kuna FIFA 11 tuli lõpuks konsoolide teema mis tegi ka FIFA 11 paremaks nii ,et elame näeme missugune PES 2011 tuleb, mina jään igastahes ootama.
Olen 2 mängu teinud ja vastased pole mulle ühtegi viga veel teinud, kuigi maha on tõmmatud..Ei saa küll aru, et see vigade süsteem parandatud oleks. Ja lõpus peab alati mingit jubepikka reklaami vahtima.
E: Ja kuidas see söötmine käib? Pes 2010 söötis nagu automaatselt enda mehele aga kas nüüd peab ise suunama kuhu vaja? _________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks."
Kui lõpus neid reklaame vaadata ei taha > alt +f4 : P
Pesi olen alates 4ndast ver. mänginud, 2011 tundub täitsa hea demo põhjal, söötmine nõuab veidi harjumist küll.
FIFA 11 demo jättis ka hea mulje, kuigi mu noname puldiga on probleeme seal : P _________________ ツ
Nad võiks kunagi käe ka mängu lisada..fifal see featuur olemas. _________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks."
DefXtreme, No kui keegi palli käega mängib siis vilistatakse see ära. _________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks."
K3ndu, Sa paned poole väljaku pealt täis litri?
Värava all oled või kasti sees, sis ei pea ju seda löögi poweri vänta lõppu kerima, lased poole jõuga või nii.
